itdaboyz 1 Posted February 19, 2017 Posted February 19, 2017 Hello, Here is my config at the moment : - Emby Server is on Asustor AS302T NAS. - Kodi with Emby for Kodi is on Rasberry Pi 2. It's usually working and sometimes sync drop and I have to reboot NAS, rPi and do a total resync on Kodi. Not the best so... And it's really slow when I try to access Emby via my phone. I'm thinking about dropping Emby server on my NAS and put everything on rPi to have something more stable. What do you think would be the best ? 1) Rasbian with Emby server and Kodi with Emby for Kodi 2) Rasbian with docker, Emby server for Docker and Kodi with Emby for Kodi 3) Rasbian with Emby server and Emby Theater 4) Rasbian with docker, Emby server for Docker and Emby Theater 5) Keep the NAS for the server Thank you!
Spaceboy 2573 Posted February 19, 2017 Posted February 19, 2017 I'm liking theatre on the pi 3. I have used Emby for Kodi at various points and it's nice but the sync breaks very regularly.
itdaboyz 1 Posted February 19, 2017 Author Posted February 19, 2017 Do you also have the server on the pi ? I wonder if it's not to much to handle.
Luke 42239 Posted February 19, 2017 Posted February 19, 2017 Hi, take a look here for instructions on setting up Emby Theater with Raspberry Pi: https://emby.media/community/index.php?/topic/42760-emby-theater-on-raspberry-pi/ And yes, Emby Server is supported, just use the normal linux install instructions.
itdaboyz 1 Posted February 22, 2017 Author Posted February 22, 2017 Ok so I tried this. Emby server is installed correctly (I had a lot of crash because of Anime plugin but now it seems ok) with this media paths : Animes /mnt/media/Animes Films /mnt/media/Films Musique /mnt/music Séries /mnt/media/Séries /mnt/media and /mnt/music are NFS mount of my NAS. I granted the right to access it and I can browse the folders on my pi without any problem.I'm not sure if I need path substitution. I tryed nfs://192.168.1.20/volume1/mnt/media/Séries for example and end up with the same result : can't get direct play. I have these errors in log : 2017-02-22 15:10:47.5024 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 16044640, max bitrate: 1649485 2017-02-22 15:10:47.5024 Info App: Profile: Unknown Profile, Path: /mnt/media/Films/Bad Moms (2016)/Bad Moms (2016) [Bluray-1080p].mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: False If it's any help, transcode.log : http://192.168.1.3:8096/emby/videos/35424c853d0aceceeeb8d9b1f933b95d/stream.mkv?DeviceId=raspberrypi&MediaSourceId=35424c853d0aceceeeb8d9b1f933b95d&VideoCodec=h264&AudioCodec=mp3,ac3,aac&AudioStreamIndex=1&SubtitleStreamIndex=3&VideoBitrate=1201485&AudioBitrate=448000&PlaySessionId=889b871bfac3412a827293a9f9d25486&api_key=07ec4f6f8b75410aae3259d6d60351cc&CopyTimestamps=false&SubtitleMethod=Embed&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=28076ae7292ba3b2315eeffb2cdcfb81&RequireAvc=false&SubtitleCodec=subrip {"Protocol":"File","Id":"35424c853d0aceceeeb8d9b1f933b95d","Path":"/mnt/media/Films/Bad Moms (2016)/Bad Moms (2016) [Bluray-1080p].mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/AC3","IsRemote":false,"ETag":"28076ae7292ba3b2315eeffb2cdcfb81","RunTimeTicks":60570238976,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"Bad.Moms.2016.MULTi.1080p.BluRay.DTS.HD-MA.x264.AC3-KiKi","DisplayTitle":"Eng Bad.Moms.2016.MULTi.1080p.BluRay.DTS.HD-MA.x264.AC3-KiKi","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":15596640,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":800,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"VFQ AC3 5.1 @ 448 Kbps","DisplayTitle":"Fre VFQ AC3 5.1 @ 448 Kbps","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"VO DTS HD MA 7.1 @ 4137Kbps","DisplayTitle":"Eng VO DTS HD MA 7.1 @ 4137Kbps","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"subrip","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"SRT Forcés (Homemade)","DisplayTitle":"Fre SRT Forcés (Homemade)","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0,"IsAnamorphic":false},{"Codec":"subrip","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"SRT Complets","DisplayTitle":"Fre SRT Complets","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"PGS Complets","DisplayTitle":"Fre PGS Complets","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":16044640,"RequiredHttpHeaders":{}} ffmpeg -i file:"/mnt/media/Films/Bad Moms (2016)/Bad Moms (2016) [Bluray-1080p].mkv" -map 0:0 -map 0:1 -map 0:3 -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 1201485 -bufsize 2402970 -vsync -1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -codec:s:0 copy -y "/var/lib/emby-server/transcoding-temp/79fc181d912682aadb5e42275c63ba74.mkv" ffmpeg version git-2017-02-19-aa2b752 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --arch=armhf --target-os=linux --enable-gpl --enable-libx264 --enable-nonfree libavutil 55. 47.100 / 55. 47.100 libavcodec 57. 80.101 / 57. 80.101 libavformat 57. 66.102 / 57. 66.102 libavdevice 57. 2.100 / 57. 2.100 libavfilter 6. 73.100 / 6. 73.100 libswscale 4. 3.101 / 4. 3.101 libswresample 2. 4.100 / 2. 4.100 libpostproc 54. 2.100 / 54. 2.100 [matroska,webm @ 0x27f6400] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:/mnt/media/Films/Bad Moms (2016)/Bad Moms (2016) [Bluray-1080p].mkv': Metadata: title : Bad.Moms.2016.MULTi.1080p.BluRay.DTS.HD-MA.x264.AC3-KiKi encoder : libebml v1.3.4 + libmatroska v1.4.5 creation_time : 2016-11-05T06:21:57.000000Z Duration: 01:40:57.02, start: 0.000000, bitrate: 15596 kb/s Chapter #0:0: start 0.000000, end 298.548000 Metadata: title : 00:00:00.000 Chapter #0:1: start 298.548000, end 557.056000 Metadata: title : 00:04:58.548 Chapter #0:2: start 557.056000, end 964.839000 Metadata: title : 00:09:17.056 Chapter #0:3: start 964.839000, end 1305.221000 Metadata: title : 00:16:04.839 Chapter #0:4: start 1305.221000, end 1606.271000 Metadata: title : 00:21:45.221 Chapter #0:5: start 1606.271000, end 1776.149000 Metadata: title : 00:26:46.271 Chapter #0:6: start 1776.149000, end 2135.508000 Metadata: title : 00:29:36.149 Chapter #0:7: start 2135.508000, end 2360.900000 Metadata: title : 00:35:35.508 Chapter #0:8: start 2360.900000, end 2681.012000 Metadata: title : 00:39:20.900 Chapter #0:9: start 2681.012000, end 2913.202000 Metadata: title : 00:44:41.012 Chapter #0:10: start 2913.202000, end 3223.178000 Metadata: title : 00:48:33.202 Chapter #0:11: start 3223.178000, end 3548.503000 Metadata: title : 00:53:43.178 Chapter #0:12: start 3548.503000, end 3864.110000 Metadata: title : 00:59:08.503 Chapter #0:13: start 3864.110000, end 4135.882000 Metadata: title : 01:04:24.110 Chapter #0:14: start 4135.882000, end 4443.856000 Metadata: title : 01:08:55.882 Chapter #0:15: start 4443.856000, end 4737.358000 Metadata: title : 01:14:03.856 Chapter #0:16: start 4737.358000, end 5028.982000 Metadata: title : 01:18:57.358 Chapter #0:17: start 5028.982000, end 5218.713000 Metadata: title : 01:23:48.982 Chapter #0:18: start 5218.713000, end 5579.073000 Metadata: title : 01:26:58.713 Chapter #0:19: start 5579.073000, end 6057.024000 Metadata: title : 01:32:59.073 Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: title : Bad.Moms.2016.MULTi.1080p.BluRay.DTS.HD-MA.x264.AC3-KiKi BPS : 10993246 BPS-eng : 10993246 DURATION : 01:40:57.010000000 DURATION-eng : 01:40:57.010000000 NUMBER_OF_FRAMES: 145223 NUMBER_OF_FRAMES-eng: 145223 NUMBER_OF_BYTES : 8323275231 NUMBER_OF_BYTES-eng: 8323275231 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Metadata: title : VFQ AC3 5.1 @ 448 Kbps BPS : 448000 BPS-eng : 448000 DURATION : 01:40:57.024000000 DURATION-eng : 01:40:57.024000000 NUMBER_OF_FRAMES: 189282 NUMBER_OF_FRAMES-eng: 189282 NUMBER_OF_BYTES : 339193344 NUMBER_OF_BYTES-eng: 339193344 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit) Metadata: title : VO DTS HD MA 7.1 @ 4137Kbps BPS : 4137053 BPS-eng : 4137053 DURATION : 01:40:57.014000000 DURATION-eng : 01:40:57.014000000 NUMBER_OF_FRAMES: 567845 NUMBER_OF_FRAMES-eng: 567845 NUMBER_OF_BYTES : 3132273632 NUMBER_OF_BYTES-eng: 3132273632 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(fre): Subtitle: subrip (default) Metadata: title : SRT Forcés (Homemade) BPS : 0 BPS-eng : 0 DURATION : 01:10:53.666000000 DURATION-eng : 01:10:53.666000000 NUMBER_OF_FRAMES: 13 NUMBER_OF_FRAMES-eng: 13 NUMBER_OF_BYTES : 461 NUMBER_OF_BYTES-eng: 461 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4(fre): Subtitle: subrip Metadata: title : SRT Complets BPS : 82 BPS-eng : 82 DURATION : 01:39:50.526000000 DURATION-eng : 01:39:50.526000000 NUMBER_OF_FRAMES: 1786 NUMBER_OF_FRAMES-eng: 1786 NUMBER_OF_BYTES : 61459 NUMBER_OF_BYTES-eng: 61459 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:5(fre): Subtitle: hdmv_pgs_subtitle Metadata: title : PGS Complets BPS : 14469 BPS-eng : 14469 DURATION : 01:39:50.526000000 DURATION-eng : 01:39:50.526000000 NUMBER_OF_FRAMES: 3573 NUMBER_OF_FRAMES-eng: 3573 NUMBER_OF_BYTES : 10834725 NUMBER_OF_BYTES-eng: 10834725 _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-11-05 06:21:57 _STATISTICS_WRITING_DATE_UTC-eng: 2016-11-05 06:21:57 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [libx264 @ 0x2ec8750] using SAR=399/400 [libx264 @ 0x2ec8750] using cpu capabilities: ARMv6 NEON [libx264 @ 0x2ec8750] profile Main, level 3.1 [libx264 @ 0x2ec8750] 264 - core 148 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=1201 vbv_bufsize=2402 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 Output #0, matroska, to '/var/lib/emby-server/transcoding-temp/79fc181d912682aadb5e42275c63ba74.mkv': Metadata: encoder : Lavf57.66.102 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1280x532 [SAR 399:400 DAR 12:5], q=-1--1, 23.98 fps, 1k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.80.101 libx264 Side data: cpb: bitrate max/min/avg: 1201000/0/0 buffer size: 2402000 vbv_delay: -1 Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Stream #0:2: Subtitle: subrip (default) Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy) Stream #0:3 -> #0:2 (copy) Press [q] to stop, [?] for help frame= 3 fps=0.0 q=0.0 size= 0kB time=00:00:00.48 bitrate= 0.0kbits/s speed=0.841x frame= 5 fps=4.5 q=0.0 size= 0kB time=00:00:00.48 bitrate= 0.0kbits/s speed=0.436x frame= 9 fps=5.6 q=0.0 size= 0kB time=00:00:00.99 bitrate= 0.0kbits/s speed=0.614x frame= 12 fps=5.6 q=0.0 size= 0kB time=00:00:00.99 bitrate= 0.0kbits/s speed=0.459x frame= 15 fps=5.6 q=0.0 size= 0kB time=00:00:00.99 bitrate= 0.0kbits/s speed=0.37x frame= 18 fps=5.6 q=0.0 size= 0kB time=00:00:01.24 bitrate= 0.0kbits/s speed=0.388x frame= 21 fps=5.6 q=17.0 size= 0kB time=00:00:01.24 bitrate= 0.0kbits/s speed=0.334x frame= 24 fps=5.6 q=20.0 size= 0kB time=00:00:01.24 bitrate= 0.0kbits/s speed=0.292x frame= 28 fps=5.7 q=19.0 size= 0kB time=00:00:01.76 bitrate= 0.0kbits/s speed=0.357x frame= 31 fps=5.7 q=19.0 size= 0kB time=00:00:01.76 bitrate= 0.0kbits/s speed=0.322x frame= 35 fps=5.7 q=19.0 size= 0kB time=00:00:01.76 bitrate= 0.0kbits/s speed=0.287x frame= 38 fps=5.7 q=18.0 size= 0kB time=00:00:02.01 bitrate= 0.0kbits/s speed=0.303x frame= 42 fps=5.8 q=18.0 size= 0kB time=00:00:02.01 bitrate= 0.0kbits/s speed=0.277x frame= 44 fps=5.7 q=19.0 size= 0kB time=00:00:02.04 bitrate= 0.0kbits/s speed=0.263x frame= 49 fps=5.8 q=17.0 size= 0kB time=00:00:02.27 bitrate= 0.0kbits/s speed=0.27x frame= 53 fps=5.9 q=17.0 size= 0kB time=00:00:02.52 bitrate= 0.0kbits/s speed=0.279x frame= 56 fps=5.8 q=19.0 size= 0kB time=00:00:02.78 bitrate= 0.0kbits/s speed=0.29x frame= 59 fps=5.8 q=19.0 size= 0kB time=00:00:02.78 bitrate= 0.0kbits/s speed=0.276x frame= 61 fps=5.7 q=17.0 size= 0kB time=00:00:02.81 bitrate= 0.0kbits/s speed=0.265x frame= 64 fps=5.7 q=19.0 size= 0kB time=00:00:03.04 bitrate= 0.0kbits/s speed=0.273x frame= 68 fps=5.8 q=19.0 size= 0kB time=00:00:03.04 bitrate= 0.0kbits/s speed=0.261x frame= 71 fps=5.7 q=20.0 size= 0kB time=00:00:03.29 bitrate= 0.0kbits/s speed=0.266x frame= 73 fps=5.6 q=20.0 size= 0kB time=00:00:03.55 bitrate= 0.0kbits/s speed=0.273x frame= 77 fps=5.6 q=21.0 size= 0kB time=00:00:03.55 bitrate= 0.0kbits/s speed=0.26x frame= 80 fps=5.6 q=23.0 size= 0kB time=00:00:03.55 bitrate= 0.0kbits/s speed=0.251x frame= 83 fps=5.6 q=23.0 size= 0kB time=00:00:03.80 bitrate= 0.0kbits/s speed=0.258x frame= 86 fps=5.6 q=23.0 size= 0kB time=00:00:03.80 bitrate= 0.0kbits/s speed=0.25x frame= 89 fps=5.6 q=22.0 size= 0kB time=00:00:04.06 bitrate= 0.0kbits/s speed=0.257x frame= 92 fps=5.6 q=24.0 size= 0kB time=00:00:04.06 bitrate= 0.0kbits/s speed=0.249x frame= 94 fps=5.6 q=23.0 size= 0kB time=00:00:04.32 bitrate= 0.0kbits/s speed=0.256x frame= 98 fps=5.6 q=24.0 size= 0kB time=00:00:04.32 bitrate= 0.0kbits/s speed=0.248x frame= 101 fps=5.6 q=23.0 size= 0kB time=00:00:04.57 bitrate= 0.0kbits/s speed=0.254x frame= 103 fps=5.6 q=25.0 size= 0kB time=00:00:04.57 bitrate= 0.0kbits/s speed=0.247x frame= 107 fps=5.6 q=26.0 size= 0kB time=00:00:04.83 bitrate= 0.0kbits/s speed=0.252x frame= 111 fps=5.6 q=28.0 size= 0kB time=00:00:04.96 bitrate= 0.0kbits/s speed=0.252x frame= 114 fps=5.6 q=29.0 size= 0kB time=00:00:04.96 bitrate= 0.0kbits/s speed=0.245x frame= 117 fps=5.6 q=27.0 size= 0kB time=00:00:05.21 bitrate= 0.0kbits/s speed=0.252x frame= 119 fps=5.6 q=29.0 size= 0kB time=00:00:05.24 bitrate= 0.0kbits/s speed=0.247x frame= 123 fps=5.7 q=26.0 size= 0kB time=00:00:05.47 bitrate= 0.0kbits/s speed=0.252x frame= 126 fps=5.7 q=29.0 size= 0kB time=00:00:05.47 bitrate= 0.0kbits/s speed=0.246x frame= 129 fps=5.7 q=28.0 size= 0kB time=00:00:05.72 bitrate= 0.0kbits/s speed=0.251x frame= 132 fps=5.6 q=29.0 size= 0kB time=00:00:05.72 bitrate= 0.0kbits/s speed=0.245x frame= 135 fps=5.6 q=30.0 size= 0kB time=00:00:05.82 bitrate= 0.0kbits/s speed=0.244x frame= 138 fps=5.7 q=32.0 size= 0kB time=00:00:06.08 bitrate= 0.0kbits/s speed=0.249x frame= 140 fps=5.6 q=32.0 size= 0kB time=00:00:06.33 bitrate= 0.0kbits/s speed=0.254x frame= 143 fps=5.6 q=27.0 size= 0kB time=00:00:06.33 bitrate= 0.0kbits/s speed=0.249x frame= 146 fps=5.6 q=27.0 size= 0kB time=00:00:06.59 bitrate= 0.0kbits/s speed=0.254x frame= 149 fps=5.6 q=29.0 size= 0kB time=00:00:06.59 bitrate= 0.0kbits/s speed=0.248x frame= 152 fps=5.6 q=29.0 size= 0kB time=00:00:06.59 bitrate= 0.0kbits/s speed=0.244x frame= 155 fps=5.6 q=29.0 size= 0kB time=00:00:06.75 bitrate= 0.0kbits/s speed=0.245x frame= 157 fps=5.6 q=30.0 size= 0kB time=00:00:06.78 bitrate= 0.0kbits/s speed=0.241x frame= 161 fps=5.6 q=31.0 size= 0kB time=00:00:07.00 bitrate= 0.0kbits/s speed=0.244x frame= 163 fps=5.6 q=31.0 size= 0kB time=00:00:07.04 bitrate= 0.0kbits/s speed=0.24x frame= 167 fps=5.6 q=31.0 size= 0kB time=00:00:07.26 bitrate= 0.0kbits/s speed=0.242x frame= 170 fps=5.6 q=28.0 size= 0kB time=00:00:07.52 bitrate= 0.0kbits/s speed=0.246x frame= 173 fps=5.6 q=30.0 size= 0kB time=00:00:07.52 bitrate= 0.0kbits/s speed=0.242x frame= 176 fps=5.6 q=29.0 size= 0kB time=00:00:07.61 bitrate= 0.0kbits/s speed=0.241x frame= 178 fps=5.5 q=31.0 size= 0kB time=00:00:07.64 bitrate= 0.0kbits/s speed=0.237x frame= 182 fps=5.5 q=31.0 size= 0kB time=00:00:07.87 bitrate= 0.0kbits/s speed=0.24x frame= 185 fps=5.5 q=30.0 size= 0kB time=00:00:08.12 bitrate= 0.0kbits/s speed=0.244x frame= 185 fps=5.2 q=-1.0 Lsize= 1374kB time=00:00:08.12 bitrate=1385.3kbits/s speed=0.229x video:924kB audio:446kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.296803% [libx264 @ 0x2ec8750] frame I:3 Avg QP: 9.17 size: 12521 [libx264 @ 0x2ec8750] frame P:58 Avg QP:17.82 size: 9492 [libx264 @ 0x2ec8750] frame B:124 Avg QP:18.52 size: 2883 [libx264 @ 0x2ec8750] consecutive B-frames: 3.8% 18.4% 6.5% 71.4% [libx264 @ 0x2ec8750] mb I I16..4: 84.7% 0.0% 15.3% [libx264 @ 0x2ec8750] mb P I16..4: 21.7% 0.0% 0.0% P16..4: 28.3% 0.0% 0.0% 0.0% 0.0% skip:50.0% [libx264 @ 0x2ec8750] mb B I16..4: 3.0% 0.0% 0.0% B16..8: 19.0% 0.0% 0.0% direct: 5.7% skip:72.3% L0:34.5% L1:42.9% BI:22.6% [libx264 @ 0x2ec8750] coded y,uvDC,uvAC intra: 49.6% 45.1% 17.6% inter: 6.1% 10.5% 0.2% [libx264 @ 0x2ec8750] i16 v,h,dc,p: 35% 34% 18% 12% [libx264 @ 0x2ec8750] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 45% 14% 2% 5% 1% 8% 1% 8% [libx264 @ 0x2ec8750] i8c dc,h,v,p: 47% 33% 11% 10% [libx264 @ 0x2ec8750] Weighted P-Frames: Y:3.4% UV:0.0% [libx264 @ 0x2ec8750] kb/s:980.38 Thank you for your help!
Luke 42239 Posted February 22, 2017 Posted February 22, 2017 Hi, those are not errors. To increase likelihood of direct play, ensure that the media is shared over your network and that in Emby library setup you've filled out the optional network path for each library folder. let us know if this helps. thanks.
itdaboyz 1 Posted February 23, 2017 Author Posted February 23, 2017 (edited) Ok, I did that with optionnal path link like this : /mnt/media/Films= \\NAS\media\Films Now some files are playing but not all. For exemple, the ones with AC3 or DTS audio won't direct play, like this one : http://paste.awesom.eu/SNxg or this one http://paste.awesom.eu/WQ9y I tried Emby Theater on my windows computer and it works for all files. Is there something I need to do to have these files in direct play on the pi ? Side question : Is it possible to define multiple optional path ? I would like to access my files from outside my network so \\NAS\media\Films won't work but MYIP/media/Films could. But in my network I want to stay on lan. Edited February 23, 2017 by itdaboyz
Luke 42239 Posted February 23, 2017 Posted February 23, 2017 It's due to burning in subtitles. OMXPlayer on Pi does not natively support those subtitle formats.
itdaboyz 1 Posted February 24, 2017 Author Posted February 24, 2017 Well that's a no-go for me then. I'll stay with Emby for Kodi. I'll keep an eye on Emby Theater to see how it goes. Thank you
