No Audio v2.9.6 Web download
Go to solution Solved by kanipek,
Guest asrequested
I will probably do that in the future, After I move the shield I am currently using.
What is the command to get it to spit out a list of audio devices ?
From the command line, you can use this
--audio-device=help
Or if you enable logging, generate a log, the device will be in there. Like this
[ao] Trying audio driver 'wasapi'
[   0.173][v][ao] Using preferred device 'SC-95 (Intel(R) Display Audio)'
[   0.173][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3
[   0.173][d][ao/wasapi] Init wasapi
[   0.173][d][ao/wasapi] Find device 'SC-95 (Intel(R) Display Audio)'
[   0.174][v][ao/wasapi] Selecting device by name: 'SC-95 (Intel(R) Display Audio)'
[   0.174][v][ao/wasapi] Selecting device '{ae916b2b-6e93-4676-b99b-9152070302f7}' (SC-95 (Intel(R) Display Audio))
--audio-device=help
Does not work for me. what directory should I be in?
C:\Users\kanip\AppData\Roaming\Emby-Theater\system\x64\mpv is where I am trying from
You have open a command prompt in the folder where the mpv.exe is. Then type, mpv --audio-device=help
It's easier to look in your logs.
https://emby.media/community/index.php?/topic/50975-how-to-enable-mpv-logging-for-theater/
Okay. Got it.
I see what you are talking about with things changing compared to one I ran from September.
So the better way to do the mpv.conf (when I get around to it) would be:--audio-device=wasapi/Speakers (JBL Charge 2+ Stereo)  ?
Guest asrequested
You can leave off the the dashes, and as long as that is the device name mpv uses, that's correct.
If your speakers are analogue, and you use the jack, then you'll be using the internal audio device (probably Realtek). Like I said, enable logging, and it'll tell you exactly what the device name is.
  • Like 1
Thanks so much!
Guest asrequested
Thanks so much!
You're welcome.
