Luke 42243 Posted October 19, 2017 Posted October 19, 2017 We're happy to look at your transcoding issue if you can see how to report a problem. thanks !
Home0002 0 Posted October 19, 2017 Posted October 19, 2017 In short, No. DS216play comes with different processor architecture and the only way to use it's hardware transcoding power is DS Video for now. Thank for your reply, currently having to use VLC player as a work around for now, not ideal but serves a purpose.
Home0002 0 Posted October 19, 2017 Posted October 19, 2017 We're happy to look at your transcoding issue if you can see how to report a problem. thanks ! Thanks Luke, I'm pretty new to all this, so I hope i have given you the correct report, my issue is transcoding speed is so slow, playback is as good as impossible, I have Emby installed on Synology DS216Play. Application version: 3.2.33.0 http://10.0.0.136:8096/emby/videos/8f32ec2c58ecf3c6332589638117975b/hls1/main/0.ts?DeviceId=7d5017127fc7e4cd&MediaSourceId=8f32ec2c58ecf3c6332589638117975b&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=20808000&AudioBitrate=192000&MaxAudioChannels=2&MaxFramerate=60&PlaySessionId=0604e9adfddd4fb4bd319d84ca1ca480&api_key=f4eafbfdca984e059bd1212da68edd4c&CopyTimestamps=true&SubtitleMethod=Encode&EnableSubtitlesInManifest=false&Tag=66c16b91b48fb99b20a70aa25b11f15a&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&mpeg2video-deinterlace=true&hevc-profile=none {"Protocol":"File","Id":"8f32ec2c58ecf3c6332589638117975b","Path":"/volume1/MyEmbyMedia/Record/Money for Nothing/Season 3/Money for Nothing S03E03.ts","Type":"Default","Container":"mpegts","Name":"1080P/H264/AAC_LATM","IsRemote":false,"ETag":"66c16b91b48fb99b20a70aa25b11f15a","RunTimeTicks":29378660352,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"EnableMpDecimate":false,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":true,"IsAVC":false,"BitRate":6057986,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac_latm","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC_LATM stereo","IsInterlaced":false,"ChannelLayout":"stereo","Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"dvbsub","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"0/1","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":6057986,"RequiredHttpHeaders":{}} User policy for Steve: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -f mpegts -i file:"/volume1/MyEmbyMedia/Record/Money for Nothing/Season 3/Money for Nothing S03E03.ts" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 6057986 -bufsize 12115972 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -vf "yadif=0:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f%d.ts" ffmpeg version 3.3.3-20170905T045951UTC Copyright © 2000-2017 the FFmpeg developers built with gcc 5.4.0 (GCC) configuration: --prefix=/var/packages/EmbyServer/target/ffmpeg --enable-cross-compile --cross-prefix=arm-linux-gnueabihf- --target-os=linux --disable-rpath --arch=arm --cpu=cortex-a9 --enable-thumb --enable-libzimg --enable-gpl --enable-shared --disable-static --disable-debug --disable-ffplay --disable-ffserver --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libfreetype --enable-fontconfig --enable-gray --enable-libfribidi --enable-libvidstab --disable-indev=sndio --disable-outdev=sndio --extra-version=20170905T045951UTC --extra-libs='-lm -ldl -lrt -lpthread -llzma -lz -lstdc++ ' libavutil 55. 58.100 / 55. 58.100 libavcodec 57. 89.100 / 57. 89.100 libavformat 57. 71.100 / 57. 71.100 libavdevice 57. 6.100 / 57. 6.100 libavfilter 6. 82.100 / 6. 82.100 libswscale 4. 6.100 / 4. 6.100 libswresample 2. 7.100 / 2. 7.100 libpostproc 54. 5.100 / 54. 5.100 [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] SPS unavailable in decode_picture_timing [h264 @ 0x113c890] non-existing PPS 0 referenced [h264 @ 0x113c890] decode_slice_header error [h264 @ 0x113c890] no frame! [h264 @ 0x113c890] mmco: unref short failure Last message repeated 4 times [h264 @ 0x113c890] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one [mpegts @ 0x1126230] PES packet size mismatch Last message repeated 1 times [mpegts @ 0x1126230] Could not find codec parameters for stream 2 (Unknown: none ([17][0][0][0] / 0x0011)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0x1126230] Could not find codec parameters for stream 4 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0x1126230] Could not find codec parameters for stream 5 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0x1126230] Could not find codec parameters for stream 6 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0x1126230] Could not find codec parameters for stream 7 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'file:/volume1/MyEmbyMedia/Record/Money for Nothing/Season 3/Money for Nothing S03E03.ts': Duration: 00:48:57.87, start: 38528.951289, bitrate: 6057 kb/s Program 17540 Stream #0:0[0x19c9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19ca](eng): Audio: aac_latm (LC) ([17][0][0][0] / 0x0011), 48000 Hz, stereo, fltp Stream #0:2[0x19ce](eng): Unknown: none ([17][0][0][0] / 0x0011) (visual impaired) Stream #0:3[0x19cd](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x1c86]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:5[0x1c97]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:6[0x1bc4]: Unknown: none ([5][0][0][0] / 0x0005) Stream #0:7[0x1bc6]: Unknown: none ([5][0][0][0] / 0x0005) Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (aac_latm (native) -> aac (native)) Press [q] to stop, [?] for help [h264 @ 0x1164780] mmco: unref short failure Last message repeated 1 times [h264 @ 0x1164780] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one frame= 0 fps=0.0 q=0.0 size=N/A time=-577014:32:22.77 bitrate=N/A speed=N/A [h264 @ 0x116a360] mmco: unref short failure Last message repeated 1 times frame= 0 fps=0.0 q=0.0 size=N/A time=-577014:32:22.77 bitrate=N/A speed=N/A [libx264 @ 0x1154900] using SAR=1/1 [libx264 @ 0x1154900] using cpu capabilities: ARMv6 NEON [libx264 @ 0x1154900] profile Main, level 4.1 [libx264 @ 0x1154900] 264 - core 148 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=3 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=6057 vbv_bufsize=12115 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 [segment @ 0x11530d0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f0.ts' for writing Output #0, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f%d.ts': Metadata: encoder : Lavf57.71.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], q=-1--1, 25 fps, 90k tbn, 25 tbc Metadata: encoder : Lavc57.89.100 libx264 Side data: cpb: bitrate max/min/avg: 6057000/0/0 buffer size: 12115000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.89.100 aac frame= 2 fps=1.3 q=0.0 size=N/A time=00:00:01.02 bitrate=N/A speed=0.651x frame= 6 fps=2.8 q=0.0 size=N/A time=00:00:01.21 bitrate=N/A speed=0.565x frame= 10 fps=3.7 q=0.0 size=N/A time=00:00:01.30 bitrate=N/A speed=0.485x frame= 14 fps=4.2 q=0.0 size=N/A time=00:00:01.47 bitrate=N/A speed=0.439x frame= 17 fps=4.3 q=0.0 size=N/A time=00:00:01.53 bitrate=N/A speed=0.393x frame= 19 fps=4.3 q=28.0 size=N/A time=00:00:01.60 bitrate=N/A speed=0.361x frame= 22 fps=4.4 q=28.0 size=N/A time=00:00:01.72 bitrate=N/A speed=0.348x frame= 25 fps=4.4 q=28.0 size=N/A time=00:00:01.84 bitrate=N/A speed=0.325x frame= 28 fps=4.5 q=28.0 size=N/A time=00:00:01.96 bitrate=N/A speed=0.317x frame= 31 fps=4.5 q=28.0 size=N/A time=00:00:02.26 bitrate=N/A speed=0.33x frame= 34 fps=4.6 q=28.0 size=N/A time=00:00:02.43 bitrate=N/A speed=0.329x frame= 37 fps=4.6 q=28.0 size=N/A time=00:00:02.68 bitrate=N/A speed=0.336x frame= 40 fps=4.7 q=28.0 size=N/A time=00:00:02.85 bitrate=N/A speed=0.333x frame= 43 fps=4.7 q=28.0 size=N/A time=00:00:02.90 bitrate=N/A speed=0.316x frame= 46 fps=4.7 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A speed=0.307x frame= 49 fps=4.7 q=28.0 size=N/A time=00:00:03.02 bitrate=N/A speed=0.293x frame= 52 fps=4.8 q=28.0 size=N/A time=00:00:03.07 bitrate=N/A speed=0.281x frame= 55 fps=4.8 q=28.0 size=N/A time=00:00:03.15 bitrate=N/A speed=0.274x frame= 58 fps=4.8 q=28.0 size=N/A time=00:00:03.17 bitrate=N/A speed=0.262x frame= 60 fps=4.8 q=28.0 size=N/A time=00:00:03.43 bitrate=N/A speed=0.272x frame= 63 fps=4.8 q=28.0 size=N/A time=00:00:03.66 bitrate=N/A speed=0.278x frame= 66 fps=4.8 q=28.0 size=N/A time=00:00:03.71 bitrate=N/A speed=0.27x frame= 69 fps=4.8 q=28.0 size=N/A time=00:00:03.77 bitrate=N/A speed=0.263x frame= 72 fps=4.8 q=28.0 size=N/A time=00:00:03.96 bitrate=N/A speed=0.265x frame= 75 fps=4.8 q=28.0 size=N/A time=00:00:04.03 bitrate=N/A speed=0.259x frame= 78 fps=4.8 q=28.0 size=N/A time=00:00:04.18 bitrate=N/A speed=0.259x frame= 81 fps=4.9 q=28.0 size=N/A time=00:00:04.30 bitrate=N/A speed=0.259x frame= 84 fps=4.8 q=28.0 size=N/A time=00:00:04.39 bitrate=N/A speed=0.252x frame= 87 fps=4.8 q=28.0 size=N/A time=00:00:04.65 bitrate=N/A speed=0.258x frame= 90 fps=4.8 q=28.0 size=N/A time=00:00:04.71 bitrate=N/A speed=0.253x frame= 92 fps=4.8 q=25.0 size=N/A time=00:00:04.73 bitrate=N/A speed=0.247x [segment @ 0x11530d0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f.m3u8.tmp' for writing [segment @ 0x11530d0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f1.ts' for writing frame= 95 fps=4.8 q=28.0 size=N/A time=00:00:04.88 bitrate=N/A speed=0.246x frame= 98 fps=4.8 q=28.0 size=N/A time=00:00:04.90 bitrate=N/A speed=0.239x frame= 100 fps=4.8 q=28.0 size=N/A time=00:00:04.92 bitrate=N/A speed=0.234x frame= 103 fps=4.8 q=28.0 size=N/A time=00:00:05.03 bitrate=N/A speed=0.232x frame= 106 fps=4.8 q=28.0 size=N/A time=00:00:05.08 bitrate=N/A speed=0.228x [segment @ 0x11530d0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/788e9655c714f45271f9249e7f19157f.m3u8.tmp' for writing frame= 107 fps=4.5 q=-1.0 Lsize=N/A time=00:00:05.80 bitrate=N/A speed=0.246x video:2356kB audio:124kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0x1154900] frame I:2 Avg QP:22.99 size: 90130 [libx264 @ 0x1154900] frame P:84 Avg QP:26.07 size: 23451 [libx264 @ 0x1154900] frame B:21 Avg QP:26.70 size: 12468 [libx264 @ 0x1154900] consecutive B-frames: 62.6% 31.8% 5.6% 0.0% [libx264 @ 0x1154900] mb I I16..4: 57.4% 0.0% 42.6% [libx264 @ 0x1154900] mb P I16..4: 14.2% 0.0% 0.0% P16..4: 22.3% 0.0% 0.0% 0.0% 0.0% skip:63.5% [libx264 @ 0x1154900] mb B I16..4: 2.5% 0.0% 0.0% B16..8: 18.1% 0.0% 0.0% direct: 8.4% skip:71.0% L0:39.4% L1:46.9% BI:13.7% [libx264 @ 0x1154900] coded y,uvDC,uvAC intra: 41.4% 23.6% 3.2% inter: 10.8% 4.1% 0.1% [libx264 @ 0x1154900] i16 v,h,dc,p: 38% 33% 16% 14% [libx264 @ 0x1154900] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 33% 23% 16% 3% 6% 4% 4% 5% 5% [libx264 @ 0x1154900] i8c dc,h,v,p: 42% 28% 26% 5% [libx264 @ 0x1154900] Weighted P-Frames: Y:0.0% UV:0.0% [libx264 @ 0x1154900] kb/s:4508.41 [aac @ 0x11563d0] Qavg: 596.494
solabc16 379 Posted October 19, 2017 Author Posted October 19, 2017 Hello @@Home0002 Thanks for getting in touch. As noted by @@sonny_life, at this time at least, 3rd parties are not able to access the transcoding h/w used in the DS216play (STM STiH412 / Faroudja Transcode Engine). It is something we keep an eye on. Are you able to consider using a different native format, so your devices can direct play instead? One final thing, if you are able, I'd appreciate if you could run the diagnostics and sendlogs utilities as this gives us more information to work with:- Run Diagnostics : https://github.com/M...Run-Diagnostics Send Support Logs : https://github.com/M...us-Support-Logs Best - James
Home0002 0 Posted October 19, 2017 Posted October 19, 2017 (edited) Hello @@Home0002 Thanks for getting in touch. As noted by @@sonny_life, at this time at least, 3rd parties are not able to access the transcoding h/w used in the DS216play (STM STiH412 / Faroudja Transcode Engine). It is something we keep an eye on. Are you able to consider using a different native format, so your devices can direct play instead? One final thing, if you are able, I'd appreciate if you could run the diagnostics and sendlogs utilities as this gives us more information to work with:- Run Diagnostics : https://github.com/M...Run-Diagnostics Send Support Logs : https://github.com/M...us-Support-Logs Best - James Hi @@solabc16 Thank for your reply. Currently I'm having to use VLC player as a work around, this, for me, enables direct play, however I have seemed to have lost the ability to fast forward or any type of seek, a small price to pay having to watch adverts. I have sent you a support log, I do hope this helps. Best Regards Steve ******************************************************************************** Upload completed successfully, please include this filename with your ticket... sendlogs_MediaServer_synology_monaco_ds216play_20171019T201209UTC.tgz ******************************************************************************** Edited October 19, 2017 by Home0002
johanbcn 0 Posted March 26, 2018 Posted March 26, 2018 I have been playing around with Emby on my DS214Play and overall it's working pretty good There are some files, though, that I can't transcode to chromecast. Seems that the ffmpeg command is not being built correctly: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: syntax error near unexpected token `min' /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: `sudo /usr/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 h264_smd -prefer_smd -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex [0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af volume=2 -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv"'
Luke 42243 Posted March 26, 2018 Posted March 26, 2018 @@johanbcn, please attach the complete ffmpeg log, thanks.
johanbcn 0 Posted March 26, 2018 Posted March 26, 2018 Sure: 2018-03-26 19:14:15.421 Application version: 3.3.1.0 http://192.168.1.254:8096/emby/videos/0f0d2acf630bd44d3a1b78f133c194e1/stream.mkv?DeviceId=VGVsZXZpc29yIGRlbCBzYWxu&MediaSourceId=0f0d2acf630bd44d3a1b78f133c194e1&VideoCodec=h264,vp8&AudioCodec=aac,mp3,opus,flac,vorbis&AudioStreamIndex=1&SubtitleStreamIndex=5&VideoBitrate=30000000&AudioBitrate=384000&PlaySessionId=57192d2c17544306b3f906ba7b1c2758&api_key=24a21ae504c74459932a26570e838f02&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&CopyTimestamps=true&RequireAvc=true&Tag=7089af471b627c74d677d0406db96d80&h264-profile=high,main,baseline,constrainedbaseline&h264-level=42&h264-deinterlace=true&audiochannels=2&TranscodeReasons=SubtitleCodecNotSupported&allowVideoStreamCopy=false&allowAudioStreamCopy=false {"Protocol":"File","Id":"0f0d2acf630bd44d3a1b78f133c194e1","Path":"/volume1/EmbyTest/movies/test.mkv","Type":"Default","Container":"mkv,webm","Name":"test.mkv","IsRemote":false,"ETag":"7089af471b627c74d677d0406db96d80","RunTimeTicks":64862400512,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"test","DisplayTitle":"1080P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":11926739,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":802,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"DTS-HD Master Audio / 7.1 / 48 kHz / 4892 kbps / 24-bit","DisplayTitle":"Eng DTS 7.1 Default","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"SDH","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"spa","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Spa","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Fre","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Forced","DisplayTitle":"Eng Default Forced","IsInterlaced":false,"IsDefault":true,"IsForced":true,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":11926739,"RequiredHttpHeaders":{}} User policy for johanbcn: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex "[0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af "volume=2" -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv" /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: syntax error near unexpected token `min' /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: `sudo /usr/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 h264_smd -prefer_smd -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex [0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af volume=2 -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv"' /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: syntax error near unexpected token `min' /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: `sudo /usr/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 h264_smd -prefer_smd -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex [0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af volume=2 -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv"'
Luke 42243 Posted March 26, 2018 Posted March 26, 2018 is that really the whole thing? because there is supposed to be lots of info in there pertaining to the ffmpeg build. can you please just attach the file?
johanbcn 0 Posted March 26, 2018 Posted March 26, 2018 (edited) There are a lot of log files, so I emptied the log directory, restarted the server and tried again. Here's the whole bunch of log files. logs.tar.gz Edited March 26, 2018 by johanbcn
johanbcn 0 Posted April 4, 2018 Posted April 4, 2018 I have been playing around with Emby on my DS214Play and overall it's working pretty good There are some files, though, that I can't transcode to chromecast. Seems that the ffmpeg command is not being built correctly: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: syntax error near unexpected token `min' /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg: eval: line 196: `sudo /usr/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 h264_smd -prefer_smd -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex [0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af volume=2 -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv"' Ok, I have figured it out. It's a message thrown by the shell, not by ffmpeg. The value of the filter_complex argument should be wrapped in double quotes for it to work correctly, such as this: sudo /usr/bin/ffmpeg -f matroska,webm -i file:"/volume1/EmbyTest/movies/test.mkv" -map 0:0 -map 0:1 -codec:v:0 h264_smd -prefer_smd -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -filter_complex "[0:5]scale=1920:802:force_original_aspect_ratio=decrease[sub];[0:0][sub]overlay,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 11926739 -bufsize 23853478 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af volume=2 -y "/var/packages/EmbyServer/target/var/transcoding-temp/2bdac344ba7c244f3e1acef886c0c5d1.mkv"
Darkjeje 11 Posted May 27, 2018 Posted May 27, 2018 Do you have any news to have transcoding options from the web menu for the ds214play ?
Luke 42243 Posted May 27, 2018 Posted May 27, 2018 Do you have any news to have transcoding options from the web menu for the ds214play ? Can you elaborate more on what exactly you're asking? Thanks !
Darkjeje 11 Posted May 28, 2018 Posted May 28, 2018 Can you elaborate more on what exactly you're asking? Thanks ! Hello Luke, I wanted to know if we could now have hardware transcoding without going through ssh but directly from the dashboard ? I wanted to know if we could now have hardware transcoding without going through ssh but directly from the dashboard 1
muppets4 24 Posted July 5, 2018 Posted July 5, 2018 Hello Luke, I wanted to know if we could now have hardware transcoding without going through ssh but directly from the dashboard ? I wanted to know if we could now have hardware transcoding without going through ssh but directly from the dashboard[/size] I was hoping for this too. Is there a possibility? 1
muppets4 24 Posted July 12, 2018 Posted July 12, 2018 (edited) After I did what was in the topic start I am not able to start any live TV anymore. The screen stays black with the circle that keeps circling (: I've added the ffmpeg log. And I can't seem to get it off again. I used sudo ./switchcomp ffmpeg 3.4.1 and it gives me a fail on validating version ffmpeg.txt Edited July 12, 2018 by muppets4
muppets4 24 Posted July 12, 2018 Posted July 12, 2018 Have you tried enabling vaapi? I tried. Makes no difference.
Luke 42243 Posted July 12, 2018 Posted July 12, 2018 Looks like an encoding failure. We'll see what @@solabc16 thinks. Thanks.
solabc16 379 Posted July 13, 2018 Author Posted July 13, 2018 Hello @@muppets4 Assuming you are running the latest stable, use 4.0 as the FFmpeg version - let me know how you get on. I'll take a look at making this a little more straightforward with the next stable; it is an experimental feature. Best - James
solabc16 379 Posted July 13, 2018 Author Posted July 13, 2018 (edited) Hello All On some of the other points, it's probably best to refer back to these posts... we'll keep looking at how to make the experience as good as it can be and make changes where it makes sense to do so. https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=443715 https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/?p=457952 Anybody who is running DSM 6.2 on their DS415play or DS214play system, it would helpful if you could run the following: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James Edited July 13, 2018 by solabc16
eevv 0 Posted July 27, 2018 Posted July 27, 2018 Installed the official Emby .spk from Synology Community Package Center On my Synology DS415PLAY Evansport with hardware transcoding capabilities Latest DSM 6.2-23739-2 and Emby version installed was 3.5.0.0-1 I then ran the SSH commands listed for DSM6 at the first post in this thread, like this: ------------------------------------- Using username . . password: :$ cd /var/packages/EmbyServer/scripts/utilities :/var/packages/EmbyServer/scripts/utilities$ sudo ./switchcomp ffmpeg 0.0.0.0 We trust you have received the usual lecture ffem the local System Administrator. It usually boils down to these three things: #1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility. Password: Script invoked as [./switchcemp] by [root]. File Version : 3.5.0.0—l This script enables you to safely switch versions of the internal components used by the package. PLEASE ONLY USE AS DIRECTED BY SUPPORT Type [yes] and press return to continue: yes Requested Cfimponent : ffmpeg Requested Version : 0.0.0 Validating Component : SUCCESS Validating Version : SUCCESS Component [ffmpeg] successfully switched to version [0.0.0]. *** Please stop and start Emby Server in Package Center for the changes to take effect. *** ------------------------------------- Restarted Emby both from the internal dashboard reboot and a start/stop from the package center One difference: I could not log in as "admin", login rejected, I logged in with my personal (admin) account, and I think the way it works in DSM at the moment is you can do sudo/root etc. kind of stuff as long as you are presented with the We trust you have received the usual lecture ffem the local System Administrator message first and then retype your password ? It looks from the output pasted above that the specified commands are carried out successfully even though I logged in as my own admin username not "admin" ? More important question - do you still have to do these SSH commands even though you install official spk directly from Synology package center ? If so it's really important so you get hw transcoding but there is no warning about this anywhere that I can see, I just came across these instructions on the forum. Most important question - after installing Emby and doing the SSH commands outlined above, under Server - Transcoding - Hardware Acceleration, which option do I choose ? There is no "auto" option as I have seen in other documentation. There is: AMD AMF Intel Quick Sync MediaCodec Android OpenMAX OMX Nvidia NVENC Video Acceleration API (VA API) Exonys V4L2 MFC Encoder I have searched thoroughly for anything in the DS415PLAY data sheets etc. for more information about which of these, if any, support the Intel Evansport CE5335 Atom processor. According to my research Intel Quick Sync it is not, in spite of Evansport being a Intel processor. Which option if any do I choose? Are the SSH commands still necessary even when you do a normal Synology package center Emby install ? How can I tell if transcoding is being used or not when I'm playing a file ? Many detailed questions, I know, I am an enthusiastic newbie and eager to learn, hope someone can help. Thank you.
Darkjeje 11 Posted July 29, 2018 Posted July 29, 2018 Hello James, I send my log, if I can help you with DSM 6.2. sendlogs_DiskstationJR_synology_evansport_214play_20180729T165749UTC.tgz
Luke 42243 Posted July 29, 2018 Posted July 29, 2018 hi @@eevv Are the SSH commands still necessary even when you do a normal Synology package center Emby install ? Have you followed our Synology install guide here? https://emby.media/nas-server.html How can I tell if transcoding is being used or not when I'm playing a file ? Yes the server dashboard will display this information. Many Emby apps also have ways to show this in the video player directly. Does this answer your question?
eevv 0 Posted July 30, 2018 Posted July 30, 2018 Yes have followed that guide So the FFMPEG change that I did was NOT necesssary and that documentation should not be out there then ? Could I have broken anything now ? It gives the impression this must be done in spite of official package etc., these installs should usually also set the shared folder permissions they need etc. too Yes I've seen the "stats for nerds" option for videos sometimes say "transcode". CPU etc goes up to over 90% for at least beginning of a transcoding movie (when I've checked it) and IMMEDIATELY cpu usage etc goes down when the movie is turnedoff ... but isnt transcoding supposed to be a dedicated hardware component that processes stuff the CPU otherwise would have done, thereby... so isn't supposed to transcode accompanied by high high CPU usage, while the others, "direct play" etc., my CPU usage is maybe 20% of the other scenario. - so from this I can at least conclude that there is no hw transcoding when I use the Synology Emby server ? ds415play tips reeived with thanks hi @@eevv Have you followed our Synology install guide here? https://emby.media/nas-server.html Yes the server dashboard will display this information. Many Emby apps also have ways to show this in the video player directly. Does this answer your question?
