brontron4k 0 Posted February 6, 2017 Posted February 6, 2017 I'm experiencing an odd issue with video playback on Emby Theater for Xbox One. The video plays just fine, however the volume is significantly lower than it should be. Playing the same video using the built-in Media Player App playbacks with "normal" volume. I've tried restarting the app, re-downloading the app, signing in and out of my account, resetting the server, and nothing is able to resolve the issue. I have to turn my speakers up near max to approach appropriate listening levels. Obviously this isn't ideal as the rest of the system sounds are extremely loud at this setting.
Luke 42243 Posted February 6, 2017 Posted February 6, 2017 We have the app set to max volume, so at that point you just use the system volume. I vaguely recall someone else reporting this and it turned out to be something in system settings causing it.
xxJonoxx 4 Posted February 8, 2017 Posted February 8, 2017 (edited) https://emby.media/community/index.php?/topic/43150-sound-volume-output/ Try that. Had me baffled for a while. Edited February 8, 2017 by xxJonoxx
