spriggig 9 Posted March 11, 2014 Posted March 11, 2014 Hello, I just installed MBC over the weekend and it seems to work OK, so I thought I'd try MBT. The only significant problem I've had is that my Harmony 640 remote, which is setup to work with MBC does not work in MBT. I have a Hauppauge WinTV HVR-1850 (Model 85xxx, Combo ATSC/QAM, 888 DIF) and I'm using the IR receiver and driver that came with that. When I install MBT, the remote stops working in both MBC and MBT, if I "Restart IR" (a Hauppauge utility) the remote then works in MBC, but still not in MBT. This is true even if I run both MBC and MBT at the same time, switching between them, the remote works in MBC but not in MBT. Any ideas? I've attached my most recent MBT log, if that will help. Thank you. theater-63530077412.log
Redshirt 1487 Posted March 11, 2014 Posted March 11, 2014 When you say doesn't work... Do you mean doesn't work at all, or certain buttons work but others don't?
spriggig 9 Posted March 11, 2014 Author Posted March 11, 2014 Does not work at all. Works perfectly in WMC and MBC, zero in MBT.
wraslor 70 Posted March 11, 2014 Posted March 11, 2014 What do you have your remote setup for in the harmony config? I know I had to set mine to windows media center SE. I've had a one, 900, and 650 that all worked fine with mbc and mbt.
spriggig 9 Posted March 11, 2014 Author Posted March 11, 2014 It's configured to run a WMC PC, my Toshiba TV and my 5.1 receiver, nothing special as far as that goes, but I haven't looked at it in detail since I set it up. I'll take a look at the setup and mess around with it tonight. Maybe just wiping it and starting over will work.
elshagon 44 Posted March 11, 2014 Posted March 11, 2014 Yeah do what wraslor suggested and set up the activity to include windows media center SE as one of the devices to give you more control over your pc. Check to see what the "customize buttons" are set for in the activity making sure they're set for media center pc
spriggig 9 Posted March 12, 2014 Author Posted March 12, 2014 Figured it out. For whatever reason I had this thing installed and running at start up: IR Remote control applicationIR Remote control version 28015 Remote control applet for use with WinTV 7. After you run this applet, an icon will appear in your Windows device tray showing that the Hauppauge remote control is active. Name: ir32_28015.exeName: 442KBName: 2/3/2010 Which is found on the "Accessories" tab of this page: http://www.hauppauge.com/site/support/support_hvr1800.htm Exiting that fixed my problem. Thank you for time and responses.
Luke 42243 Posted January 5, 2018 Posted January 5, 2018 @@spriggig We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge Thanks.
