kryptonyte 5 Posted September 25, 2017 Posted September 25, 2017 @@Luke are the "Premium" plugins compatible with the Asustor apk version 3.2.32.0 ? I cannot see any "Premium" plugins within the Catalog. I cannot see Premium plugins such as Playon, Movie Theme Songs, Movie Theme Videos, TV Theme Songs, TV Theme Videos, Emby Statistics & Timelord Movies/Timelord TV. I'm specifically after the Timelord plugins. Is this due to me migrating from Emby for Linux Mono version 3.2.30.0 to Emby Asustor apk version 3.2.32.0 via the use of the backup & restore plugin? I used this plugin to restore the database etc and manually copied over the metadata folder for all images etc. Everything appears to be working well in the Emby Asustor apk version 3.2.32.0 (including VA API hardware transcoding support!) apart from not being able to see/install "Premium" plugins from the Catalog. Is this a known issue or something with my setup? I can post logs if required.
Luke 42234 Posted September 26, 2017 Author Posted September 26, 2017 You're able to see all plugins that are compatible with your edition of the server. If/when the developers of those plugins make theirs compatible, then you'll be able to install them.
kryptonyte 5 Posted September 26, 2017 Posted September 26, 2017 You're able to see all plugins that are compatible with your edition of the server. If/when the developers of those plugins make theirs compatible, then you'll be able to install them. Thanks @@Luke . As the TImelord plugins previously worked under the unofficial Linux Mono version of Emby (that was published by Asustor on their App Central store), does this mean it should work under the official Emby apk? Or will this require @@BeppoMonkeyBoy & other developers to update their "Premium" plugins to support this new Emby official Asustor apk version?
Luke 42234 Posted September 26, 2017 Author Posted September 26, 2017 No, the ones that will work are the ones that are available for installation in the plugin catalog. thanks.
docb7 3 Posted September 30, 2017 Posted September 30, 2017 (edited) Hi, on my Ausustor 6302 (very potential hardware), Emby regularily crashes. It has become worse, now Emby stays on max 5 Minutes and crashes. I always need to shut it down via ADM (there it looks like Emby still would be running) and start again. I have the latest version (https://emby.media/nas-server.html) installed. I attached my server logs, maybe you can see something there, I am a basic linux user and don't get any clue out of them. Best regards doc server-63642311968.txt server-63642378487.txt server-63642380430.txt server-63642380618.txt Edited September 30, 2017 by docb7
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 @@docb7 try removing the vuplus plugin.
docb7 3 Posted September 30, 2017 Posted September 30, 2017 Thanks for the advice, but that unfortunately that did not help. Some new logs attached. server-63642393033.txt server-63642394611.txt server-63642396332.txt server-63642397847.txt
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 It might be related to photos. Try the latest beta release here: https://github.com/MediaBrowser/Emby/releases Thanks.
docb7 3 Posted September 30, 2017 Posted September 30, 2017 I've tried, but now emby crashes after about 10 seconds so that I can not get to the logs - or do anything else (I wanted to delete the Foto-Library).
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 why do you think that it crashes? how are you measuring that?
docb7 3 Posted September 30, 2017 Posted September 30, 2017 well it does not respond any more. When I open the IP:8096/web/home.html it says "Page not found". That is why I assume it crashed.
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 Are you able to get to the program data path on the file system? /home/emby
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 What is the latest log file in the logs folder?
docb7 3 Posted September 30, 2017 Posted September 30, 2017 I found these logs - all from the Beta-Version. server-63642400336.txt server-63642400811.txt server-63642400845.txt server-63642401054.txt unhandled_432c05cf-5bf3-4cc8-862b-76020d5c393d.txt
Luke 42234 Posted September 30, 2017 Author Posted September 30, 2017 ok, try rebooting the device. that unhandled error is just something that can happen if the device takes longer than usual to free up the port after shutting down emby.
docb7 3 Posted September 30, 2017 Posted September 30, 2017 Ok - it seems to work. I hope it will stay on this time ;-) If not - I'll be back Thank you very much for you quick help!
Dariusz 25 Posted September 30, 2017 Posted September 30, 2017 I noticed that sometimes emby still hangs and when I try to access it I get "Page not found".. basically I need to turn off the app and turn it back on in asustor appstore and then all starts working again.. I have added my logs.. what I noticed in the alerts section was that I had one error where task scheduler encountered and issue and about an hour later there was another alert that said cache was unable to be cleared because of too many files.. Log1-09-30-2017.txt Log2-09-30-2017.txt Log3-09-30-2017.txt
docb7 3 Posted September 30, 2017 Posted September 30, 2017 And again ... I was able to delete the photo library, but that did not help... new log attached server-63642404820.txt
Luke 42234 Posted October 2, 2017 Author Posted October 2, 2017 Emby Server 3.2.33 for Asustor is up for download on our website. As part of our promise, Asustor builds are immediately available following the new release. Enjoy.
docb7 3 Posted October 3, 2017 Posted October 3, 2017 I think you did a little wonder over night - now it runs smoothly since about 12 hours - THANK YOU!
docb7 3 Posted October 4, 2017 Posted October 4, 2017 Ok, I again have been too early pleased. Again it crashes. I copied the logs from home/emby again... As you can see, the *600 log is quite huge, it worked for a while. And since then - crashes. unhandled_3095c5bb-21ac-4c10-9b5b-6fe86a901031.txt server-63642585600.txt server-63642621113.txt server-63642625597.txt server-63642705285.txt server-63642705339.txt server-63642708482.txt
docb7 3 Posted October 7, 2017 Posted October 7, 2017 Hi, i decided to delete the emby installation and I made the home/emby directory empty. Then I've installed 3.2.33.0. Emby server did not start when clicking on the icon, so I've started it via ssh "nohup /usr/local/AppCentral/emby-server/bin/emby-server &" As soon as I started to add my photos, the log shows a lot of errors, all like: 2017-10-07 01:00:37.139 Error App: Image Provider - Error reading image tag for /volume1/Fotos/2008-Privat/2008-Wohnung/DSC02359.JPG *** Error Report *** Version: 3.2.33.0 Command line: /volume1/.@plugins/AppCentral/emby-server/system/EmbyServer.dll -programdata /home/emby -ffmpeg /usr/local/AppCentral/emby-server/bin/ffmpeg -ffprobe /usr/local/AppCentral/emby-server/bin/ffprobe -updatepackage emby-server-asustor-x64.apk Operating system: Unix 4.4.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /home/emby Application directory: /volume1/.@plugins/AppCentral/emby-server/system System.Exception: Cannot change named node at TagLib.File.Create(IFileAbstraction abstraction, String mimetype, ReadStyle propertiesStyle) at Emby.Photos.PhotoProvider.FetchAsync(Photo item, MetadataRefreshOptions options, CancellationToken cancellationToken) System.Exception at TagLib.File.Create(IFileAbstraction abstraction, String mimetype, ReadStyle propertiesStyle) at Emby.Photos.PhotoProvider.FetchAsync(Photo item, MetadataRefreshOptions options, CancellationToken cancellationToken) And finally it crashed with this as the last lines: 2017-10-07 01:21:52.575 Error App: Image Provider - Error reading image tag for /volume1/Fotos/2009-Privat/2009-08-Hochzeit/7_Hochzeit Bürgers(Johanna)/Gästebuch Carina/Zugeschnitten/33.BMP *** Error Report *** Version: 3.2.33.0 Command line: /volume1/.@plugins/AppCentral/emby-server/system/EmbyServer.dll -programdata /home/emby -ffmpeg /usr/local/AppCentral/emby-server/bin/ffmpeg -ffprobe /usr/local/AppCentral/emby-server/bin/ffprobe -updatepackage emby-server-asustor-x64.apk Operating system: Unix 4.4.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /home/emby Application directory: /volume1/.@plugins/AppCentral/emby-server/system System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Photos.PhotoProvider.FetchAsync(Photo item, MetadataRefreshOptions options, CancellationToken cancellationToken) System.NullReferenceException at Emby.Photos.PhotoProvider.FetchAsync(Photo item, MetadataRefreshOptions options, CancellationToken cancellationToken) I've deleted the Photo-library, but now emby still crashes. Last lines were: 2017-10-07 11:10:02.679 Info HttpServer: HTTP Response 200 to 10.11.30.31. Time: 712ms. http://10.11.30.100:8096/emby/Items/aa831fb658f41136b637edd356a15b74/Images/Primary?maxHeight=498&maxWidth=332&tag=d43e29c4b41878ba0703996566adc2b4&quality=90 2017-10-07 11:10:02.734 Info HttpResultFactory: Transmit file /home/emby/cache/temp/a51933162f7a4e5793afc5e91d91bffa.jpg 2017-10-07 11:10:02.735 Info HttpServer: HTTP Response 200 to 10.11.30.31. Time: 771ms. http://10.11.30.100:8096/emby/Items/500594dd6379f945d88076a1296d6c24/Images/Primary?maxHeight=498&maxWidth=332&tag=1753e16fef5d232c0b90c606db9d2f5b&quality=90 2017-10-07 11:10:17.079 Info HttpServer: HTTP GET http://10.11.30.100:8096/emby/Users/6e59cdb807a248618f9b5d3e3d829264/Items/Latest?IncludeItemTypes=Movie&Limit=24&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ParentId=7a2175bccb1f1a94152cbd2b2bae8f6d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 Edge/15.15063 2017-10-07 11:10:17.079 Info HttpServer: HTTP GET http://10.11.30.100:8096/emby/Users/6e59cdb807a248618f9b5d3e3d829264/Items?SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie&Filters=IsResumable&Limit=18&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ParentId=7a2175bccb1f1a94152cbd2b2bae8f6d&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 Edge/15.15063 And reviewing the log, i repeatedly see this error, every 10 Minutes: 2017-10-07 10:57:03.628 Error HttpClient: Error ProtocolError getting response from http://10.11.30.1:49000 *** Error Report *** Version: 3.2.33.0 Command line: /volume1/.@plugins/AppCentral/emby-server/system/EmbyServer.dll -programdata /home/emby -ffmpeg /usr/local/AppCentral/emby-server/bin/ffmpeg -ffprobe /usr/local/AppCentral/emby-server/bin/ffprobe -updatepackage emby-server-asustor-x64.apk Operating system: Unix 4.4.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /home/emby Application directory: /volume1/.@plugins/AppCentral/emby-server/system System.Net.WebException: The remote server returned an error: (500) Internal Server Error. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2017-10-07 10:57:03.628 Error PortMapper: Error creating port map: The remote server returned an error: (500) Internal Server Error.
