chuga 4 Posted January 13, 2018 Posted January 13, 2018 (edited) Hi Issues playing mp4 on iPad. I have tried a few different mp4s. Tried both emby iOS app and via safari but the movie just hangs and never starts playing at all I was able to play the mp4s using vlc on my computer Edit- just checked and I can play the files on the iPad vlc app also Ideas on how to troubleshoot? Thanks Edited January 13, 2018 by chuga
Luke 42243 Posted January 13, 2018 Posted January 13, 2018 hi there @@chuga can we please look at an example? please attach the information requested in how to report a media playback issue. thanks !
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 (edited) Hi @@Luke I am using newest 3.2.60 server via Unraid Docker. Also latest IOS app. I just tried to play a .mp4 (unforgiven) - see attached log. thanks server-63651398400.txt Edited January 13, 2018 by chuga
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 And the ffmpeg log? Was there one? where can I find it? nothing in the appdata\emby\logs folder
Luke 42243 Posted January 13, 2018 Posted January 13, 2018 It looks like either the ffmpeg/ffprobe files have gone missing, or they are not marked as executable. Can you check on that? They are located here: /config/ffmpeg/20150917 Thanks.
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 (edited) It looks like either the ffmpeg/ffprobe files have gone missing, or they are not marked as executable. Can you check on that? They are located here: /config/ffmpeg/20150917 Thanks. Hi - there is not even a ffmpeg folder inside of "config". (see screenshot) there is a ffmpeg folder in appdata\emby\ffmpeg - but no log files in it see second screenshot for this folder Edited January 13, 2018 by chuga
Luke 42243 Posted January 13, 2018 Posted January 13, 2018 Ok, so you have two options: Use the server transcoding menu to configure your ffmpeg build Or switch to the new installation package on our website which will manage the ffmpeg build for you The second option is preferred and will also perform better, but it will require you to uninstall and then install the new package.
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 Ok, so you have two options: Use the server transcoding menu to configure your ffmpeg build Or switch to the new installation package on our website which will manage the ffmpeg build for you The second option is preferred and will also perform better, but it will require you to uninstall and then install the new package. thanks - I have only ever installed Dockers on unraid via their gui - see attached screenshot for the emby dockers available from the docker gui. is one of these the new installation package you are referring to ? thanks
Luke 42243 Posted January 13, 2018 Posted January 13, 2018 For docker you would use the one listed on our website.
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 For docker you would use the one listed on our website. Thanks. I'm not quite sure how to switch to the installation package you referenced In regards that configuring ffmpeg can you provide more information on how to do that?
Luke 42243 Posted January 13, 2018 Posted January 13, 2018 You basically need to download a build from somewhere, you can find some for linux on https://www.ffmpeg.org Then make sure to mark the ffmpeg and ffprobe files as executable and then configure them in emby under the transcoding menu.
chuga 4 Posted January 13, 2018 Author Posted January 13, 2018 thanks for getting me this far - I have posted in unraid emby docker forum for some help how (hurricanehrndz). He uses https://github.com/MediaBrowser/Emby.Build/tree/master/unraid-templates/Emby not sure I can do either of the suggestions you had but maybe someone can update the unraid emby docker to resolve this. thanks
chuga 4 Posted January 14, 2018 Author Posted January 14, 2018 Hi @@Luke FYI - kept at it and came across this post https://emby.media/community/index.php?/topic/50441-docker-unable-to-locate-ffmpeg-unraid/ and the user posted "Solved it myself by swtiching from /config/ffmpeg to /usr/bin/ffmpeg. Now playing media does work again." I tried this (the usr/bin/ffmpeg path) and it seems to be working. Not sure why? thanks
