heula 192 Posted March 9, 2018 Author Posted March 9, 2018 Yes wake for recordings is planned for the future. As for the file name, we don't currently have a setting to add channel name to the end but that's reasonable. I see this is implanted now in Emby and I have tested it and it is working like expected. Comparing the native use of my HDhomerun tuner with the DVBlink software I hope recordings naming (mentioned here) can be implanted and also the option to import our own images for having all images landscape or poster format (mentioned here). Under the "Serie" button all images are poster format and that is a good thing. Perhaps give us the option to choose what format we want per section. Poster or landscape. And an Emby PVR client for Kodi would be the final touch to have. A feature request is already made here. And if possible make the recording icon for series recording directly visible so we can see directly what we have set for recording. Discussed that already here. Issue when using the DVBlink plugin but also when using Native support of the tuner. Thanks for the good work!
heula 192 Posted March 9, 2018 Author Posted March 9, 2018 (edited) I have set a sort order for the channels and that works but the numbering is the numbering from the tuner and not the sort order number. Maybe the numbers used here can be the sort order numbers. Looks nicer also. Or if you ask me it can be optional if people want to see those numbers. The icons centered or on the left would be just fine for me. Thanks. Edited March 9, 2018 by heula
Luke 42208 Posted March 9, 2018 Posted March 9, 2018 Well the sort title is just for sorting. We're going to revamp our channel management soon though. 1
