ohhofer 2 Posted December 3, 2017 Posted December 3, 2017 Hi I am new to emby theater and it is probably a silly question, but please help me out. I run emby server and emby theater on the same windows 10 pc. the pc is linked to an denon avr receiver. when playing a video-file with dts-hd audio via emby theater there is no sound. when playing the same video-file on the same machine via kodi it works well. In Kodi the video/audio plays well because I selectes the output device WASAPI: HDMI I cannot find a setting within emby theater where I can change the output device to WASAPI. The audio settings page looks as follows: what am i doing wrong? thanks in advance for your help, oliver
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 hi luke the receiver supports dts but not dtshd. the aim is to get normal 5.1 sound when playing a dtshd-file. this works with kodi/wasapi and it also works with emby run on a fire tv stick. but it does not work with emby theater.
Luke 42242 Posted December 3, 2017 Posted December 3, 2017 So then you would need to uncheck that box if your receiver does not support it. Thanks.
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 I unchecked the boxes like shown below, but still no sound.
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 OK, I'm going to have you set up mpv logging, in a few minutes. I need to get to my computer, first. Then I'll take a look at what's happening.
CBers 7554 Posted December 3, 2017 Posted December 3, 2017 I have problems with the Android TV app playing DTS-HD MA, but it plays DTS just fine. Also Atmos (TrueHD) plays fine. Just saying.
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 Here's how to set up mpv logging Play once, and attach the log, and I'll take a look. Out of curiosity, in windows, what is your default audio device?
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 Hi Doofus Here ist the log file: [ 0.034][v][cplayer] mpv 0.27.0 © 2000-2017 mpv/MPlayer/mplayer2 projects [ 0.034][v][cplayer] built on Wed Sep 13 04:18:08 CEST 2017 [ 0.034][v][cplayer] ffmpeg library versions: [ 0.034][v][cplayer] libavutil 55.74.100 [ 0.034][v][cplayer] libavcodec 57.105.100 [ 0.034][v][cplayer] libavformat 57.82.100 [ 0.034][v][cplayer] libswscale 4.7.103 [ 0.034][v][cplayer] libavfilter 6.105.100 [ 0.034][v][cplayer] libswresample 2.8.100 [ 0.034][v][cplayer] ffmpeg version: N-87286-g6ce4a635ed [ 0.034][v][cplayer] [ 0.034][v][cplayer] Configuration: /home/lachs0r/mingw-w64-cmake/buildroot/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-encoding --enable-egl-angle-lib --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --prefix=/home/lachs0r/mingw-w64-cmake/buildroot/build64/prefix/mingw [ 0.034][v][cplayer] List of enabled features: asm atomics avutil-content-light-level avutil-icc-profile avutil-imgcpy-uc avutil-spherical build-date cplayer cuda-hwaccel d3d-hwaccel d3d-hwaccel-new d3d9-hwaccel debug-build direct3d dos-paths dvdnav dvdread dvdread-common egl-angle egl-angle-lib egl-angle-win32 egl-helpers encoding gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc iconv is_ffmpeg javascript jpeg lcms2 libarchive libass libass-osd libav libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack optimize plain-gl posix-or-mingw rubberband static-build stdatomic uchardet wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.035][v][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.036][v][ytdl_hook] loading mp.defaults [ 0.036][v][ytdl_hook] loading @ytdl_hook.lua [ 0.037][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.037][v][cplayer] Run command: hook-add, flags=0, args=[on_load, 1, 10] [ 0.037][v][cplayer] Run command: hook-add, flags=0, args=[on_preloaded, 2, 10] [ 0.037][v][cplayer] Done loading @ytdl_hook.lua. [ 0.037][v][ipc] Starting IPC master [ 0.038][v][refreshrate] Loading lua script C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua... [ 0.038][v][ipc] Listening to IPC pipe. [ 0.039][v][ipc_0] Client connected [ 0.039][v][refreshrate] loading mp.defaults [ 0.039][v][refreshrate] loading file C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua [ 0.040][v][cplayer] Done loading C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua. [ 0.041][v][cplayer] Set property: volume=100 -> 1 [ 0.041][v][cplayer] Run command: loadfile, flags=0, args=[\\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv, replace, ] [ 0.042][cplayer] Playing: \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.042][v][cplayer] Running hook: ytdl_hook/on_load [ 0.042][v][cplayer] Run command: hook-ack, flags=0, args=[on_load] [ 0.042][v][ifo] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.042][v][ifo_dvdnav] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.044][v][bdmv/bluray] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.044][v][file] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.069][v][file] Stream opened successfully. [ 0.070][v][cache] Cache size set to 150000 KiB (75000 KiB backbuffer) [ 0.070][v][demux] Trying demuxers for level=normal. [ 0.071][v][mkv] Found the head... [ 0.071][v][mkv] + a segment... [ 0.071][v][mkv] Parsing seek head... [ 0.071][v][mkv] |+ segment information... [ 0.071][v][mkv] | + muxing app: libmakemkv v1.10.2 (1.3.3/1.4.4) win(x64-release) [ 0.071][v][mkv] | + writing app: MakeMKV v1.10.2 win(x64-release) [ 0.071][v][mkv] | + timecode scale: 1000000 [ 0.071][v][mkv] | + duration: 59.934s [ 0.071][v][mkv] | + segment uid e1 15 8f 28 39 c9 23 2a 7d 34 e2 c5 6c 65 f3 f1 [ 0.071][v][mkv] |+ segment tracks... [ 0.071][v][mkv] | + a track... [ 0.071][v][mkv] | + Track number: 1 [ 0.072][v][mkv] | + Track type: Video [ 0.072][v][mkv] | + Video track [ 0.072][v][mkv] | + Display width: 1920 [ 0.072][v][mkv] | + Display height: 1080 [ 0.072][v][mkv] | + Pixel width: 1920 [ 0.072][v][mkv] | + Pixel height: 1080 [ 0.072][v][mkv] | + Codec ID: V_MPEG4/ISO/AVC [ 0.072][v][mkv] | + CodecPrivate, length 73 [ 0.072][v][mkv] | + Default flag: 0 [ 0.072][v][mkv] | + Default duration: 41.708ms ( = 23.976 fps) [ 0.072][v][mkv] | + a track... [ 0.072][v][mkv] | + Track number: 2 [ 0.072][v][mkv] | + Name: Surround 7.1 [ 0.072][v][mkv] | + Track type: Audio [ 0.072][v][mkv] | + Audio track [ 0.072][v][mkv] | + Sampling frequency: 48000.000000 [ 0.072][v][mkv] | + Bit depth: 24 [ 0.072][v][mkv] | + Channels: 8 [ 0.072][v][mkv] | + Codec ID: A_DTS [ 0.072][v][mkv] | + Language: eng [ 0.072][v][mkv] | + Default flag: 1 [ 0.072][v][mkv] | + Default duration: 10.667ms ( = 93.750 fps) [ 0.072][v][mkv] | + a track... [ 0.072][v][mkv] | + Track number: 3 [ 0.072][v][mkv] | + Name: Surround 5.1 [ 0.072][v][mkv] | + Track type: Audio [ 0.072][v][mkv] | + Audio track [ 0.072][v][mkv] | + Sampling frequency: 48000.000000 [ 0.072][v][mkv] | + Channels: 6 [ 0.072][v][mkv] | + Codec ID: A_DTS [ 0.072][v][mkv] | + Language: eng [ 0.072][v][mkv] | + Default flag: 0 [ 0.072][v][mkv] | + Default duration: 10.667ms ( = 93.750 fps) [ 0.072][v][mkv] |+ found cluster [ 0.072][v][mkv] Seeking to 250029342 to read header element 0x1c53bb6b. [ 0.072][v][cache] Dropping cache at pos 250029342, cached range: 0-393216. [ 0.072][v][cache] Seeking underlying stream: 393216 -> 250029342 [ 0.075][v][mkv] Parsing cues... [ 0.075][v][mkv] Seeking to 250030354 to read header element 0x1254c367. [ 0.075][v][cache] EOF reached. [ 0.075][v][cache] Dropping cache at pos 2741, cached range: 250029342-250031580. [ 0.075][v][cache] Seeking underlying stream: 250031580 -> 2741 [ 0.075][v][mkv] All headers are parsed! [ 0.075][v][demux] Detected file format: Matroska [ 0.075][v][cache] blocking for STREAM_CTRL 6 [ 0.075][v][cplayer] Opening done: \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.077][v][find_files] Loading external files in \\heimserver\Filme\Videoclips\Dolby Digital Trailer\ [ 0.087][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.087][v][cplayer] Run command: hook-ack, flags=0, args=[on_preloaded] [ 0.087][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.087][cplayer] (+) Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.087][cplayer] Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.087][display-tags] File tags: [ 0.087][display-tags] Title: DTS [ 0.088][v][vo/opengl] Initializing OpenGL backend 'angle' [ 0.093][v][vo/opengl] Using Direct3D 11 feature level 10_1 [ 0.093][v][vo/opengl] Device: Intel® HD Graphics [ 0.093][v][vo/opengl] VendorId: 0x32902 [ 0.093][v][vo/opengl] DeviceId: 0x0258 [ 0.093][v][vo/opengl] LUID: 0000000000008567 [ 0.096][v][vo/opengl] EGL_VERSION=1.4 (ANGLE 2.1.0.) [ 0.096][v][vo/opengl] EGL_VENDOR=Google Inc. (adapter LUID: 0000000000008567) [ 0.096][v][vo/opengl] EGL_CLIENT_APIS=OpenGL_ES [ 0.096][v][vo/opengl] Trying to create GLES 3.x context. [ 0.099][v][vo/opengl/win32] resize window: 1920:1080 [ 0.099][v][vo/opengl/win32] DPI detected from the new API: 96 [ 0.099][v][vo/opengl/win32] display-fps: 24.000000 [ 0.101][v][vo/opengl/win32] color-profile: C:\WINDOWS\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.118][v][vo/opengl/win32] DPI detected from the new API: 96 [ 0.131][v][vo/opengl] Using DXGI 1.2+ [ 0.131][v][vo/opengl] Using flip-model presentation [ 0.131][v][vo/opengl] GL_VERSION='OpenGL ES 3.0 (ANGLE 2.1.0.)' [ 0.131][v][vo/opengl] Detected GLES 3.0. [ 0.131][v][vo/opengl] GL_VENDOR='Google Inc.' [ 0.131][v][vo/opengl] GL_RENDERER='ANGLE (Intel® HD Graphics Direct3D11 vs_4_1 ps_4_1)' [ 0.131][v][vo/opengl] GL_SHADING_LANGUAGE_VERSION='OpenGL ES GLSL ES 3.00 (ANGLE 2.1.0.)' [ 0.131][v][vo/opengl] Loaded extension GL_EXT_texture_norm16. [ 0.131][v][vo/opengl] Loaded extension GL_EXT_color_buffer_half_float. [ 0.131][v][vo/opengl] Loaded extension GL_EXT_disjoint_timer_query. [ 0.131][v][vo/opengl] Loaded extension GL_ANGLE_translated_shader_source. [ 0.132][v][vo/opengl] Testing FBO format rgba16 [ 0.132][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.132][v][vo/opengl] Using FBO format rgba16. [ 0.132][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.132][v][vo/opengl] Reported display depth: 10 [ 0.133][v][vo/opengl] Resize: 1920x1080 [ 0.133][v][vo/opengl] Assuming 24.000000 FPS for display sync. [ 0.133][v][vd] Container reported FPS: 23.976025 [ 0.134][v][vd] Codec list: [ 0.134][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.134][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.134][v][vd] Opening video decoder h264 [ 0.134][v][vd] Using software decoding. [ 0.134][v][vd] Detected 4 logical cores. [ 0.134][v][vd] Requesting 5 threads for decoding. [ 0.135][v][vd] Selected video codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.135][v][ad] Codec list: [ 0.135][v][ad] spdif_dts (dts) - libavformat/spdifenc audio pass-through decoder [ 0.135][v][ad] dca (dts) - DCA (DTS Coherent Acoustics) [ 0.135][v][ad] Opening audio decoder spdif_dts [ 0.135][v][ad] Selected audio codec: spdif_dts (libavformat/spdifenc audio pass-through decoder) [ 0.135][v][cplayer] Starting playback... [ 0.136][v][ad] In: profile=60 samplerate=48000 [ 0.136][v][af] Audio filter chain: [ 0.136][v][af] [in] 48000Hz stereo 2ch spdif-dts [ 0.136][v][af] [out] 48000Hz stereo 2ch spdif-dts [ 0.136][v][af] [ao] 48000Hz stereo 2ch spdif-dts [ 0.136][v][ao] Trying audio driver 'wasapi' [ 0.136][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-dts [ 0.140][v][ao/wasapi] No device specified. Selecting default. [ 0.141][v][ao/wasapi] Selecting device '{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9}' (SONY TV XV (Intel® Display-Audio)) [ 0.141][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9} [ 0.156][v][ao/wasapi] Trying stereo spdif-dts (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.156][v][ao/wasapi] Retrying as AC3. [ 0.157][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> ok [ 0.157][v][ao/wasapi] Accepted as stereo spdif-dts @ 48000hz -> stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) [ 0.157][v][ao/wasapi] Device period: 10 ms [ 0.178][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 0.178][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 0.181][v][ao/wasapi] device buffer: 480 samples. [ 0.181][v][ao/wasapi] using soft-buffer of 9728 samples. [ 0.181][cplayer] AO: [wasapi] 48000Hz stereo 2ch spdif-dts [ 0.181][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.182][v][ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: yuv420p [ 0.233][v][vd] Decoder format: 1920x1080 yuv420p auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.233][v][vd] Using container aspect ratio. [ 0.234][v][vf] Video filter chain: [ 0.234][v][vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.234][v][vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.235][cplayer] VO: [opengl] 1920x1080 yuv420p [ 0.235][v][cplayer] VO: Description: Extended OpenGL Renderer [ 0.235][v][vo/opengl] Resize: 1920x1080 [ 0.235][v][vo/opengl] Window size: 1920x1080 [ 0.235][v][vo/opengl] Video source: 1920x1080 (1:1) [ 0.235][v][vo/opengl] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080 [ 0.235][v][vo/opengl] Video scale: 1.000000/1.000000 [ 0.235][v][vo/opengl] OSD borders: l=0 t=0 r=0 b=0 [ 0.235][v][vo/opengl] Video borders: l=0 t=0 r=0 b=0 [ 0.235][v][vo/opengl] Testing FBO format rgba16 [ 0.235][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.236][v][vo/opengl] Using FBO format rgba16. [ 0.236][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.236][v][vo/opengl] Texture for plane 0: 1920x1080 [ 0.236][v][vo/opengl] Texture for plane 1: 960x540 [ 0.236][v][vo/opengl] Texture for plane 2: 960x540 [ 0.245][v][vo/opengl] new shader program: [ 0.245][v][vo/opengl] [ 1] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.245][v][vo/opengl] [ 2] color.g = 1.000000 * vec4(texture(texture1, texcoord1)).r; [ 0.245][v][vo/opengl] [ 3] color.b = 1.000000 * vec4(texture(texture2, texcoord2)).r; [ 0.245][v][vo/opengl] [ 4] color = color.rgbr; [ 0.245][v][vo/opengl] [ 5] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.245][v][vo/opengl] [ 6] color.a = 1.0; [ 0.245][v][vo/opengl] [ 7] // color mapping [ 0.264][v][vo/opengl] shader link log (status=1): [ 0.264][v][vo/opengl] [ 0.264][v][vo/opengl] [ 0.264][v][vo/opengl] [ 0.268][v][cplayer] first video frame after restart shown [ 0.268][v][cplayer] starting audio playback [ 0.268][v][cplayer] playback restart complete [ 0.273][v][ad] Uninit audio decoder. [ 0.304][v][ad] Codec list: [ 0.304][v][ad] spdif_dts (dts) - libavformat/spdifenc audio pass-through decoder [ 0.304][v][ad] dca (dts) - DCA (DTS Coherent Acoustics) [ 0.304][v][ad] Opening audio decoder spdif_dts [ 0.304][v][ad] Selected audio codec: spdif_dts (libavformat/spdifenc audio pass-through decoder) [ 0.304][cplayer] Track switched: [ 0.304][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.304][cplayer] Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.304][cplayer] (+) Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.304][v][cplayer] Set property: aid=2 -> 1 [ 0.304][cplayer] Track switched: [ 0.304][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.304][cplayer] Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.304][cplayer] (+) Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.304][v][cplayer] Set property: sid="no" -> 1 [ 0.305][v][mkv] refresh seek to -0.958000 [ 0.320][v][ad] In: profile=20 samplerate=48000 [ 0.320][v][af] Audio filter chain: [ 0.320][v][af] [in] 48000Hz stereo 2ch spdif-dts [ 0.320][v][af] [out] 48000Hz stereo 2ch spdif-dts [ 0.321][v][af] [ao] 48000Hz stereo 2ch spdif-dts [ 0.321][v][ao] Trying audio driver 'wasapi' [ 0.321][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-dts [ 0.321][v][ao/wasapi] No device specified. Selecting default. [ 0.322][v][ao/wasapi] Selecting device '{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9}' (SONY TV XV (Intel® Display-Audio)) [ 0.322][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9} [ 0.331][v][ao/wasapi] Trying stereo spdif-dts (16/16 bits) @ 48000hz (exclusive) -> unsupported [ 0.331][v][ao/wasapi] Retrying as AC3. [ 0.332][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> ok [ 0.332][v][ao/wasapi] Accepted as stereo spdif-dts @ 48000hz -> stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) [ 0.333][v][ao/wasapi] Device period: 10 ms [ 0.351][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 0.351][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 0.351][v][ao/wasapi] device buffer: 480 samples. [ 0.351][v][ao/wasapi] using soft-buffer of 9728 samples. [ 0.351][cplayer] AO: [wasapi] 48000Hz stereo 2ch spdif-dts [ 0.352][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.359][v][cplayer] starting audio playback [ 32.948][v][cache] EOF reached. [ 49.687][v][mkv] EOF reached. [ 59.976][v][cplayer] audio EOF reached [ 60.091][v][cplayer] video EOF reached [ 60.091][v][cplayer] EOF code: 1 [ 60.091][v][ad] Uninit audio decoder. [ 60.092][v][vd] Uninit video. [ 60.094][v][cache] Terminating cache... [ 60.094][v][cache] Cache exiting... [ 60.116][v][cplayer] finished playback, success (reason 0) [ 60.116][cplayer] [ 60.178][v][vo/opengl] flushing shader cache [ 60.181][v][vo/opengl/win32] uninit [ 60.327][v][cplayer] Run command: stop, flags=0, args=[] [ 60.327][v][cplayer] Run command: quit, flags=0, args=[0] [ 60.327][cplayer] [ 60.327][cplayer] Exiting... (Quit) [ 60.327][v][ipc_0] Exiting... [ 60.328][v][ytdl_hook] Exiting... [ 60.328][v][refreshrate] Exiting...
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 as my avr receiver is an older model without hdmi ports, the connection is as follows: windows 10 pc and fire tv stick are both connected to the TV via hdmi to hdmi port 1 and hdmi port 2 the tv has an optical audio output which is connected to the receiver. via fire tv stick emby plays the audio of the dts-hd file via windows pc it does not work but i cannont stick to the fire tv stick (1st generation) because the wlan connection is quite unstable
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 windows 10 pc and fire tv stick are both connected to the TV via hdmi to hdmi port 1 and hdmi port 2 the tv has an optical audio output which is connected to the receiver. Optical doesn't support anything above core audio (5.1). It looks like you have both 5.1 and 7.1 tracks. Try selecting the 5.1 [ 0.087][i][cplayer] (+) Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.087][i][cplayer] Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz)
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 (edited) I tested the video file again. To my surprise with different results than before: via fire tv stick. --> audio track 5.1: plays in 5.1 --> audio track 7.1: plays in 5.1 via emby theater (windows pc): 1. dts checked, dts-hd checked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo 2. dts checked, dts-hd unchecked: --> audio track 5.1: no sound --> audio track 7.1: no sound 3. dts unchecked, dts-hd checked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo 4. dts unchecked, dts-hd unckecked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo I don't understand, why there is sound now. But I also do not understand why fire tv stick gives me a 5.1 output for both audio tracks, whereas emby theater only gives me stereo. Edited December 3, 2017 by ohhofer
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 I tested the video file again. To my surprise with different results than before: via fire tv stick. --> audio track 5.1: plays in 5.1 --> audio track 7.1: plays in 5.1 via emby theater (windows pc): 1. dts checked, dts-hd checked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo 2. dts checked, dts-hd unchecked: --> audio track 5.1: no sound --> audio track 7.1: no sound 3. dts unchecked, dts-hd checked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo 4. dts unchecked, dts-hd unckecked: --> audio track 5.1: plays in stereo --> audio track 7.1: plays in stereo I don't understand, why there is sound now. But I also do not understand why fire tv stick gives me a 5.1 output for both audio tracks, whereas emby theater only gives me stereo. How are you determining that it's in stereo?
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 I assumed it must be stereo, because... ... when playing via fire tv stick, the display of the receiver says "dolby digital" and the two rear speakers are approached seperately ... when playing via emby theater the display of the receiver says "dolby pro logic II" and the two rear speakers are not approached seperately. Am I wrong?
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 A quick way to see what's happening is to look at the stats for nerds in Theater while playing the movie. You can press ctrl+j or click on the cog in the overlay and select stats for nerds. Keep in mind that when bitstreaming, it will say stereo for the output, but will tell you the codec if it's bitstreaming. Given that your AVR is switching to pro logic, does suggest that mpv is converting to PCM, possibly because you're using optical. In either case, when you play with sound, I'd like to see the log from that.
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 (edited) And as for the DTS settings, this would apply. It would appear that mpv is seeing the DTS-HD and wants to use it, choosing the DTS second. Which would account for no sound with DTS-HD unchecked. Your AVR then doesn't support it, so mpv is converting to PCM, and your AVR is then applying the Pro Logic processor. here is the log: That's the stats, can you attach the log? Edited December 3, 2017 by Doofus
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 Before playing the movie, have you tried selecting the alternate track?
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 both (dts and dtshd) were checked. here is the log: [ 0.012][v][cplayer] mpv 0.27.0 © 2000-2017 mpv/MPlayer/mplayer2 projects [ 0.012][v][cplayer] built on Wed Sep 13 04:18:08 CEST 2017 [ 0.012][v][cplayer] ffmpeg library versions: [ 0.012][v][cplayer] libavutil 55.74.100 [ 0.012][v][cplayer] libavcodec 57.105.100 [ 0.012][v][cplayer] libavformat 57.82.100 [ 0.012][v][cplayer] libswscale 4.7.103 [ 0.012][v][cplayer] libavfilter 6.105.100 [ 0.012][v][cplayer] libswresample 2.8.100 [ 0.012][v][cplayer] ffmpeg version: N-87286-g6ce4a635ed [ 0.012][v][cplayer] [ 0.012][v][cplayer] Configuration: /home/lachs0r/mingw-w64-cmake/buildroot/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-encoding --enable-egl-angle-lib --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --prefix=/home/lachs0r/mingw-w64-cmake/buildroot/build64/prefix/mingw [ 0.012][v][cplayer] List of enabled features: asm atomics avutil-content-light-level avutil-icc-profile avutil-imgcpy-uc avutil-spherical build-date cplayer cuda-hwaccel d3d-hwaccel d3d-hwaccel-new d3d9-hwaccel debug-build direct3d dos-paths dvdnav dvdread dvdread-common egl-angle egl-angle-lib egl-angle-win32 egl-helpers encoding gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc iconv is_ffmpeg javascript jpeg lcms2 libarchive libass libass-osd libav libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack optimize plain-gl posix-or-mingw rubberband static-build stdatomic uchardet wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.012][v][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.013][v][ytdl_hook] loading mp.defaults [ 0.014][v][ytdl_hook] loading @ytdl_hook.lua [ 0.015][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.015][v][cplayer] Run command: hook-add, flags=0, args=[on_load, 1, 10] [ 0.015][v][cplayer] Run command: hook-add, flags=0, args=[on_preloaded, 2, 10] [ 0.015][v][cplayer] Done loading @ytdl_hook.lua. [ 0.015][v][ipc] Starting IPC master [ 0.016][v][refreshrate] Loading lua script C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua... [ 0.016][v][ipc] Listening to IPC pipe. [ 0.016][v][ipc_0] Client connected [ 0.016][v][refreshrate] loading mp.defaults [ 0.017][v][refreshrate] loading file C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua [ 0.017][v][cplayer] Set property: volume=100 -> 1 [ 0.017][v][cplayer] Run command: loadfile, flags=0, args=[\\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv, replace, ] [ 0.018][v][cplayer] Done loading C:/Users/htpch/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/refreshrate.lua. [ 0.018][cplayer] Playing: \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.018][v][cplayer] Running hook: ytdl_hook/on_load [ 0.018][v][cplayer] Run command: hook-ack, flags=0, args=[on_load] [ 0.019][v][ifo] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.019][v][ifo_dvdnav] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.020][v][bdmv/bluray] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.020][v][file] Opening \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.021][v][file] Stream opened successfully. [ 0.022][v][cache] Cache size set to 150000 KiB (75000 KiB backbuffer) [ 0.022][v][demux] Trying demuxers for level=normal. [ 0.023][v][mkv] Found the head... [ 0.023][v][mkv] + a segment... [ 0.023][v][mkv] Parsing seek head... [ 0.023][v][mkv] |+ segment information... [ 0.023][v][mkv] | + muxing app: libmakemkv v1.10.2 (1.3.3/1.4.4) win(x64-release) [ 0.023][v][mkv] | + writing app: MakeMKV v1.10.2 win(x64-release) [ 0.023][v][mkv] | + timecode scale: 1000000 [ 0.023][v][mkv] | + duration: 59.934s [ 0.023][v][mkv] | + segment uid e1 15 8f 28 39 c9 23 2a 7d 34 e2 c5 6c 65 f3 f1 [ 0.023][v][mkv] |+ segment tracks... [ 0.023][v][mkv] | + a track... [ 0.023][v][mkv] | + Track number: 1 [ 0.023][v][mkv] | + Track type: Video [ 0.023][v][mkv] | + Video track [ 0.023][v][mkv] | + Display width: 1920 [ 0.023][v][mkv] | + Display height: 1080 [ 0.023][v][mkv] | + Pixel width: 1920 [ 0.023][v][mkv] | + Pixel height: 1080 [ 0.023][v][mkv] | + Codec ID: V_MPEG4/ISO/AVC [ 0.023][v][mkv] | + CodecPrivate, length 73 [ 0.023][v][mkv] | + Default flag: 0 [ 0.023][v][mkv] | + Default duration: 41.708ms ( = 23.976 fps) [ 0.023][v][mkv] | + a track... [ 0.023][v][mkv] | + Track number: 2 [ 0.023][v][mkv] | + Name: Surround 7.1 [ 0.023][v][mkv] | + Track type: Audio [ 0.023][v][mkv] | + Audio track [ 0.023][v][mkv] | + Sampling frequency: 48000.000000 [ 0.023][v][mkv] | + Bit depth: 24 [ 0.023][v][mkv] | + Channels: 8 [ 0.023][v][mkv] | + Codec ID: A_DTS [ 0.024][v][mkv] | + Language: eng [ 0.024][v][mkv] | + Default flag: 1 [ 0.024][v][mkv] | + Default duration: 10.667ms ( = 93.750 fps) [ 0.024][v][mkv] | + a track... [ 0.024][v][mkv] | + Track number: 3 [ 0.024][v][mkv] | + Name: Surround 5.1 [ 0.024][v][mkv] | + Track type: Audio [ 0.024][v][mkv] | + Audio track [ 0.024][v][mkv] | + Sampling frequency: 48000.000000 [ 0.024][v][mkv] | + Channels: 6 [ 0.024][v][mkv] | + Codec ID: A_DTS [ 0.024][v][mkv] | + Language: eng [ 0.024][v][mkv] | + Default flag: 0 [ 0.024][v][mkv] | + Default duration: 10.667ms ( = 93.750 fps) [ 0.024][v][mkv] |+ found cluster [ 0.024][v][mkv] Seeking to 250029342 to read header element 0x1c53bb6b. [ 0.024][v][cache] Dropping cache at pos 250029342, cached range: 0-2162688. [ 0.024][v][cache] Seeking underlying stream: 2162688 -> 250029342 [ 0.024][v][mkv] Parsing cues... [ 0.024][v][mkv] Seeking to 250030354 to read header element 0x1254c367. [ 0.024][v][cache] EOF reached. [ 0.024][v][cache] Dropping cache at pos 2741, cached range: 250029342-250031580. [ 0.024][v][cache] Seeking underlying stream: 250031580 -> 2741 [ 0.024][v][mkv] All headers are parsed! [ 0.024][v][demux] Detected file format: Matroska [ 0.024][v][cache] blocking for STREAM_CTRL 6 [ 0.024][v][cplayer] Opening done: \\heimserver\Filme\Videoclips\Dolby Digital Trailer\DTS_HD_OUT_OF_THE_BOX_60-thedigitaltheater.mkv [ 0.030][v][find_files] Loading external files in \\heimserver\Filme\Videoclips\Dolby Digital Trailer\ [ 0.036][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.036][v][cplayer] Run command: hook-ack, flags=0, args=[on_preloaded] [ 0.036][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.036][cplayer] (+) Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.036][cplayer] Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.036][display-tags] File tags: [ 0.036][display-tags] Title: DTS [ 0.038][v][vo/opengl] Initializing OpenGL backend 'angle' [ 0.050][v][vo/opengl] Using Direct3D 11 feature level 10_1 [ 0.050][v][vo/opengl] Device: Intel® HD Graphics [ 0.050][v][vo/opengl] VendorId: 0x32902 [ 0.050][v][vo/opengl] DeviceId: 0x0258 [ 0.050][v][vo/opengl] LUID: 00000000000085c2 [ 0.055][v][vo/opengl] EGL_VERSION=1.4 (ANGLE 2.1.0.) [ 0.055][v][vo/opengl] EGL_VENDOR=Google Inc. (adapter LUID: 00000000000085c2) [ 0.055][v][vo/opengl] EGL_CLIENT_APIS=OpenGL_ES [ 0.055][v][vo/opengl] Trying to create GLES 3.x context. [ 0.061][v][vo/opengl/win32] resize window: 1920:1080 [ 0.061][v][vo/opengl/win32] DPI detected from the new API: 96 [ 0.061][v][vo/opengl/win32] display-fps: 24.000000 [ 0.065][v][vo/opengl/win32] color-profile: C:\WINDOWS\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.088][v][vo/opengl/win32] DPI detected from the new API: 96 [ 0.104][v][vo/opengl] Using DXGI 1.2+ [ 0.104][v][vo/opengl] Using flip-model presentation [ 0.104][v][vo/opengl] GL_VERSION='OpenGL ES 3.0 (ANGLE 2.1.0.)' [ 0.104][v][vo/opengl] Detected GLES 3.0. [ 0.104][v][vo/opengl] GL_VENDOR='Google Inc.' [ 0.104][v][vo/opengl] GL_RENDERER='ANGLE (Intel® HD Graphics Direct3D11 vs_4_1 ps_4_1)' [ 0.104][v][vo/opengl] GL_SHADING_LANGUAGE_VERSION='OpenGL ES GLSL ES 3.00 (ANGLE 2.1.0.)' [ 0.104][v][vo/opengl] Loaded extension GL_EXT_texture_norm16. [ 0.104][v][vo/opengl] Loaded extension GL_EXT_color_buffer_half_float. [ 0.104][v][vo/opengl] Loaded extension GL_EXT_disjoint_timer_query. [ 0.105][v][vo/opengl] Loaded extension GL_ANGLE_translated_shader_source. [ 0.105][v][vo/opengl] Testing FBO format rgba16 [ 0.105][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.106][v][vo/opengl] Using FBO format rgba16. [ 0.106][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.106][v][vo/opengl] Reported display depth: 10 [ 0.107][v][vo/opengl] Resize: 1920x1080 [ 0.107][v][vo/opengl] Assuming 24.000000 FPS for display sync. [ 0.107][v][vd] Container reported FPS: 23.976025 [ 0.108][v][vd] Codec list: [ 0.108][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.108][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.109][v][vd] Opening video decoder h264 [ 0.109][v][vd] Using software decoding. [ 0.109][v][vd] Detected 4 logical cores. [ 0.109][v][vd] Requesting 5 threads for decoding. [ 0.111][v][vd] Selected video codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.113][v][ad] Codec list: [ 0.113][v][ad] spdif_dts_hd (dts) - libavformat/spdifenc audio pass-through decoder [ 0.113][v][ad] dca (dts) - DCA (DTS Coherent Acoustics) [ 0.113][v][ad] Opening audio decoder spdif_dts_hd [ 0.113][v][ad] Selected audio codec: spdif_dts_hd (libavformat/spdifenc audio pass-through decoder) [ 0.113][v][cplayer] Starting playback... [ 0.114][v][ad] In: profile=60 samplerate=48000 [ 0.115][v][af] Audio filter chain: [ 0.115][v][af] [in] 192000Hz 7.1 8ch spdif-dtshd [ 0.115][v][af] [out] 192000Hz 7.1 8ch spdif-dtshd [ 0.115][v][af] [ao] 192000Hz 7.1 8ch spdif-dtshd [ 0.115][v][ao] Trying audio driver 'wasapi' [ 0.115][v][ao/wasapi] requested format: 192000 Hz, 7.1 channels, spdif-dtshd [ 0.126][v][ao/wasapi] No device specified. Selecting default. [ 0.128][v][ao/wasapi] Selecting device '{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9}' (SONY TV XV (Intel® Display-Audio)) [ 0.128][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9} [ 0.143][v][ao/wasapi] Trying 7.1 spdif-dtshd (16/16 bits) @ 192000hz (exclusive) -> unsupported [ 0.143][v][ao/wasapi] Retrying as AC3. [ 0.143][v][ao/wasapi] Trying 7.1 spdif-ac3 (16/16 bits) @ 192000hz (exclusive) -> unsupported [ 0.144][f][ao/wasapi] Received failure from audio thread [ 0.144][e][ao] Failed to initialize audio driver 'wasapi' [ 0.144][v][cplayer] Falling back to PCM output. [ 0.144][v][ad] Uninit audio decoder. [ 0.144][v][ad] Codec list: [ 0.144][v][ad] dca (dts) - DCA (DTS Coherent Acoustics) [ 0.144][v][ad] Opening audio decoder dca [ 0.144][v][ad] Requesting 1 threads for decoding. [ 0.145][v][ad] Selected audio codec: dca (DCA (DTS Coherent Acoustics)) [ 0.145][v][ffmpeg/audio] dca: Forcing XLL recovery mode [ 0.145][v][af] Audio filter chain: [ 0.146][v][af] [in] 48000Hz 7.1 8ch s32p [ 0.146][v][af] [out] 48000Hz 7.1 8ch s32p [ 0.146][v][af] [ao] 48000Hz 7.1 8ch s32p [ 0.146][v][ao] Trying audio driver 'wasapi' [ 0.146][v][ao/wasapi] requested format: 48000 Hz, 5.1 channels, s32p [ 0.146][v][ao/wasapi] No device specified. Selecting default. [ 0.147][v][ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: yuv420p [ 0.147][v][ao/wasapi] Selecting device '{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9}' (SONY TV XV (Intel® Display-Audio)) [ 0.147][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{1e8b4d3f-e46f-4e5c-9289-760a668bdfb9} [ 0.157][v][ao/wasapi] Trying 5.1 s32 (32/32 bits) @ 48000hz (shared) -> ok [ 0.157][v][ao/wasapi] Closest match is stereo float (32/32 bits) @ 48000hz [ 0.157][v][ao/wasapi] Accepted as stereo float @ 48000hz -> stereo float (32/32 bits) @ 48000hz (shared) [ 0.157][v][ao/wasapi] Device period: 10 ms [ 0.162][v][ao/wasapi] Buffer frame count: 2400 (50 ms) [ 0.162][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 384000. [ 0.165][v][ao/wasapi] device buffer: 2400 samples. [ 0.165][v][ao/wasapi] using soft-buffer of 9600 samples. [ 0.165][cplayer] AO: [wasapi] 48000Hz stereo 2ch float [ 0.165][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.165][v][af] Adding filter lavrresample [ 0.166][v][lavrresample] Remix: 7.1 -> stereo [ 0.166][v][af] Audio filter chain: [ 0.166][v][af] [in] 48000Hz 7.1 8ch s32p [ 0.166][v][af] [lavrresample] 48000Hz stereo 2ch float [a] [ 0.166][v][af] [out] 48000Hz stereo 2ch float [ 0.166][v][af] [ao] 48000Hz stereo 2ch float [ 0.203][v][vd] Decoder format: 1920x1080 yuv420p auto/auto/auto/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.203][v][vd] Using container aspect ratio. [ 0.204][v][vf] Video filter chain: [ 0.204][v][vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.204][v][vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.204][cplayer] VO: [opengl] 1920x1080 yuv420p [ 0.204][v][cplayer] VO: Description: Extended OpenGL Renderer [ 0.204][v][vo/opengl] Resize: 1920x1080 [ 0.204][v][vo/opengl] Window size: 1920x1080 [ 0.204][v][vo/opengl] Video source: 1920x1080 (1:1) [ 0.204][v][vo/opengl] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080 [ 0.204][v][vo/opengl] Video scale: 1.000000/1.000000 [ 0.204][v][vo/opengl] OSD borders: l=0 t=0 r=0 b=0 [ 0.204][v][vo/opengl] Video borders: l=0 t=0 r=0 b=0 [ 0.204][v][vo/opengl] Testing FBO format rgba16 [ 0.204][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.206][v][vo/opengl] Using FBO format rgba16. [ 0.206][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.206][v][vo/opengl] Texture for plane 0: 1920x1080 [ 0.206][v][vo/opengl] Texture for plane 1: 960x540 [ 0.206][v][vo/opengl] Texture for plane 2: 960x540 [ 0.215][v][vo/opengl] new shader program: [ 0.215][v][vo/opengl] [ 1] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.215][v][vo/opengl] [ 2] color.g = 1.000000 * vec4(texture(texture1, texcoord1)).r; [ 0.215][v][vo/opengl] [ 3] color.b = 1.000000 * vec4(texture(texture2, texcoord2)).r; [ 0.215][v][vo/opengl] [ 4] color = color.rgbr; [ 0.215][v][vo/opengl] [ 5] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.215][v][vo/opengl] [ 6] color.a = 1.0; [ 0.215][v][vo/opengl] [ 7] // color mapping [ 0.229][v][vo/opengl] shader link log (status=1): [ 0.229][v][vo/opengl] [ 0.229][v][vo/opengl] [ 0.229][v][vo/opengl] [ 0.233][v][cplayer] first video frame after restart shown [ 0.233][v][cplayer] starting audio playback [ 0.233][v][cplayer] playback restart complete [ 0.239][cplayer] Track switched: [ 0.239][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.239][cplayer] (+) Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.239][cplayer] Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.239][v][cplayer] Set property: aid=1 -> 1 [ 0.239][cplayer] Track switched: [ 0.239][cplayer] (+) Video --vid=1 (h264 1920x1080 23.976fps) [ 0.239][cplayer] (+) Audio --aid=1 --alang=eng (*) 'Surround 7.1' (dts 8ch 48000Hz) [ 0.239][cplayer] Audio --aid=2 --alang=eng 'Surround 5.1' (dts 6ch 48000Hz) [ 0.240][v][cplayer] Set property: sid="no" -> 1 [ 32.949][v][cache] EOF reached. [ 49.673][v][mkv] EOF reached. [ 59.933][v][cplayer] audio EOF reached [ 60.098][v][cplayer] video EOF reached [ 60.099][v][cplayer] EOF code: 1 [ 60.099][v][ad] Uninit audio decoder. [ 60.099][v][af] Removing filter lavrresample [ 60.099][v][vd] Uninit video. [ 60.103][v][cache] Terminating cache... [ 60.103][v][cache] Cache exiting... [ 60.127][v][cplayer] finished playback, success (reason 0) [ 60.128][cplayer] [ 60.145][v][vo/opengl] flushing shader cache [ 60.149][v][vo/opengl/win32] uninit [ 60.291][v][cplayer] Run command: stop, flags=0, args=[] [ 60.291][v][cplayer] Run command: quit, flags=0, args=[0] [ 60.291][cplayer] [ 60.291][cplayer] Exiting... (Quit) [ 60.292][v][ipc_0] Exiting... [ 60.292][v][ytdl_hook] Exiting... [ 60.292][v][refreshrate] Exiting...
ohhofer 2 Posted December 3, 2017 Author Posted December 3, 2017 yes before playing I selected the 5.1 track as shown in your screenshot
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 (edited) yes before playing I selected the 5.1 track as shown in your screenshot It isn't using the 5.1 track, and mpv is doing what I suspected. It's converting to PCM [ 0.143][v][ao/wasapi] Trying 7.1 spdif-dtshd (16/16 bits) @ 192000hz (exclusive) -> unsupported [ 0.143][v][ao/wasapi] Retrying as AC3. [ 0.143][v][ao/wasapi] Trying 7.1 spdif-ac3 (16/16 bits) @ 192000hz (exclusive) -> unsupported [ 0.144][f][ao/wasapi] Received failure from audio thread [ 0.144][e][ao] Failed to initialize audio driver 'wasapi' [ 0.144][v][cplayer] Falling back to PCM output. Ok, another way you can try switching the audio is in the overlay. Try switching during playback Edited December 3, 2017 by Doofus
Guest asrequested Posted December 3, 2017 Posted December 3, 2017 @@Luke, I just tested the audio selection before playback, it isn't working. You can only select audio using the overlay while playing.
