FordGT90Concept 103 Posted June 8, 2017 Author Posted June 8, 2017 Checking now... Hmm, working fine now. Not sure what happened but it seems to have passed, whatever it was.
mwongjay 74 Posted June 9, 2017 Posted June 9, 2017 (edited) Emby server: v3.2.19.6 Just switched the server to beta and live tv isn't working. Invalid decoder type 'mpeg2video' Edited June 9, 2017 by mwongjay
Luke 42245 Posted June 9, 2017 Posted June 9, 2017 Emby server: v3.2.19.6 Just switched the server to beta and live tv isn't working. Invalid decoder type 'mpeg2video' Try the next beta. We thank you for being a part of the beta testing team. Thanks !
mwongjay 74 Posted June 9, 2017 Posted June 9, 2017 Please attach the emby server and ffmpeg log. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks ! Weird. I selected the files, but it didn't auto upload.. Did that change?
mwongjay 74 Posted June 9, 2017 Posted June 9, 2017 Switched back to 3.2.19.0 and live tv works again. If you guys release a new beta version that fixes the issue let me know and I'll switch back and test it out.
mwongjay 74 Posted June 10, 2017 Posted June 10, 2017 Emby server: v3.2.19.7 Live tv is still not being deinterlaced!
FordGT90Concept 103 Posted June 10, 2017 Author Posted June 10, 2017 I tried 3.2.19.6. Audio desync'd from video immediately, then it started pausing about 5 minutes in every 30 seconds or so. Just updated to 3.2.19.7 and "too many errors" again. Submitted logs from Android TV under user "Lynn." Logs attached. Live TV is too broken to be usable again. logs.zip
ebr 16337 Posted June 10, 2017 Posted June 10, 2017 I tried 3.2.19.6. Audio desync'd from video immediately, then it started pausing about 5 minutes in every 30 seconds or so. Just updated to 3.2.19.7 and "too many errors" again. Submitted logs from Android TV under user "Lynn." Logs attached. Live TV is too broken to be usable again. Exact same thing from the app's perspective. The stream simply isn't coming through for some reason. All of these different results with different server versions may be coincidental and we may just be dealing with some sort of intermittent environmental issue here.
FordGT90Concept 103 Posted June 10, 2017 Author Posted June 10, 2017 (edited) They started after updating to 3.2.19.5 on server. Didn't have this issue at all on 3.2.19.0 and older. Nothing has changed here environmentally in that period. No hints in the server log? Edited June 10, 2017 by FordGT90Concept
mini__me 28 Posted June 10, 2017 Posted June 10, 2017 Seeing issues with just my FireTV with playback of certain channels. Sent logs from the app Roughly 17:35 GMT User Steve Three logs sent all trying different options to try and playback ITV HD. Same channel plays back fine on my Sony Android TV. Are my issues related to this topic or separate and need a new thread?
mwongjay 74 Posted June 10, 2017 Posted June 10, 2017 Thanks @@Luke, @@ebr for your work on fixing the deinterlacing. Version 3.2.19.8 has finally resolved the deinterlacing for live tv!
ebr 16337 Posted June 10, 2017 Posted June 10, 2017 Seeing issues with just my FireTV with playback of certain channels. Sent logs from the app Roughly 17:35 GMT User Steve Three logs sent all trying different options to try and playback ITV HD. Same channel plays back fine on my Sony Android TV. Are my issues related to this topic or separate and need a new thread? The player is definitely having trouble reading the stream. It probably worked on your Android TV because it has built-in support for mpeg-2 (the native codec for live TV) since it is an actual TV. Therefore, the TV was probably direct streaming it while the Fire is forced to transcode. So, we will probably need to see server and transcode logs.
mwongjay 74 Posted June 10, 2017 Posted June 10, 2017 Thanks @@Luke, @@ebr for your work on fixing the deinterlacing. Version 3.2.19.8 has finally resolved the deinterlacing for live tv! Or not.. Deinterlacing appears to be an issue with specific channels. transcode-log-working.txt
mini__me 28 Posted June 10, 2017 Posted June 10, 2017 Would a FireTV 2 help....I'd rather just buy new hardware to replace the FireTV 1 rather than face the wrath of the wife again :-|
FordGT90Concept 103 Posted June 12, 2017 Author Posted June 12, 2017 3.2.19.8 seems to be working a lot better, however, I noticed a problem since changing to the Live TV -> On Now, Channels, Guide, etc. menu: the information doesn't update frequently enough. For example, I was watching one program from about 6:55 to 7:02, decided I didn't like what came on at 7:00 and went to search for something else to watch by hitting the back button to see the guide again. It was still showing everything based on 6:30 instead of refreshing to 7:00. I had to hit back again (out of Live TV entirely) then back into Live TV to force a refresh. There was also a minor audio sync issue but HDHomeRun app was doing the same (and much worse at that) so it might be something to do with the HDHomeRun firmware moreso than software.
FordGT90Concept 103 Posted June 12, 2017 Author Posted June 12, 2017 Yeah I can but then the guide scrolling issue rears its head on when scrolling past shows that are over 30 minutes long and staggered. Fixing the left most item to current via refreshing the guide is the best way to maintain usability.
ebr 16337 Posted June 12, 2017 Posted June 12, 2017 Yeah I can but then the guide scrolling issue rears its head on when scrolling past shows that are over 30 minutes long and staggered. What issue is that?
FordGT90Concept 103 Posted June 12, 2017 Author Posted June 12, 2017 #2 in this thread: https://emby.media/community/index.php?/topic/41028-some-tv-guide-suggestions/ It would require writing a new control for handling the guide which isn't on the agenda. Simplest solution is to remove the expired data so it doesn't happen.
mwongjay 74 Posted June 12, 2017 Posted June 12, 2017 I think it would be good to keep to the topic of live tv pausing, pixelation, and deinterlacing and create a new topic for issues related to the guide
FordGT90Concept 103 Posted June 14, 2017 Author Posted June 14, 2017 (edited) Live TV broke again. Submitted logs from Lauren on the device (latest beta). He was basically trying to channel surf and then all requests for Live TV just dump back at the previous screen. Web access can't tune at all. Tried to restart server (3.2.20.3). It froze. Tried again from the shortcut, same result. Tried to downgrade to 3.2.20.0, setup threw an exception. Emby Server is FUBAR Edit: Submitted logs from the device under local user Lauren at the time. Forgot to mention that. logs.zip setup.zip Edited June 14, 2017 by FordGT90Concept
mwongjay 74 Posted June 14, 2017 Posted June 14, 2017 Live TV broke again. Submitted logs from Lauren on the device (latest beta). He was basically trying to channel surf and then all requests for Live TV just dump back at the previous screen. Web access can't tune at all. Tried to restart server (3.2.20.3). It froze. Tried again from the shortcut, same result. Tried to downgrade to 3.2.20.0, setup threw an exception. Emby Server is FUBAR I am also on 20.3 and don't experience these issues. I reviewed the commits and supposedly live tv deinterlacing was "fixed", but I'm still having issues deinterlacing certain channels (HGTV, ABC-HD, CNN, and several others). The stream is deinterlaced when viewing through the web app, but not on Fire tv
ebr 16337 Posted June 15, 2017 Posted June 15, 2017 I am also on 20.3 and don't experience these issues. I reviewed the commits and supposedly live tv deinterlacing was "fixed", but I'm still having issues deinterlacing certain channels (HGTV, ABC-HD, CNN, and several others). The stream is deinterlaced when viewing through the web app, but not on Fire tv What version of the Fire TV app (please don't say "latest" )?
