CharleyVarrick 284 Posted February 24, 2017 Posted February 24, 2017 (edited) Sorry to nitpick, but the artist name should read: a-ha Edited February 24, 2017 by jlr19
Tremas 205 Posted February 24, 2017 Posted February 24, 2017 (edited) You're right. At least I was consistant (repeatible, but not accurate)! [edited post above] Edited February 24, 2017 by Tremas 1
yardameus 221 Posted February 26, 2017 Posted February 26, 2017 The new answer is to remove the metadata from your artist folder. This change was made to try and resolve Artist issues. So Emby will not write to Artist folder anymore. You are seeing the effects of reading existing metadata in Artist folder. So it no longer saves into the artist folder? Will that affect using Kodi? I'm not quite sure how much of the info Kodi gets from Emby server versus how much it get's from .nfo in music artist folder.
Happy2Play 9802 Posted February 26, 2017 Posted February 26, 2017 (edited) So it no longer saves into the artist folder? Will that affect using Kodi? I'm not quite sure how much of the info Kodi gets from Emby server versus how much it get's from .nfo in music artist folder. Have you seen this topic? Edited February 26, 2017 by Happy2Play 1
yardameus 221 Posted February 26, 2017 Posted February 26, 2017 (edited) No, I had not seen that topic. Shouldn't we have the option to save metadata into media folders removed? Edited February 26, 2017 by yardameus 1
damian 6 Posted March 19, 2017 Posted March 19, 2017 @@Luke Did you ever get to the bottom of this? I have a few duplicate artists and its very annoying. I can't get rid of them. Same as above. If I remove the artist both disappear after a scan. If I read the artist both appear again. I can confirm all tags are perfect in the source folders. The tags used to be wrong as in "Alice in Chains" and was "Alice In Chains" but after I fixed them the artist with the old tags would never disappear.
Happy2Play 9802 Posted March 19, 2017 Posted March 19, 2017 @@Luke Did you ever get to the bottom of this? I have a few duplicate artists and its very annoying. I can't get rid of them. Same as above. If I remove the artist both disappear after a scan. If I read the artist both appear again. I can confirm all tags are perfect in the source folders. The tags used to be wrong as in "Alice in Chains" and was "Alice In Chains" but after I fixed them the artist with the old tags would never disappear. Without manually finding the issue in the library.db and correcting the issue yourself, you will probably have to delete/backup (just in case) and rebuild it. But note your watched status is stored in that database now so you would need to use the Server Configuration Backup plugin.
yardameus 221 Posted March 19, 2017 Posted March 19, 2017 The new answer is to remove the metadata from your artist folder. This change was made to try and resolve Artist issues. So Emby will not write to Artist folder anymore. You are seeing the effects of reading existing metadata in Artist folder. This took care of the issue for me. Removed all the artist.nfo from the actual media folders. 1
skynet600 33 Posted September 12, 2017 Author Posted September 12, 2017 (edited) I am now duplicate free but where I had duplicates the titles I have now have a path pointing to appdata and not the artist folder. The duplicates also had one entry pointing to the artist folder but that went away after I removed the nfo file. What is the correct path? Edited September 12, 2017 by skynet600
Solution Happy2Play 9802 Posted September 12, 2017 Solution Posted September 12, 2017 Well the metadata should be only in one place. Emby by default will put it in appdata now on new installs. The conflict will come from old install and pre-existing metadata. Emby will read from both location, it just becomes a conflict when both locations have metadata. I personally prefer everything in artist folder so I move info from appdata to artist if it gets created there. 1
skynet600 33 Posted September 13, 2017 Author Posted September 13, 2017 I'm inclined to agree. I moved what was in appdata to artist and now things are consistent. There is a place to toggle "Saving metadata into media folder" under Music so I guess if enabled this will save to artist folder and not appdata? Also under library/advanced there is a metadata path. I guess the default here is appdata also. It would be nice if it showed the active path.
