gnollo 17 Posted December 5, 2017 Posted December 5, 2017 I'm a premiere user, currently using Emby Theater on an HTPC connected to a 50 inches Panasonic plasma (720p).Looking to upgrade to the 65 inches C7 but reading mixed reports about picture quality if you feed it anything less than bluray. 90% of my library is not bluray so I'm concerned about going back in terms of picture quality. Has anyone done A/B comparisons between- HTPC- LG Emby app- wired amazon fire tv hd@ @@FrostByteSent from my Nexus 5 using Tapatalk
CBers 7554 Posted December 5, 2017 Posted December 5, 2017 I bought a 55" C7V during the Black Friday sales here in the UK and the picture quality is amazing, whether it SD, HD or UHD. 1
FrostByte 5452 Posted December 5, 2017 Posted December 5, 2017 (edited) Rtings did some testing and has a good write-up on the C7 and SDR content viewing is rated pretty high. They also have some calibration tweaks if you like https://www.rtings.com/tv/reviews/lg/c7-oled https://www.rtings.com/tv/reviews/lg/c7-oled/settings Some of what you read may have been prior to calibration. Calibrating can help with any TV of course. They usually come calibrated for showrooms at Best Buy or something and not someone's living room Edited December 5, 2017 by FrostByte
gnollo 17 Posted December 6, 2017 Author Posted December 6, 2017 I bought a 55" C7V during the Black Friday sales here in the UK and the picture quality is amazing, whether it SD, HD or UHD.Do you use an HTPC or the Emby app on WebOS? Sent from my Nexus 5 using Tapatalk
CBers 7554 Posted December 6, 2017 Posted December 6, 2017 Do you use an HTPC or the Emby app on WebOS? The Android TV app on my Shield TV.
gnollo 17 Posted December 6, 2017 Author Posted December 6, 2017 The Android TV app on my Shield TV.Any upsides on using a shield tv vs amazon fire HD? Sent from my Nexus 5 using Tapatalk
gnollo 17 Posted December 6, 2017 Author Posted December 6, 2017 Any upsides on using a shield tv vs amazon fire HD? Sent from my Nexus 5 using Tapatalk https://www.google.co.uk/amp/s/www.androidcentral.com/nvidia-shield-tv-vs-amazon-fire-tv-vs-roku%3famp Mhm I think this answers my own question. I'm using MCE on the HTPC as a PVR, do you guys use Emby as PVR? Is it mature enough to use for that purpose? Can you stream live satellite HD channels to the Shield using the Emby app? And setup new recordings via the same app on Shield? Sent from my Nexus 5 using Tapatalk
andyblac644 69 Posted December 6, 2017 Posted December 6, 2017 https://www.google.co.uk/amp/s/www.androidcentral.com/nvidia-shield-tv-vs-amazon-fire-tv-vs-roku%3famp Mhm I think this answers my own question. I'm using MCE on the HTPC as a PVR, do you guys use Emby as PVR? Is it mature enough to use for that purpose? Can you stream live satellite HD channels to the Shield using the Emby app? And setup new recordings via the same app on Shield? Sent from my Nexus 5 using Tapatalk Yes and yes 1
gnollo 17 Posted December 28, 2017 Author Posted December 28, 2017 Yes and yesAny good setup guides for EmbyTv? I have already created a Schedules Direct lineup to replace the original MCE TV guide, it would be great to reuse that. Sent from my Nexus 5 using Tapatalk
andyblac644 69 Posted December 28, 2017 Posted December 28, 2017 Any good setup guides for EmbyTv? I have already created a Schedules Direct lineup to replace the original MCE TV guide, it would be great to reuse that. Sent from my Nexus 5 using Tapatalk I use my Enigma2 STB with emby, but I'm sure you could do same with USB or PCI DVB-S2 tuner.
gnollo 17 Posted December 28, 2017 Author Posted December 28, 2017 I am using a TBS dual DVB-S2 hi def satellite tuner with MCE. I was more after a tutorial on how to setup the Emby TV server. Sent from my Nexus 5 using Tapatalk
andyblac644 69 Posted December 28, 2017 Posted December 28, 2017 I am using a TBS dual DVB-S2 hi def satellite tuner with MCE. I was more after a tutorial on how to setup the Emby TV server. Sent from my Nexus 5 using Tapatalk maybe start here Server Installation Guide And here https://emby.media/community/index.php?/forum/49-server/ 1
gnollo 17 Posted December 29, 2017 Author Posted December 29, 2017 https://emby.media/community/index.php?/topic/53979-live-tv-for-satellites/?hl=dvb-s2 Does this mean that Emby does not support satellite tv cards, like my DVB-S dual card?
Luke 42234 Posted December 29, 2017 Posted December 29, 2017 Yes it does via any of our live TV plugins. Thanks. 1
gnollo 17 Posted December 29, 2017 Author Posted December 29, 2017 Yes it does via any of our live TV plugins. Thanks.Great I'll test it tonight Sent from my Nexus 5 using Tapatalk
gnollo 17 Posted December 30, 2017 Author Posted December 30, 2017 Tested the Dvbviewer plugin, no use to me as it doesn't support schedules direct. NextPVR does, and I was able to get channels working on the Emby TV server. I can see some guide in NextPVR but none yet in Emby TV. Does it need to be setup separately? Sent from my Nexus 5 using Tapatalk
Luke 42234 Posted December 30, 2017 Posted December 30, 2017 Try running the refresh guide scheduled task.
