How to enable mpv logging for Theater
  • Please log in to reply
9 replies to this topic
#1 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13578 posts
  • Local time: 09:51 AM
Posted 20 September 2017 - 02:05 AM
The default player in Emby Theater Desktop is mpv. It is a self-contained player that has been incorporated into the Theater app. The Theater app logs don't contain information directly from mpv. MPV can generate it's own logs. If you use Emby Theater Desktop and are experiencing some playback issues, you may want to enable mpv logging. To do this, you need to make an mpv.conf file and add the correct command.
1. Make an mpv folder in this location
%AppData%\Roaming
2. In the mpv folder, make the file mpv.conf. You can do this using notepad and change the extension from .txt to .conf
3. Add the command log-file= to the mpv.conf. You will need to choose where the log file is saved. In the command you will also need to name the file. I suggest Theater mpv log.txt
It will look something like this: log-file="D:\mpv logs\Theater mpv log.txt"
You can also increase the log level by adding this line:
https://mpv.io/manua...tions-msg-level
msg-level=
Note:
Each time you play something, this log will be written over. It will not generate new logs.
Edited by Doofus, 07 December 2019 - 06:47 PM.
  • Sammy, SikSlayer, denz and 3 others like this
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149338 posts
  • Local time: 12:51 PM
Posted 20 September 2017 - 11:18 AM
Thanks @Doofus !
  • Sammy and Doofus like this
#3 lorac OFFLINE
lorac
    Advanced Member
  • Members
  • 475 posts
  • LocationVancouver, Canada
Posted 17 February 2019 - 11:49 PM
Also you need to manually create the directory where the log files will be stored if it doesn't already exist.
#4 mrfaulk OFFLINE
mrfaulk
    Advanced Member
  • Members
  • 230 posts
  • Local time: 05:51 PM
Posted 05 January 2020 - 01:23 AM
any idea how to see mpv.conf entries in the log file?
for example, if using mpv with plex, mpv.conf entries are displayed in the mpv log file, you can easily see which mpv.conf entries loaded successfully, which ones didn't, and you can also see if the paths and content of scripts and shaders worked correctly...
however using just mpv, i can't seem to see/find any of this in the log file even tho it's easy to tell whether or not the mpv.conf entries and/or scripts/shaders have loaded because of cpu/gpu load and difference in video image.
#5 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13578 posts
Posted 05 January 2020 - 01:45 AM
They should be the same unless the two mpv versions are very different. You can also add  ## comments above conf entries. Also, depending on what you're looking for, you may need to elevate the log level. Try msg-level=v
#6 mrfaulk OFFLINE
mrfaulk
    Advanced Member
  • Members
  • 230 posts
Posted 07 January 2020 - 08:51 AM
my mpv.conf script, log file is created in the specified location but still can't find anything in the log file that specifically references the mpv.conf entries... if you search for mpv.conf in your log file do you come up with a hit? thanks!
log-file="C:\Users\MEDIA\AppData\Roaming\mpv\logs\mpv-log.txt"
msg-level=v
#7 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13578 posts
Posted 07 January 2020 - 03:41 PM
Unless you make profiles, you just have to dig through it. What specifically are you looking for?
#8 sundaypex153 OFFLINE
sundaypex153
    Newbie
  • Members
  • 4 posts
  • Local time: 06:51 PM
Posted 09 February 2020 - 07:55 PM
doofus i dont understad... what do you when you say Add the command log-file= to the mpv.conf.
#9 sundaypex153 OFFLINE
sundaypex153
    Newbie
  • Members
  • 4 posts
can you please explain?
#10 Doofus OFFLINE
Doofus
    Advanced Member
  • Members
  • 13578 posts
Posted 09 February 2020 - 08:09 PM
Did you not see the examples? What is confusing you?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
