Danklord 2 Posted September 4, 2017 Posted September 4, 2017 Hey guys, Been a while since I used emby last with Kodi. Glad to see some fantastic changes! However, when using a fresh Kodi install on Nexus player and the Emby app - Kodi crashes when Emby loads and does a sync. I noted that there was another thread that has been locked with this issue from a few months ago. Was there anything I can do to help test or provide logs?
xnappo 1611 Posted September 4, 2017 Posted September 4, 2017 Yes - see the 'How to report a problem' sticky thread. 1
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 I really wish people would post their logs. I'm not a mindreader Sent from my iPhone using Tapatalk 1
Danklord 2 Posted September 4, 2017 Author Posted September 4, 2017 Yes, I would read the "how to report a problem" thread, but I can't find it anywhere. What's the best way to get the logs out of a Nexus player? Have you got a link to a guide?
CBers 7554 Posted September 4, 2017 Posted September 4, 2017 Yes, I would read the "how to report a problem" thread, but I can't find it anywhere. What's the best way to get the logs out of a Nexus player? Have you got a link to a guide? It's not hard to find https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ 1
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 @@CBers do you use any logfile addon in Kodi or are you able to get them in another way? Sent from my iPhone using Tapatalk
Danklord 2 Posted September 4, 2017 Author Posted September 4, 2017 It's not hard to find https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ Thanks, I scanned through so many times and didn't see that! Must be tired !
Danklord 2 Posted September 4, 2017 Author Posted September 4, 2017 Ok, sweet. I'll have a play today to generate some logs and upload them. 1
CBers 7554 Posted September 4, 2017 Posted September 4, 2017 @@CBers do you use any logfile addon in Kodi or are you able to get them in another way? No, I just access the files directly on my Shield from my PC, or via ES FILE EXPLORER on my Shield and then copy to my PC. 1
Danklord 2 Posted September 4, 2017 Author Posted September 4, 2017 No, I just access the files directly on my Shield from my PC, or via ES FILE EXPLORER on my Shield and then copy to my PC. Cool, that's a good idea. Less things to worry about loading up in Kodi. 1
Danklord 2 Posted September 6, 2017 Author Posted September 6, 2017 Hi all, Before I tried getting the logs, I decided to try completely removing Kodi from both my Nexus players and starting from scratch installing the latest Emby add-on. This seemed to work fine. Not sure what the go was given I had reset Kodi by deleting it's all storage but not the app itself, but anyway, it works. If I gave future drama, I will post any logs and info I can. However, if anyone else has this issue, try reinstalling Kodi.
