Wacind 1 Posted August 23, 2017 Posted August 23, 2017 (edited) Hi I seem to be missing guide data for certain channels. I am using HDhomerun Prime and Schedules Direct. I tried uninstalling Emby and doing a fresh install. I have tried Refreshing Channels and Refreshing Guide multiple times. Examples of channels with Missing Guide Data: 605 NBC HD, 607 ABC HD, 650 CNN HD. There are more channels with missing data but these are a few examples. Examples of chanels with good guide data: 622 TBS HD, 626 FX HD, 632 Comede Central HD I should note that i have disabled all of my SD channels from HDhomerun but My WMC which also uses Schedules Direct guide data seems to be fine for these channels. attached server logs with debug logging Here is the error in the logs: 2017-08-23 09:08:42.182 Info App: Channel Station ID is: 58646 2017-08-23 09:08:42.183 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/schedules 2017-08-23 09:08:42.441 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/programs 2017-08-23 09:08:42.524 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/metadata/programs 2017-08-23 09:08:42.702 Error App: Error getting programs *** Error Report *** Version: 3.2.28.0 Command line: C:\Users\Ashish\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Ashish\AppData\Roaming\Emby-Server Application directory: C:\Users\Ashish\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.GetProgram(String channelId, Program programInfo, ProgramDetails details) at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsyncInternal>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__76.MoveNext() System.NullReferenceException at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.GetProgram(String channelId, Program programInfo, ProgramDetails details) at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsyncInternal>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__76.MoveNext() 2017-08-23 09:08:42.717 Info App: Channel Station ID is: 58780 2017-08-23 09:08:42.717 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/schedules 2017-08-23 09:08:42.976 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/programs 2017-08-23 09:08:43.125 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/metadata/programs 2017-08-23 09:08:43.309 Error App: Error getting programs *** Error Report *** Version: 3.2.28.0 Command line: C:\Users\Ashish\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Ashish\AppData\Roaming\Emby-Server Application directory: C:\Users\Ashish\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.GetProgram(String channelId, Program programInfo, ProgramDetails details) at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsyncInternal>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__76.MoveNext() System.NullReferenceException at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.GetProgram(String channelId, Program programInfo, ProgramDetails details) at Emby.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsyncInternal>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__76.MoveNext() 2017-08-23 09:08:43.324 Info App: Channel Station ID is: 64241 2017-08-23 09:08:43.325 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/schedules 2017-08-23 09:08:43.546 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/programs 2017-08-23 09:08:43.651 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/metadata/programs Anything I can do to try and fix this? Thanks server-63639075951.txt Edited August 23, 2017 by Wacind
Luke 42237 Posted August 23, 2017 Posted August 23, 2017 https://emby.media/community/index.php?/topic/50228-guide-problems/
