gardar 16 Posted November 29, 2017 Posted November 29, 2017 I'm having some problems with dpad login on 3.2.40. When I enter my password I get a "invalid user or password" error, tried changing the easy pin code but I keep getting the same error. I also noticed that other users that did not have a pin number set now have a lock icon next to them. Upgraded from 3.2.36 which did not have these issues, and I just rolled back to a snapshot I took before upgrading so I can confirm 3.2.36 does not have this issue. I wonder if this has something to do with this issue: https://emby.media/community/index.php?/topic/52492-security-issue-with-easy-pin-code-local-network-detection/ Since my emby server and android tv box are on different subnets.
Luke 42468 Posted November 29, 2017 Posted November 29, 2017 You're trying to log into the android tv app?
gardar 16 Posted November 30, 2017 Author Posted November 30, 2017 Yep forgot to mention that in the previous post, android tv app on a mibox.
ebr 16423 Posted November 30, 2017 Posted November 30, 2017 Is the issue really limited to just using the d-pad technique in that app?
gardar 16 Posted December 1, 2017 Author Posted December 1, 2017 Yes seems to be, or well I didn't try turning off d-pad in the app so I don't know if the users could log in with a pin or without a password with d-pad turned off. But the Android app and the web interface worked as previously.
ebr 16423 Posted December 3, 2017 Posted December 3, 2017 Can you please try turning off the d-pad option to see if the issue persists? Thanks.
gardar 16 Posted December 30, 2017 Author Posted December 30, 2017 Can you please try turning off the d-pad option to see if the issue persists? Thanks. Sorry for the late reply, I have confirmed that with the d-pad option the issue persists.
ebr 16423 Posted December 30, 2017 Posted December 30, 2017 Okay, so the issue is not related to that option. You are sure you are providing a valid pw?
gardar 16 Posted January 1, 2018 Author Posted January 1, 2018 I was wrong in a previous post where I stated that the web app and android phone app worked correctly, also this does not seem to be bound to the dpad login. I can not log with the easy pin code when on a different subnet on versions newer than 3.2.36, and the full password works. When connecting from the same subnet, the easy pin code still works.
Luke 42468 Posted January 1, 2018 Posted January 1, 2018 Ok so that explains it, it's not really an app-specific issue. can you please provide an emby server log from this attempt? thanks.
