gabasr581 0 Posted February 12, 2017 Posted February 12, 2017 hello i am using emby-server on the first machine where i have all media (o.s. debian) and i am using a second machine with kodi as a client. How do i have to configure shared folder? media local path is /mnt/disk1/movie is it enough insert as shared folder this: //192.168.0.7/mnt/disk1/movie???do i have to change some folder permissions??do i have to use samba???i am really confused!!!:)thank you
Luke 42245 Posted February 12, 2017 Posted February 12, 2017 Hi, welcome. well first things first, are you having a problem? Thanks !
gabasr581 0 Posted February 12, 2017 Author Posted February 12, 2017 hi luke!no i haven't any problem with playback but i ve read that using shared folder the client can get access directly to the media without transcoding...so i would like to use this system!
mastrmind11 722 Posted February 15, 2017 Posted February 15, 2017 (edited) Share your folders (preferably via NFS since you're on Linux), point Emby server to the share, install the Emby for Kodi addon on your Kodi client, point it to your Emby server, let it scan. Voila. Edited February 15, 2017 by mastrmind11
Luke 42245 Posted February 15, 2017 Posted February 15, 2017 @@gabasr581, when you created your Emby libraries, did you fill out the optional network path for each library folder? if not, you can go back and do that by clicking on each folder and then entering the path. Let us know if this helps. thanks !
gabasr581 0 Posted February 15, 2017 Author Posted February 15, 2017 Yes i did it. local path is: /mnt/disk/movie "shared folder path" is: //192.168.0.7/mnt/disk/movie is it enough??thanks for your help!!!
Luke 42245 Posted February 15, 2017 Posted February 15, 2017 Hi @@gabasr581, the path looks OK to me, but only you can answer if it is a valid path on your network or not.
gabasr581 0 Posted February 16, 2017 Author Posted February 16, 2017 hi luke. Path is valid but i don't understand if i have to share folder via NFS too!
mastrmind11 722 Posted February 16, 2017 Posted February 16, 2017 hi luke. Path is valid but i don't understand if i have to share folder via NFS too! See post #5....
gabasr581 0 Posted February 16, 2017 Author Posted February 16, 2017 ops!!!thank you!!i didn't read that!!
gabasr581 0 Posted April 11, 2017 Author Posted April 11, 2017 hi guys,i wasn't able to get a good result! i shared folder by nfs; i can see the folder on my pc client (so i suppose that shared folder is working) but there is no way to get a direct access from kodi addon "emby for kodi". if i choose inside addon setting "native access" i get an error message because addon can't find any folder at net path //192.168.0.7/diskname/foldername...any suggestion?
Luke 42245 Posted April 11, 2017 Posted April 11, 2017 what did you fill out in emby library setup for that folder?
gabasr581 0 Posted April 11, 2017 Author Posted April 11, 2017 folder: /mnt/771e1f9b-c44c-4093-a89e-5805c0992110/Film shared folder (optional): //192.168.0.7/mnt/771e1f9b-c44c-4093-a89e-5805c0992110/Film thanks!
Luke 42245 Posted April 11, 2017 Posted April 11, 2017 From that point on, it is up to you to make sure the other machines can access: //192.168.0.7/mnt/771e1f9b-c44c-4093-a89e-5805c0992110/Film have you done that?
gabasr581 0 Posted April 11, 2017 Author Posted April 11, 2017 (edited) This is my exports file on server: # /etc/exports: the access control list for filesystems which may be exported # to NFS clients. See exports(5). # # Example for NFSv2 and NFSv3: # /srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check) ## Example for NFSv4: # /srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check) # /srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check) # /mnt/771e1f9b-c44c-4093-a89e-5805c0992110/Film 192.168.0.7 (rw,no_root_squash) 192.168.0.9 (rw,no_root_squash) 192.168.0.3 (rw,no_root_squash) /mnt/7f4b2b5b-d0f2-4714-96fa-25e84bb78e32/Film2 192.168.0.7 (rw,no_root_squash) 192.168.0.9 (rw,no_root_squash) 192.168.0.3 (rw,no_root_squash) i have no problem to see both folders on pc client (192.168.0.3). i'm not using kodi or emby on this machine. I have simply mounted the two folders on a local path and i can get access without any issue. on the other hand,When i try to sync emby from kodi on my HTPC (192.168.0.9) there is no way to get a direct access! Edited April 11, 2017 by gabasr581
Luke 42245 Posted April 12, 2017 Posted April 12, 2017 i have no problem to see both folders on pc client When you verify this, what path are you testing with?
gabasr581 0 Posted April 12, 2017 Author Posted April 12, 2017 On pc client i have installed nfs-common, then i've created these two folders: /mnt/nfs/film and /mnt/nfs/film2. I use this command for mounting the shared folders: sudo mount 192.168.0.7:/mnt/771e1f9b-c44c-4093-a89e-5805c0992110/Film /mnt/nfs/film sudo mount 192.168.0.7:/mnt/7f4b2b5b-d0f2-4714-96fa-25e84bb78e32/Film2 /mnt/nfs/film2 I can see the folders and the file inside by manage folder (idon't use emby or kodi on pc client)
Luke 42245 Posted April 12, 2017 Posted April 12, 2017 Ok, best thing to do is provide the info requested here, and then we can learn more about what's happening in the emby for kodi add-on. thanks.
gabasr581 0 Posted April 12, 2017 Author Posted April 12, 2017 hi luke, you can find my logfile at this link: https://paste.ubuntu.com/24369602/ thanks
Luke 42245 Posted April 13, 2017 Posted April 13, 2017 @@Angelblue05, he was an issue in his log with emby for kodi reporting the path is not found. can you confirm that in the log above and if so, what is generally the next step? he's using the optional network path feature, and when he tries to play from the add-on, he gets an error message. thanks !
Angelblue05 4132 Posted April 13, 2017 Posted April 13, 2017 (edited) When he switched the path mode, did he reset his database? Make sure the playback mode is set to addon under the addon's settings. Press Ok. Then, reset the database by launching the addon and scroll to the bottom, reset local database. That should resolves it. Edited April 13, 2017 by Angelblue05 1
gabasr581 0 Posted April 13, 2017 Author Posted April 13, 2017 (edited) Hi guys, i reset local DB. Do i have to change playback option from "native" to "addon"? Is not "native" the correct option for direct streaming (without transcoding)? Edited April 13, 2017 by gabasr581
