Luke 42240 Posted May 11, 2017 Posted May 11, 2017 ok thanks, i see it. give it another shot tomorrow.
Guest asrequested Posted May 12, 2017 Posted May 12, 2017 ok thanks, i see it. give it another shot tomorrow. Very well done, Luke!
Luke 42240 Posted May 12, 2017 Posted May 12, 2017 Very good. So now assuming direct access is possible, those folder rips should direct play. Anytime a folder rip has to transcode it is only experimental so you want to avoid that.
Guest asrequested Posted May 12, 2017 Posted May 12, 2017 Anytime a folder rip has to transcode it is only experimental so you want to avoid that. I'm not quite understanding, that. You mean you're still testing folder rip playback?
Luke 42240 Posted May 12, 2017 Posted May 12, 2017 We say that all over the community anytime people are trying to play folder rips from the web app or roku. it is only experimental therefore perfect playback should not be expected.
Guest asrequested Posted May 12, 2017 Posted May 12, 2017 Ah, gotcha. But as long as theater has direct access, we're good to go, right?
mystic.bertie 23 Posted May 12, 2017 Posted May 12, 2017 (edited) Last night i went to watch that particular movie that trans-codes, there was no surround sound going to my receiver, i went into the settings of Theatre to see if the audio settings had been changed, the audio settings section was missing and so was the video settings. I watched the movie in question using MPC-HC and it played fine, the movie played without fault and the chapters were all in order. I had hd surround too. Today i checked for a version update and i noticed there is a newer version of Theatre, i uninstalled the current one and installed the newest version, the video and audio setting were back. After opening and closing Theatre i noticed the video and audio settings are gone again. When i tried to play the problem movie it still trans-codes, it still plays the m2ts files in the wrong order i.e. 20 minute into the movie i get the ending and titles, when i try to skip forward it freezes. This movie played perfectly in MPC-HC. Theatre, Server and the movie files are all on the same machine. Edited May 12, 2017 by mystic.bertie
Luke 42240 Posted May 12, 2017 Posted May 12, 2017 If the audio and video settings are gone it means Windows DWM (Aero) has either stopped or crashed. We depend on that for windows transparency. Once that stops, we then disable the mpv player and revert to the embedded chromium video player, which will basically be the same as playing it in Chrome. Try rebooting your machine.
mystic.bertie 23 Posted May 12, 2017 Posted May 12, 2017 If the audio and video settings are gone it means Windows DWM (Aero) has either stopped or crashed. We depend on that for windows transparency. Once that stops, we then disable the mpv player and revert to the embedded chromium video player, which will basically be the same as playing it in Chrome. Try rebooting your machine. I rebooted and it made no difference. I uninstalled and then reinstalled and the settings returned, when i close Theatre i get a message saying 'electron has stopped working'. When i start Theatre the settings are gone, rebooting does not change anything. The dwm.exe process is still running in taskmanager.
mystic.bertie 23 Posted May 15, 2017 Posted May 15, 2017 Where should i be posting issues for the new version? I installed 2.7 today and things are worse. Still missing menu items, no surround sound, no - and X buttons to minimise or close, forcing it closed crashes electron, bluray folders dont play at all now, i get a spinning circle and then it goes away, no movie playback.
Guest asrequested Posted May 15, 2017 Posted May 15, 2017 I've seen a similar issue. Sometimes I've started (I think after an update) those have been missing or the UI is not as it should be. But when I close it, wait a minute, then restart, it corrects itself. I've also been replacing electron, due to another issue. Luke, could this be related to electron?
mystic.bertie 23 Posted May 17, 2017 Posted May 17, 2017 Today i tried the 2.7.1 version. I still have the same problem with the menu's. Electron is still crashing too when i force ET closed. ET is playing the bluray folders fine, skipping is possible but it is slow and pauses before playing again. These movies transcode and they are on the same pc as Theatre and Server. The movie i had problems with 'come and find me' still does not play in the correct order, i get the trailers 15 minutes into the movie, if i try and skip to the end it freezes. MPC-HC plays it fine.
Guest asrequested Posted May 17, 2017 Posted May 17, 2017 Do you want the trailers? I would just remove them all and only have the movie file. As for electron. Try replacing the electron folder/files with an older version.
Luke 42240 Posted May 17, 2017 Posted May 17, 2017 Please try the portable version here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/ and let me know the result. thanks.
mystic.bertie 23 Posted May 20, 2017 Posted May 20, 2017 Do you want the trailers? I would just remove them all and only have the movie file. As for electron. Try replacing the electron folder/files with an older version. No i dont want trailers, i just want the movie, this movie im having trouble with has a few m2ts files which make up the maain movie, the files are not played in the correct order, so 15 minns into the movie i get the titles which should be at the end, then it continues onto the next m2ts file. It may be a bad remux but MPCHC plays it fine. Should i just delete this movie and hope i dont get any other like that? How do you go about using an older version of electron, i downloaded electron but there was no exe file so i just forgot about it. Please try the portable version here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/ and let me know the result. thanks. Ok cheers Luke, ill try this over the next few days hopefully, working weekends at the moment and it sucks.
Luke 42240 Posted May 20, 2017 Posted May 20, 2017 You can just use the latest 2.72 because it has all the newest changes rolled in.
mystic.bertie 23 Posted May 20, 2017 Posted May 20, 2017 Today i got round to trying out 2.7.2 and its good new all round, everything is fixed apart from the pinning to the taskbar isuue which i can live with. The movies i tested were mkv and bluray folders. All movies direct played. They skipped forwards and backwards using the chapter and skip buttons with no problems and the skipping forward/ backwards was almost instant. The problem i movie i had with multiple m2ts files, that also played just fine and in the correct order. Theatre also opens and closes without issues and all menu items are still in place. Its great to see all the big issues fixed at once, great update indeed. Well done Luke, great work indeed.
xaras2 3 Posted November 15, 2020 Posted November 15, 2020 Hi, some problem here, restart mkv movie when try forward or backward. I have this issue only some mkv video played on my TV, Android APK, iPhone app. No problem if played the video with vlc for Windows. Server version: 4.5.2.0 on Ubuntu Mkv info: attached Please tell me some info. Thanks
Luke 42240 Posted November 17, 2020 Posted November 17, 2020 On 11/15/2020 at 6:21 PM, xaras2 said: Hi, some problem here, restart mkv movie when try forward or backward. I have this issue only some mkv video played on my TV, Android APK, iPhone app. No problem if played the video with vlc for Windows. Server version: 4.5.2.0 on Ubuntu Mkv info: attached Please tell me some info. Thanks But not all mkvs?
xaras2 3 Posted November 18, 2020 Posted November 18, 2020 On 11/17/2020 at 3:24 PM, Luke said: But not all mkvs? No all mkv, buy all mkv uploaded by some author. I think it depends on how the files work (you can see mkv info from my last screen). When recode the files all work perfectly.
Audiosleef 0 Posted December 11, 2020 Posted December 11, 2020 Hi @Luke I have the same issue, with MKV files. But the first episodes did not have this issue. Was there a solution to fix this?
Luke 42240 Posted December 12, 2020 Posted December 12, 2020 On 12/11/2020 at 4:51 PM, Audiosleef said: Hi @Luke I have the same issue, with MKV files. But the first episodes did not have this issue. Was there a solution to fix this? Hi there, sounds like an issue with the files. We'd have to go over an example. Thanks.
