Luke 42241 Posted March 23, 2017 Posted March 23, 2017 Release notes here: https://emby.media/community/index.php?/topic/31461-emby-for-samsung-release-notes/ Enjoy !
Luke 42241 Posted March 24, 2017 Author Posted March 24, 2017 We are working on it. In the meantime, see here for a workaround that will allow you to install it: https://emby.media/community/index.php?/topic/45404-how-to-install-the-official-emby-app-on-a-samsung-smart-tv-outside-the-us/ Thanks !
CBers 7554 Posted March 24, 2017 Posted March 24, 2017 We are working on it. In the meantime, see here for a workaround that will allow you to install it: https://emby.media/community/index.php?/topic/45404-how-to-install-the-official-emby-app-on-a-samsung-smart-tv-outside-the-us/ Thanks ! No sorry, but I'm not hacking my TV for anyone. I'll wait.
Embyslav 0 Posted March 26, 2017 Posted March 26, 2017 workaround doesnt work. When you find emby in the store it says unable to connect to samsung server AS415 error
Luke 42241 Posted March 26, 2017 Author Posted March 26, 2017 Others have been able to do it. Where does it show that message exactly?
Embyslav 0 Posted March 26, 2017 Posted March 26, 2017 (edited) in the samsung smart hub, when i search for Emby, if finds it, but when i select it, it throws this error. And im from Europe and i set whole TV for USA. I then went searching for PLEX, if found it, selected it and downloaded it without problems Edited March 26, 2017 by Embyslav
Luke 42241 Posted March 26, 2017 Author Posted March 26, 2017 Ok that error sounds out of our control, sorry.
Embyslav 0 Posted March 26, 2017 Posted March 26, 2017 when can we expect emby on europe samsung tizen?
Luke 42241 Posted March 26, 2017 Author Posted March 26, 2017 We are working on worldwide availability, thanks ! 1
omniusaspirer 1 Posted March 27, 2017 Posted March 27, 2017 On my KS8000 the alphabetic navigation side bar is completely nonfunctional after this update, making navigation in large collections very painful. The vertical scrolling is pleasant otherwise however, much better usage of screen real estate.
Jadel 7 Posted March 27, 2017 Posted March 27, 2017 No sorry, but I'm not hacking my TV for anyone. I'll wait. lol. "hacking your tv" Good one.
schmitty 66 Posted March 29, 2017 Posted March 29, 2017 Using the workaround, is there a possibility it could damage the tv... or, is the disclaimer just to cover you guys legally? Sent from my iPhone using Tapatalk
CBers 7554 Posted March 29, 2017 Posted March 29, 2017 Using the workaround, is there a possibility it could damage the tv... or, is the disclaimer just to cover you guys legally? Following the instructions are at your own risk, as you could end up "bricking" the TV.
schmitty 66 Posted March 29, 2017 Posted March 29, 2017 Ok. Thought I'd ask, just to make sure... before I tell my sister to do it. Sent from my iPhone using Tapatalk
FrostByte 5453 Posted March 29, 2017 Posted March 29, 2017 (edited) I think most people who brick their tvs do so by messing around in the hidden service menu. I suppose anything is possible though The hidden service menu codes are different than the ones posted and can easily be found using Google, but you can change just about anything in the hidden service menu including the region. Edited March 29, 2017 by FrostByte
Embyslav 0 Posted April 2, 2017 Posted April 2, 2017 you cant brick tv by using the menu for region settings (voice up mute channel up etc... or whatever is the command)....
FrostByte 5453 Posted April 2, 2017 Posted April 2, 2017 Ya, the service menu is the only place I've ever heard of someone bricking their tv. You can change a lot of stuff in there.
Nightreaver 10 Posted April 2, 2017 Posted April 2, 2017 (edited) I think with this version some issues has been introduced - at least a few I know of/noticed. Maybe you remember i had issues with transcoding cause of subtitle, so i've goit all sub's removed. But transcoding started again. So here are issues I noticed 1. (med) "auto" quality setting issue - auto doesnt seem to detect resolution anymore correctly. I have to set to 4k 120mbs so its not automatically transcoded anymore 2. (high prio) audio - some of my video get transcoded cause they have 7.1 audio with is more than 5.1. I dont care, I want my AVR handle "downmixing" this, not app or the transcoder, this is just annoying. Please add same option for audio transcoding as you have for video transcoding - please! I notices cause I have a movie with dual language in 5.1 and 7.1, and 7.1 gets transcoded while 5.1 not. Or please tell me why this gets transcoded ( https://pastebin.com/swcwDBfu ) And why video has to be transcoded if just audio is wrong? 3. (med) switching audio - it didnt seem to switch audio unless I restart the movie. some audio show it's playing 2nd audio strem, even if it plays 1st 4. (low) subtitle - switching doesnt seem to work sometimes, also then you push up/down in any of these lists (ie audio, or subtitle) the "highlight" bar for current selection seem to disappear untlich you lick up/down again. Samsung KS8000 (tizen) , I think i got a firmware update today, also reinstalled emby Edited April 2, 2017 by Nightreaver
Luke 42241 Posted April 2, 2017 Author Posted April 2, 2017 @@Nightreaver, the best thing to do is please discuss a specific example and provide the information requested in how to report a media playback issue. thanks !
SamES 1084 Posted April 2, 2017 Posted April 2, 2017 4. (low) subtitle - switching doesnt seem to work sometimes, also then you push up/down in any of these lists (ie audio, or subtitle) the "highlight" bar for current selection seem to disappear untlich you lick up/down again. @@Luke, I have seen this one on more than one occasion. For some reason focusmanager gets confused and doesn't show any focused elements on the subtitle language selector (and possibly audio channel selector by the sounds of it). It's like it is focused on an element not visible in the list. I haven't had a chance to see what's going on with this yet.
Nightreaver 10 Posted April 3, 2017 Posted April 3, 2017 @@Nightreaver, the best thing to do is please discuss a specific example and provide the information requested in how to report a media playback issue. thanks ! https://emby.media/community/index.php?/topic/46486-transcoding-issue-on-tizen-emby-1022-samsung-ks8000/
Luke 42241 Posted April 6, 2017 Author Posted April 6, 2017 1.0.23 has launched: https://emby.media/community/index.php?/topic/46555-emby-for-samsung-tizen-1023-released/ Enjoy.
Blob 7 Posted April 21, 2017 Posted April 21, 2017 workaround doesnt work. When you find emby in the store it says unable to connect to samsung server AS415 error Hi, I had this same behavior, but changing the menu language to English and gave it some time it could download via the search. Cant browse it in the video category... /Regards 1
