MClements130 1 Posted February 2, 2018 Posted February 2, 2018 So I got a hosting provider with Cent OS 7 could anyone tell me the completely script I got to type in to install the full emby server on CENTOS 7
Luke 42246 Posted February 2, 2018 Posted February 2, 2018 Hi, all the instructions can be found on our download page: https://emby.media/download Just click Linux and select CentOS. Please let us know if this helps. Thanks !
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Hey Luke, I have tried it and it says no packages
Luke 42246 Posted February 2, 2018 Posted February 2, 2018 where exactly does it say that? can you please supply the full console output? thanks.
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 My full command is yum install emby-server-rpm_3.2.70.0_x86_64.rpmit says it went it finds the files and at the end it says no packages
Luke 42246 Posted February 2, 2018 Posted February 2, 2018 please try it again and then capture and attach the full terminal output. thanks.
MClements13 0 Posted February 2, 2018 Posted February 2, 2018 [07:59] [server1.emby-server.stream ~] # yum install emby-server-rpm_3.2.70.0_x86_64.rpmLoaded plugins: fastestmirror, langpacks, universal-hooksRepository 'mariadb' is missing name in configuration, using idLoading mirror speeds from cached hostfile * EA4: 204.10.37.146 * cpanel-addons-production-feed: 204.10.37.146 * base: mirror.pac-12.org * epel: mirror.sjc02.svwh.net * extras: mirrors.xmission.com * updates: centos-distro.cavecreek.netNo package emby-server-rpm_3.2.70.0_x86_64.rpm available.Error: Nothing to do
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Hey Luke I just gave you the terminal stuff for you to look over
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Does any one have a idea as why this would happen
dcrdev 255 Posted February 2, 2018 Posted February 2, 2018 Assuming because you haven't actually downloaded the file... Do this: yum install https://github.com/MediaBrowser/Emby/releases/download/3.2.70.0/emby-server-rpm_3.2.70.0_x86_64.rpm firewall-cmd --reload firewall-cmd --add-service=emby-server firewall-cmd --add-service=emby-server --permanent 1
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 The firewall-cmd command didn’t work it says that the firewall ID is not running
dcrdev 255 Posted February 2, 2018 Posted February 2, 2018 (edited) The firewall-cmd command didn’t work it says that the firewall ID is not running In that case your cloud provider must disable it on their image - in which case don't worry about it. Edited February 2, 2018 by dcrdev
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Okay so how do I look the emby now
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 My bad I mean how do I get the emby now since I can do that command
dcrdev 255 Posted February 2, 2018 Posted February 2, 2018 (edited) My bad I mean how do I get the emby now since I can do that command Go to http://IPAddressOfServer:8096 or http://ServerDomain:8096 in a browser. Edited February 2, 2018 by dcrdev
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Okay so I got it running but my question now what do I need to do to stream it from a domain hosting service I currently am using CPanel for hosting and my domain is thru Namecheap
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Also my OS that the hosting gave me is CENTOS 7
dcrdev 255 Posted February 2, 2018 Posted February 2, 2018 Your question is a bit vague? Are you trying to use your domain instead of ip? Add it under "Advanced Settings" in the dashboard. Are you trying to just stream content? You need to upload that content to your server and add it to a library in Emby. Are you trying to access via other devices? Install one of the relevant apps... I would recommend you read the wiki https://github.com/MediaBrowser/Wiki/wiki
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 I need to know how would I setup up my ip information in order for it to go directly to my emby instead of my server
MClements130 1 Posted February 2, 2018 Author Posted February 2, 2018 Okay you should be getting a message from me
Ole Andreas Gløersen 0 Posted October 3, 2018 Posted October 3, 2018 Can't find any CentOS version now. Stopped supporting?
Luke 42246 Posted October 3, 2018 Posted October 3, 2018 Can't find any CentOS version now. Stopped supporting? Hi! Yes we do support CentOS. Have you checked the download page of our website? https://emby.media/linux-server.html
Ole Andreas Gløersen 0 Posted October 3, 2018 Posted October 3, 2018 Yes, my mistake.... Don't the OS change first time I looked. Sorry, but thanks for very quick response!
