solabc16 379 Posted October 25, 2017 Posted October 25, 2017 Thanks @@cynicism This machine is also based on the Realtek RTD1296 - which we already support, so Emby Server should be good to go out of the box. Hardware transcoding support will however remain a future goal, dependent on whether we can get access to the h/w. Best - James
cynicism 0 Posted October 25, 2017 Posted October 25, 2017 @solabc16I'll probably buy a DS118 to play with when it becomes available. I loaded the new bulid on the DS218+ that I currently have. It's working well. I haven't been able to tell any difference in CPU utilization no matter how I set transcoding options. Should this be working? If so, what do I need to do to get it going? (I'll be glad to read the manual, if you point me in the right direction; but I've already read everything I can find, to no avail.)
solabc16 379 Posted October 25, 2017 Posted October 25, 2017 Hello @@cynicism Is this still with transcoding live TV? As far as server configuration goes, all you need to do is go to Manage Server -> Transcoding -> Hardware acceleration -> Select "Video Acceleration API" and save the change. Can you send me an updated set of logs for this release, that contain a live TV session. Best - James
NeNo 0 Posted October 25, 2017 Posted October 25, 2017 (edited) Hello, I'm new ds918+ owner and would like to try Emby server with h/w transcoding. How to start, where to download apollolake build? Clients will be Samsung Smart TV, 2 x Windows 10 machine, iPhone 6plus... Thanks in advance... Edited October 25, 2017 by NeNo
solabc16 379 Posted October 25, 2017 Posted October 25, 2017 Hello @@NeNo To get started, follow the instructions in the Synology section here - https://emby.media/nas-server.html Let us know how you get on... Best - James
NeNo 0 Posted October 26, 2017 Posted October 26, 2017 (edited) I didn't realize that you made release for Package Manager. I installed it and it works Tried few movies on my TV but there wasn't any transcoding, always DirectPlay. Then on my iPhone, one was transcoding with CPU on 87%(from Dashboard: Transcoding - 2.5 Mbps ts h264 mp3) and one with 38% load (from dashboard: Transcoding (84 fps) - 4.2 Mbps ts h264 aac). In server settings on Transcodiing, I set Intel Quick Sync and enabled hardware transcoding for H264 and VC1. Are those settings ok, or should I put something else? Also should I do this procedure: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Migrating-From-the-Community-Package ? Edited October 26, 2017 by NeNo
cynicism 0 Posted October 26, 2017 Posted October 26, 2017 @solabc16 James, I had the transcoding option set to the wrong thing, sorry. New logs. One HD recording going in background, watching HD program in foreground. Service did NOT die. Great! sendlogs_Safe218_synology_apollolake_218+_20171026T193245UTC.tgz Watching a single LiveTV stream (without a background recording) gives CPU utilization in the 20-25% range. This is much better. Under LiveTV, Settings, "Automatically convert recordings to a streaming friendly format", this option is checked. Anytime there is a recording in progress, CPU goes to about 95%. Does this "convert" not use hardware transcoding? BTW: DS118 is now official. https://www.synology.com/en-us/products/DS118
pikeupe 4 Posted October 30, 2017 Posted October 30, 2017 HelloI wonder dandu DS918 + it is better used which transcode
solabc16 379 Posted October 30, 2017 Posted October 30, 2017 Hello @@pikeupe The DS918+ and DS718+ are both 'apollolake' based machines, using the Intel Celeron J3455. So in terms of raw processing power, they'll be capable of the same transcode rates. However, your intended use and library content will bring other factors into play, when making a decision on which NAS is right for you. My recommendation is always to first look at your intended usage and see if you can take advantage of direct play, by using a media format that is natively compatible with the devices you intend to playback content on. Best - James
cynicism 0 Posted November 9, 2017 Posted November 9, 2017 @solabc16 We have a reproduce-able bug! Same two recordings, second week in a row. Service is still responsive (browsing and playback are fine), but two recordings appear to be in progress hours after they should have completed and no new recordings are started regardless of schedule. Ran diagnostics while we still had two hung recordings. sendlogs_Safe218_synology_apollolake_218+_20171109T051426UTC.tgz A service restart leaves two damaged recordings (there, but not complete).
tchirou 23 Posted November 10, 2017 Posted November 10, 2017 (edited) Hi Guys I have had a DS418 for 3 weeks and I have an opportunity to migrate to a ds418play for 40$ so I am taking it. I am already using the emby repository in package center. If I understand everything, the DS418play which has an intel J3345 appololake, should be able to use H/W transcode with the emby package. I just need to select intel quick sync in the settings. Is that it ? Thanks a lot Edited November 10, 2017 by tchirou
solabc16 379 Posted November 10, 2017 Posted November 10, 2017 Hello @@tchirou That’s pretty much it, but you need to select VA-API, not QuickSync. Best - James 1
solabc16 379 Posted November 13, 2017 Posted November 13, 2017 (edited) @solabc16 We have a reproduce-able bug! Same two recordings, second week in a row. Service is still responsive (browsing and playback are fine), but two recordings appear to be in progress hours after they should have completed and no new recordings are started regardless of schedule. Ran diagnostics while we still had two hung recordings. sendlogs_Safe218_synology_apollolake_218+_20171109T051426UTC.tgz A service restart leaves two damaged recordings (there, but not complete). Hello @@cynicism Thanks for the update, this particular issue is more likely to be Emby Server related, as opposed to platform related. @@Luke, any thoughts? I've taken a quick look at the logs and don't see any specific platform issues. @@cynicism, can you give an estimated time this happened? Server logs attached for reference... Best - James logs.zip Edited November 13, 2017 by solabc16
Luke 42241 Posted November 13, 2017 Posted November 13, 2017 @cynicism has this happened again? If so, try turning off the realtime recording conversion feature under live tv settings. thanks !
cynicism 0 Posted November 13, 2017 Posted November 13, 2017 (edited) @@Luke, @@solabc16 Historically, it happens on Monday evenings, so it hasn't happened since the above logs. The two recordings are from 6:30-7:00pm and from 7:00-8:00pm (CST or GMT-6). Both recordings are affected. So, I'd guess it is around 7:00pm that it dies. I ran diagnostic logs several hours after the recordings should have completed. I will try to reproduce with different shows and will try turning off the realtime conversion (assuming that's "Automatically convert recordings to streaming friendly format", if not, please point me in the right direction). I'll send more details as I learn more... Edited November 13, 2017 by cynicism
cynicism 0 Posted November 14, 2017 Posted November 14, 2017 @@Luke @cynicism has this happened again? If so, try turning off the realtime recording conversion feature under live tv settings. thanks ! Turning off realtime recording conversion did allow the recordings to complete normally. Is there any other tests or information that would be useful?
Luke 42241 Posted November 14, 2017 Posted November 14, 2017 No, for your server I would suggest keeping the setting off as the conversion just isn't happening fast enough.
Everbrave 62 Posted January 6, 2018 Posted January 6, 2018 AV-API works fine, but will QSV be implemented for DS918+?
Luke 42241 Posted January 6, 2018 Posted January 6, 2018 It's a possibility for the future. Thanks. 1
Ron 2 Posted January 7, 2018 Posted January 7, 2018 Hi All, I have been reading so many posts and have been learning a lot. My old nas (zyxel - for files only) just died. and my Windows Media PC is on it's very last legs (grocery store PC from 8 years ago). I am moving to a Synology. But would love to hear your opinions on the DS418play or the DS918+ I have very little 4k content at the moment but that will increase I am sure. I have limited bandwidth to the TVs upstairs (wifi only). So in your opinion. faster dual-core or slower quad-core?
Everbrave 62 Posted January 7, 2018 Posted January 7, 2018 (edited) "the DS418play or the DS918+" DS918+ Edited January 7, 2018 by Everbrave
Ron 2 Posted January 8, 2018 Posted January 8, 2018 "the DS418play or the DS918+" DS918+ Hi ,Everbrave thank you for your opinion. Could I trouble you for a short reason for the DS918+. Pluses that I see are: 4 cores (but slower), possible of 8 Gig Ram (only 6 in the play), m.2 sdd support (the family will not be accessing files for working), virtualization support (I use my main machine for VMs), adding a DX517 in the future) . I am on the fence between the two :-)
Everbrave 62 Posted January 8, 2018 Posted January 8, 2018 Hi ,Everbrave thank you for your opinion. Could I trouble you for a short reason for the DS918+. Pluses that I see are: 4 cores (but slower), possible of 8 Gig Ram (only 6 in the play), m.2 sdd support (the family will not be accessing files for working), virtualization support (I use my main machine for VMs), adding a DX517 in the future) . I am on the fence between the two :-) In short, you can transcode more streams on DS918+ There are a lot of articles with detailed comparison, e.g. http://nascompares.com/2017/11/20/what-is-the-best-synology-4-bay-nas-ds918-vs-ds418play-vs-ds418-vs-ds418j/ hope this helps
Ron 2 Posted January 8, 2018 Posted January 8, 2018 In short, you can transcode more streams on DS918+ Thank you, so you say more cores are better than a little more speed. Thank you.
