aerial 0 Posted October 27, 2017 Posted October 27, 2017 I have recently built a new HTPC NUC7i5BNK with windows 10. I have it set up to launch Emby on start up. The thing is, if I have it set on full screen I get no audio on start up while playing a video. If I make the screen size smaller I have audio. I can them maximize the screen size and audio is still good. I'm using the built in player. I have tried all the settings in the audio config screen. Nothing seems to make a difference. Is there a setting in windows to fix this? Or am I missing something obvious.
Guest asrequested Posted October 27, 2017 Posted October 27, 2017 That's a weird one. Add logging and post the log. I'm assuming you're using the app from the website not the store app How to set up logging
Sammy 791 Posted October 27, 2017 Posted October 27, 2017 Maybe you need to set the audio to allow applications to have exclusive control but I believe this is the default setting anyways.
aerial 0 Posted October 28, 2017 Author Posted October 28, 2017 OK here are my logs. First one has audio when screen size is smaller on startup. [ 0.015][v][cplayer] mpv 0.27.0 © 2000-2017 mpv/MPlayer/mplayer2 projects [ 0.015][v][cplayer] built on Wed Sep 13 04:18:08 CEST 2017 [ 0.015][v][cplayer] ffmpeg library versions: [ 0.015][v][cplayer] libavutil 55.74.100 [ 0.015][v][cplayer] libavcodec 57.105.100 [ 0.015][v][cplayer] libavformat 57.82.100 [ 0.015][v][cplayer] libswscale 4.7.103 [ 0.015][v][cplayer] libavfilter 6.105.100 [ 0.015][v][cplayer] libswresample 2.8.100 [ 0.015][v][cplayer] ffmpeg version: N-87286-g6ce4a635ed [ 0.015][v][cplayer] [ 0.015][v][cplayer] Configuration: /home/lachs0r/mingw-w64-cmake/buildroot/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-encoding --enable-egl-angle-lib --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --prefix=/home/lachs0r/mingw-w64-cmake/buildroot/build64/prefix/mingw [ 0.015][v][cplayer] List of enabled features: asm atomics avutil-content-light-level avutil-icc-profile avutil-imgcpy-uc avutil-spherical build-date cplayer cuda-hwaccel d3d-hwaccel d3d-hwaccel-new d3d9-hwaccel debug-build direct3d dos-paths dvdnav dvdread dvdread-common egl-angle egl-angle-lib egl-angle-win32 egl-helpers encoding gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc iconv is_ffmpeg javascript jpeg lcms2 libarchive libass libass-osd libav libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack optimize plain-gl posix-or-mingw rubberband static-build stdatomic uchardet wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.015][v][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.016][v][ytdl_hook] loading mp.defaults [ 0.016][v][ytdl_hook] loading @ytdl_hook.lua [ 0.017][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.017][v][cplayer] Run command: hook-add, flags=0, args=[on_load, 1, 10] [ 0.017][v][cplayer] Run command: hook-add, flags=0, args=[on_preloaded, 2, 10] [ 0.017][v][cplayer] Done loading @ytdl_hook.lua. [ 0.017][v][ipc] Starting IPC master [ 0.017][v][ipc] Listening to IPC pipe. [ 0.017][v][autospeedwin] Loading lua script C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua... [ 0.018][v][ipc_0] Client connected [ 0.018][v][autospeedwin] loading mp.defaults [ 0.019][v][autospeedwin] loading file C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua [ 0.019][v][cplayer] Set property: volume=100 -> 1 [ 0.019][v][cplayer] Run command: loadfile, flags=0, args=[http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900, replace, ] [ 0.020][v][cplayer] Done loading C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua. [ 0.020][cplayer] Playing: http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.020][v][cplayer] Running hook: ytdl_hook/on_load [ 0.021][w][ytdl_hook] youtube-dl failed, trying to play URL directly ... [ 0.021][v][cplayer] Run command: hook-ack, flags=0, args=[on_load] [ 0.021][v][ffmpeg] Opening http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.027][v][ffmpeg] Could not set AVOption tls_verify='0' [ 0.027][v][ffmpeg] Mime-type: 'video/quicktime' [ 0.027][v][ffmpeg] Stream opened successfully. [ 0.027][v][cache] Cache size set to 150000 KiB (75000 KiB backbuffer) [ 0.027][v][demux] Trying demuxers for level=normal. [ 0.030][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [ 0.045][v][cache] Dropping cache at pos 238437496, cached range: 0-2032392. [ 0.045][v][cache] Seeking underlying stream: 2032392 -> 238437496 [ 0.060][v][cache] EOF reached. [ 0.065][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [ 0.065][v][cache] blocking for STREAM_CTRL 6 [ 0.065][v][cplayer] Opening done: http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.065][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.066][v][cplayer] Run command: hook-ack, flags=0, args=[on_preloaded] [ 0.066][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.066][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.066][v][vo/opengl] Initializing OpenGL backend 'angle' [ 0.075][v][vo/opengl] Using Direct3D 11 feature level 11_0 [ 0.076][v][vo/opengl] Device: Intel® Iris® Plus Graphics 640 [ 0.076][v][vo/opengl] VendorId: 0x32902 [ 0.076][v][vo/opengl] DeviceId: 0x22822 [ 0.076][v][vo/opengl] LUID: 0000000000007e68 [ 0.078][v][vo/opengl] EGL_VERSION=1.4 (ANGLE 2.1.0.) [ 0.078][v][vo/opengl] EGL_VENDOR=Google Inc. (adapter LUID: 0000000000007e68) [ 0.078][v][vo/opengl] EGL_CLIENT_APIS=OpenGL_ES [ 0.078][v][vo/opengl] Trying to create GLES 3.x context. [ 0.080][v][vo/opengl/win32] resize window: 1280:720 [ 0.080][v][vo/opengl/win32] DPI detected from the new API: 144 [ 0.080][v][vo/opengl/win32] display-fps: 59.940060 [ 0.082][v][vo/opengl/win32] color-profile: C:\Windows\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.089][v][vo/opengl/win32] DPI detected from the new API: 144 [ 0.090][v][vo/opengl] Using DXGI 1.2+ [ 0.090][v][vo/opengl] Using flip-model presentation [ 0.090][v][vo/opengl] GL_VERSION='OpenGL ES 3.0 (ANGLE 2.1.0.)' [ 0.090][v][vo/opengl] Detected GLES 3.0. [ 0.090][v][vo/opengl] GL_VENDOR='Google Inc.' [ 0.090][v][vo/opengl] GL_RENDERER='ANGLE (Intel® Iris® Plus Graphics 640 Direct3D11 vs_5_0 ps_5_0)' [ 0.090][v][vo/opengl] GL_SHADING_LANGUAGE_VERSION='OpenGL ES GLSL ES 3.00 (ANGLE 2.1.0.)' [ 0.090][v][vo/opengl] Loaded extension GL_EXT_texture_norm16. [ 0.090][v][vo/opengl] Loaded extension GL_EXT_color_buffer_half_float. [ 0.090][v][vo/opengl] Loaded extension GL_EXT_disjoint_timer_query. [ 0.090][v][vo/opengl] Loaded extension GL_ANGLE_translated_shader_source. [ 0.091][v][vo/opengl] Testing FBO format rgba16 [ 0.091][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.091][v][vo/opengl] Using FBO format rgba16. [ 0.091][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.091][v][vo/opengl] Loading hwdec driver 'd3d11-egl' [ 0.092][v][vo/opengl] Reported display depth: 10 [ 0.093][v][vo/opengl] Resize: 1280x720 [ 0.093][v][vo/opengl] Assuming 59.940060 FPS for display sync. [ 0.093][v][vd] Container reported FPS: 29.970030 [ 0.093][v][vd] Codec list: [ 0.093][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.093][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.093][v][vd] Opening video decoder h264 [ 0.093][v][vd] Probing 'd3d11va'... [ 0.093][v][vd] Trying hardware decoding. [ 0.094][v][vd] Selected video codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.094][v][ad] Codec list: [ 0.094][v][ad] aac - AAC (Advanced Audio Coding) [ 0.094][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.094][v][ad] Opening audio decoder aac [ 0.094][v][ad] Requesting 1 threads for decoding. [ 0.096][v][ad] Selected audio codec: aac (AAC (Advanced Audio Coding)) [ 0.096][v][cplayer] Starting playback... [ 0.096][v][cache] Dropping cache at pos 787364, cached range: 238437496-238437555. [ 0.096][v][cache] Seeking underlying stream: 238437555 -> 787364 [ 0.100][v][vd] Pixel formats supported by decoder: dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.100][v][vd] Codec profile: High (0x64) [ 0.101][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.104][v][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.104][v][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.104][v][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.104][v][ffmpeg/video] h264: {1b81bea4-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.104][v][ffmpeg/video] h264: {e07ec519-e651-4cd6-ac84-1370cceec851} 103 106 [ 0.104][v][ffmpeg/video] h264: {bcc5db6d-a2b6-4af0-ace4-adb1f787bc89} 103 106 [ 0.104][v][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.104][v][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.104][v][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.104][v][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.104][v][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.104][v][ffmpeg/video] h264: {705b9d82-76cf-49d6-b7e6-ac8872db013c} 103 106 [ 0.104][v][ffmpeg/video] h264: {91cd2d6e-897b-4fa1-b0d7-51dc88010e0a} 100 103 106 107 [ 0.104][v][ffmpeg/video] h264: {90b899ea-3a62-4705-88b3-8df04b2744e7} 103 106 [ 0.104][v][ffmpeg/video] h264: {442b942a-b4d9-4940-bc45-a882e5f919f3} 103 106 [ 0.104][v][ffmpeg/video] h264: {97688186-56a8-4094-b543-fc9daaa49f4b} 103 106 [ 0.104][v][ffmpeg/video] h264: {1424d4dc-7cf5-4bb1-9cd7-b63717a72a6b} 103 106 [ 0.105][v][ffmpeg/video] h264: {c346e8a3-cbed-4d27-87cc-a70eb4dc8c27} 103 106 [ 0.105][v][ffmpeg/video] h264: {ffc79924-5eaf-4666-a736-06190f281443} 103 106 [ 0.105][v][ffmpeg/video] h264: {f416f7bd-098a-4cf1-a11b-ce54959ca03d} 103 106 [ 0.105][v][ffmpeg/video] h264: {bf44dacd-217f-4370-a383-d573bc56707e} 100 103 106 [ 0.105][v][ffmpeg/video] h264: {2364d06a-f67f-4186-aed0-62b99e1784f1} 103 106 [ 0.105][v][ffmpeg/video] h264: {464bdb3c-91c4-4e9b-896f-225496ac4ed6} 103 106 [ 0.105][v][ffmpeg/video] h264: {28566328-f041-4466-8b14-8f5831e78f8b} 103 106 [ 0.105][v][ffmpeg/video] h264: {6b4a94db-54fe-4ae1-9be4-7a7dad004600} 103 104 106 [ 0.105][v][ffmpeg/video] h264: {8c56eb1e-2b47-466f-8d33-7dbcd63f3df2} 103 106 [ 0.105][v][ffmpeg/video] h264: {5b11d51b-2f4c-4452-bcc3-09f2a1160cc0} 103 106 [ 0.105][v][ffmpeg/video] h264: {75fc75f7-c589-4a07-a25b-72e03b0383b3} 103 104 105 106 [ 0.105][v][ffmpeg/video] h264: {107af0e0-ef1a-4d19-aba8-67a163073d13} 103 104 106 [ 0.105][v][ffmpeg/video] h264: {463707f8-a1d0-4585-876d-83aa6d60b89e} 103 106 [ 0.105][v][ffmpeg/video] h264: {a4c749ef-6ecf-48aa-8448-50a7a1165ff7} 103 104 105 106 [ 0.105][v][ffmpeg/video] h264: {76988a52-df13-419a-8e64-ffcf4a336cf5} 103 106 [ 0.105][v][ffmpeg/video] h264: {80a3a7bd-89d8-4497-a2b8-2126af7e6eb8} 103 104 105 106 [ 0.105][v][ffmpeg/video] h264: {50925b7b-e931-4978-a12a-586630f095f9} 103 106 [ 0.105][v][ffmpeg/video] h264: {49761bec-4b63-4349-a5ff-87ffdf088466} 103 106 [ 0.111][v][ffmpeg/video] h264: Reinit context to 1280x720, pix_fmt: d3d11 [ 0.112][v][af] Audio filter chain: [ 0.112][v][af] [in] 48000Hz stereo 2ch floatp [ 0.112][v][af] [out] 48000Hz stereo 2ch floatp [ 0.112][v][af] [ao] 48000Hz stereo 2ch floatp [ 0.112][v][ao] Trying audio driver 'wasapi' [ 0.112][v][ao/wasapi] requested format: 48000 Hz, stereo channels, floatp [ 0.114][v][ao/wasapi] No device specified. Selecting default. [ 0.114][v][ao/wasapi] Selecting device '{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37}' (marantz-AVR (Intel® Display Audio)) [ 0.114][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37} [ 0.125][v][ao/wasapi] Trying stereo float (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.125][v][ao/wasapi] Trying stereo float (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.125][v][ao/wasapi] Trying stereo s32 (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.125][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.125][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 44100hz (exclusive) -> ok [ 0.125][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 96000hz (exclusive) -> ok [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 88200hz (exclusive) -> ok [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 192000hz (exclusive) -> unsupported [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 176400hz (exclusive) -> ok [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 32000hz (exclusive) -> ok [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 22050hz (exclusive) -> unsupported [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 11025hz (exclusive) -> unsupported [ 0.126][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 8000hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 16000hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 352800hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 384000hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying 5.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.127][v][ao/wasapi] Trying 7.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.127][v][ao/wasapi] Trying 6.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying mono s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.127][v][ao/wasapi] Trying 2.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.128][v][ao/wasapi] Trying 4.0 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.128][v][ao/wasapi] Trying 5.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.128][v][ao/wasapi] Trying 3.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.128][v][ao/wasapi] Trying 3.0(back) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.128][v][ao/wasapi] Trying quad s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.128][v][ao/wasapi] Trying quad(side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.128][v][ao/wasapi] Trying 3.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.129][v][ao/wasapi] Trying 5.0(side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.129][v][ao/wasapi] Trying 4.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.129][v][ao/wasapi] Trying 5.1(side) s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.129][v][ao/wasapi] Trying 6.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.129][v][ao/wasapi] Trying 6.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.129][v][ao/wasapi] Trying 6.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.130][v][ao/wasapi] Trying 6.1(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.130][v][ao/wasapi] Trying 7.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.130][v][ao/wasapi] Trying 7.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.130][v][ao/wasapi] Trying 7.1(wide) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.130][v][ao/wasapi] Trying 7.1(wide-side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.131][v][ao/wasapi] Trying empty s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.131][v][ao/wasapi] Trying octagonal s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.131][v][ao/wasapi] Channel layouts: [ 0.131][v][ao/wasapi] - stereo [ 0.131][v][ao/wasapi] - 5.1 [ 0.131][v][ao/wasapi] - 7.1 [ 0.131][v][ao/wasapi] - 4.0 [ 0.131][v][ao/wasapi] - quad [ 0.131][v][ao/wasapi] - 3.1 [ 0.131][v][ao/wasapi] - 5.1(side) [ 0.131][v][ao/wasapi] result: stereo [ 0.131][v][ao/wasapi] Accepted as stereo s32 @ 48000hz -> stereo s32 (32/24 bits) @ 48000hz (exclusive) [ 0.131][v][ao/wasapi] Device period: 10 ms [ 0.145][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 0.145][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 0.147][v][ao/wasapi] device buffer: 480 samples. [ 0.147][v][ao/wasapi] using soft-buffer of 9600 samples. [ 0.147][cplayer] AO: [wasapi] 48000Hz stereo 2ch s32 [ 0.147][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.147][v][af] Adding filter lavrresample [ 0.147][v][af] Audio filter chain: [ 0.147][v][af] [in] 48000Hz stereo 2ch floatp [ 0.147][v][af] [lavrresample] 48000Hz stereo 2ch s32 [a] [ 0.147][v][af] [out] 48000Hz stereo 2ch s32 [ 0.147][v][af] [ao] 48000Hz stereo 2ch s32 [ 0.149][vd] Using hardware decoding (d3d11va). [ 0.149][v][vd] Decoder format: 1280x720 d3d11_nv12[nv12] bt.709/auto/auto/limited CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.149][v][vf] Video filter chain: [ 0.149][v][vf] [in] 1280x720 d3d11_nv12[nv12] bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.149][v][vf] [out] 1280x720 d3d11_nv12[nv12] bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.149][cplayer] VO: [opengl] 1280x720 d3d11_nv12[nv12] [ 0.149][v][cplayer] VO: Description: Extended OpenGL Renderer [ 0.149][v][vo/opengl] Resize: 1280x720 [ 0.149][v][vo/opengl] Window size: 1280x720 [ 0.149][v][vo/opengl] Video source: 1280x720 (1:1) [ 0.149][v][vo/opengl] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720 [ 0.149][v][vo/opengl] Video scale: 1.000000/1.000000 [ 0.149][v][vo/opengl] OSD borders: l=0 t=0 r=0 b=0 [ 0.149][v][vo/opengl] Video borders: l=0 t=0 r=0 b=0 [ 0.149][v][vo/opengl] Testing FBO format rgba16 [ 0.149][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.150][v][vo/opengl] Using FBO format rgba16. [ 0.150][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.150][v][vo/opengl] new shader program: [ 0.150][v][vo/opengl] [ 1] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.150][v][vo/opengl] [ 2] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg; [ 0.150][v][vo/opengl] [ 3] color = color.rgbr; [ 0.150][v][vo/opengl] [ 4] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.150][v][vo/opengl] [ 5] color.a = 1.0; [ 0.150][v][vo/opengl] [ 6] // color mapping [ 0.164][v][vo/opengl] shader link log (status=1): [ 0.164][v][vo/opengl] [ 0.164][v][vo/opengl] [ 0.164][v][vo/opengl] [ 0.166][v][cplayer] first video frame after restart shown [ 0.167][v][cplayer] starting audio playback [ 0.167][v][cplayer] playback restart complete [ 0.170][cplayer] Track switched: [ 0.170][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.170][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.170][v][cplayer] Set property: aid=1 -> 1 [ 0.170][autospeedwin] Saving Exit Refresh Rate -: 59 [ 0.170][cplayer] Track switched: [ 0.170][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.170][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.170][v][cplayer] Set property: sid="no" -> 1 [ 0.170][v][cplayer] Run command: seek, flags=0, args=[170.000000, absolute, exact] [ 0.170][v][cplayer] Run command: define-section, flags=0, args=[input_autospeedwin, y script-binding autospeedwin/autospeedwin [ 0.170][v][cplayer] , default] [ 0.170][v][cplayer] Run command: enable-section, flags=0, args=[input_autospeedwin, allow-hide-cursor+allow-vo-dragging] [ 0.171][v][cplayer] Run command: define-section, flags=0, args=[input_forced_autospeedwin, , force] [ 0.171][v][cplayer] Run command: enable-section, flags=0, args=[input_forced_autospeedwin, allow-hide-cursor+allow-vo-dragging] [ 0.171][v][lavf] queuing seek to 170.000000 [ 0.173][v][cplayer] hr-seek, skipping to 170.000000 [ 0.174][v][lavf] execute seek (to 170.000000 flags 40) [ 0.174][v][lavf] seek done [ 0.174][v][cache] Dropping cache at pos 32526359, cached range: 787364-7972256. [ 0.174][v][cache] Seeking underlying stream: 7972256 -> 32526359 [ 0.194][v][vd] Pixel formats supported by decoder: dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.194][v][vd] Codec profile: High (0x64) [ 0.194][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.194][v][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.194][v][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.194][v][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.194][v][ffmpeg/video] h264: {1b81bea4-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.194][v][ffmpeg/video] h264: {e07ec519-e651-4cd6-ac84-1370cceec851} 103 106 [ 0.194][v][ffmpeg/video] h264: {bcc5db6d-a2b6-4af0-ace4-adb1f787bc89} 103 106 [ 0.194][v][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.194][v][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.194][v][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.194][v][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.194][v][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.194][v][ffmpeg/video] h264: {705b9d82-76cf-49d6-b7e6-ac8872db013c} 103 106 [ 0.194][v][ffmpeg/video] h264: {91cd2d6e-897b-4fa1-b0d7-51dc88010e0a} 100 103 106 107 [ 0.194][v][ffmpeg/video] h264: {90b899ea-3a62-4705-88b3-8df04b2744e7} 103 106 [ 0.194][v][ffmpeg/video] h264: {442b942a-b4d9-4940-bc45-a882e5f919f3} 103 106 [ 0.194][v][ffmpeg/video] h264: {97688186-56a8-4094-b543-fc9daaa49f4b} 103 106 [ 0.194][v][ffmpeg/video] h264: {1424d4dc-7cf5-4bb1-9cd7-b63717a72a6b} 103 106 [ 0.194][v][ffmpeg/video] h264: {c346e8a3-cbed-4d27-87cc-a70eb4dc8c27} 103 106 [ 0.194][v][ffmpeg/video] h264: {ffc79924-5eaf-4666-a736-06190f281443} 103 106 [ 0.194][v][ffmpeg/video] h264: {f416f7bd-098a-4cf1-a11b-ce54959ca03d} 103 106 [ 0.194][v][ffmpeg/video] h264: {bf44dacd-217f-4370-a383-d573bc56707e} 100 103 106 [ 0.195][v][ffmpeg/video] h264: {2364d06a-f67f-4186-aed0-62b99e1784f1} 103 106 [ 0.195][v][ffmpeg/video] h264: {464bdb3c-91c4-4e9b-896f-225496ac4ed6} 103 106 [ 0.195][v][ffmpeg/video] h264: {28566328-f041-4466-8b14-8f5831e78f8b} 103 106 [ 0.195][v][ffmpeg/video] h264: {6b4a94db-54fe-4ae1-9be4-7a7dad004600} 103 104 106 [ 0.195][v][ffmpeg/video] h264: {8c56eb1e-2b47-466f-8d33-7dbcd63f3df2} 103 106 [ 0.195][v][ffmpeg/video] h264: {5b11d51b-2f4c-4452-bcc3-09f2a1160cc0} 103 106 [ 0.195][v][ffmpeg/video] h264: {75fc75f7-c589-4a07-a25b-72e03b0383b3} 103 104 105 106 [ 0.195][v][ffmpeg/video] h264: {107af0e0-ef1a-4d19-aba8-67a163073d13} 103 104 106 [ 0.195][v][ffmpeg/video] h264: {463707f8-a1d0-4585-876d-83aa6d60b89e} 103 106 [ 0.195][v][ffmpeg/video] h264: {a4c749ef-6ecf-48aa-8448-50a7a1165ff7} 103 104 105 106 [ 0.195][v][ffmpeg/video] h264: {76988a52-df13-419a-8e64-ffcf4a336cf5} 103 106 [ 0.195][v][ffmpeg/video] h264: {80a3a7bd-89d8-4497-a2b8-2126af7e6eb8} 103 104 105 106 [ 0.195][v][ffmpeg/video] h264: {50925b7b-e931-4978-a12a-586630f095f9} 103 106 [ 0.195][v][ffmpeg/video] h264: {49761bec-4b63-4349-a5ff-87ffdf088466} 103 106 [ 0.199][v][ffmpeg/video] h264: Reinit context to 1280x720, pix_fmt: d3d11 [ 0.201][v][vd] Decoder format: 1280x720 d3d11_nv12[nv12] bt.709/auto/auto/limited CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.213][v][cplayer] first video frame after restart shown [ 0.214][v][cplayer] starting audio playback [ 0.214][v][cplayer] playback restart complete [ 20.948][v][vo/opengl/win32] resize window: 1920:1080 [ 20.969][v][vo/opengl] Resize: 1920x1080 [ 20.969][v][vo/opengl] Window size: 1920x1080 [ 20.969][v][vo/opengl] Video source: 1280x720 (1:1) [ 20.969][v][vo/opengl] Video display: (0, 0) 1280x720 -> (0, 0) 1920x1080 [ 20.969][v][vo/opengl] Video scale: 1.500000/1.500000 [ 20.969][v][vo/opengl] OSD borders: l=0 t=0 r=0 b=0 [ 20.969][v][vo/opengl] Video borders: l=0 t=0 r=0 b=0 [ 750.666][v][cache] EOF reached. [ 813.516][v][cplayer] Run command: stop, flags=0, args=[] [ 813.516][v][cplayer] EOF code: 4 [ 813.516][v][ad] Uninit audio decoder. [ 813.517][v][af] Removing filter lavrresample [ 813.518][v][vd] Uninit video. [ 813.522][v][cache] Terminating cache... [ 813.522][v][cache] Cache exiting... [ 813.542][v][cplayer] finished playback, success (reason 2) [ 813.542][cplayer] [ 813.547][v][vo/opengl] flushing shader cache [ 813.578][v][vo/opengl/win32] uninit [ 813.580][v][cplayer] Run command: quit, flags=0, args=[0] [ 813.581][cplayer] [ 813.581][cplayer] Exiting... (Quit) [ 813.581][v][ytdl_hook] Exiting... [ 813.581][v][ipc_0] Exiting... [ 813.582][v][autospeedwin] Exiting...
aerial 0 Posted October 28, 2017 Author Posted October 28, 2017 Log when screen is maximized on start up no audio. [ 0.010][v][cplayer] mpv 0.27.0 © 2000-2017 mpv/MPlayer/mplayer2 projects [ 0.010][v][cplayer] built on Wed Sep 13 04:18:08 CEST 2017 [ 0.010][v][cplayer] ffmpeg library versions: [ 0.010][v][cplayer] libavutil 55.74.100 [ 0.010][v][cplayer] libavcodec 57.105.100 [ 0.010][v][cplayer] libavformat 57.82.100 [ 0.010][v][cplayer] libswscale 4.7.103 [ 0.010][v][cplayer] libavfilter 6.105.100 [ 0.010][v][cplayer] libswresample 2.8.100 [ 0.010][v][cplayer] ffmpeg version: N-87286-g6ce4a635ed [ 0.010][v][cplayer] [ 0.010][v][cplayer] Configuration: /home/lachs0r/mingw-w64-cmake/buildroot/build64/packages/mpv-prefix/src/mpv/waf configure --enable-static-build --enable-pdf-build --disable-manpage-build --enable-libmpv-shared --enable-encoding --enable-egl-angle-lib --enable-lua --enable-javascript --enable-libarchive --enable-libass --enable-libbluray --enable-dvdread --enable-dvdnav --enable-uchardet --enable-rubberband --enable-lcms2 --prefix=/home/lachs0r/mingw-w64-cmake/buildroot/build64/prefix/mingw [ 0.010][v][cplayer] List of enabled features: asm atomics avutil-content-light-level avutil-icc-profile avutil-imgcpy-uc avutil-spherical build-date cplayer cuda-hwaccel d3d-hwaccel d3d-hwaccel-new d3d9-hwaccel debug-build direct3d dos-paths dvdnav dvdread dvdread-common egl-angle egl-angle-lib egl-angle-win32 egl-helpers encoding gl gl-dxinterop gl-dxinterop-d3d9 gl-win32 glob glob-win32 gnuc iconv is_ffmpeg javascript jpeg lcms2 libarchive libass libass-osd libav libavcodec libavdevice libbluray libm libmpv-shared lua luajit mingw noexecstack optimize plain-gl posix-or-mingw rubberband static-build stdatomic uchardet wasapi win32-desktop win32-internal-pthreads win32-pipes zlib [ 0.010][v][ytdl_hook] Loading lua script @ytdl_hook.lua... [ 0.011][v][ytdl_hook] loading mp.defaults [ 0.011][v][ytdl_hook] loading @ytdl_hook.lua [ 0.012][v][ytdl_hook] lua-settings/ytdl_hook.conf not found. [ 0.012][v][cplayer] Run command: hook-add, flags=0, args=[on_load, 1, 10] [ 0.012][v][cplayer] Run command: hook-add, flags=0, args=[on_preloaded, 2, 10] [ 0.012][v][cplayer] Done loading @ytdl_hook.lua. [ 0.012][v][ipc] Starting IPC master [ 0.012][v][autospeedwin] Loading lua script C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua... [ 0.012][v][ipc] Listening to IPC pipe. [ 0.012][v][autospeedwin] loading mp.defaults [ 0.013][v][ipc_0] Client connected [ 0.013][v][autospeedwin] loading file C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua [ 0.014][v][cplayer] Set property: volume=100 -> 1 [ 0.014][v][cplayer] Run command: loadfile, flags=0, args=[http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900, replace, ] [ 0.015][v][cplayer] Done loading C:/Users/HTPC LIVINGROOM/AppData/Roaming/Emby-Theater/system/x64/mpv/scripts/autospeedwin.lua. [ 0.015][cplayer] Playing: http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.015][v][cplayer] Running hook: ytdl_hook/on_load [ 0.016][w][ytdl_hook] youtube-dl failed, trying to play URL directly ... [ 0.016][v][cplayer] Run command: hook-ack, flags=0, args=[on_load] [ 0.016][v][ffmpeg] Opening http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.044][v][ffmpeg] Could not set AVOption tls_verify='0' [ 0.044][v][ffmpeg] Mime-type: 'video/quicktime' [ 0.044][v][ffmpeg] Stream opened successfully. [ 0.045][v][cache] Cache size set to 150000 KiB (75000 KiB backbuffer) [ 0.045][v][demux] Trying demuxers for level=normal. [ 0.047][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [ 0.074][v][cache] Dropping cache at pos 238437496, cached range: 0-1744112. [ 0.074][v][cache] Seeking underlying stream: 1744112 -> 238437496 [ 0.089][v][cache] EOF reached. [ 0.094][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [ 0.094][v][cache] blocking for STREAM_CTRL 6 [ 0.094][v][cplayer] Opening done: http://192.168.5.90:8096/emby/Videos/ab9e31712cf2369320d478f6f18f96d0/stream.mov?Static=true&mediaSourceId=ab9e31712cf2369320d478f6f18f96d0&deviceId=DESKTOP-DFB6E99&api_key=0b1ef0a475e84f09a673392e641e687b&Tag=b27405d11baffea95a177392f37df900 [ 0.095][v][cplayer] Running hook: ytdl_hook/on_preloaded [ 0.095][v][cplayer] Run command: hook-ack, flags=0, args=[on_preloaded] [ 0.095][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.095][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.095][v][vo/opengl] Initializing OpenGL backend 'angle' [ 0.105][v][vo/opengl] Using Direct3D 11 feature level 11_0 [ 0.105][v][vo/opengl] Device: Intel® Iris® Plus Graphics 640 [ 0.105][v][vo/opengl] VendorId: 0x32902 [ 0.105][v][vo/opengl] DeviceId: 0x22822 [ 0.105][v][vo/opengl] LUID: 0000000000007e68 [ 0.108][v][vo/opengl] EGL_VERSION=1.4 (ANGLE 2.1.0.) [ 0.108][v][vo/opengl] EGL_VENDOR=Google Inc. (adapter LUID: 0000000000007e68) [ 0.108][v][vo/opengl] EGL_CLIENT_APIS=OpenGL_ES [ 0.108][v][vo/opengl] Trying to create GLES 3.x context. [ 0.111][v][vo/opengl/win32] resize window: 1920:1080 [ 0.111][v][vo/opengl/win32] DPI detected from the new API: 144 [ 0.111][v][vo/opengl/win32] display-fps: 59.940060 [ 0.113][v][vo/opengl/win32] color-profile: C:\Windows\system32\spool\drivers\color\sRGB Color Space Profile.icm [ 0.118][v][vo/opengl/win32] DPI detected from the new API: 144 [ 0.120][v][vo/opengl] Using DXGI 1.2+ [ 0.120][v][vo/opengl] Using flip-model presentation [ 0.120][v][vo/opengl] GL_VERSION='OpenGL ES 3.0 (ANGLE 2.1.0.)' [ 0.120][v][vo/opengl] Detected GLES 3.0. [ 0.120][v][vo/opengl] GL_VENDOR='Google Inc.' [ 0.120][v][vo/opengl] GL_RENDERER='ANGLE (Intel® Iris® Plus Graphics 640 Direct3D11 vs_5_0 ps_5_0)' [ 0.120][v][vo/opengl] GL_SHADING_LANGUAGE_VERSION='OpenGL ES GLSL ES 3.00 (ANGLE 2.1.0.)' [ 0.120][v][vo/opengl] Loaded extension GL_EXT_texture_norm16. [ 0.120][v][vo/opengl] Loaded extension GL_EXT_color_buffer_half_float. [ 0.120][v][vo/opengl] Loaded extension GL_EXT_disjoint_timer_query. [ 0.120][v][vo/opengl] Loaded extension GL_ANGLE_translated_shader_source. [ 0.121][v][vo/opengl] Testing FBO format rgba16 [ 0.121][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.121][v][vo/opengl] Using FBO format rgba16. [ 0.121][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.121][v][vo/opengl] Loading hwdec driver 'd3d11-egl' [ 0.122][v][vo/opengl] Reported display depth: 10 [ 0.124][v][vo/opengl] Resize: 1920x1080 [ 0.124][v][vo/opengl] Assuming 59.940060 FPS for display sync. [ 0.124][v][vd] Container reported FPS: 29.970030 [ 0.124][v][vd] Codec list: [ 0.124][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.124][v][vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [ 0.124][v][vd] Opening video decoder h264 [ 0.124][v][vd] Probing 'd3d11va'... [ 0.124][v][vd] Trying hardware decoding. [ 0.125][v][vd] Selected video codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [ 0.125][v][ad] Codec list: [ 0.126][v][ad] aac - AAC (Advanced Audio Coding) [ 0.126][v][ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ 0.126][v][ad] Opening audio decoder aac [ 0.126][v][ad] Requesting 1 threads for decoding. [ 0.127][v][ad] Selected audio codec: aac (AAC (Advanced Audio Coding)) [ 0.127][v][cplayer] Starting playback... [ 0.128][v][cache] Dropping cache at pos 787364, cached range: 238437496-238437555. [ 0.128][v][cache] Seeking underlying stream: 238437555 -> 787364 [ 0.133][v][vd] Pixel formats supported by decoder: dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.133][v][vd] Codec profile: High (0x64) [ 0.133][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.136][v][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.136][v][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.136][v][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.136][v][ffmpeg/video] h264: {1b81bea4-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.136][v][ffmpeg/video] h264: {e07ec519-e651-4cd6-ac84-1370cceec851} 103 106 [ 0.136][v][ffmpeg/video] h264: {bcc5db6d-a2b6-4af0-ace4-adb1f787bc89} 103 106 [ 0.136][v][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.136][v][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.136][v][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.136][v][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.136][v][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.136][v][ffmpeg/video] h264: {705b9d82-76cf-49d6-b7e6-ac8872db013c} 103 106 [ 0.136][v][ffmpeg/video] h264: {91cd2d6e-897b-4fa1-b0d7-51dc88010e0a} 100 103 106 107 [ 0.136][v][ffmpeg/video] h264: {90b899ea-3a62-4705-88b3-8df04b2744e7} 103 106 [ 0.136][v][ffmpeg/video] h264: {442b942a-b4d9-4940-bc45-a882e5f919f3} 103 106 [ 0.137][v][ffmpeg/video] h264: {97688186-56a8-4094-b543-fc9daaa49f4b} 103 106 [ 0.137][v][ffmpeg/video] h264: {1424d4dc-7cf5-4bb1-9cd7-b63717a72a6b} 103 106 [ 0.137][v][ffmpeg/video] h264: {c346e8a3-cbed-4d27-87cc-a70eb4dc8c27} 103 106 [ 0.137][v][ffmpeg/video] h264: {ffc79924-5eaf-4666-a736-06190f281443} 103 106 [ 0.137][v][ffmpeg/video] h264: {f416f7bd-098a-4cf1-a11b-ce54959ca03d} 103 106 [ 0.137][v][ffmpeg/video] h264: {bf44dacd-217f-4370-a383-d573bc56707e} 100 103 106 [ 0.137][v][ffmpeg/video] h264: {2364d06a-f67f-4186-aed0-62b99e1784f1} 103 106 [ 0.137][v][ffmpeg/video] h264: {464bdb3c-91c4-4e9b-896f-225496ac4ed6} 103 106 [ 0.137][v][ffmpeg/video] h264: {28566328-f041-4466-8b14-8f5831e78f8b} 103 106 [ 0.137][v][ffmpeg/video] h264: {6b4a94db-54fe-4ae1-9be4-7a7dad004600} 103 104 106 [ 0.137][v][ffmpeg/video] h264: {8c56eb1e-2b47-466f-8d33-7dbcd63f3df2} 103 106 [ 0.137][v][ffmpeg/video] h264: {5b11d51b-2f4c-4452-bcc3-09f2a1160cc0} 103 106 [ 0.137][v][ffmpeg/video] h264: {75fc75f7-c589-4a07-a25b-72e03b0383b3} 103 104 105 106 [ 0.137][v][ffmpeg/video] h264: {107af0e0-ef1a-4d19-aba8-67a163073d13} 103 104 106 [ 0.137][v][ffmpeg/video] h264: {463707f8-a1d0-4585-876d-83aa6d60b89e} 103 106 [ 0.137][v][ffmpeg/video] h264: {a4c749ef-6ecf-48aa-8448-50a7a1165ff7} 103 104 105 106 [ 0.137][v][ffmpeg/video] h264: {76988a52-df13-419a-8e64-ffcf4a336cf5} 103 106 [ 0.137][v][ffmpeg/video] h264: {80a3a7bd-89d8-4497-a2b8-2126af7e6eb8} 103 104 105 106 [ 0.138][v][ffmpeg/video] h264: {50925b7b-e931-4978-a12a-586630f095f9} 103 106 [ 0.138][v][ffmpeg/video] h264: {49761bec-4b63-4349-a5ff-87ffdf088466} 103 106 [ 0.143][v][ffmpeg/video] h264: Reinit context to 1280x720, pix_fmt: d3d11 [ 0.144][v][af] Audio filter chain: [ 0.144][v][af] [in] 48000Hz stereo 2ch floatp [ 0.144][v][af] [out] 48000Hz stereo 2ch floatp [ 0.144][v][af] [ao] 48000Hz stereo 2ch floatp [ 0.144][v][ao] Trying audio driver 'wasapi' [ 0.144][v][ao/wasapi] requested format: 48000 Hz, stereo channels, floatp [ 0.146][v][ao/wasapi] No device specified. Selecting default. [ 0.147][v][ao/wasapi] Selecting device '{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37}' (marantz-AVR (Intel® Display Audio)) [ 0.147][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37} [ 0.158][v][ao/wasapi] Trying stereo float (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.159][v][ao/wasapi] Trying stereo float (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.159][v][ao/wasapi] Trying stereo s32 (32/32 bits) @ 48000hz (exclusive) -> unsupported [ 0.159][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.159][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 44100hz (exclusive) -> ok [ 0.159][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 96000hz (exclusive) -> ok [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 88200hz (exclusive) -> ok [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 192000hz (exclusive) -> unsupported [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 176400hz (exclusive) -> ok [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 32000hz (exclusive) -> ok [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 22050hz (exclusive) -> unsupported [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 11025hz (exclusive) -> unsupported [ 0.160][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 8000hz (exclusive) -> unsupported [ 0.161][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 16000hz (exclusive) -> unsupported [ 0.161][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 352800hz (exclusive) -> unsupported [ 0.161][v][ao/wasapi] Trying stereo s32 (32/24 bits) @ 384000hz (exclusive) -> unsupported [ 0.161][v][ao/wasapi] Trying 5.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.161][v][ao/wasapi] Trying 7.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.161][v][ao/wasapi] Trying 6.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.162][v][ao/wasapi] Trying mono s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.162][v][ao/wasapi] Trying 2.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.162][v][ao/wasapi] Trying 4.0 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.162][v][ao/wasapi] Trying 5.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.162][v][ao/wasapi] Trying 3.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.162][v][ao/wasapi] Trying 3.0(back) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.163][v][ao/wasapi] Trying quad s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.163][v][ao/wasapi] Trying quad(side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.163][v][ao/wasapi] Trying 3.1 s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.163][v][ao/wasapi] Trying 5.0(side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.163][v][ao/wasapi] Trying 4.1 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.163][v][ao/wasapi] Trying 5.1(side) s32 (32/24 bits) @ 48000hz (exclusive) -> ok [ 0.163][v][ao/wasapi] Trying 6.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.164][v][ao/wasapi] Trying 6.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.164][v][ao/wasapi] Trying 6.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.164][v][ao/wasapi] Trying 6.1(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.164][v][ao/wasapi] Trying 7.0 s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.164][v][ao/wasapi] Trying 7.0(front) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.165][v][ao/wasapi] Trying 7.1(wide) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.165][v][ao/wasapi] Trying 7.1(wide-side) s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.165][v][ao/wasapi] Trying empty s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.165][v][ao/wasapi] Trying octagonal s32 (32/24 bits) @ 48000hz (exclusive) -> unsupported [ 0.165][v][ao/wasapi] Channel layouts: [ 0.165][v][ao/wasapi] - stereo [ 0.165][v][ao/wasapi] - 5.1 [ 0.165][v][ao/wasapi] - 7.1 [ 0.165][v][ao/wasapi] - 4.0 [ 0.165][v][ao/wasapi] - quad [ 0.165][v][ao/wasapi] - 3.1 [ 0.165][v][ao/wasapi] - 5.1(side) [ 0.165][v][ao/wasapi] result: stereo [ 0.165][v][ao/wasapi] Accepted as stereo s32 @ 48000hz -> stereo s32 (32/24 bits) @ 48000hz (exclusive) [ 0.165][v][ao/wasapi] Device period: 10 ms [ 0.179][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 0.179][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 0.181][v][ao/wasapi] device buffer: 480 samples. [ 0.181][v][ao/wasapi] using soft-buffer of 9600 samples. [ 0.181][cplayer] AO: [wasapi] 48000Hz stereo 2ch s32 [ 0.181][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.181][v][af] Adding filter lavrresample [ 0.181][v][af] Audio filter chain: [ 0.181][v][af] [in] 48000Hz stereo 2ch floatp [ 0.181][v][af] [lavrresample] 48000Hz stereo 2ch s32 [a] [ 0.181][v][af] [out] 48000Hz stereo 2ch s32 [ 0.181][v][af] [ao] 48000Hz stereo 2ch s32 [ 0.183][vd] Using hardware decoding (d3d11va). [ 0.183][v][vd] Decoder format: 1280x720 d3d11_nv12[nv12] bt.709/auto/auto/limited CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.183][v][vf] Video filter chain: [ 0.183][v][vf] [in] 1280x720 d3d11_nv12[nv12] bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.183][v][vf] [out] 1280x720 d3d11_nv12[nv12] bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264 [ 0.183][cplayer] VO: [opengl] 1280x720 d3d11_nv12[nv12] [ 0.183][v][cplayer] VO: Description: Extended OpenGL Renderer [ 0.183][v][vo/opengl] Resize: 1920x1080 [ 0.183][v][vo/opengl] Window size: 1920x1080 [ 0.183][v][vo/opengl] Video source: 1280x720 (1:1) [ 0.183][v][vo/opengl] Video display: (0, 0) 1280x720 -> (0, 0) 1920x1080 [ 0.183][v][vo/opengl] Video scale: 1.500000/1.500000 [ 0.183][v][vo/opengl] OSD borders: l=0 t=0 r=0 b=0 [ 0.183][v][vo/opengl] Video borders: l=0 t=0 r=0 b=0 [ 0.183][v][vo/opengl] Testing FBO format rgba16 [ 0.183][v][vo/opengl] Create FBO: 16x16 (16x16) [ 0.183][v][vo/opengl] Using FBO format rgba16. [ 0.183][v][vo/opengl] No advanced processing required. Enabling dumb mode. [ 0.184][v][vo/opengl] new shader program: [ 0.184][v][vo/opengl] [ 1] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [ 0.184][v][vo/opengl] [ 2] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg; [ 0.184][v][vo/opengl] [ 3] color = color.rgbr; [ 0.184][v][vo/opengl] [ 4] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [ 0.184][v][vo/opengl] [ 5] color.a = 1.0; [ 0.184][v][vo/opengl] [ 6] // color mapping [ 0.198][v][vo/opengl] shader link log (status=1): [ 0.198][v][vo/opengl] [ 0.198][v][vo/opengl] [ 0.198][v][vo/opengl] [ 0.201][v][cplayer] first video frame after restart shown [ 0.201][v][cplayer] starting audio playback [ 0.203][v][cplayer] playback restart complete [ 0.210][cplayer] Track switched: [ 0.210][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.210][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.210][v][cplayer] Set property: aid=1 -> 1 [ 0.210][cplayer] Track switched: [ 0.210][cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [ 0.210][cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 48000Hz) [ 0.210][v][cplayer] Set property: sid="no" -> 1 [ 0.210][v][cplayer] Run command: seek, flags=0, args=[983.000000, absolute, exact] [ 0.211][autospeedwin] Saving Exit Refresh Rate -: 59 [ 0.211][v][lavf] queuing seek to 983.000000 [ 0.212][v][lavf] execute seek (to 983.000000 flags 40) [ 0.212][v][lavf] seek done [ 0.221][v][cplayer] hr-seek, skipping to 983.000000 [ 0.221][v][cache] Dropping cache at pos 170744583, cached range: 787364-8303166. [ 0.221][v][cache] Seeking underlying stream: 8303166 -> 170744583 [ 0.222][v][cplayer] Run command: define-section, flags=0, args=[input_autospeedwin, y script-binding autospeedwin/autospeedwin [ 0.223][v][cplayer] , default] [ 0.223][v][cplayer] Run command: enable-section, flags=0, args=[input_autospeedwin, allow-hide-cursor+allow-vo-dragging] [ 0.223][v][cplayer] Run command: define-section, flags=0, args=[input_forced_autospeedwin, , force] [ 0.223][v][cplayer] Run command: enable-section, flags=0, args=[input_forced_autospeedwin, allow-hide-cursor+allow-vo-dragging] [ 0.223][autospeedwin] New Media Loaded #1, Estimated Refresh Rate -: 29.970029830933, Type -: container-fps [ 0.223][autospeedwin] Possible Refresh Rates (Computed) -: 29;30;59;290;300;261;270;232;240;203;210;174;180;145;150;116;120;87;90;58;60 [ 0.223][autospeedwin] Speed Adjustment -: true [ 0.223][autospeedwin] Current Refresh Rate -: 59, Requested Rate -: 29 [ 0.224][v][cplayer] Set property: pause="yes" -> 1 [ 0.224][autospeedwin] Trying Requested Rate -: 29 [ 0.237][v][vd] Pixel formats supported by decoder: dxva2_vld d3d11va_vld d3d11 yuv420p [ 0.237][v][vd] Codec profile: High (0x64) [ 0.238][v][vd] Requesting pixfmt 'd3d11' from decoder. [ 0.238][v][ffmpeg/video] h264: Decoder GUIDs reported as supported: [ 0.238][v][ffmpeg/video] h264: {ee27417f-5e28-4e65-beea-1d26b508adc9} 103 106 [ 0.238][v][ffmpeg/video] h264: {bf22ad00-03ea-4690-8077-473346209b7e} 103 106 [ 0.238][v][ffmpeg/video] h264: {1b81bea4-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.238][v][ffmpeg/video] h264: {e07ec519-e651-4cd6-ac84-1370cceec851} 103 106 [ 0.238][v][ffmpeg/video] h264: {bcc5db6d-a2b6-4af0-ace4-adb1f787bc89} 103 106 [ 0.238][v][ffmpeg/video] h264: {1b81be94-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.238][v][ffmpeg/video] h264: {1b81bea2-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.238][v][ffmpeg/video] h264: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} 103 106 [ 0.238][v][ffmpeg/video] h264: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} 103 106 [ 0.238][v][ffmpeg/video] h264: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} 103 106 [ 0.238][v][ffmpeg/video] h264: {705b9d82-76cf-49d6-b7e6-ac8872db013c} 103 106 [ 0.239][v][ffmpeg/video] h264: {91cd2d6e-897b-4fa1-b0d7-51dc88010e0a} 100 103 106 107 [ 0.239][v][ffmpeg/video] h264: {90b899ea-3a62-4705-88b3-8df04b2744e7} 103 106 [ 0.239][v][ffmpeg/video] h264: {442b942a-b4d9-4940-bc45-a882e5f919f3} 103 106 [ 0.239][v][ffmpeg/video] h264: {97688186-56a8-4094-b543-fc9daaa49f4b} 103 106 [ 0.239][v][ffmpeg/video] h264: {1424d4dc-7cf5-4bb1-9cd7-b63717a72a6b} 103 106 [ 0.239][v][ffmpeg/video] h264: {c346e8a3-cbed-4d27-87cc-a70eb4dc8c27} 103 106 [ 0.239][v][ffmpeg/video] h264: {ffc79924-5eaf-4666-a736-06190f281443} 103 106 [ 0.239][v][ffmpeg/video] h264: {f416f7bd-098a-4cf1-a11b-ce54959ca03d} 103 106 [ 0.239][v][ffmpeg/video] h264: {bf44dacd-217f-4370-a383-d573bc56707e} 100 103 106 [ 0.239][v][ffmpeg/video] h264: {2364d06a-f67f-4186-aed0-62b99e1784f1} 103 106 [ 0.239][v][ffmpeg/video] h264: {464bdb3c-91c4-4e9b-896f-225496ac4ed6} 103 106 [ 0.240][v][ffmpeg/video] h264: {28566328-f041-4466-8b14-8f5831e78f8b} 103 106 [ 0.240][v][ffmpeg/video] h264: {6b4a94db-54fe-4ae1-9be4-7a7dad004600} 103 104 106 [ 0.240][v][ffmpeg/video] h264: {8c56eb1e-2b47-466f-8d33-7dbcd63f3df2} 103 106 [ 0.240][v][ffmpeg/video] h264: {5b11d51b-2f4c-4452-bcc3-09f2a1160cc0} 103 106 [ 0.240][v][ffmpeg/video] h264: {75fc75f7-c589-4a07-a25b-72e03b0383b3} 103 104 105 106 [ 0.240][v][ffmpeg/video] h264: {107af0e0-ef1a-4d19-aba8-67a163073d13} 103 104 106 [ 0.240][v][ffmpeg/video] h264: {463707f8-a1d0-4585-876d-83aa6d60b89e} 103 106 [ 0.240][v][ffmpeg/video] h264: {a4c749ef-6ecf-48aa-8448-50a7a1165ff7} 103 104 105 106 [ 0.240][v][ffmpeg/video] h264: {76988a52-df13-419a-8e64-ffcf4a336cf5} 103 106 [ 0.240][v][ffmpeg/video] h264: {80a3a7bd-89d8-4497-a2b8-2126af7e6eb8} 103 104 105 106 [ 0.240][v][ffmpeg/video] h264: {50925b7b-e931-4978-a12a-586630f095f9} 103 106 [ 0.240][v][ffmpeg/video] h264: {49761bec-4b63-4349-a5ff-87ffdf088466} 103 106 [ 0.245][v][ffmpeg/video] h264: Reinit context to 1280x720, pix_fmt: d3d11 [ 0.247][v][vd] Decoder format: 1280x720 d3d11_nv12[nv12] bt.709/auto/auto/limited CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000) [ 0.254][v][cplayer] first video frame after restart shown [ 0.254][v][cplayer] starting audio playback [ 0.254][v][cplayer] playback restart complete [ 0.365][v][ao/wasapi] OnDeviceStateChanged triggered on device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37}: requesting ao reload [ 0.365][v][ao/wasapi] OnDefaultDeviceChanged triggered: requesting ao reload [ 0.403][v][ao/wasapi] OnPropertyValueChanged triggered on device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37} [ 0.404][v][ao/wasapi] Changed property: {9c119480-ddc2-4954-a150-5bd240d454ad},1 [ 0.404][v][ao/wasapi] OnPropertyValueChanged triggered on device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37} [ 0.404][v][ao/wasapi] Changed property: {9c119480-ddc2-4954-a150-5bd240d454ad},2 [ 0.408][v][ao/wasapi] OnDeviceStateChanged triggered on device {0.0.0.00000000}.{a1bea3c0-f3ea-4b01-a7cc-0f941b71cd37}: requesting ao reload [ 0.408][v][ao/wasapi] OnDefaultDeviceChanged triggered: requesting ao reload [ 0.543][v][af] Removing filter lavrresample [ 0.543][v][af] Adding filter lavrresample [ 0.544][v][af] Audio filter chain: [ 0.544][v][af] [in] 48000Hz stereo 2ch floatp [ 0.544][v][af] [lavrresample] 48000Hz stereo 2ch s32 [a] [ 0.544][v][af] [out] 48000Hz stereo 2ch s32 [ 0.544][v][af] [ao] 48000Hz stereo 2ch s32 [ 0.544][v][af] Removing filter lavrresample [ 0.544][v][af] Audio filter chain: [ 0.544][v][af] [in] 48000Hz stereo 2ch floatp [ 0.544][v][af] [out] 48000Hz stereo 2ch floatp [ 0.544][v][af] [ao] 48000Hz stereo 2ch floatp [ 0.544][v][ao] Trying audio driver 'wasapi' [ 0.544][v][ao/wasapi] requested format: 48000 Hz, stereo channels, floatp [ 0.545][autospeedwin] Pausing Playback for 4 second(s) [ 0.547][e][ao/wasapi] There are no playback devices available [ 0.547][e][ao] Failed to initialize audio driver 'wasapi' [ 0.547][e][cplayer] Could not open/initialize audio device -> no sound. [ 0.547][v][ad] Uninit audio decoder. [ 0.548][cplayer] Audio: no audio [ 0.617][v][vo/opengl/win32] resize window: 1942:1102 [ 0.637][v][vo/opengl] Resize: 1942x1102 [ 0.637][v][vo/opengl] Window size: 1942x1102 [ 0.637][v][vo/opengl] Video source: 1280x720 (1:1) [ 0.637][v][vo/opengl] Video display: (0, 0) 1280x720 -> (0, 5) 1942x1092 [ 0.637][v][vo/opengl] Video scale: 1.517187/1.516667 [ 0.637][v][vo/opengl] OSD borders: l=0 t=5 r=0 b=5 [ 0.637][v][vo/opengl] Video borders: l=0 t=5 r=0 b=5 [ 0.929][v][cache] EOF reached. [ 4.546][v][cplayer] Set property: pause="no" -> 1 [ 4.546][v][cplayer] Set property: speed=1.000000 -> 1 [ 18.632][v][cplayer] Run command: stop, flags=0, args=[] [ 18.632][v][cplayer] EOF code: 4 [ 18.635][v][vd] Uninit video. [ 18.639][v][cache] Terminating cache... [ 18.639][v][cache] Cache exiting... [ 18.650][v][cplayer] finished playback, success (reason 2) [ 18.650][cplayer] [ 18.662][v][vo/opengl] flushing shader cache [ 18.685][v][vo/opengl/win32] uninit [ 18.686][v][cplayer] Run command: quit, flags=0, args=[0] [ 18.686][cplayer] [ 18.686][cplayer] Exiting... (Quit) [ 18.686][autospeedwin] Reverting Refresh To -: 59 [ 18.686][v][ipc_0] Exiting... [ 18.687][v][ytdl_hook] Exiting... [ 19.013][v][autospeedwin] Exiting...
Luke 42243 Posted October 28, 2017 Posted October 28, 2017 Make sure windows is up to date as well as all hardware drivers. Make sure you have completed the windows sound setup wizard. if you're not sure, do it again. Then if the issue persists, change any Theater audio settings you may have toggled back to their defaults and see if that helps.
Guest asrequested Posted October 29, 2017 Posted October 29, 2017 I agree with Luke. Try that first, you can get the latest driver here: https://downloadcenter.intel.com/product/97539/Intel-Core-i5-7260U-Processor-4M-Cache-up-to-3-40-GHz- In the log, we can see that mpv failed to play the audio. [ 0.544][v][ao/wasapi] requested format: 48000 Hz, stereo channels, floatp [ 0.545][i][autospeedwin] Pausing Playback for 4 second(s) [ 0.547][e][ao/wasapi] There are no playback devices available [ 0.547][e][ao] Failed to initialize audio driver 'wasapi' [ 0.547][e][cplayer] Could not open/initialize audio device -> no sound. [ 0.547][v][ad] Uninit audio decoder. [ 0.548][i][cplayer] Audio: no audio It looks like you have refresh rate switching, enabled. As a test, try disabling it.
aerial 0 Posted October 29, 2017 Author Posted October 29, 2017 I was already updated with the latest drivers. I ended up removing Emby Theater from my NUC. Reinstalled and everything is happy! Thanks for your help.
Luke 42243 Posted October 29, 2017 Posted October 29, 2017 Sounds like the problem was caused by some combination of settings in your previous installation.
