APL 0 Posted March 2, 2017 Posted March 2, 2017 I have tried and tried and cant get emby to install - what am i doing wrong ? i have ran the following sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' > /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install emby-server i get this and emby server wont start , fine on windows all working great "Cannot open assembly /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe : No Such file or directory" "Starting emby-server daemon /usr/lib/emby-server/ : No such file or directory Help Please !!
mastrmind11 722 Posted March 2, 2017 Posted March 2, 2017 (edited) I have tried and tried and cant get emby to install - what am i doing wrong ? i have ran the following sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' > /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install emby-server i get this and emby server wont start , fine on windows all working great "Cannot open assembly /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe : No Such file or directory" "Starting emby-server daemon /usr/lib/emby-server/ : No such file or directory Help Please !! Did you do this? wget http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key sudo apt-key add - < Release.key sudo apt-get update Then: sudo apt-get install emby-server ? Why 14.04 btw? Edited March 2, 2017 by mastrmind11
Luke 42245 Posted March 3, 2017 Posted March 3, 2017 Yea makes sure to run all of the required installation commands. To locate the commands for your distro, check out the download page of our website: https://emby.media/linux-server.html Let us know if this helps. Thanks !
APL 0 Posted March 3, 2017 Author Posted March 3, 2017 Did you do this? wget http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key sudo apt-key add - < Release.key sudo apt-get update Then: sudo apt-get install emby-server ? Why 14.04 btw? hosted dedicated server - 14.04 has been on for a while and don't want to lose my library by reinstalling , and yes I have added the release key
APL 0 Posted March 3, 2017 Author Posted March 3, 2017 Yea makes sure to run all of the required installation commands. To locate the commands for your distro, check out the download page of our website: https://emby.media/linux-server.html Let us know if this helps. Thanks ! Yes followed the instructions , still unable to start the emby-server service , keep getting starting emby-server daemon ..... fail
hurricanehrndz 149 Posted March 3, 2017 Posted March 3, 2017 Have you checked if the file or directory exists? Sent from my ONEPLUS A3000 using Tapatalk
Luke 42245 Posted March 13, 2017 Posted March 13, 2017 @@APL has this helped? please let us know. thanks !
