Guest asrequested Posted February 12, 2018 Posted February 12, 2018 display-sync-active Return whether --video-sync=display is actually active. thats no option thats a property that shows what video-sync is active I know
Guest asrequested Posted February 12, 2018 Posted February 12, 2018 Updated to latest MPV build and the result with Audio Passthrough disabled is different: very heavy video stutter. Audio is still not present. Result with Audio Passthrough enabled is the same as previous test. Try this https://emby.media/community/index.php?/topic/46763-theater-mpv-test/
mark235 5 Posted February 12, 2018 Author Posted February 12, 2018 What do you want me to try? The build on the 1st page of the thread?
Guest asrequested Posted February 12, 2018 Posted February 12, 2018 Yeah, it's had some adjustments and it has the latest mpv build.
FerLuisxd 0 Posted July 29, 2018 Posted July 29, 2018 Hey is there something new? Interpolation seems to be stock at 24fps on my samsung s7 Maybe I did something wrong, or is it still not possible to match refresh rate?(60hz)
Guest asrequested Posted July 29, 2018 Posted July 29, 2018 If your GPU is set to 60Hz, it should interpolate without any other settings. What are you trying to do?
mark235 5 Posted August 18, 2018 Author Posted August 18, 2018 (edited) Just to wrap this thread up, In the end, I settled on a combination of "Change display refresh rate to match video" and a low frame interpolation setting on my Samsung tv. Not 100% the same viewing experience as MPV Smooth Motion, but close enough. Edited August 18, 2018 by mark235
