revengineer 142 Posted August 9, 2017 Posted August 9, 2017 Just a quick report on issues with download for offline viewing. When offline mode was introduced a few weeks ago, I reported problems with downloading content for offline viewing away from home. It seemed to work when when connected to my home network so I thought it was the mediocre hotel internet. These days I am again on travel and have exactly the same issues. The transcoding seems to work fine, and the transfer start after completion of transcoding. However, the download never finishes. I also find that the download notification keeps flashing constantly when I pull down the android notifications window, which is rather annoying. I also tried downloading the original without transcoding. This download did not complete either. On the other hand, I have been streaming TV from emby for the past hour without interruption, so the connection works and the internet is decent. I conclude that downloading content from emby to android devices is buggy.
Luke 42243 Posted August 9, 2017 Posted August 9, 2017 Can you please provide an android app log? You can learn how to do that here: https://emby.media/community/index.php?/topic/15638-how-to-report-an-android-problem/ Thanks.
revengineer 142 Posted August 10, 2017 Author Posted August 10, 2017 (edited) Luke, I have trouble finding the logs. I found a folder /data/data/com.mb.android/files but there is no logs folder inside. Do I need to enable logging? I noticed that the synced content path in offline sync settings is empty again, but on attempt to set it the app crashes every time. This is on the latest beta. not sure how to proceed. Edited August 10, 2017 by revengineer
zeyoner 4 Posted August 22, 2017 Posted August 22, 2017 I too have experienced this issue. But I have also had this issue when I used Plex. So I think neither side has really figured it out. It's spotty which sucks because this is one of the features I really want to use. Have there been any updates?
revengineer 142 Posted August 22, 2017 Author Posted August 22, 2017 I would liked to provide input but cannot locate the logs. I have asked for help with respect to this but not received an answer.
Luke 42243 Posted August 23, 2017 Posted August 23, 2017 I would liked to provide input but cannot locate the logs. I have asked for help with respect to this but not received an answer. It would be in your device's pre-defined external storage folder for apps (not the same as SD card). It might be a good idea to display this in the app so that you can easily locate it, because it will vary per device and that's probably what's going on here.
revengineer 142 Posted August 23, 2017 Author Posted August 23, 2017 It would be in your device's pre-defined external storage folder for apps (not the same as SD card). It might be a good idea to display this in the app so that you can easily locate it, because it will vary per device and that's probably what's going on here. I did find the com.mb.android folder, but there is no logs folder anywhere inside this. Displaying this in the app would help indeed so I can say for sure whether or not the folder exists. 1
Luke 42243 Posted August 25, 2017 Posted August 25, 2017 Please try the next release of the app, thanks.
revengineer 142 Posted August 25, 2017 Author Posted August 25, 2017 Please try the next release of the app, thanks. I am on the beta track and did not find any updates today or the past days. Will keep looking.
revengineer 142 Posted August 27, 2017 Author Posted August 27, 2017 Selecting sync folder still crashes app, still cannot find log file. Submitted crash report through android.
revengineer 142 Posted August 27, 2017 Author Posted August 27, 2017 When I click OK after browsing to the folder where I want to store the sync files.
Luke 42243 Posted August 27, 2017 Posted August 27, 2017 What device and android version? This isn't a custom ROM by chance is it?
revengineer 142 Posted August 27, 2017 Author Posted August 27, 2017 I also notice that on the settings screen, the playback and offline sync are just as plain green circles without an icon inside. Not sure whether this is a bug or work to go.
revengineer 142 Posted August 27, 2017 Author Posted August 27, 2017 This is a Moto X (2nd gen) with Android 4.4.4. I am running a rooted stock rom. It's an older device but still works well and I used to be able to select the sync folder.
guynamedbilly 18 Posted August 28, 2017 Posted August 28, 2017 I am also getting this on my Samsung Galaxy Tab Pro 10.1 on android 4.4.2 on the factory rom, not rooted. I tried to find the error message, but it does not generate an error log file. The folder is empty. Anytime I try to set the offline path, it crashes immediately. I did report it from that little window that pops up.
revengineer 142 Posted August 28, 2017 Author Posted August 28, 2017 Glad to hear there is someone else with the same issue. Maybe it is Android 4.4.x issue. I would like to help with the issue in the OP. I am going on travel again next week, and crappy wifi seems to be common to US hotels so I am sure I won't be disappointed. However, I will need the logs to work. For this, the first step is for the app to display where the logs are stored. I am pretty sure no logs are generated on my device but I cannot say for sure until the emby app tells me where they are supposed to be. If we fix the logging, I can run some tests next week.
revengineer 142 Posted September 1, 2017 Author Posted September 1, 2017 @Luke: i updated the Android app to v2.9.51 and it fixed both the crash with setting the path and creation of the log file. This means that I will be able to supply log files for instances where the sync over internet fail. THANK YOU!!!
revengineer 142 Posted September 2, 2017 Author Posted September 2, 2017 I tried syncing another movie. Upon selecting download in the Android app, the movie starts transcoding. When transcoding finishes, I select the gear icon next to "My Downloads" on main screen it the movie is listed "ready to transfer". But it never transfers. I see the error below in the server log. 2017-09-02 15:05:36.259 Info HttpServer: HTTP Response 200 to 192.168.1.70. Time: 2ms. http://192.168.1.50:8096/emby/Sync/Jobs?TargetId=c1f796b6bac2f7e2 2017-09-02 15:05:36.737 Error App: Error sending web socket message SyncJobs *** Error Report *** Version: 3.2.30.0 Command line: C:\Users\admin\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\admin\AppData\Roaming\Emby-Server Application directory: C:\Users\admin\AppData\Roaming\Emby-Server\system System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException) at System.Guid.TryParseGuidWithNoStyle(String guidString, GuidResult& result) at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result) at System.Guid..ctor(String g) at Emby.Server.Implementations.Library.UserManager.GetUserById(String id) at Emby.Server.Sync.SyncRepository.GetJobs(SyncJobQuery query) at Emby.Server.Sync.SyncManager.GetJobs(SyncJobQuery query) at Emby.Server.Sync.Api.SyncJobsWebSocketListener.<GetDataToSend>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Sync.Api.BasePeriodicWebSocketListener`2.<SendData>d__19.MoveNext() System.FormatException at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException) at System.Guid.TryParseGuidWithNoStyle(String guidString, GuidResult& result) at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result) at System.Guid..ctor(String g) at Emby.Server.Implementations.Library.UserManager.GetUserById(String id) at Emby.Server.Sync.SyncRepository.GetJobs(SyncJobQuery query) at Emby.Server.Sync.SyncManager.GetJobs(SyncJobQuery query) at Emby.Server.Sync.Api.SyncJobsWebSocketListener.<GetDataToSend>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Sync.Api.BasePeriodicWebSocketListener`2.<SendData>d__19.MoveNext()
Luke 42243 Posted September 2, 2017 Posted September 2, 2017 Can you please attach the complete log file? thanks.
revengineer 142 Posted September 2, 2017 Author Posted September 2, 2017 Here it is together with the transcode log. server-63639907200.txt transcode-b33bee1e-0cac-46ec-a18a-3122b6c5b43d.txt
revengineer 142 Posted September 2, 2017 Author Posted September 2, 2017 And here is the Android log.
kkot 0 Posted September 5, 2017 Posted September 5, 2017 (edited) not working , ready to transfer ,but never downloads server-63640179491.txt 4d6c8ade-af7c-464a-8845-4d159279f283.log S7 SM-G930V, android ver 7.0 Edited September 6, 2017 by kkot
Luke 42243 Posted September 5, 2017 Posted September 5, 2017 not working , ready to transfer ,but never downloads server-63640179491.txt 4d6c8ade-af7c-464a-8845-4d159279f283.log Capture.PNG What device and version of android? thanks.
