Supersilver 4 Posted November 3, 2017 Posted November 3, 2017 (edited) So far I'm able to scrobble movies fine but I can't get it to scrobble any TV show and I don't know if it's just a problem with the trakt add-on or emby add-on or both so I'm hoping someone can help me with it. I'm using Kodi 17.5 and saulfreds Embuary skin. https://paste.ubuntu.com/25879590/ Sent from my ZTE A2017U using Tapatalk Edited November 3, 2017 by Supersilver
Angelblue05 4132 Posted November 3, 2017 Posted November 3, 2017 Post your log. Sent from my iPhone using Tapatalk
Supersilver 4 Posted November 3, 2017 Author Posted November 3, 2017 Okay sorry will do currently at work right now. Sent from my ZTE A2017U using Tapatalk 1
Angelblue05 4132 Posted November 3, 2017 Posted November 3, 2017 No problem, I'll help you once you are able to provide your log. https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/
Supersilver 4 Posted November 3, 2017 Author Posted November 3, 2017 (edited) Post your log. Sent from my iPhone using Tapatalk https://paste.ubuntu.com/25879480/ Forget about the first URL forgot to put on debug mode in trakt add-on https://paste.ubuntu.com/25879590/ Sent from my ZTE A2017U using Tapatalk Edited November 3, 2017 by Supersilver
Angelblue05 4132 Posted November 3, 2017 Posted November 3, 2017 Trakt seems to be throwing an error. But honestly you don't need the trakt add-on. The server trakt plugin should be enough for scrobbling. Sent from my iPhone using Tapatalk
Supersilver 4 Posted November 3, 2017 Author Posted November 3, 2017 Trakt seems to be throwing an error. But honestly you don't need the trakt add-on. The server trakt plugin should be enough for scrobbling. Sent from my iPhone using Tapatalk Yea but I kinda want to use the trakt add-on cause I like the way it works and that it asks for me to rate after I finish watching something, are you saying it can't be fixed? Sent from my ZTE A2017U using Tapatalk
Angelblue05 4132 Posted November 4, 2017 Posted November 4, 2017 Ok. Well the error is coming from Trakt. Not sure what it's complaining about, but for maximum compatibility with other Kodi add-ons you need to use native playback mode rather than add-on playback. You could try to make the switch, see if it makes a difference. Otherwise report to the trakt add-on dev. To make the switch, in the add-on settings > sync options > playback mode, then reset your local database. 13:23:54.064 T:139133400144 FATAL: [script.trakt] resources.lib.service: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'TypeError'> Error Contents: ("'NoneType' object has no attribute '__getitem__'",) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.trakt/resources/lib/service.py", line 42, in _dispatch self.scrobbler.playbackStarted(data) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.trakt/resources/lib/scrobbler.py", line 188, in playbackStarted result['episode']['episodeid'] = self.curVideo['id'] TypeError: 'NoneType' object has no attribute '__getitem__' -->End of Python script error report<--
Supersilver 4 Posted November 4, 2017 Author Posted November 4, 2017 Ok. Well the error is coming from Trakt. Not sure what it's complaining about, but for maximum compatibility with other Kodi add-ons you need to use native playback mode rather than add-on playback. You could try to make the switch, see if it makes a difference. Otherwise report to the trakt add-on dev. To make the switch, in the add-on settings > sync options > playback mode, then reset your local database. 13:23:54.064 T:139133400144 FATAL: [script.trakt] resources.lib.service: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'TypeError'> Error Contents: ("'NoneType' object has no attribute '__getitem__'",) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.trakt/resources/lib/service.py", line 42, in _dispatch self.scrobbler.playbackStarted(data) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.trakt/resources/lib/scrobbler.py", line 188, in playbackStarted result['episode']['episodeid'] = self.curVideo['id'] TypeError: 'NoneType' object has no attribute '__getitem__' -->End of Python script error report<-- Okay thank you very much for your help Angelblue05 Sent from my ZTE A2017U using Tapatalk 1
Supersilver 4 Posted November 5, 2017 Author Posted November 5, 2017 Hey Angelblue05 I contacted the trakt add-on dev and he said this: "Not sure which emby addon your using, but they seem to insert the data somehow. They just seem to not do it right or at all for episodes. So if it is indeed working for you with movies, they "just" need to do the similar for episodes. See: https://github.com/trakt/script.trakt/blob/master/resources/lib/scrobbler.py#L184-L188" Hopefully you can do something with this. Sent from my ZTE A2017U using Tapatalk
Luke 42241 Posted November 5, 2017 Posted November 5, 2017 To be honest this topic is a little confusing because are we talking about the kodi trakt add-on, or the emby server trakt plugin?
Supersilver 4 Posted November 5, 2017 Author Posted November 5, 2017 To be honest this topic is a little confusing because are we talking about the kodi trakt add-on, or the emby server trakt plugin?Sorry I thought I said, it's the Kodi trakt add-on not the server plugin. Sent from my ZTE A2017U using Tapatalk
Angelblue05 4132 Posted November 5, 2017 Posted November 5, 2017 Can you try with native playback mode? Let me know if the problem exists then. Thank you.
Supersilver 4 Posted November 5, 2017 Author Posted November 5, 2017 (edited) Can you try with native playback mode? Let me know if the problem exists then. Thank you.When using native playback do the files have to exist on your local network because I've tried it and it won't even play any of the files with native playback? My files aren't on my local network Sent from my ZTE A2017U using Tapatalk Edited November 5, 2017 by Supersilver
Angelblue05 4132 Posted November 6, 2017 Posted November 6, 2017 (edited) It can be local or pn your network. To find your path, check in the emby dashboard > library > check folders and check the path. You can also add a network path that points to the same directory. Anyway, don't worry about it. Stick with addon playback. I'll let you know once this is corrected. Sent from my iPhone using Tapatalk Edited November 6, 2017 by Angelblue05 2
Supersilver 4 Posted November 6, 2017 Author Posted November 6, 2017 Okay thank you for looking into the problem hopefully it's not too much hassle, I'll see if I can get the native playback working in the mean time. Sent from my ZTE A2017U using Tapatalk
tchirou 23 Posted November 11, 2017 Posted November 11, 2017 Hi guys I have the exact same problem with Kodi 17.5, latest emby synology server, latest emby for kodi and trakt for kodi add-on. I use native playback The scrobble is working for movies but not for tv shows How it helps narrowing down the problem 1
tchirou 23 Posted November 19, 2017 Posted November 19, 2017 Hi I noticed it scrobbles only the s01e01 episode of a tv show. Must be linked to the issue of using IMDb instead of tvdb. I will report back when this issue is fixed to let you know if it fixed the trakt problem Thanks 1
Supersilver 4 Posted November 19, 2017 Author Posted November 19, 2017 (edited) Hey I've also just noticed there that the PlexKodiConnect Add-on for Kodi seems to be able to scrobble TV shows fine and that is supposedly a fork of Emby Add-on https://github.com/croneter/PlexKodiConnect Edited November 19, 2017 by Supersilver
Angelblue05 4132 Posted November 19, 2017 Posted November 19, 2017 Yeah, as stated in the post above yours, that is likely the issue. For some reason, imdb is used for tvshow and that is a problem because it should be tvdb. Thank you for your patience. 1
Angelblue05 4132 Posted November 21, 2017 Posted November 21, 2017 Try the build here: https://emby.media/community/index.php?/topic/53022-items-missing-or-merged-with-another-item-when-syncing-kodi-with-emby-using-pluginvideoemby/?p=513143 You could try the repair database > tvshows. I believe it will correct this, but if it doesn't then a database reset to be safe. 1
tchirou 23 Posted November 21, 2017 Posted November 21, 2017 Hi Supersilver I tried the test build with resetting the database and the scrobbling for tv shows now works for all the shows on my side. What about you ? Thanks 2
Supersilver 4 Posted November 21, 2017 Author Posted November 21, 2017 Hi guys It worked for me as well so happy now thank you for your time on this Angelblue05 2
