Mopar_Mudder 14 Posted January 17, 2018 Posted January 17, 2018 Playing around with Cinema Mode and having it working and it is pretty decent. I do have one suggestion though that would make it better. For the codec intros how about changing it so that we could have a folder that is named what ever the code is and then it would play a random file from that folder. I don't like being stuck with one intro when their are so many cool DTS and Dolby intro. Also I have it set to play two new trailers and have the trailer plug in installed. I played two movies last night and too my surprise it played exactly the same two trailers for both movies, but in reverse order. 1
mastrmind11 722 Posted January 17, 2018 Posted January 17, 2018 (edited) December 2016: https://emby.media/community/index.php?/topic/43122-quick-question-on-codec-intros-in-cinema-mode/?hl=%2Bintro+%2Bcodec And yes, this would be awesome. Edited January 17, 2018 by mastrmind11
Luke 42186 Posted January 17, 2018 Posted January 17, 2018 this is a good idea, however in the meantime you can still achieve the same thing because the video file just has to start with the codec name.
Guest asrequested Posted January 17, 2018 Posted January 17, 2018 So we can name them, ac3 - intro 1.mkv, ac3 - intro 2.mkv? And it will choose randomly?
Guest asrequested Posted January 17, 2018 Posted January 17, 2018 Sweet! I'm going to be doing that. That isn't clear in the wiki, so maybe that could be adjusted?
Luke 42186 Posted January 17, 2018 Posted January 17, 2018 Actually sorry, I lied. That's not true anymore. After reviewing the code I remembered that we had to stop doing that because then you'd have a situation where dts would be picking up codec intros for dts-hd. We could obviously put a hack in the code for that specific one but that won't be able to handle them all.
Guest asrequested Posted January 17, 2018 Posted January 17, 2018 Damn! So then I also would like to have folders for each codec, so we can have multiple and have them play, randomly.
Mopar_Mudder 14 Posted January 17, 2018 Author Posted January 17, 2018 Actually sorry, I lied. That's not true anymore. After reviewing the code I remembered that we had to stop doing that because then you'd have a situation where dts would be picking up codec intros for dts-hd. We could obviously put a hack in the code for that specific one but that won't be able to handle them all. Man I was already off to go change them then I read this. Your kind of a tease..... Well I will keep hoping for a change, I would think a folder with the name of the codec or tag would be the easiest way to do it, but then I don't write the code
Luke 42186 Posted January 18, 2018 Posted January 18, 2018 Ok, we can add this to the next beta. I will be depending on you guys for testing this though, thanks.
Mopar_Mudder 14 Posted January 18, 2018 Author Posted January 18, 2018 Happy to test, just let me know how to get the Beta.
Guest asrequested Posted January 18, 2018 Posted January 18, 2018 Ok, we can add this to the next beta. I will be depending on you guys for testing this though, thanks. I'm running a beta. I'll be able to test it
Guest asrequested Posted January 20, 2018 Posted January 20, 2018 (edited) So this is in the Beta now, right? What's the naming convention for the folders? Just ac3, truehd etc? Edited January 20, 2018 by Doofus
Luke 42186 Posted January 20, 2018 Posted January 20, 2018 not yet, and it would have to match whatever the codec in the media info is.
Guest asrequested Posted January 20, 2018 Posted January 20, 2018 So, a parent folder with codec sub-folders? Codecs > ac3 > intro 1.mkv > dts > intro 1.mkv
Guest asrequested Posted January 20, 2018 Posted January 20, 2018 That works, nicely! One thing, though. if you have a movie with multiple sound tracks, and you choose a different track other than the first in the list, the codec intro always matches the the first in the list, and not the track you pick.
Mopar_Mudder 14 Posted January 22, 2018 Author Posted January 22, 2018 Just wanted to update the new trailer play back. I had stated in my first post that I played two movies and it played the same two trailers for both of them. Well last night we played a movie and again got one of the same trailers plus the second trailer was another trailer for the exact same movie, so two trailers for the same movie. Something is off with "random" trailer play back. Also on a forth movie we watched I never played a trailer, just stuck on a spinning circle doing nothing. Now this could be do to internet service which can be less then great where I am, I really miss downloading the trailers for quick play back. Any way is it possible to have something that if it can't get a trailer playing from the internet in say 10 seconds or something it will just skip them and move on to the next item in the Cinema Mode list?
Luke 42186 Posted January 22, 2018 Posted January 22, 2018 that if it can't get a trailer playing from the internet in say 10 seconds or something it will just skip them and move on to the next item in the Cinema Mode list? That's what we should be doing, and if it's not happening, then please discuss an example and attach the information requested in how to report a media playback issue. thanks !
Mopar_Mudder 14 Posted May 25, 2018 Author Posted May 25, 2018 Just bringing this back up to see if anything has been happening to improve the Codec intro's options.
Luke 42186 Posted May 25, 2018 Posted May 25, 2018 It looks like there's still a question that needs answering?
Mopar_Mudder 14 Posted May 25, 2018 Author Posted May 25, 2018 We were discussing making a change that would allow more then one video per codec. Something like having a folder for a codec and they play a random video from that folder. I thought it sounded like you were going to look into changing it.
Mopar_Mudder 14 Posted July 4, 2018 Author Posted July 4, 2018 If it is in place how does it work? Every thing on the settings screen and instructions still say you can only have one file for each codec.
Solution Guest asrequested Posted July 4, 2018 Solution Posted July 4, 2018 If it is in place how does it work? Every thing on the settings screen and instructions still say you can only have one file for each codec. You just make a folder named correctly with the codec, and put the videos in the folder. 1
