dcook 303 Posted March 10, 2017 Posted March 10, 2017 I have some Library's that I want to scan often and others that do not change much at all. I would like to have the Scan Library Task changes to be per Library or even per Folder so that I can customize the Scans to suit the Library. This is required as Real Time Monitoring does not seem to work with Object Based File Systems like StorNext for example 2
tymanthius 18 Posted March 18, 2017 Posted March 18, 2017 As library scanning doesn't take that long, ~8 mins on 13TB here, I don't see much of a need for this. I would think the add'l overhead would outweigh the time savings. I think a better solution would be to search for fixes for the real time monitoring situation.
Happy2Play 9812 Posted June 23, 2017 Posted June 23, 2017 (edited) There is now a manual Individual Library Scan option. Edited June 23, 2017 by Happy2Play
