madkins 3 Posted January 26, 2018 Posted January 26, 2018 Around the time of the 3.2.7 update, my recordings started to malfunction. It takes a very long time to start playback and when it does start, there is no sound. If I browse to the file and use the Windows built in media player, it starts instantaneously but still no sound. I found that if I turn off conversion to mkv in Emby Server everything works fine again. It's not a huge deal, but I figured I would report it. Server log is attached...let me know if you need anything else. Thanks in advance server-63652435200.txt
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 (edited) You should post the ffmpeg logs for the recordings that were converted Edited January 26, 2018 by Doofus
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 You show post the ffmpeg logs for the recordings that were converted Will do...thanks. These are all the files in the time frame that I was testing. ffmpeg-transcode-69a48f53-bcb9-40b5-b91a-0a3adf460c46.txt ffmpeg-transcode-e13ffffc-b157-42c1-8144-8ee0ab3a901b.txt record-transcode-22fb4261-3b39-45c4-951b-f7132d56d920.txt ffmpeg-transcode-0364752f-63b1-42a3-b35d-dc5650936342.txt ffmpeg-transcode-ba62ca80-cd76-4033-b1c5-82750c01f65d.txt record-transcode-1d2aa2bc-8a3d-4d94-ac73-b73693960467.txt ffmpeg-transcode-c67f2788-536c-4ed0-b803-4ce894249991.txt ffmpeg-transcode-c3878a53-6f80-4dd3-b806-98e5c383462a.txt ffmpeg-transcode-9868c73a-efe0-4549-a70a-ff8102dbf085.txt ffmpeg-transcode-6bebe3a6-69a2-47db-b8b7-5cdc64deca62.txt ffmpeg-transcode-6cb11c2f-6c93-4045-b509-8bce10c26ae0.txt ffmpeg-transcode-727f9539-fea7-4829-8f7b-4773f6a2f892.txt record-transcode-f6cd15df-ab77-4dc1-a6ac-990a11a48ea3.txt ffmpeg-transcode-96e28009-3f8e-4c22-b3c9-d15365ad6492.txt ffmpeg-transcode-f265d100-3303-4d66-a699-c2e1fe57cb30.txt
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 Can you share one of the videos? It looks like they recorded, correctly.
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 Can you share one of the videos? It looks like they recorded, correctly. I had already deleted my test videos, but I created another and attached it. I have some more info, too... While recording, there are three instances of ffmpeg maxing out my processor. The resulting mkv, besides having no sound, also exhibits some visual artifacts. If it matters, Emby Server and Theater are running on a Windows 10 PC I built fairly recently. 7th gen i3, 8gb ddr4, nvme ssd. Is there a way to roll back an Emby update? Then I could test if it really was the last update. Thanks for your time.
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 Nothing attached I just tried again and it said, "Error You aren't permitted to upload this kind of file"
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 Zip it (90MB limit) or use google drive etc
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 Zip it (90MB limit) or use google drive etc I noticed that and thought it would be fine since it was only 16.3MB. Zipping seems to have worked. Chicago Fire S06E10 Slamigan - 1.zip
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 That's just fine, for me. What app are you using?
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 (edited) That's just fine, for me. What app are you using? Emby Theater, then I tried the default Win10 Movies & TV app. However, after your last message I tried VLC and it has sound. Edited January 26, 2018 by madkins
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 Which version of Theater? Store app or from the emby website?
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 Which version of Theater? Store app or from the emby website? Store app. I just did some more testing: Emby Theater takes about 2 minutes to start playing any recent mkv recorded by Emby Server, then there is no sound. If I play it through Emby in the browser, everything is fine. Emby Theater plays older recorded MKVs just fine. TS files work fine either way. I have to head to bed for now, but hopefully that helps narrow the problem down.
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 (edited) I just tried in the store app, and it doesn't play, correctly. I suggest using the desktop app. It's much better. If you have any questions on config, I can help. But it should play your recordings, and pretty much anything else. https://emby.media/emby-theater.html I'll try and figure out why the store app, doesn't like it. Edited January 26, 2018 by Doofus
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 I downloaded Emby Theater from the website and it plays. My Harmony remote seems to work fine the way I have it programmed too. My only problem is the UI was extremely laggy. I'll see if I can get that figured out tomorrow. Thanks for your help so far.
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 You can try the present test build. You may have the same window issue that I have. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 For what it's worth I would just record the raw stream without the on the fly mkv recording feature. Unfortunately that feature is something that's going to have to be dropped in the future for reasons such as this, just as soon as we have a replacement feature to convert after the recording has completed.
madkins 3 Posted January 26, 2018 Author Posted January 26, 2018 For what it's worth I would just record the raw stream without the on the fly mkv recording feature. Unfortunately that feature is something that's going to have to be dropped in the future for reasons such as this, just as soon as we have a replacement feature to convert after the recording has completed. That's what I'm doing for now. I'll just have to keep a close eye on my NAS since the raw files are a fair amount bigger. Or, I can use it as an excuse to upgrade. Haha Thanks for the responses, guys!
Guest asrequested Posted January 26, 2018 Posted January 26, 2018 And keep using the desktop app. You'll have less issues.
