Guest asrequested Posted May 19, 2017 Posted May 19, 2017 I think this is related to this thread https://emby.media/community/index.php?/topic/47642-new-theater-user-with-some-questions/page-2&do=findComment&comment=451124 The issue is very similar and share the same solution.
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 battery had died on my mousepad.. that's why I couldn't choose another refresh rate... 23hz sorted it.. frame rate switching not working??? What we've done here, is to circumvent the GPU needing to increase the frame rate, and and be under that heavy load. I'm willing to bet that if you switch back to 59 and watch your CPU usage, it will max it out.
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 That doesn't explain why it works natively in mpv tho does it?
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 I think this is related to this thread https://emby.media/community/index.php?/topic/47642-new-theater-user-with-some-questions/page-2&do=findComment&comment=451124 The issue is very similar and share the same solution. I said it was terribly slow at start up and thru menus also.. I think you're right @ Can I get a copy of that electron u have see if it resolves my issues?
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 (edited) That doesn't explain why it works natively in mpv tho does it? I think electron is involved in what is happening. Mpv standalone obviously doesn't use electron. Edited May 19, 2017 by Doofus 1
Lee 212 Posted May 19, 2017 Author Posted May 19, 2017 I'm going to try that portable version of emby see if it works..
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 I'm unable to provide a link, right now. I copied mine from and older version, pre-mpv
Luke 42243 Posted May 19, 2017 Posted May 19, 2017 doofus could you help him capture mpv logging from both standalone mpv as well as embedded with in the app? thanks !
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 doofus could you help him capture mpv logging from both standalone mpv as well as embedded with in the app? thanks ! Yeah, I was thinking about that. It'll have to wait until tonight, though. I'm not able to dig into this, right now.
Guest asrequested Posted May 19, 2017 Posted May 19, 2017 (edited) One thing though, @@Luke, they both report the same juddering/slow responding UI. That isn't going to be in the mpv log. When we resolve the UI issue, playback is also resolved. I'm not sure the mpv logs are going to show much, if anything. At GPU 23Hz, everything operates much better. Edited May 19, 2017 by Doofus 1
Luke 42243 Posted May 20, 2017 Posted May 20, 2017 So why not leave it at 23hz? Or is that a problem?
Lee 212 Posted May 20, 2017 Author Posted May 20, 2017 @@Luke the screen res appears over size and sharpness is not as good in other applications at 23hz
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 OK. So in a little bit, I'll get you setup for MPv logging, so Luke can compare what's happening. Luke, I had Lee test with older electron, and there was improvement. Especially in the UI. Playback still not perfect, but we'll see what's happening in the logs
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 Before I get the logging setup, try the latest test build. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/ 1
Lee 212 Posted May 20, 2017 Author Posted May 20, 2017 been out most the day, just got round to downloading the test version will report back asap
Lee 212 Posted May 20, 2017 Author Posted May 20, 2017 the ui is definitely better/quicker playback is a bit better too not as good as on the test build you sent me. is intel quicksync going to be available at any point? perhaps that might help me??? i'm puzzled as to what happened after it was working fine a few builds ago though??? soooo frustrating
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 the ui is definitely better/quicker playback is a bit better too not as good as on the test build you sent me. is intel quicksync going to be available at any point? perhaps that might help me??? i'm puzzled as to what happened after it was working fine a few builds ago though??? soooo frustrating Ok so I'm going to help you with logging
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 (edited) Here's the standalone. Audio pass-through, deinterlacing and auto copyback are enabled, too. In the mpv.conf, you'll need to change the drive location (in red) to where you've unzipped it. log-file="E:\Downloads\mpv\portable_config\logs\log.txt" For Theater, go to AppData\Roaming\mpv, make an mpv.conf file (make a text file and change .txt to .conf), and add log-file=" your path to log file " Choose a different location. When testing, only test one file at a time. As soon as you test another file, the previous log file will be written over. Play a file, then post that log. Edited May 20, 2017 by Doofus
Luke 42243 Posted May 20, 2017 Posted May 20, 2017 What electron version exactly led to UI improvement? if it was 1.3.15, does 1.4.16 have the same improvement? https://github.com/electron/electron/releases/tag/v1.4.16
Lee 212 Posted May 20, 2017 Author Posted May 20, 2017 @@Luke the old electron and the one in the emby test build both gave improvements. i'll have to look at this tomorrow some time now..
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 What electron version exactly led to UI improvement? if it was 1.3.15, does 1.4.16 have the same improvement? https://github.com/electron/electron/releases/tag/v1.4.16
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 1.4.16 also resolves my window dragging issue.
Luke 42243 Posted May 20, 2017 Posted May 20, 2017 I'm more concerned about ui performance between versions.
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 (edited) I never had that issue, @@Lee and @@themimperials will have to test that. The version I gave to them, was the one I posted Edited May 20, 2017 by Doofus
Lee 212 Posted May 20, 2017 Author Posted May 20, 2017 1.7.1 is in the new test build that one and the one in doofus test build work better for me
