mrhollywood360 0 Posted February 9, 2018 Posted February 9, 2018 I've noticed recently that emby no longer starts on system boot. I have to start it with "systemctl start emby-server" on every boot. Before updating it, emby would start up just fine. I have run systemctl enable emby-server, however that doesn't seem to help.
Luke 42245 Posted February 9, 2018 Posted February 9, 2018 Hi, what distro and installation package are you using?
dcrdev 255 Posted February 9, 2018 Posted February 9, 2018 Output of: systemctl status emby-server -l journalctl -b | grep emby
mrhollywood360 0 Posted February 9, 2018 Author Posted February 9, 2018 Hi, what distro and installation package are you using? Debian 9, using the deb packages from https://emby.media/linux-server.html Output of: systemctl status emby-server -l journalctl -b | grep emby emby-server.service - Emby Server is a personal media server with apps on just about every devic Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2018-02-08 19:39:44 EST; 13h ago Main PID: 2452 (EmbyServer) Tasks: 17 (limit: 4915) CGroup: /system.slice/emby-server.service └─2452 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffmpeg /opt/emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info Main: Application path: /opt/emby-server/system/EmbyServer.dll Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info Main: Emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info App: Application version: 3.2.70.0 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info App: Loading assemblies Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Sqlite version: 3.21.0 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info AuthenticationRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info DeviceManager: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info ActivityRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteItemRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteNotificationsRepository: PRAGMA synchronous=1 Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info HttpServer: Calling ServiceStack AppHost.Init Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info ServerManager: Loading Http Server Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info HttpServer: Adding HttpListener prefix http://+:8096/ Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info HttpServer: Adding HttpListener prefix https://+:8920/ Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info Skia: SkiaSharp version: 1.58.0.0 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info TaskManager: Daily trigger for Chapter image extraction set to fire at 2/9/18 2:00:00 AM, which is 383.160565385 minutes from now. Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info TaskManager: Daily trigger for Start new log file set to fire at 2/9/18 12:00:00 AM, which is 263.160384068333 minutes from now. Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavutil 55. 78.100 / 55. 78.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavcodec 57.107.100 / 57.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavformat 57. 83.100 / 57. 83.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavdevice 57. 10.100 / 57. 10.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavfilter 6.107.100 / 6.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswscale 4. 8.100 / 4. 8.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswresample 2. 9.100 / 2. 9.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libpostproc 54. 7.100 / 54. 7.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: mpeg2video Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: ac3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: aac Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: mp3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: h264 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: hevc Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavutil 55. 78.100 / 55. 78.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavcodec 57.107.100 / 57.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavformat 57. 83.100 / 57. 83.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavdevice 57. 10.100 / 57. 10.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavfilter 6.107.100 / 6.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswscale 4. 8.100 / 4. 8.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswresample 2. 9.100 / 2. 9.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libpostproc 54. 7.100 / 54. 7.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libx264 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: mpeg4 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: msmpeg4 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: aac Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libmp3lame Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libopus Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libvorbis Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: srt Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: h264_vaapi Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: hevc_vaapi Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: h264_v4l2m2m Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libwebp Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: ac3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder validation complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: ServerId: e07fd5a23b0544d2b4253484936eb80b Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Core startup complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Post-init migrations complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 4.79E-05 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0009218 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0060218 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0011073 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0003781 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Loading live tv data from /var/lib/emby/data/livetv/timers Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.2846417 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0549302 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0011799 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.027379 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0003437 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0026773 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0.0003524 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0019926 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0040965 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.001056 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0005698 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0048051 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0028643 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0006668 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0012446 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0030213 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.1121101 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 0.0001231 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info HttpClient: GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Error HttpClient: Error getting response from http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: *** Error Report *** Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Version: 3.2.70.0 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of inner exception stack trace --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: InnerException: System.Net.Http.CurlException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Error App: Error downloading news Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: *** Error Report *** Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Version: 3.2.70.0 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of inner exception stack trace --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: InnerException: System.Net.Http.CurlException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]:
dcrdev 255 Posted February 9, 2018 Posted February 9, 2018 Debian 9, using the deb packages from https://emby.media/linux-server.html emby-server.service - Emby Server is a personal media server with apps on just about every devic Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2018-02-08 19:39:44 EST; 13h ago Main PID: 2452 (EmbyServer) Tasks: 17 (limit: 4915) CGroup: /system.slice/emby-server.service └─2452 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffmpeg /opt/emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info Main: Application path: /opt/emby-server/system/EmbyServer.dll Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info Main: Emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info App: Application version: 3.2.70.0 Feb 08 19:36:47 Nebuchadnezzar emby-server[708]: Info App: Loading assemblies Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Sqlite version: 3.21.0 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteUserRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info AuthenticationRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info DeviceManager: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info ActivityRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteItemRepository: PRAGMA synchronous=1 Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is wal Feb 08 19:36:48 Nebuchadnezzar emby-server[708]: Info SqliteNotificationsRepository: PRAGMA synchronous=1 Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info HttpServer: Calling ServiceStack AppHost.Init Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info ServerManager: Loading Http Server Feb 08 19:36:49 Nebuchadnezzar emby-server[708]: Info HttpServer: Adding HttpListener prefix http://+:8096/ Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info HttpServer: Adding HttpListener prefix https://+:8920/ Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info Skia: SkiaSharp version: 1.58.0.0 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info TaskManager: Daily trigger for Chapter image extraction set to fire at 2/9/18 2:00:00 AM, which is 383.160565385 minutes from now. Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info TaskManager: Daily trigger for Start new log file set to fire at 2/9/18 12:00:00 AM, which is 263.160384068333 minutes from now. Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavutil 55. 78.100 / 55. 78.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavcodec 57.107.100 / 57.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavformat 57. 83.100 / 57. 83.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavdevice 57. 10.100 / 57. 10.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavfilter 6.107.100 / 6.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswscale 4. 8.100 / 4. 8.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswresample 2. 9.100 / 2. 9.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libpostproc 54. 7.100 / 54. 7.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: mpeg2video Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: ac3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: aac Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: mp3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: h264 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Decoder available: hevc Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavutil 55. 78.100 / 55. 78.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavcodec 57.107.100 / 57.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavformat 57. 83.100 / 57. 83.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavdevice 57. 10.100 / 57. 10.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libavfilter 6.107.100 / 6.107.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswscale 4. 8.100 / 4. 8.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libswresample 2. 9.100 / 2. 9.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: libpostproc 54. 7.100 / 54. 7.100 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libx264 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: mpeg4 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: msmpeg4 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: aac Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libmp3lame Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libopus Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libvorbis Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: srt Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: h264_vaapi Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: hevc_vaapi Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: h264_v4l2m2m Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: libwebp Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder available: ac3 Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info MediaEncoder: Encoder validation complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: ServerId: e07fd5a23b0544d2b4253484936eb80b Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Core startup complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Post-init migrations complete Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 4.79E-05 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0009218 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0060218 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0011073 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0003781 seconds Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint Feb 08 19:36:50 Nebuchadnezzar emby-server[708]: Info App: Loading live tv data from /var/lib/emby/data/livetv/timers Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.2846417 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0549302 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0011799 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.027379 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0003437 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0026773 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0.0003524 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0019926 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0040965 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.001056 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0005698 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0048051 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0028643 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0006668 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0012446 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0030213 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.1121101 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 0.0001231 seconds Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Info HttpClient: GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Error HttpClient: Error getting response from http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: *** Error Report *** Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Version: 3.2.70.0 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of inner exception stack trace --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: InnerException: System.Net.Http.CurlException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Error App: Error downloading news Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: *** Error Report *** Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Version: 3.2.70.0 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Operating system: Unix 4.9.0.5 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit OS: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: 64-Bit Process: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: User Interactive: True Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Processor count: 16 Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Program data path: /var/lib/emby Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Application directory: /opt/emby-server/system Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of inner exception stack trace --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.HttpRequestException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: --- End of stack trace from previous location where exception was thrown --- Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: InnerException: System.Net.Http.CurlException Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: System.Net.Http.CurlException: Couldn't resolve host name Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 08 19:36:51 Nebuchadnezzar emby-server[708]: Can you post those outputs after a fresh boot? It's not really going to show much if Emby is running....
mrhollywood360 0 Posted February 9, 2018 Author Posted February 9, 2018 After a fresh boot $ systemctl status emby-server -l ● emby-server.service - Emby Server is a personal media server with apps on just about every devic Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Fri 2018-02-09 17:47:34 EST; 2min 23s ago Process: 698 ExecStart=/opt/emby-server/bin/emby-server (code=exited, status=5) Main PID: 698 (code=exited, status=5) $ sudo journalctl -b | grep emby Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Info Main: Application path: /opt/emby-server/system/EmbyServer.dll Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Info Main: Emby Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Operating system: Unix 4.9.0.5 Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: 64-Bit OS: True Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: 64-Bit Process: True Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: User Interactive: True Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Processor count: 16 Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Program data path: /var/lib/emby Feb 09 17:47:25 Nebuchadnezzar emby-server[698]: Application directory: /opt/emby-server/system Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Application version: 3.2.70.0 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading assemblies Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteUserRepository: Sqlite version: 3.21.0 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteUserRepository: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info AuthenticationRepository: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info DeviceManager: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info ActivityRepository: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteItemRepository: PRAGMA synchronous=1 Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is wal Feb 09 17:47:26 Nebuchadnezzar emby-server[698]: Info SqliteNotificationsRepository: PRAGMA synchronous=1 Feb 09 17:47:27 Nebuchadnezzar emby-server[698]: Info HttpServer: Calling ServiceStack AppHost.Init Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info ServerManager: Loading Http Server Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info HttpServer: Adding HttpListener prefix http://+:8096/ Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info HttpServer: Adding HttpListener prefix https://+:8920/ Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info Skia: SkiaSharp version: 1.58.0.0 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info TaskManager: Daily trigger for Chapter image extraction set to fire at 2/10/18 2:00:00 AM, which is 492.526072021667 minutes from now. Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info TaskManager: Daily trigger for Start new log file set to fire at 2/10/18 12:00:00 AM, which is 372.525876513333 minutes from now. Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavutil 55. 78.100 / 55. 78.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavcodec 57.107.100 / 57.107.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavformat 57. 83.100 / 57. 83.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavdevice 57. 10.100 / 57. 10.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavfilter 6.107.100 / 6.107.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libswscale 4. 8.100 / 4. 8.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libswresample 2. 9.100 / 2. 9.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libpostproc 54. 7.100 / 54. 7.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: mpeg2video Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: ac3 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: aac Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: mp3 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: h264 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Decoder available: hevc Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --arch=x86_64 --target-os=linux --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-static --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-shared --enable-fontconfig --enable-gnutls --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libsmbclient --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-vaapi --enable-version3 --extra-libs='-laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -ldrm -lexpat -lflag-mapping-samba4 -lfreetype -lfribidi -lfontconfig -lgenrand-samba4 -lgensec-samba4 -lgmp -lgse-samba4 -lgssapi_krb5 -lhogweed -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lnettle -lpng -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavutil 55. 78.100 / 55. 78.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavcodec 57.107.100 / 57.107.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavformat 57. 83.100 / 57. 83.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavdevice 57. 10.100 / 57. 10.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libavfilter 6.107.100 / 6.107.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libswscale 4. 8.100 / 4. 8.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libswresample 2. 9.100 / 2. 9.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: libpostproc 54. 7.100 / 54. 7.100 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: libx264 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: mpeg4 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: msmpeg4 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: aac Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: libmp3lame Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: libopus Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: libvorbis Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: srt Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: h264_vaapi Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: hevc_vaapi Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: h264_v4l2m2m Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: libwebp Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder available: ac3 Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info MediaEncoder: Encoder validation complete Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: ServerId: e07fd5a23b0544d2b4253484936eb80b Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Core startup complete Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Post-init migrations complete Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0.0001967 seconds Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0008124 seconds Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0059325 seconds Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0011087 seconds Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0004766 seconds Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint Feb 09 17:47:28 Nebuchadnezzar emby-server[698]: Info App: Loading live tv data from /var/lib/emby/data/livetv/timers Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.259872 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.109345 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0012735 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.0286662 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0004717 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0023404 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0.000331 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0021494 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0040145 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0012292 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.000769 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0046855 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.002965 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0006394 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0014396 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0031398 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0715567 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 9.16E-05 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info HttpClient: GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Error HttpClient: Error getting response from http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: *** Error Report *** Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Version: 3.2.70.0 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Operating system: Unix 4.9.0.5 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: 64-Bit OS: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: 64-Bit Process: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: User Interactive: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Processor count: 16 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Program data path: /var/lib/emby Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Application directory: /opt/emby-server/system Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of inner exception stack trace --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.HttpRequestException Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: InnerException: System.Net.Http.CurlException Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.CurlException: Couldn't resolve host name Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Error App: Error downloading news Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: *** Error Report *** Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Version: 3.2.70.0 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Operating system: Unix 4.9.0.5 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: 64-Bit OS: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: 64-Bit Process: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: User Interactive: True Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Processor count: 16 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Program data path: /var/lib/emby Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Application directory: /opt/emby-server/system Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Couldn't resolve host name Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of inner exception stack trace --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.HttpRequestException Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.News.NewsEntryPoint.<DownloadNews>d__13.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.News.NewsEntryPoint.<OnTimerFired>d__12.MoveNext() Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: InnerException: System.Net.Http.CurlException Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: System.Net.Http.CurlException: Couldn't resolve host name Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.2198062 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0005158 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Security.PluginSecurityManager Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 7.28E-05 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0006056 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Loading data from /var/lib/emby/data/connect.txt Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Loading data from /var/lib/emby/data/wan.dat Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0746581 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Security.PluginSecurityManager Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 5.1E-05 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Sqlite version: 3.21.0 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Default journal_mode for /var/lib/emby/data/sync14.db is wal Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: PRAGMA synchronous=1 Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0177787 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0009805 seconds Feb 09 17:47:29 Nebuchadnezzar emby-server[698]: Info App: All entry points have started Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: UnhandledException Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: System.Net.Sockets.SocketException (0x80004005): Unknown error -1 Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.SetMulticastOption(SocketOptionName optionName, MulticastOption MR) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.SetSocketOption(SocketOptionLevel optionLevel, SocketOptionName optionName, Object optionValue) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.Net.SocketFactory.CreateUdpMulticastSocket(String ipAddress, Int32 multicastTimeToLive, Int32 localPort) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpCommunicationsServer.ListenForBroadcastsAsync() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpCommunicationsServer.BeginListeningForBroadcasts() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpDeviceLocator.<OnBroadcastTimerCallback>d__16.MoveNext() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Threading.ThreadPoolWorkQueue.Dispatch() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: System.Net.Sockets.SocketException Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.SetMulticastOption(SocketOptionName optionName, MulticastOption MR) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Net.Sockets.Socket.SetSocketOption(SocketOptionLevel optionLevel, SocketOptionName optionName, Object optionValue) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Emby.Server.Implementations.Net.SocketFactory.CreateUdpMulticastSocket(String ipAddress, Int32 multicastTimeToLive, Int32 localPort) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpCommunicationsServer.ListenForBroadcastsAsync() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpCommunicationsServer.BeginListeningForBroadcasts() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at Rssdp.Infrastructure.SsdpDeviceLocator.<OnBroadcastTimerCallback>d__16.MoveNext() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: --- End of stack trace from previous location where exception was thrown --- Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) Feb 09 17:47:34 Nebuchadnezzar emby-server[698]: at System.Threading.ThreadPoolWorkQueue.Dispatch() Feb 09 17:47:34 Nebuchadnezzar systemd[1]: emby-server.service: Main process exited, code=exited, status=5/NOTINSTALLED Feb 09 17:47:34 Nebuchadnezzar systemd[1]: emby-server.service: Unit entered failed state. Feb 09 17:47:34 Nebuchadnezzar systemd[1]: emby-server.service: Failed with result 'exit-code'.
dcrdev 255 Posted February 10, 2018 Posted February 10, 2018 (edited) Looks like it's starting before the network is up properly and then subsequently is failing on some discovery features. a ) I would investigate why it's starting before the network is up. b ) I would disable automatic port mapping under "Advanced Settings" as that appears to be where the crash is happening. Edited February 10, 2018 by dcrdev
tgessendorfer 7 Posted February 13, 2018 Posted February 13, 2018 (edited) Same problem here... It worked nicely after a fresh install of 3.2.70 until I changed the private and public http / https ports... I have to start emby-server from Debian CLI manually and it works even with the changed ports, however after a system reboot the emby-server does not start automatically anymore. Also the "restart" button in the admin dashboard doesn't work properly anymore. Changed back to standard http and https ports and rebooted my emby server and works like a charm!? Edited February 13, 2018 by tgessendorfer
dcrdev 255 Posted February 13, 2018 Posted February 13, 2018 (edited) Same problem here... It worked nicely after a fresh install of 3.2.70 until I changed the private and public http / https ports... I have to start emby-server from Debian CLI manually and it works even with the changed ports, however after a system reboot the emby-server does not start automatically anymore. Also the "restart" button in the admin dashboard doesn't work properly anymore. Changed back to standard http and https ports and rebooted my emby server and works like a charm!? Any chance something else is using those ports? What happens if you pick some obscure ports? Edited February 13, 2018 by dcrdev
tgessendorfer 7 Posted February 13, 2018 Posted February 13, 2018 Any chance something else is using those ports? What happens if you pick some obscure ports? Just tried that and mapped ports 88 (http) and 89 (https), then after starting the emby-server via CLI the Dashboard isn't available at all anymore!? Had to manually edit the /var/lib/emby/config/system.xml file and change the ports back from there to get access to the Dashboard Gui. So even more worse than using ports 80 and 443... Interesting though as it's a new and clean Debian VM with no services except emby running and not using those ports at all...
mrhollywood360 0 Posted February 13, 2018 Author Posted February 13, 2018 Just tried that and mapped ports 88 (http) and 89 (https), then after starting the emby-server via CLI the Dashboard isn't available at all anymore!? Had to manually edit the /var/lib/emby/config/system.xml file and change the ports back from there to get access to the Dashboard Gui. So even more worse than using ports 80 and 443... Interesting though as it's a new and clean Debian VM with no services except emby running and not using those ports at all... Could be an issue with Debian specifically? I'm having this issue on Debian 9
dcrdev 255 Posted February 13, 2018 Posted February 13, 2018 Lol just remembered something - What you're doing is actually quite weird - most people don't change the local ports to 80/443 they do nat forwarding and that's most likely why this has never come up. Basically in Linux ports under 1024 are restricted to root only - Emby runs as the 'emby' user, you're likely able to start it via the cli because systemd is elevated via polkit. Why do you need the local ports to be 443/80 ? There are ways around this - http://man7.org/linux/man-pages/man7/capabilities.7.html under CAP_NET_BIND_SERVICE , but it's not advisable.
dcrdev 255 Posted February 13, 2018 Posted February 13, 2018 Could be an issue with Debian specifically? I'm having this issue on Debian 9 Did you follow my advise? b ) I would disable automatic port mapping under "Advanced Settings" as that appears to be where the crash is happening. That would appear to be the cause of your problems - Emby is actually crashing.
