Question on Transcoding
daniel.bmyer
Well, it was playing much smoother but after 20seconds stopped working.  I'm going to reboot and try again
Guest asrequested
Can you provide a link to the exact make and model of your laptop?
daniel.bmyer
I replaced both my hard drive and optical disk with an SSD.
Guest asrequested
Ok, chuck this in your mpv.conf, and give it a whirl
hwdec=auto
vo=gpu
scale=oversample
tscale=oversample
daniel.bmyer
Nope, same problem.  Stops working and closes.
daniel.bmyer
Well, it seemed ok for the 5 seconds it played before it stopped working
daniel.bmyer
So the mpv folder in roaming was empty.  I copied the conf file into the root of the mpv folder.  Is that right?
Guest asrequested
Yup! Set your audio to stereo, and give it a shot.
daniel.bmyer
If I load Emby it connects to my server so I can't play the file from my local disk
daniel.bmyer
From Emby it plays without crashing but it's choppy
Guest asrequested
That's fine, the issue doesn't appear to be related to that
Guest asrequested
OK, in your video settings, select 'Enable video display syncing' , 'Enable Interpolation' , 'Temporal Axis scaling method = oversample' and your audio set to stereo
and HWA to auto
Edited by Doofus
daniel.bmyer
Ok, did all that but still plays choppy. Keep in mind I'm playing the file from my laptop wirelessly.
I'm going to have to all it a night.  Gotta get up early for work.
I appreciate the effort.  If you need more testing I can do so tomorrow as well.
Guest asrequested
I'm willing if you are :)
Guest asrequested
Ok, next you can try this. Clear out your mpv.conf, except the logging. Then add this.
hwdec=auto
video-sync=display-resample
interpolation=yes
tscale=oversample
display-sync-active
In Theater, in the audio settings deselect all audio passthrough. Set HWA to auto, and all other video settings to default/auto, and play your file.
You can also try it in the standalone.
Edited by Doofus
daniel.bmyer
Using the standalone of ET or the installed version it still plays choppy.
MPV alone, just crashes after a few seconds.
Guest asrequested
Remove that from the mpv.conf for theater, and enable opengl hq in the settings, and try again.
Guest asrequested
Luke, it might be a good idea to add this in the stats. It will show up as DS to show that display sync is actually being used.
display-sync-active
daniel.bmyer
You mean from the mpv.conf in c:\users\me\appdata\roaming\mpv?
I"m getting confused to which Emby I should be running, the installed version or the standalone version?
Guest asrequested
Sorry, yes, that one. That's the one theater will use. The other one is specifically for the standalone.
daniel.bmyer
Ok removed all settings from that mpv.conf file and tried again...exact same, very choppy
Guest asrequested
And you enabled opengl hq?
