alex_wahl 1 Posted September 21, 2017 Posted September 21, 2017 Hi there! I use emby Version 3.2.30.0 on a synology disk station. So far it runs well. I purchasesd emby permiere because i need the downlad to device feature for offline listening. On my android device i tab on the download butten e.q. in a album view. The download gets prepared an after the transcoding i see the download on the server with the hin "ready for download". On my Android device i see the "ready for download" also in the download settings menu. But the download never starts. I can not find any button or whatever to start it. If i tab on the prepared ready for doenload object i get a menu with a save button at the end. If i tab that the menu closes and nothing happens. How can i start the download???? It is very sad that this feature isnt working because it is the reason why i switched to emby. Hopefully someone ot there with a solution? Greetings Alex Ah i dont know if its important but most of my music files have flac encoding. 1
Luke 42243 Posted September 21, 2017 Posted September 21, 2017 Can you please attach the log from the app: https://emby.media/community/index.php?/topic/15638-how-to-report-an-android-problem/ Thanks.
alex_wahl 1 Posted September 21, 2017 Author Posted September 21, 2017 Here is the log from my android appandroid.txt Gesendet von meinem A0001 mit Tapatalk
Luke 42243 Posted September 22, 2017 Posted September 22, 2017 @@alex_wahl, thanks the report. I see your issue and it is resolved for the next release of the app. Thanks !
alex_wahl 1 Posted September 22, 2017 Author Posted September 22, 2017 That sounds good, thank you! Can you estimate the releasedate?
