shocker 135 Posted April 26, 2018 Author Posted April 26, 2018 I confirm, it's not working with 1.0.40.
Suurbier91 2 Posted April 26, 2018 Posted April 26, 2018 It means that the SRT subtitles are not showing while they are showing when you're using DLNA to stream from your pc to your tv. The fault is in the Samsung app
Sammy 791 Posted April 30, 2018 Posted April 30, 2018 Just chiming in here, @@Luke. Do you need any more logs on this or is it something you're waiting for Samsung to get off their derriere and release so we can test out Emby's handling of subtitles?
Luke 42241 Posted April 30, 2018 Posted April 30, 2018 The only issue I'm aware of right now is subtitles in combination with DTS audio. If you look through the other threads in the Samsung section, another user mentioned this as a Samsung platform defect and other media apps are currently working around it until Samsung fixes it, so I guess we'll have to do the same.
Sammy 791 Posted April 30, 2018 Posted April 30, 2018 I'll check but since this is recently aired TV episode the likelihood of dts audio is slim. I might take a look at it in Plex and see if it will play the subs. I know it will play in AndroidTV, Roku and Android Mobile but Tizen not so much. The only other apps I use for the most part are YoutubeTV and Hulu and I've not seen issues with subtitles with them but maybe they're muxing them in on their end if the user requests subtitles to be on? Is this what you are thinking of as a work-around? That would be fine by me. It wouldn't be direct play but it surely would have WAF on the watching end plus, due to my diminished hearing from too many Van Halen Concerts in my youth, subtitles help me out too. My setup can easily transcode but I also realize issues with that for those running Emby Server on a NAS. Thanks.
Luke 42241 Posted July 6, 2018 Posted July 6, 2018 New app releases available: https://emby.media/community/index.php?/topic/60524-emby-for-samsung-smart-tv-updates/ Thanks guys.
Suurbier91 2 Posted July 11, 2018 Posted July 11, 2018 I can confirm that the srt subtitles are working again. Thank you so much! 1
shocker 135 Posted July 11, 2018 Author Posted July 11, 2018 I can confirm as well on J models with Tizen. @@Suurbier91 did you successfully managed to load them on K models as well? If yes then the issue is fixed Thanks Luke
SamES 1084 Posted July 11, 2018 Posted July 11, 2018 I can confirm as well on J models with Tizen. @@Suurbier91 did you successfully managed to load them on K models as well? If yes then the issue is fixed Thanks Luke Thanks. Yes, but... it seems to be causing an issue with double subs on K series.
shocker 135 Posted July 12, 2018 Author Posted July 12, 2018 Thanks. Yes, but... it seems to be causing an issue with double subs on K series. Thanks for the feedback. Yes there is an issue with the double subtitle and it's discussed here: https://emby.media/community/index.php?/topic/56043-double-subtitles/page-2
Luke 42241 Posted July 20, 2018 Posted July 20, 2018 1.0.43 has launched for 2016 models. Hopefully it will be out soon for 2015. Thanks guys. 1
Solution shocker 135 Posted July 23, 2018 Author Solution Posted July 23, 2018 1.0.43 fixed the issue, thanks Luke 1
Luke 42241 Posted December 12, 2018 Posted December 12, 2018 New Samsung releases: https://emby.media/community/index.php?/topic/66442-new-samsung-releases/ Thanks everyone.
Luke 42241 Posted May 28, 2019 Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks !
Luke 42241 Posted June 30, 2019 Posted June 30, 2019 For those interested, Install from USB: https://emby.media/community/index.php?/topic/74969-samsung-tizen-install-from-usb/
