Luke 42241 Posted October 26, 2022 Posted October 26, 2022 23 hours ago, TheNewRacket said: Hi! is there anyway to change screen orientation for Emby Theater RPi? I didn't see a setting poking around the menus, but it would really help me out if there was. Hi, do you mean aspect ratio during playback, or for browsing around the user interface?
mprasil 14 Posted October 26, 2022 Posted October 26, 2022 (edited) On 10/25/2022 at 7:24 PM, TheNewRacket said: Hi! is there anyway to change screen orientation for Emby Theater RPi? I didn't see a setting poking around the menus, but it would really help me out if there was. I'm not using Raspberry with Emby anymore, but if you want to change the orientation of the entire screen, Raspberry Pi should read the /boot/config.txt file on the SD card, where you can set display_hdmi_rotate value appropriately - see details in the docs. So for example, you could add display_hdmi_rotate=2 there to rotate it by 180 degrees. (upside down) Screen should be rotated depending on the value after you reboot. Edited October 26, 2022 by mprasil
Luke 42241 Posted November 4, 2022 Posted November 4, 2022 For those who have been unable to play using the .deb or RPI packages, can you try redownloading the 3.0.16 .deb and let us know how that compares? We've repackaged it with some library updates. We're also working on a 3.0.17 release with more updates but wanted to do a quick repackaging for now. Thanks ! 2
rdhardi 42 Posted November 4, 2022 Posted November 4, 2022 Never posted, but I had this problem on Ubuntu 22.04 so I've been on 3.0.14. When I tried 3.0.15 & 3.0.16, they never worked, just got spinning circle. Just redownloaded the new 3.0.16 .deb and it's working now. Thank you! 1
dedyms 2 Posted November 4, 2022 Posted November 4, 2022 (edited) The newer 3.0.16 got playback instead spinning circle but still not utilize hardware acceleration, im on amd igpu. There is logs about missing file, maybe related. OS: Bullseye AMD64 Logs: ❯ emby-theater Gtk-Message: 01:36:42.321: Failed to load module "colorreload-gtk-module" Gtk-Message: 01:36:42.321: Failed to load module "window-decorations-gtk-module" /opt/emby-theater/extra/share/libdrm/amdgpu.ids: No such file or directory Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: '' } ERROR: cec-client not installed, running without cec functionality. cec-client exited with code -2 UDP Client listening on 0.0.0.0:55855 starting udp receive timer with timeout ms: 1000 timer expired 0 servers received And also if im trying to use external player `/usr/bin/mpv` that used to be working "as workaround spinning circle" now throwing missing file /usr/bin/mpv: symbol lookup error: /lib/x86_64-linux-gnu/libva-x11.so.2: undefined symbol: va_fool_postp ` Edited November 4, 2022 by dedyms Add log about missing file
alucryd 318 Posted November 4, 2022 Posted November 4, 2022 @dedyms What OS are you using? Probably need to adjust an env variable to fix that missing file issue.
Luticus 13 Posted November 4, 2022 Posted November 4, 2022 5 hours ago, Luke said: For those who have been unable to play using the .deb or RPI packages, can you try redownloading the 3.0.16 .deb and let us know how that compares? We've repackaged it with some library updates. We're also working on a 3.0.17 release with more updates but wanted to do a quick repackaging for now. Thanks ! @LukeI don't think I was having any issues with playback on Debian 11 and Debian 12 (testing) but I'll give the new package a look and let you know. One thing I have noticed lately is I have a lot of images that don't seem to work. Like after I scan a library for new content the images for new media appear broken, even if I manually edit the images and then search for them they all look broken, but if I restart the server it will sometimes fix it and the images come down. It's weird and intermittent, not sure If others have that issue, but I'd be curious if they do. I think I'm using tvdb and moviedb as sources, among other. All of them seem to behave the same though. 1
Luticus 13 Posted November 5, 2022 Posted November 5, 2022 @LukePlayback appears fine, even with hardware acceleration for me, tested using nvidia 3090 GPU. 1
dedyms 2 Posted November 5, 2022 Posted November 5, 2022 6 hours ago, alucryd said: @dedyms What OS are you using? Probably need to adjust an env variable to fix that missing file issue. Debian 11 64bit My exported env, firefox and mpv looking vaapi correctly export PATH #export http_proxy HTTP_PROXY export LC_ALL=en_US.UTF-8 export LANG=en_US.UTF-8 export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01' export DXVK_HUD=devinfo,fps,pipelines,memory,version export DXVK_STATE_CACHE_PATH=/home/dedyms/.dxvk/ export DXVK_LOG_PATH=/home/dedyms/.dxvk/ export DXVK_ASYNC=1 #export MOZ_ENABLE_WAYLAND=1 export MOZ_X11_EGL=1 export MOZ_DISABLE_RDD_SANDBOX=1 #export PULSE_LATENCY_MSEC=60 #export __GL_THREADED_OPTIMIZATIONS=1 #export MESA_GLTHREAD=TRUE #export PBA_DISABLE=1 export QT_QPA_PLATFORMTHEME=qt5ct #export QT_QPA_PLATFORM=wayland #export GDK_BACKEND=wayland #export CLUTTER_BACKEND=wayland #export SDL_VIDEODRIVER=wayland #export LIBVA_DRIVER_NAME=nvidia export XCURSOR_SIZE=32 #export MESA_GL_VERSION_OVERRIDE=3.3 #export LANG=id_ID.UTF8 #export export LC_ALL=id_ID.UTF-8 #export export LANG=id_ID.UTF-8 #export __GL_THREADED_OPTIMIZATIONS=1 export ZLSCOLORS="${LS_COLORS}"
alucryd 318 Posted November 5, 2022 Posted November 5, 2022 @dedyms Thanks, that file is really missing, will have a fix soon.
mprasil 14 Posted November 5, 2022 Posted November 5, 2022 22 hours ago, Luke said: For those who have been unable to play using the .deb or RPI packages, can you try redownloading the 3.0.16 .deb and let us know how that compares? We've repackaged it with some library updates. We're also working on a 3.0.17 release with more updates but wanted to do a quick repackaging for now. Thanks ! I can also confirm the fixed version works as expected. Thanks a lot for fixing it. 1
hukt_own_fonikz 10 Posted November 7, 2022 Posted November 7, 2022 I haven't had any playback issues at all, just an issue with the client holding focus and not letting me use other open applications.
daldana 126 Posted November 7, 2022 Posted November 7, 2022 @Luke and @alucryd, Unfortunately, the latest release still does not work on RPI 3b. I tried it on both Live TV and a movie file, but still only get the spinning circle, no audio or video. Logs attached, just for the Live TV attempts (the movie file does exactly the same). Reverting back to 3.0.15. embyserver.txt ffmpeg-transcode-4c848b63-4ec0-4fec-b930-72053458bcfb_1.txt ffmpeg-transcode-9e80d097-2a67-4fe8-abc8-38c36c100704_1.txt ffmpeg-transcode-faae2cf7-3527-48e8-9808-603e31bfc252_1.txt
alucryd 318 Posted November 7, 2022 Posted November 7, 2022 (edited) @daldanaThought we were in the clear regarding rpi so I didn't have a look at it recently. Will do soon. Edit: Confirmed, I also get the spinning blue ring of death on rpi3, looking into it. Edited November 8, 2022 by alucryd
Der R 5 Posted November 12, 2022 Posted November 12, 2022 I'm using the flatpak version of Emby Theater. For a few weeks now, maybe a month or so, whenever i run flatpak update I receive these warnings: Looking for updates… Info: runtime org.freedesktop.Platform branch 20.08 is end-of-life, with reason: org.freedesktop.Platform 20.08 is no longer receiving fixes and security updates. Please update to a supported runtime version. Info: applications using this runtime: media.emby.EmbyTheater Info: runtime org.freedesktop.Platform.GL.default branch 20.08 is end-of-life, with reason: org.freedesktop.Platform 20.08 is no longer receiving fixes and security updates. Please update to a supported runtime version. Info: applications using this extension: media.emby.EmbyTheater And it's getting tiresome. Would you, please, update the flatpak version to make use of more modern versions of these runtimes, such as 22.08?
Luke 42241 Posted November 12, 2022 Posted November 12, 2022 55 minutes ago, Der R said: I'm using the flatpak version of Emby Theater. For a few weeks now, maybe a month or so, whenever i run flatpak update I receive these warnings: Looking for updates… Info: runtime org.freedesktop.Platform branch 20.08 is end-of-life, with reason: org.freedesktop.Platform 20.08 is no longer receiving fixes and security updates. Please update to a supported runtime version. Info: applications using this runtime: media.emby.EmbyTheater Info: runtime org.freedesktop.Platform.GL.default branch 20.08 is end-of-life, with reason: org.freedesktop.Platform 20.08 is no longer receiving fixes and security updates. Please update to a supported runtime version. Info: applications using this extension: media.emby.EmbyTheater And it's getting tiresome. Would you, please, update the flatpak version to make use of more modern versions of these runtimes, such as 22.08? Hi, yes it's in our to do list. Thanks.
anthonws 42 Posted November 18, 2022 Posted November 18, 2022 Installed 3.0.16 version for Fedora (version 37). Cannot launch it. Error: Quote /opt/emby-theater/electron/emby-theater: /opt/emby-theater/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib64/libicuuc.so.71) All deps are installed. And GLIBCXX version 3.4.30 is installed. Quote strings /usr/lib64/libstdc++.so.6 | grep GLIBCXX GLIBCXX_3.4 GLIBCXX_3.4.1 GLIBCXX_3.4.2 GLIBCXX_3.4.3 GLIBCXX_3.4.4 GLIBCXX_3.4.5 GLIBCXX_3.4.6 GLIBCXX_3.4.7 GLIBCXX_3.4.8 GLIBCXX_3.4.9 GLIBCXX_3.4.10 GLIBCXX_3.4.11 GLIBCXX_3.4.12 GLIBCXX_3.4.13 GLIBCXX_3.4.14 GLIBCXX_3.4.15 GLIBCXX_3.4.16 GLIBCXX_3.4.17 GLIBCXX_3.4.18 GLIBCXX_3.4.19 GLIBCXX_3.4.20 GLIBCXX_3.4.21 GLIBCXX_3.4.22 GLIBCXX_3.4.23 GLIBCXX_3.4.24 GLIBCXX_3.4.25 GLIBCXX_3.4.26 GLIBCXX_3.4.27 GLIBCXX_3.4.28 GLIBCXX_3.4.29 GLIBCXX_3.4.30 GLIBCXX_DEBUG_MESSAGE_LENGTH Any hints?
pSYoniK 1 Posted November 21, 2022 Posted November 21, 2022 On 04/11/2022 at 17:53, Luke said: For those who have been unable to play using the .deb or RPI packages, can you try redownloading the 3.0.16 .deb and let us know how that compares? We've repackaged it with some library updates. We're also working on a 3.0.17 release with more updates but wanted to do a quick repackaging for now. Thanks ! I just tried it out this morning and it plays videos fine, the error is no longer showing up. I tested out several movies and a few tv shows and no problems. Thank you! 1
Dissuade 0 Posted November 24, 2022 Posted November 24, 2022 Installed from this source :- dnf install https://github.com/MediaBrowser/emby-theater-electron/releases/download/3.0.16/emby-theater-rpm_3.0.16_x86_64.rpm Trying to lauch emby-theater fails with error. /opt/emby-theater/electron/emby-theater: /opt/emby-theater/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib64/libicuuc.so.71) Any fix for this issue ?
Happy2Play 9811 Posted November 29, 2022 Posted November 29, 2022 (edited) @Dissuade mergee with ET Linux discussion. Edited November 29, 2022 by Happy2Play
Luke 42241 Posted November 30, 2022 Posted November 30, 2022 On 11/24/2022 at 3:16 PM, Dissuade said: Installed from this source :- dnf install https://github.com/MediaBrowser/emby-theater-electron/releases/download/3.0.16/emby-theater-rpm_3.0.16_x86_64.rpm Trying to lauch emby-theater fails with error. /opt/emby-theater/electron/emby-theater: /opt/emby-theater/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib64/libicuuc.so.71) Any fix for this issue ? Hi, we are looking into it. Thanks.
Luke 42241 Posted December 9, 2022 Posted December 9, 2022 Hi, there is a new 3.0.19 release headed up to our website: https://emby.media/emby-theater-linux.html Please try it out and report your experience. Thanks ! 1
daldana 126 Posted December 12, 2022 Posted December 12, 2022 (edited) @Luke, I'm very happy to report that 3.0.19 works on an RPI 3b running Debian Bullseye (32-bit) as the OS. I get hardware acceleration on Live TV, Recorded TV, and Movies (mine are all mkv format) using the Auto (copy back) setting. I used to have to turn off hardware acceleration when watching either Recorded TV or Movies, but now I don't need to. Thanks to you, @alucryd, and the whole team for this! Edited December 12, 2022 by daldana 2
InnKeepNY 4 Posted December 17, 2022 Posted December 17, 2022 Emby theater in arch is throwing up emby theater not found after install. This is arch version 3.0.16-2 November 14th update. I know its an easy fix but I just can't seem to get it to work.
alucryd 318 Posted December 17, 2022 Posted December 17, 2022 @InnKeepNYI have yet to update the Arch package, will have a look when I do, probably tomorrow, maybe it's an issue with the package itself.
