zenwryly 6 Posted April 10, 2017 Posted April 10, 2017 https://github.com/MediaBrowser/Emby/issues/2574 When I install `emby-server`, `emby-server-beta`, or `emby-server-dev` under Ubuntu 16.10 using `deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10/ /`, I get the following error when starting the service: Apr 10 12:36:41 media-server emby-server[15531]: System.TypeInitializationException: The type initializer for 'NLog.Common.InternalLogger' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Error Initializing the configuration system. ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section <appSettings> (/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe.config line 9) Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigInfo.ThrowException (System.String text, System.Xml.XmlReader reader) [0x00007] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.SectionGroupInfo.ReadContent (System.Xml.XmlReader reader, System.Configuration.Configuration config, System.Boolean overrideAllowed, System.Boolean root) [0x00170] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.SectionGroupInfo.ReadRootData (System.Xml.XmlReader reader, System.Configuration.Configuration config, System.Boolean overrideAllowed) [0x00007] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.ReadConfigFile (System.Xml.XmlReader reader, System.String fileName) [0x000ec] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.Load () [0x00052] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.Init (System.Configuration.Internal.IConfigSystem system, System.String configPath, System.Configuration.Configuration parent) [0x00065] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration..ctor (System.Configuration.InternalConfigurationSystem system, System.String locationSubPath) [0x0005c] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.InternalConfigurationFactory.Create (System.Type typeConfigHost, System.Object[] hostInitConfigurationParams) [0x0000e] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.OpenExeConfigurationInternal (System.Configuration.ConfigurationUserLevel userLevel, System.Reflection.Assembly calling_assembly, System.String exePath) [0x00107] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.get_Configuration () [0x00011] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: --- End of inner exception stack trace --- Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.get_Configuration () [0x00030] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection (System.String configKey) [0x00000] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.GetSection (System.String sectionName) [0x00005] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.get_AppSettings () [0x00000] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.GetSettingString (System.String configName, System.String envName) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.GetSetting[T] (System.String configName, System.String envName, T defaultValue) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.Reset () [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger..cctor () [0x00010] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: --- End of inner exception stack trace --- Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Config.LoggingConfiguration.Dump () [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.LogFactory.set_Configuration (NLog.Config.LoggingConfiguration value) [0x0006f] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.LogManager.set_Configuration (NLog.Config.LoggingConfiguration value) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at Emby.Common.Implementations.Logging.NlogManager..ctor (System.String logDirectory, System.String logFileNamePrefix) [0x00043] in <3f2b57224a3e41debfce9f9a4ec723c4>:0 Apr 10 12:36:41 media-server emby-server[15531]: at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00044] in <dd98a272d3c7417dab6b45c61dfc5a8f>:0 Apr 10 12:36:41 media-server emby-server[15531]: [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'NLog.Common.InternalLogger' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Error Initializing the configuration system. ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section <appSettings> (/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe.config line 9) Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigInfo.ThrowException (System.String text, System.Xml.XmlReader reader) [0x00007] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.SectionGroupInfo.ReadContent (System.Xml.XmlReader reader, System.Configuration.Configuration config, System.Boolean overrideAllowed, System.Boolean root) [0x00170] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.SectionGroupInfo.ReadRootData (System.Xml.XmlReader reader, System.Configuration.Configuration config, System.Boolean overrideAllowed) [0x00007] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.ReadConfigFile (System.Xml.XmlReader reader, System.String fileName) [0x000ec] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.Load () [0x00052] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration.Init (System.Configuration.Internal.IConfigSystem system, System.String configPath, System.Configuration.Configuration parent) [0x00065] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.Configuration..ctor (System.Configuration.InternalConfigurationSystem system, System.String locationSubPath) [0x0005c] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server systemd[1]: emby-server.service: Main process exited, code=exited, status=1/FAILURE Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.InternalConfigurationFactory.Create (System.Type typeConfigHost, System.Object[] hostInitConfigurationParams) [0x0000e] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.OpenExeConfigurationInternal (System.Configuration.ConfigurationUserLevel userLevel, System.Reflection.Assembly calling_assembly, System.String exePath) [0x00107] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.get_Configuration () [0x00011] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: --- End of inner exception stack trace --- Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.get_Configuration () [0x00030] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection (System.String configKey) [0x00000] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.GetSection (System.String sectionName) [0x00005] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at System.Configuration.ConfigurationManager.get_AppSettings () [0x00000] in <d6de850e07274db588ca7c247bfa5ec6>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.GetSettingString (System.String configName, System.String envName) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.GetSetting[T] (System.String configName, System.String envName, T defaultValue) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger.Reset () [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Common.InternalLogger..cctor () [0x00010] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: --- End of inner exception stack trace --- Apr 10 12:36:41 media-server emby-server[15531]: at NLog.Config.LoggingConfiguration.Dump () [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.LogFactory.set_Configuration (NLog.Config.LoggingConfiguration value) [0x0006f] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at NLog.LogManager.set_Configuration (NLog.Config.LoggingConfiguration value) [0x00000] in <8ea00faa812d4bf999fe44a51e324269>:0 Apr 10 12:36:41 media-server emby-server[15531]: at Emby.Common.Implementations.Logging.NlogManager..ctor (System.String logDirectory, System.String logFileNamePrefix) [0x00043] in <3f2b57224a3e41debfce9f9a4ec723c4>:0 Apr 10 12:36:41 media-server emby-server[15531]: at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00044] in <dd98a272d3c7417dab6b45c61dfc5a8f>:0
zenwryly 6 Posted April 10, 2017 Author Posted April 10, 2017 Via `apt` per the instructions on https://emby.media/linux-server.html. IOW, from the repo at https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server.
zenwryly 6 Posted April 10, 2017 Author Posted April 10, 2017 Why would the exact command matter? On Debian based systems installing via `apt`, `aptitude`, `synaptic`, a GUI apt front-end, or any other apt front-end, it doesn't matter. The packages dependencies will be resolved and all necessary packages are installed the same way. It is sufficient to say that I set up `/etc/apt/sources.list.d/emby-server.list` and imported the repo key as documented at the links above and installed the packages via apt. Here's proof if that's what you're looking for: root@media-server:~# apt-cache policy emby-server emby-server: Installed: 3.2.12-28.1 Candidate: 3.2.12-28.1 Version table: *** 3.2.12-28.1 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status
Luke 42245 Posted April 10, 2017 Posted April 10, 2017 In other words, I haven't seen this situation before, and when that happens the first thing I always want to ensure is that it was set up based on the instructions, and it looks like that is true here. Right now it looks like a missing dependency but I am not yet sure. What is your mono runtime version?
zenwryly 6 Posted April 10, 2017 Author Posted April 10, 2017 Thanks, here are the versions of all the installed mono packages: root@media-server:~# apt-cache policy $(aptitude search -F %p ~i~nmono) ca-certificates-mono: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages fonts-noto-mono: Installed: 20160724-1 Candidate: 20160724-1 Version table: *** 20160724-1 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages 100 /var/lib/dpkg/status libmono-2.0-dev: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages libmono-accessibility4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-cairo4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-cecil-private-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-cil-dev: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-codecontracts4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-compilerservices-symbolwriter4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-corlib4.5-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-cscompmgd0.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-csharp4.0c-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-custommarshalers4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-data-tds4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-db2-1.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-debugger-soft4.0a-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-http4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n-cjk4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n-mideast4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n-other4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n-rare4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n-west4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n4.0-all: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-i18n4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-ldap4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-management4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-messaging-rabbitmq4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-messaging4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-build-engine4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-build-framework4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-build-tasks-v4.0-4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-build-utilities-v4.0-4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-build4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-csharp4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-visualc10.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-microsoft-web-infrastructure1.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-oracle4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-parallel4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-peapi4.0a-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-posix4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-rabbitmq4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-relaxng4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-security4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-sharpzip4.84-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-simd4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-smdiagnostics0.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-sqlite4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-componentmodel-composition4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-componentmodel-dataannotations4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-configuration-install4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-configuration4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-core4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data-datasetextensions4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data-entity4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data-linq4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data-services-client4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data-services4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-data4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-deployment4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-design4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-drawing-design4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-drawing4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-dynamic4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-enterpriseservices4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-identitymodel-selectors4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-identitymodel4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-io-compression-filesystem4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-io-compression4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-json-microsoft4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-json4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-ldap-protocols4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-ldap4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-management4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-messaging4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-net-http-formatting4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-net-http-webrequest4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-net-http4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-net4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-numerics-vectors4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-numerics4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-core2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-debugger2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-experimental2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-interfaces2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-linq2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-observable-aliases0.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-platformservices2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-providers2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-runtime-remoting2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-windows-forms2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reactive-windows-threading2.2-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-reflection-context4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-runtime-caching4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-runtime-durableinstancing4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-runtime-interopservices-runtimeinformation4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-runtime-serialization-formatters-soap4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-runtime-serialization4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-runtime4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-security4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel-activation4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel-discovery4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel-internals0.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel-routing4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel-web4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-servicemodel4.0a-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-serviceprocess4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-threading-tasks-dataflow4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-transactions4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-abstractions4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-applicationservices4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-dynamicdata4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-extensions-design4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-extensions4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-http-selfhost4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-http-webhost4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-http4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-mobile4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-web-mvc3.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-razor2.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-regularexpressions4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-web-routing4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-services4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-webpages-deployment2.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-webpages-razor2.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web-webpages2.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-web4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-windows-forms-datavisualization4.0a-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-windows-forms4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-windows4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-workflow-activities4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-workflow-componentmodel4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-workflow-runtime4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status libmono-system-xaml4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-xml-linq4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-xml-serialization4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system-xml4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-system4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-tasklets4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-webbrowser4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-webmatrix-data4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-windowsbase4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmono-xbuild-tasks4.0-cil: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages libmonosgen-2.0-1: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages libmonosgen-2.0-dev: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages mono-4.0-gac: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages mono-csharp-shell: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages mono-devel: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages mono-gac: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages mono-mcs: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages mono-runtime: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages mono-runtime-common: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages mono-runtime-sgen: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages mono-xbuild: Installed: 4.6.2.7-0xamarin3 Candidate: 4.6.2.7-0xamarin3 Version table: *** 4.6.2.7-0xamarin3 500 500 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages 100 /var/lib/dpkg/status 4.2.1.102+dfsg2-7ubuntu4 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages ubuntu-mono: Installed: 16.10+16.10.20161024-0ubuntu1 Candidate: 16.10+16.10.20161024-0ubuntu1 Version table: *** 16.10+16.10.20161024-0ubuntu1 500 500 http://us.archive.ubuntu.com/ubuntu yakkety-updates/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety-updates/main i386 Packages 100 /var/lib/dpkg/status 16.10+16.10.20161007-0ubuntu1 500 500 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 Packages 500 http://us.archive.ubuntu.com/ubuntu yakkety/main i386 Packages
Luke 42245 Posted April 10, 2017 Posted April 10, 2017 what mono package is that? is it mono-complete? was it already there prior to attempting to install emby server?
zenwryly 6 Posted April 10, 2017 Author Posted April 10, 2017 How do you mean? What package is what? Those are the versions and sources of all installed packaged with `mono` in their name as per the command I used to generate that at the top of the code block.
