csadoian 36 Posted August 22, 2017 Posted August 22, 2017 Something has happened to my guide. All of a sudden there are several channels with missing guide data. The channels are there, but there is no guide data. I have attached server logs and a screen shot of part of my guide (as a test I had the guide only suck in 2 days worth of data, I normally have 8). The missing guide data occurs in many channels, not limited to just one tuner. I have both OTA and Cable HDHomerun tuners. The missing guide data appears to be random. I have refreshed the guide a couple of times, it didn't help. I deleted ALL my tuners (I have three) and my guide provider (Schedules Direct) and then re-added them. No change. Should I contact Schedules Direct, or do you think this is a server problem? Where is the guide data cached? Thanks. Server logs.zip
Luke 42206 Posted August 22, 2017 Posted August 22, 2017 Hi, there are a lot of logs there. Which one is from the time that you refreshed the guide? thanks.
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 Not sure. I refreshed the guide several times over the last couple of hours in attempting to track down the problem. I will do another refresh and then send that log shortly.
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 (edited) Look at server-63639006827.txt (2:11pm) That one has a lot of errors and exceptions that have the keyword Schedules Direct. Edited August 22, 2017 by csadoian
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 Ok, here is the latest log. Guide refresh was done starting at 14:36. Made no difference in the guide. Still have missing guide data on several channels (always the same ones). server-63639008425.txt
TylerV76 84 Posted August 22, 2017 Posted August 22, 2017 (edited) I am having the same issue. Im beginning to think somethings up with Schedules Direct again. I sent a ticket to them earlier, waiting on a reply. Im getting cached data and thats it. Had to plug my Tablo back in to record tonights stuff. I was trying to switch everything over to emby tonight but its not going so well. Edited August 22, 2017 by TylerV76
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 It's funny, I still have a Next PVR server running, which is what I used to use before I recently switched to Emby. It updates the guide each night at 2am, and when I went to the server a few minutes ago and checked the guide all the guide data is there, nothing is missing. So if it is a Schedules Direct problem, it is not affecting Next PVR. Of course, the NextPVR could be displaying cached listings, since it is set to suck in 7 days worth of guide data, as Emby is. Could this be related to the recent firmware update to the HDHomerun tuners? I just updated all three of mine yesterday.
TylerV76 84 Posted August 22, 2017 Posted August 22, 2017 It's funny, I still have a Next PVR server running, which is what I used to use before I recently switched to Emby. It updates the guide each night at 2am, and when I went to the server a few minutes ago and checked the guide all the guide data is there, nothing is missing. So if it is a Schedules Direct problem, it is not affecting Next PVR. Of course, the NextPVR could be displaying cached listings, since it is set to suck in 7 days worth of guide data, as Emby is. Could this be related to the recent firmware update to the HDHomerun tuners? I just updated all three of mine yesterday. Im not sure if the update affected them or not but I updated all 3 of mine. My one hooked to my hdhomerun Prime had guide data for 7 days so I changed the amount of days to list to 10 and refreshed it. Past the 7 days theres tons of data missing which leads me to believe its Schedules Direct. Tonight I hooked up my 2 new hdhomerun connects to replace my Tablo and I got a little bit of data originally but missing a bunch of OTA channels, NBC of course being the one I need to record tonight. Ive tried changing to another service provider on schedules direct and mapping the channels but it still wont populate. I wish I could figure out the xml guide and go that route but Ive spent 3 hours trying to get it working and finally gave up.
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 The log I posted for the Admin has lots of errors and exceptions in it, so I'm thinking that: 1. Something changed in Server 3.2.28 (which I just installed yesterday 2. Something changed at Schedules Direct 3. The updated firmware for the HDHomerun tuners screwed something up 4. Combination of any of the above
TylerV76 84 Posted August 22, 2017 Posted August 22, 2017 The log I posted for the Admin has lots of errors and exceptions in it, so I'm thinking that: 1. Something changed in Server 3.2.28 (which I just installed yesterday 2. Something changed at Schedules Direct 3. The updated firmware for the HDHomerun tuners screwed something up 4. Combination of any of the above I seriously hope its not the hdhomerun update because there doesnt appear to be any way to rollback. The reason I dont believe its that though is the guide shouldnt rely on the hdhomerun to populate. Once youve activated the tuner it should only be used to tune into the channel you direct it to in Emby. The guide should be totally separate and populate unless there is a failure to do so between Emby and Schedules Direct. On a side note, my Tablo is on Ebay so Im really hoping this is resolved before it sells lol.
TylerV76 84 Posted August 22, 2017 Posted August 22, 2017 Just got a reply from Schedules Direct and they claim theres no issue on their end. So now I dont know whats going on.
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 I seriously hope its not the hdhomerun update because there doesnt appear to be any way to rollback. The reason I dont believe its that though is the guide shouldnt rely on the hdhomerun to populate. Once youve activated the tuner it should only be used to tune into the channel you direct it to in Emby. The guide should be totally separate and populate unless there is a failure to do so between Emby and Schedules Direct. On a side note, my Tablo is on Ebay so Im really hoping this is resolved before it sells lol. If it does have something to do with the recent firmware update, it probably changed the way the tuners reply to certain commands issued by the Server. If the server sends a request to the tuner and expects a reply in a certain format, changing that format can cause all sorts of problems. If this is the case, I'm sure the Emby developers will figure it out and be able to implement a fix in the server code.
TylerV76 84 Posted August 22, 2017 Posted August 22, 2017 (edited) Ok another reply from Schedules direct which seems to verify its not on their end. So it would appear this is either an issue in emby or the hdhomerun update somehow broke the EPG. I can still tune to those channels but I dont have any guide data for them. This is the first part of the lineup:{ "map": [{ "stationID": "19600", "uhfVhf": 7, "atscMajor": 2, "atscMinor": 1 }, { "stationID": "35451", "uhfVhf": 7, "atscMajor": 2, "atscMinor": 2 }, { "stationID": "94750", "uhfVhf": 7, "atscMajor": 2, "atscMinor": 3 }, { "stationID": "98069", "uhfVhf": 7, "atscMajor": 2, "atscMinor": 4 }, { "stationID": "20359", "uhfVhf": 45, "atscMajor": 4, "atscMinor": 1 }, { "stationID": "35449", "uhfVhf": 45, "atscMajor": 4, "atscMinor": 2 }, { "stationID": "40547", "uhfVhf": 45, "atscMajor": 4, "atscMinor": 3 }, {You can see that 4.1 is in there, and it's stationID 20359.The lineup hasn't been touched since:"metadata": { "lineup": "USA-OTA-48092", "modified": "2017-07-25T01:47:26Z", "transport": "Antenna" }So, 3 weeks ago?stationID 20359 has data:{ "stationID": "20359", "programs": [{ "programID": "EP008298780360", "airDateTime": "2017-08-23T00:00:00Z", "duration": 7260, "md5": "A6GqcpCK\/Bf3zgNO6FXWwA", "liveTapeDelay": "Live", "new": true, "audioProperties": ["cc", "DD 5.1", "stereo], "videoProperties": ["HD 1080i", "hdtv", "letterbox"], "ratings": [{ "body": "USA Parental Rating", "code": "TVPG" }], "programData": { "resourceID": "187477", "programID": "EP008298780360", "titles": [{ "title120": "America's Got Talent" }], "descriptions": { "description1000": [{ "descriptionLanguage": "en", "description": "Twelve acts perform live." }] }, "originalAirDate": "2017-08-22", "genres": ["Reality", "Variety", "Music", "Comedy", "Dance"], "episodeTitle150": "Live Show 2", "metadata": [{ "Gracenote": { "season": 12, "episode": 15 } }], "contentRating": [{ "body": "Australian Classification Board", "code": "PG", "country": "AUS" }, { "body": "Canadian Parental Rating", "code": "14+", "country": "CAN" }, { "body": "Departamento de Justi\u00e7a, Classifica\u00e7\u00e3o, T\u00edtulos e Qualifica\u00e7\u00e3o", "code": "12", "country": "BRA" }, { "body": "Film & Publication Board", "code": "10", "country": "ZAF" }, { "body": "USA Parental Rating", "code": "TVPG", "country": "USA" }], "cast": [{ "billingOrder": "05", "role": "Host", "nameId": "71052", "personId": "71052", "name": "Tyra Banks" }], "crew": [{ "billingOrder": "01", "role": "Judge", "nameId": "298266", "personId": "294389", "name": "Simon Cowell" }, { "billingOrder": "01", "role": "Executive Producer", "nameId": "298266", "personId": "294389", "name": "Simon Cowell" }, { "billingOrder": "02", "role": "Judge", "nameId": "75587", "personId": "75587", "name": "Melanie Brown" }, { "billingOrder": "02", "role": "Executive Producer", "nameId": "834838", "personId": "796232", "name": "Sam Donnelly" }, { "billingOrder": "03", "role": "Judge", "nameId": "81943", "personId": "81943", "name": "Heidi Klum" }, { "billingOrder": "03", "role": "Executive Producer", "nameId": "274797", "personId": "271204", "name": "Ken Warwick" }, { "billingOrder": "04", "role": "Judge", "nameId": "1082", "personId": "1082", "name": "Howie Mandel" }, { "billingOrder": "04", "role": "Executive Producer", "nameId": "274796", "personId": "271203", "name": "Cecile Frot-Coutaz" }, { "billingOrder": "05", "role": "Executive Producer", "nameId": "422814", "personId": "413939", "name": "Jason Raff" }, { "billingOrder": "06", "role": "Executive Producer", "nameId": "845708", "personId": "806277", "name": "Trish Kinane" }, { "billingOrder": "07", "role": "Executive Producer", "nameId": "757224", "personId": "725726", "name": "Richard Wallace" }, { "billingOrder": "08", "role": "Executive Producer", "nameId": "541146", "personId": "521869", "name": "Georgie Hurford-Jones" }], "entityType": "Episode", "showType": "Series", "hasImageArtwork": true, "hasSeriesArtwork": true, "md5": "A6GqcpCK\/Bf3zgNO6FXWwA" } }, { "programID": "EP016672640061", "airDateTime": "2017-08-23T02:01:00Z", "duration": 3540, "md5": "lL18xjShRGeoh2oAzCjo8g", "new": true, "audioProperties": ["cc", "DD 5.1", "stereo"], "videoProperties": ["HD 1080i", "hdtv", "letterbox"], "ratings": [{ "body": "USA Parental Rating", "code": "TV14" }], "programData": { "resourceID": "9660538", "programID": "EP016672640061", "titles": [{ "title120": "Hollywood Game Night" }], "descriptions": { "description100": [{ "descriptionLanguage": "en", "description": "Mel B., Darius Rucker, Sherri Shepherd, David Feherty, Derek Hough and Andy Richter." }], "description1000": [{ "descriptionLanguage": "en", "description": "Celebrity contestants Mel B., Darius Rucker, Sherri Shepherd, David Feherty, Derek Hough and Andy Richter." }] }, "originalAirDate": "2017-08-22", "genres": ["Game show"], "episodeTitle150": "HGN's Got Talent", "metadata": [{ "Gracenote": { "season": 5, "episode": 7 } }], "contentRating": [{ "body": "Canadian Parental Rating", "code": "14+", "country": "CAN" }, { "body": "USA Parental Rating", "code": "TV14", "country": "USA" }], "cast": [{ "billingOrder": "01", "role": "Host", "nameId": "224010", "personId": "221495", "name": "Jane Lynch" }, { "billingOrder": "02", "role": "Guest", "nameId": "539921", "personId": "75587", "name": "Mel B." }, { "billingOrder": "03", "role": "Guest", "nameId": "67947", "personId": "67947", "name": "Darius Rucker" }, { "billingOrder": "04", "role": "Guest", "nameId": "225461", "personId": "222893", "name": "Sherri Shepherd" }, { "billingOrder": "05", "role": "Guest", "nameId": "589152", "personId": "564899", "name": "David Feherty" }, { "billingOrder": "06", "role": "Guest", "nameId": "538526", "personId": "520347", "name": "Derek Hough" }, { "billingOrder": "07", "role": "Guest", "nameId": "173427", "personId": "172148", "name": "Andy Richter" }], "crew": [{ "billingOrder": "01", "role": "Executive Producer", "nameId": "153066", "personId": "86955", "name": "Sean Hayes" }, { "billingOrder": "02", "role": "Executive Producer", "nameId": "646590", "personId": "624973", "name": "Todd Milliner" }, { "billingOrder": "03", "role": "Executive Producer", "nameId": "342750", "personId": "333876", "name": "Michael Agbabian" }, { "billingOrder": "04", "role": "Executive Producer", "nameId": "434610", "personId": "425735", "name": "Dwight D. Smith" }, { "billingOrder": "05", "role": "Executive Producer", "nameId": "272484", "personId": "268898", "name": "Michael Binkow" }], "entityType": "Episode", "showType": "Series", "hasImageArtwork": true, "hasSeriesArtwork": true, "md5": "lL18xjShRGeoh2oAzCjo8g" } }, { Edited August 22, 2017 by TylerV76
csadoian 36 Posted August 22, 2017 Author Posted August 22, 2017 Yes, I have been able to tune the channels that are missing guide data. I just click on the channel in the guide. Can't record anything on those channels. Like I mentioned before, the guide data is showing up in NextPVR, and it also shows up in the HDHomeRun VIEW app. It's only Emby that is having issues with it. I am leaning towards the firmware update from Silicon Dust doing something that changed the command syntax slightly, and the Emby Server is having trouble dealing with it. Note to self: Wait a month before updating firmware. In fact, in the future I might take the attitude "If it ain't broke, don't fix it!"
TylerV76 84 Posted August 23, 2017 Posted August 23, 2017 Yes, I have been able to tune the channels that are missing guide data. I just click on the channel in the guide. Can't record anything on those channels. Like I mentioned before, the guide data is showing up in NextPVR, and it also shows up in the HDHomeRun VIEW app. It's only Emby that is having issues with it. I am leaning towards the firmware update from Silicon Dust doing something that changed the command syntax slightly, and the Emby Server is having trouble dealing with it. Note to self: Wait a month before updating firmware. In fact, in the future I might take the attitude "If it ain't broke, don't fix it!" Yeah I agree, once this gets fixed Im done updating the hdhomerun.
Chuck 17 Posted August 23, 2017 Posted August 23, 2017 After resetting HDHomeRun Prime, selecting favorites, updating SchedulesDirect, and running the guide refresh, I'm getting multiple channels not showing guide information. I'm attaching images of what's seen, as well as a log file from a guide refresh. server-63639028046.txt
csadoian 36 Posted August 23, 2017 Author Posted August 23, 2017 Here is the changelog for release 20170815: Release 20170815:Update to work with new Silicondust guide servers. Support broadcasts where multiple PMTs are on the same PID with intermixed sequence numbers. Support broadcasts where one video ES is shared by multiple programs. Increase the amount of video data that can be buffered. Improvements to XML processing. Improvements to system logging and diagnostic logging. Add support for upgrading the firmware via the device webpage. Add X-HDHomeRun-Error HTTP header to provide additional information when a stream request is rejected. Drop RUI support until a TV with RUI support is available. CC/DC models: Fix problem where Ethernet could stall and stop receiving packets. HDHR4 models: Support SSDP multicast test. Legacy models: Update to work with new Silicondust guide servers. Something tells me the line "Update to work with new Silicondust guide servers" is the root cause of what we are experiencing.
TylerV76 84 Posted August 23, 2017 Posted August 23, 2017 (edited) Same as the discussion going on here: https://emby.media/community/index.php?/topic/50228-guide-problems/ By any chance did you update your hdhomerun lately? SchedulesDirect says theres no issue on their end. Im missing the same channels as you but on an OTA connect device. Edited August 23, 2017 by TylerV76
TylerV76 84 Posted August 23, 2017 Posted August 23, 2017 (edited) Here is the changelog for release 20170815: Release 20170815:Update to work with new Silicondust guide servers. Support broadcasts where multiple PMTs are on the same PID with intermixed sequence numbers. Support broadcasts where one video ES is shared by multiple programs. Increase the amount of video data that can be buffered. Improvements to XML processing. Improvements to system logging and diagnostic logging. Add support for upgrading the firmware via the device webpage. Add X-HDHomeRun-Error HTTP header to provide additional information when a stream request is rejected. Drop RUI support until a TV with RUI support is available. CC/DC models: Fix problem where Ethernet could stall and stop receiving packets. HDHR4 models: Support SSDP multicast test. Legacy models: Update to work with new Silicondust guide servers. Something tells me the line "Update to work with new Silicondust guide servers" is the root cause of what we are experiencing. Another user just posted the same guide issues. Ill be curious if he updated also. edit: Yep he updated also. ugh. https://emby.media/community/index.php?/topic/50237-live-tv-guide-not-showing-guide-information/ Edited August 23, 2017 by TylerV76
Chuck 17 Posted August 23, 2017 Posted August 23, 2017 There was a problem with the tv, so i installed a new hdhomerun. Turns out it was the cable signal. After the tech fixed the signal problem, I put the original hdhomerun back into service, including pairing and re-signaling. I did update the hdhomerun firmware at the same time I was working on this. I also opened a case with schedules direct, and they replied that they had all of the information on their side. I sent them the same log file and images I posted here. No word back yet.
TylerV76 84 Posted August 23, 2017 Posted August 23, 2017 ok so your hdhomerun is on 20170815 now? If so that appears to be the issue. The 3 of us with the problem all updated our devices and it appears it broke something in emby.
Chuck 17 Posted August 23, 2017 Posted August 23, 2017 Sorry ... I opened a new topic ... from the other post .... After resetting HDHomeRun Prime, selecting favorites, updating SchedulesDirect, and running the guide refresh, I'm getting multiple channels not showing guide information.I'm attaching images of what's seen, as well as a log file from a guide refresh. There was a problem with the tv, so i installed a new hdhomerun. Turns out it was the cable signal. After the tech fixed the signal problem, I put the original hdhomerun back into service, including pairing and re-signaling. I did update the hdhomerun firmware at the same time I was working on this.I also opened a case with schedules direct, and they replied that they had all of the information on their side. I sent them the same log file and images I posted here. No word back yet. server-63639028046.txt
Chuck 17 Posted August 23, 2017 Posted August 23, 2017 Interesting ... Moving this discussion to original thread ... https://emby.media/community/index.php?/topic/50228-guide-problems/?p=479565
Chuck 17 Posted August 23, 2017 Posted August 23, 2017 Oops ... PS again: PS: Emby Server 3.2.28.0, Windows 10
