mbnwa 49 Posted January 9, 2018 Posted January 9, 2018 (edited) Is there anyway to retain the HDR meta data when direct streaming a container switch from MKV -> M4V? Currently on my Apple TV (4K) if I remux the MKV to MP4 I get HDR however I am trying to retain Dolby Atmos for the future so I am using MKV. EDIT: As the post below shows Emby is doing a full transcode for some reason, Emby should do a direct stream remux vs a full on transcode. Thanks Edited January 9, 2018 by mbnwa 1
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 (edited) OK it seems that this is getting transcoded not direct streamed, not sure why that would be the case as the HEVC and AC3 streams should be supported only the container is not supported. (This is while selecting the AC3 track not TrueHD track) 2018-01-08 19:39:40.470 Info App: User policy for XXXXXXXXXXXX. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv2018-01-08 19:39:40.470 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 192.168.50.80, IsInLocalNetwork: True2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv2018-01-08 19:39:40.470 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 192.168.50.80, IsInLocalNetwork: True2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True2018-01-08 19:39:40.470 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\192.168.50.10\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv2018-01-08 19:39:40.470 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 192.168.50.80, IsInLocalNetwork: True2018-01-08 19:39:40.471 Info HttpServer: HTTP Response 200 to 192.168.50.80. Time: 5ms. http://192.168.50.10:8096/emby/Items/fdfbeab9812d77a39be3219e45633a4b/PlaybackInfo?UserId=66f17f239d9172dd0aef9b4f6743c04c&StartTimeTicks=0&AutoOpenLiveStream=true&MaxStreamingBitrate=1400000002018-01-08 19:39:40.472 Info HttpServer: HTTP GET http://192.168.50.10:8096/emby/Users/66f17f239d9172dd0aef9b4f6743c04c/Items?recursive=true&limit=4&includeItemTypes=Movie&filters=IsUnplayed&sortBy=DateCreated&sortOrder=Descending. UserAgent: Emby/3 CFNetwork/893.14 Darwin/17.4.02018-01-08 19:39:40.505 Info HttpServer: HTTP Response 200 to 192.168.50.80. Time: 33ms. http://192.168.50.10:8096/emby/Users/66f17f239d9172dd0aef9b4f6743c04c/Items?recursive=true&limit=4&includeItemTypes=Movie&filters=IsUnplayed&sortBy=DateCreated&sortOrder=Descending2018-01-08 19:39:40.795 Info HttpResultFactory: Transmit file S:\Mediabrowser\transcoding\transcoding-temp\ac627edf5f4535e0eef2bf5d0984f39320.ts2018-01-08 19:39:40.797 Info HttpServer: HTTP Response 500 to 192.168.50.80. Time: 765ms. http://192.168.50.10:8096/emby/videos/fdfbeab9812d77a39be3219e45633a4b/hls1/main/20.ts?DeviceId=B1C0DE9E-97E7-495F-BA29-6AB45B941382&MediaSourceId=fdfbeab9812d77a39be3219e45633a4b&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=2&VideoBitrate=139616000&AudioBitrate=384000&MaxAudioChannels=6&MaxWidth=3840&PlaySessionId=e117c43679954da99661b00873c06f7c&CopyTimestamps=false&EnableSubtitlesInManifest=true&Tag=5865b6669dc90c1d4a0af916cb312190&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-deinterlace=true&h264-level=42 The following is the same MKV converted to M4V it looks like "Codec Tag" was added would that cause this issue? In addition the bitrates seem to be different but no transcoding was done just remux into M4V container. The below will direct play with out issues. Edited January 9, 2018 by mbnwa
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 Apple TV doesn't support them. https://www.apple.com/apple-tv/specs/
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 (edited) Apple TV does not support what? I have shown if it's in m4v it works as expected however it does not work as expected in MKV where Emby should do on the fly direct stream (remux) from MKV to M4V leaving the audio and video alone. (I am also talking about Apple TV 4K) https://www.apple.com/apple-tv-4k/specs/ Edited January 9, 2018 by mbnwa
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 Apple TV does not support what? I have shown if it's in m4v it works as expected however it does not work as expected in MKV where Emby should do on the fly direct stream (remux) from MKV to M4V leaving the audio and video alone. (I am also talking about Apple TV 4K) I was just going to ask about that. So then you should post the transcode log. That will tell us what's happening
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 But it still looks like TrueHD/Atmos isn't supported
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 It's not however that's not the stream I am selecting, I am selecting 5.1 AC3 stream - Apple will be releasing an update later to add Atmos support based on it's release notes. Transcode Log: 2018-01-08 20:29:57.698 Application version: 3.2.60.0 http://192.168.50.10:8096/emby/videos/fdfbeab9812d77a39be3219e45633a4b/hls1/main/0.ts?DeviceId=B1C0DE9E-97E7-495F-BA29-6AB45B941382&MediaSourceId=fdfbeab9812d77a39be3219e45633a4b&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=2&VideoBitrate=139616000&AudioBitrate=384000&MaxAudioChannels=6&MaxWidth=3840&PlaySessionId=b9728acdc2eb4e0dbda2cc6c6c0885d5&api_key=feefc10ebb72450e9a9e400222931e56&CopyTimestamps=false&EnableSubtitlesInManifest=true&Tag=5865b6669dc90c1d4a0af916cb312190&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-deinterlace=true&h264-level=42 {"Protocol":"File","Id":"fdfbeab9812d77a39be3219e45633a4b","Path":"S:\\Media Storage\\Movies\\Deadpool\\Deadpool (4K UHD).mkv","Type":"Default","Container":"mkv,webm","Name":"Deadpool (4K UHD).mkv","IsRemote":false,"ETag":"5865b6669dc90c1d4a0af916cb312190","RunTimeTicks":64862400512,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"4K HEVC","IsInterlaced":false,"BitRate":51141683,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":2160,"Width":3840,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":153,"IsAnamorphic":false},{"Codec":"truehd","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 7.1","DisplayTitle":"Eng TRUEHD 7.1 Default","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 5.1","DisplayTitle":"Eng Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Stereo","DisplayTitle":"Eng Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":224000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Stereo","DisplayTitle":"Eng Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":224000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":51141683,"RequiredHttpHeaders":{}} User policy for XXXXXXXXXXXXXXXXXXXXXX: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True C:\Users\XXXXXXXXXXXXXXXXXXXXXX\AppData\Roaming\MediaBrowser-Server\system\ffmpeg.exe -f matroska,webm -i file:"S:\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv" -threads 0 -map 0:0 -map 0:2 -map -0:s -codec:v:0 libx264 -vf "scale=trunc(min(max(iw\,ih*dar)\,3840)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset veryfast -crf 18 -maxrate 102283366 -bufsize 204566732 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 ac3 -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8" -y "S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1%d.ts" ffmpeg version 3.4.1 Copyright © 2000-2017 the FFmpeg developers built with gcc 7.2.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 [matroska,webm @ 00000172cc898360] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:S:\Media Storage\Movies\Deadpool\Deadpool (4K UHD).mkv': Metadata: title : Deadpool encoder : libmakemkv v1.10.9 (1.3.5/1.4.7) darwin(x64-release) creation_time : 2018-01-09T02:58:57.000000Z Duration: 01:48:06.24, start: 0.000000, bitrate: 51141 kb/s Chapter #0:0: start 0.000000, end 184.726208 Metadata: title : Chapter 01 Chapter #0:1: start 184.726208, end 353.019333 Metadata: title : Chapter 02 Chapter #0:2: start 353.019333, end 570.570000 Metadata: title : Chapter 03 Chapter #0:3: start 570.570000, end 799.089958 Metadata: title : Chapter 04 Chapter #0:4: start 799.089958, end 1008.716042 Metadata: title : Chapter 05 Chapter #0:5: start 1008.716042, end 1212.294417 Metadata: title : Chapter 06 Chapter #0:6: start 1212.294417, end 1326.408417 Metadata: title : Chapter 07 Chapter #0:7: start 1326.408417, end 1629.628000 Metadata: title : Chapter 08 Chapter #0:8: start 1629.628000, end 1918.958708 Metadata: title : Chapter 09 Chapter #0:9: start 1918.958708, end 2211.709500 Metadata: title : Chapter 10 Chapter #0:10: start 2211.709500, end 2466.088625 Metadata: title : Chapter 11 Chapter #0:11: start 2466.088625, end 2685.474458 Metadata: title : Chapter 12 Chapter #0:12: start 2685.474458, end 2816.605458 Metadata: title : Chapter 13 Chapter #0:13: start 2816.605458, end 3010.799458 Metadata: title : Chapter 14 Chapter #0:14: start 3010.799458, end 3198.028167 Metadata: title : Chapter 15 Chapter #0:15: start 3198.028167, end 3332.662667 Metadata: title : Chapter 16 Chapter #0:16: start 3332.662667, end 3547.752542 Metadata: title : Chapter 17 Chapter #0:17: start 3547.752542, end 3785.072958 Metadata: title : Chapter 18 Chapter #0:18: start 3785.072958, end 4026.439083 Metadata: title : Chapter 19 Chapter #0:19: start 4026.439083, end 4155.442958 Metadata: title : Chapter 20 Chapter #0:20: start 4155.442958, end 4349.720375 Metadata: title : Chapter 21 Chapter #0:21: start 4349.720375, end 4606.059792 Metadata: title : Chapter 22 Chapter #0:22: start 4606.059792, end 4843.713875 Metadata: title : Chapter 23 Chapter #0:23: start 4843.713875, end 5153.064583 Metadata: title : Chapter 24 Chapter #0:24: start 5153.064583, end 5463.791667 Metadata: title : Chapter 25 Chapter #0:25: start 5463.791667, end 5686.972958 Metadata: title : Chapter 26 Chapter #0:26: start 5686.972958, end 5992.736750 Metadata: title : Chapter 27 Chapter #0:27: start 5992.736750, end 6486.240000 Metadata: title : Chapter 28 Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc Metadata: BPS-eng : 44972821 DURATION-eng : 01:48:06.229750000 NUMBER_OF_FRAMES-eng: 155514 NUMBER_OF_BYTES-eng: 36463002673 SOURCE_ID-eng : 001011 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default) Metadata: title : Surround 7.1 BPS-eng : 5024481 DURATION-eng : 01:48:06.230000000 NUMBER_OF_FRAMES-eng: 7783476 NUMBER_OF_BYTES-eng: 4073742712 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s Metadata: title : Surround 5.1 BPS-eng : 640000 DURATION-eng : 01:48:06.240000000 NUMBER_OF_FRAMES-eng: 202695 NUMBER_OF_BYTES-eng: 518899200 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:3(eng): Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Metadata: title : Stereo BPS-eng : 224000 DURATION-eng : 01:48:06.208000000 NUMBER_OF_FRAMES-eng: 202694 NUMBER_OF_BYTES-eng: 181613824 SOURCE_ID-eng : 001104 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:4(eng): Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Metadata: title : Stereo BPS-eng : 224000 DURATION-eng : 01:48:06.208000000 NUMBER_OF_FRAMES-eng: 202694 NUMBER_OF_BYTES-eng: 181613824 SOURCE_ID-eng : 001105 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:5(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 41605 DURATION-eng : 01:47:39.307020833 NUMBER_OF_FRAMES-eng: 3704 NUMBER_OF_BYTES-eng: 33593007 SOURCE_ID-eng : 0012A0 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.9 darwin(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2018-01-09 02:58:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264)) Stream #0:2 -> #0:1 (ac3 (native) -> ac3 (native)) Press [q] to stop, [?] for help [libx264 @ 00000172ce14db00] using SAR=1/1 [libx264 @ 00000172ce14db00] frame MB size (240x135) > level limit (8192) [libx264 @ 00000172ce14db00] DPB size (4 frames, 129600 mbs) > level limit (1 frames, 32768 mbs) [libx264 @ 00000172ce14db00] VBV bitrate (102283) > level limit (50000) [libx264 @ 00000172ce14db00] VBV buffer (204566) > level limit (62500) [libx264 @ 00000172ce14db00] MB rate (776823) > level limit (245760) [libx264 @ 00000172ce14db00] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 [libx264 @ 00000172ce14db00] profile Main, level 4.1 [libx264 @ 00000172ce14db00] 264 - core 152 r2851 ba24899 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=18 lookahead_threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=18.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=102283 vbv_bufsize=204566 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d10.ts' for writing Output #0, segment, to 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1%d.ts': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (libx264), yuv420p, 3840x2160 [sAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc Metadata: encoder : Lavc57.107.100 libx264 Side data: cpb: bitrate max/min/avg: 102283000/0/0 buffer size: 204566000 vbv_delay: -1 Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s Metadata: encoder : Lavc57.107.100 ac3 frame= 1 fps=0.9 q=0.0 size=N/A time=00:00:00.66 bitrate=N/A speed=0.58x frame= 3 fps=1.8 q=0.0 size=N/A time=00:00:00.66 bitrate=N/A speed=0.401x frame= 22 fps= 10 q=0.0 size=N/A time=00:00:01.49 bitrate=N/A speed=0.686x frame= 33 fps= 12 q=23.0 size=N/A time=00:00:01.91 bitrate=N/A speed=0.711x frame= 54 fps= 17 q=23.0 size=N/A time=00:00:02.87 bitrate=N/A speed=0.897x frame= 75 fps= 20 q=23.0 size=N/A time=00:00:03.67 bitrate=N/A speed=0.989x frame= 94 fps= 22 q=23.0 size=N/A time=00:00:04.57 bitrate=N/A speed=1.08x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d11.ts' for writing frame= 112 fps= 23 q=23.0 size=N/A time=00:00:05.24 bitrate=N/A speed=1.09x frame= 129 fps= 24 q=23.0 size=N/A time=00:00:05.91 bitrate=N/A speed= 1.1x frame= 142 fps= 24 q=23.0 size=N/A time=00:00:06.55 bitrate=N/A speed=1.11x frame= 159 fps= 25 q=23.0 size=N/A time=00:00:07.22 bitrate=N/A speed=1.13x frame= 172 fps= 25 q=23.0 size=N/A time=00:00:07.77 bitrate=N/A speed=1.12x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d12.ts' for writing frame= 189 fps= 25 q=23.0 size=N/A time=00:00:08.50 bitrate=N/A speed=1.13x frame= 205 fps= 26 q=23.0 size=N/A time=00:00:09.05 bitrate=N/A speed=1.13x frame= 219 fps= 26 q=23.0 size=N/A time=00:00:09.65 bitrate=N/A speed=1.13x frame= 234 fps= 26 q=23.0 size=N/A time=00:00:10.23 bitrate=N/A speed=1.13x frame= 248 fps= 26 q=23.0 size=N/A time=00:00:10.87 bitrate=N/A speed=1.14x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d13.ts' for writing frame= 266 fps= 26 q=23.0 size=N/A time=00:00:11.67 bitrate=N/A speed=1.16x frame= 282 fps= 27 q=23.0 size=N/A time=00:00:12.25 bitrate=N/A speed=1.16x frame= 296 fps= 27 q=23.0 size=N/A time=00:00:12.98 bitrate=N/A speed=1.17x frame= 310 fps= 27 q=23.0 size=N/A time=00:00:13.46 bitrate=N/A speed=1.16x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d14.ts' for writing frame= 321 fps= 26 q=23.0 size=N/A time=00:00:13.97 bitrate=N/A speed=1.15x frame= 338 fps= 27 q=23.0 size=N/A time=00:00:14.65 bitrate=N/A speed=1.16x frame= 354 fps= 27 q=23.0 size=N/A time=00:00:15.25 bitrate=N/A speed=1.16x frame= 368 fps= 27 q=23.0 size=N/A time=00:00:15.89 bitrate=N/A speed=1.16x frame= 386 fps= 27 q=23.0 size=N/A time=00:00:16.66 bitrate=N/A speed=1.17x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d15.ts' for writing frame= 404 fps= 27 q=23.0 size=N/A time=00:00:17.43 bitrate=N/A speed=1.18x frame= 417 fps= 27 q=23.0 size=N/A time=00:00:17.97 bitrate=N/A speed=1.18x frame= 435 fps= 28 q=23.0 size=N/A time=00:00:18.68 bitrate=N/A speed=1.18x frame= 451 fps= 28 q=23.0 size=N/A time=00:00:19.38 bitrate=N/A speed=1.19x [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d16.ts' for writing [segment @ 00000172ce59d5a0] Opening 'S:\Mediabrowser\transcoding\transcoding-temp\0ea1665e3cdafef049ddc0594ebf69d1.m3u8.tmp' for writing frame= 462 fps= 27 q=-1.0 Lsize=N/A time=00:00:19.86 bitrate=N/A speed=1.18x video:17201kB audio:932kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 00000172ce14db00] frame I:8 Avg QP:11.12 size:218077 [libx264 @ 00000172ce14db00] frame P:138 Avg QP:14.06 size: 68843 [libx264 @ 00000172ce14db00] frame B:316 Avg QP:17.10 size: 20153 [libx264 @ 00000172ce14db00] consecutive B-frames: 6.3% 4.8% 8.4% 80.5% [libx264 @ 00000172ce14db00] mb I I16..4: 77.9% 0.0% 22.1% [libx264 @ 00000172ce14db00] mb P I16..4: 33.1% 0.0% 0.0% P16..4: 23.1% 0.0% 0.0% 0.0% 0.0% skip:43.8% [libx264 @ 00000172ce14db00] mb B I16..4: 4.1% 0.0% 0.0% B16..8: 16.1% 0.0% 0.0% direct: 5.5% skip:74.4% L0:40.6% L1:50.8% BI: 8.7%
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 Well, MKV isn't supported, and are you trying to use subtitles? [matroska,webm @ 00000172cc898360] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size You said when you remuxed to MP4 (as you tested, earlier), then play it with the AC3 track, what happens?
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 (edited) I understand that MKV is not supported however Emby has 3 modes Direct Play (nothing done, plays direct from the NAS), Direct Stream (remux based on invalid container as in this case and what I am aiming for or invalid audio codec) and Transcode (CPU HOG) Subtitle was not selected (none) When I remux to M4V HDR works, AC3 works and it's Direct Play, in my MKV example everything that was selected is supported by the device however for some reason Emby feels it necessary to transcode the audio and video as well as the container, however only the container should need to be changed thus falling under direct streaming vs transcode. Edited January 9, 2018 by mbnwa
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 Luke would have to confirm this, but (and I for get the correct terminology) in some instances, when a change needs to made (remux etc), the streams aren't transferable through the server, and are then transcoded. In your case, the container isn't supported and probably is forcing a full transcode. As you see by your own remux, it will direct play (with the AC3 track, selected)
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 Funny your thread https://emby.media/community/index.php?/topic/48799-direct-play-vs-direct-streaming-vs-transcoding/ states basically what I am doing base on the selected audio / video being supported by the device in question Under the Direct Stream section, maybe Luke will chime in and advise why a full transcode is being forced and not just a simple remux into the new container. The container isn't supported by the player (MKV, AVI, MP4 etc). In this case, the server will demux the file and remux it in a supported container, with no change to the audio or video.
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 ffmpeg-transcode-d9506f88-6ba6-4702-81b1-48a27c623bd2.txt was posted 5 posts up inline.
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 (edited) If you look at my 2nd post the remuxed file is still in main 10 and it plays with direct play and HDR as expected the only difference is the addition of the "codec tag" that is missing from the MKV. In addition the Apple TV 4K link that was posted states it supports Main 10 https://www.apple.co...le-tv-4k/specs/ Edited January 9, 2018 by mbnwa
Luke 42238 Posted January 9, 2018 Posted January 9, 2018 the video codec tag is not hvc1 and that is the reason for the full transcode. @@ebr can further elaborate
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 Luke, the M4V has the codec tag of HVC1 (as seen by my screen shots) and does not transcode the MKV does not have the codec tag and transcodes vs direct stream, both files has the codec listed as "HEVC" this can all be seen in my screenshots on the 2nd post.
Luke 42238 Posted January 9, 2018 Posted January 9, 2018 right, the video codec tag is not hvc1 and that is the reason for the full transcode. @ebr can further elaborate
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 MakeMKV does not put codec tag's in the MKV container as far as I can tell, so if the MKV needs to have codec tag's added hvc1, ac-3, ect how can that be added to the MKV?
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 MakeMKV does not put codec tag's in the MKV container as far as I can tell, so if the MKV needs to have codec tag's added hvc1, ac-3, ect how can that be added to the MKV? I'm thinking that you can't. Apple does stupid things. I have a feeling that apple tv requires that tag, and can only be applied in the containers that apple, supports. I'm curious to see what @@ebr says. This interests me.
Luke 42238 Posted January 9, 2018 Posted January 9, 2018 We figured that over time apple would improve hevc playback so if there have been any tvos updates recently that might affect it then we can re-evaluate to see if the condition is still needed. but @@ebr can elaborate.
Guest asrequested Posted January 9, 2018 Posted January 9, 2018 Apple are so far behind the curve #yesterday's tech
andyblac644 69 Posted January 9, 2018 Posted January 9, 2018 (edited) another reason to use infuse pro 5 as the external player . Edited January 9, 2018 by andyblac644
ebr 16332 Posted January 9, 2018 Posted January 9, 2018 Yes, it is the absence of the codec tag that is the problem. The issue here is we have to err on the conservative side of transcoding when we don't know that codec tag. Because Apple actually only supports one flavor of HEVC. So, if your video happened to be the other flavor, it simply would not play.
mbnwa 49 Posted January 9, 2018 Author Posted January 9, 2018 (edited) I have not found a way to be able to add the codec tag into the MKV MakeMKV does not do it, MKVToolNix does not add the proper tag via it's hex editor it does allow a codec name tag to be added but Emby does not see that as Codec tag or any tag at all for that matter. What suggestion do you have to be able to add the Codec tag to the MKV so transcoding is not required? Edited January 9, 2018 by mbnwa
Zodler 18 Posted March 2, 2018 Posted March 2, 2018 Please help. I have the same problem. If I play an MKV HEVC HDR, the TV does not switch to HDR and the server is saying it is transcoding. If I play other MKV AVC it says Direct playing. If I use Infuse or MrMC emby client, they play the file correctly with TV switching to HDR and Emby server saying Direct Playing. I hope you can correct this in Emby Apple TV app. In the meantime I tried to mux the MKV to MP4 with no success. The resulted file is unplayable even on PC. The program I use it uses MP4BOX, what should I use to mux MKV HDR to MP4?
