SHSPVR 125 Posted January 14, 2022 Posted January 14, 2022 3 hours ago, alucryd said: Do you have either i965-va-driver or intel-media-va-driver installed? What's the output of the `vainfo` command (you may need to install the corresponding package) ? The ubuntu wiki also recommends installing libvdpau-va-gl1, but I fail to see why that would be needed. For Intel, it's split generationally, and into free and non-free drivers. The non-free drivers are necessary to encode media while the free drivers can only decode. As for libvdpau-va-gl1 gl = OpenGL under the hood to accelerate drawing and scaling and VA-API i965-va-driver is for 9 gen or older intel-media-va-driver is for 8 gen or newer HardwareVideoAcceleration - Debian Wiki
Luke 42241 Posted January 14, 2022 Posted January 14, 2022 5 hours ago, alucryd said: @Luke Does theater use native paths over samba or is it http(s) only? Out of the box its http
fantaxp7 191 Posted February 7, 2022 Posted February 7, 2022 Hello, For downloading within Emby Theater, I attempt to download a series of a season but it points to another device. Is there something I'm missing? Thanks
GrimReaper 4896 Posted February 7, 2022 Posted February 7, 2022 2 minutes ago, fantaxp7 said: Hello, For downloading within Emby Theater, I attempt to download a series of a season but it points to another device. Is there something I'm missing? Thanks AFAIK Only Theater UWP (Windows Store) has offline capability/download features, Theater Desktop doesn't still. Feature unification is on the roadmap, though. 1
fantaxp7 191 Posted February 7, 2022 Posted February 7, 2022 3 minutes ago, GrimReaper said: AFAIK Only Theater UWP (Windows Store) has offline capability/download features, Theater Desktop doesn't still. Feature unification is on the roadmap, though. Gotcha, thanks
GrimReaper 4896 Posted February 7, 2022 Posted February 7, 2022 4 minutes ago, fantaxp7 said: Gotcha, thanks Just now saw it's Linux thread, tbh don't know what's the situation there, someone might chime in, as per Premiere Feature Matrix it IS listed as such:
fantaxp7 191 Posted February 7, 2022 Posted February 7, 2022 4 minutes ago, GrimReaper said: Just now saw it's Linux thread, tbh don't know what's the situation there, someone might chime in, as per Premiere Feature Matrix it IS listed as such: Ok cool so there is hope
GrimReaper 4896 Posted February 7, 2022 Posted February 7, 2022 1 minute ago, fantaxp7 said: Ok cool so there is hope I'd say there's hope either way, if not already implemented should be in some foreseeable future. @Luke
TurtleXIII 0 Posted February 8, 2022 Posted February 8, 2022 I'm not sure where to ask this. I've been using Emby Server on my server PC and my main desktop (Ubuntu) I've been using Emby Theater and it's been working great for a long time. I just today added a harddrive to the server and started moving stuff around. For some reason, my Emby Theater on my main desktop PC, now will not load any media from the server. It will just infinite loading circle until I close the application and reopen. Playback works on other PCs, I tested through browser which works, and I tested on my phone which also works. So it seems like it's a problem with my main PC but I'm not sure how to fix. Anyone have any ideas? Edit: Shoot sorry it doesn't seem to be doing it anymore. I restarted PC to see if that might work and it seems to be working fine now.
smw36 2 Posted February 27, 2022 Posted February 27, 2022 Hello I am using emby-server-4.6.7.0-1.x86_64 on Rocky Linux 8.5. Two android clients (Android 12 resp. 9) as well as one Windows 10 client are working well playing all vidoes, all music and liveTV. I have tried the same on two different hardwares running fedora 35 as well as from the server with emby-theater-3.0.15-1.x86_64, all content is visible, but no videos nor music is playing (running circle). I can download the video file to local space and then play with vlc or xine, playing within the web app is working too. I have read this forum, but I have no clue. What is the problem with emby-theater on my linux devices ?
smw36 2 Posted March 17, 2022 Posted March 17, 2022 After trying a lot of things, testing hardware acceleration and so on, I wondered, what will happen, if I remove all the installed graphic libraries installed within /opt/emby-theater/extra/ and moved the folder lib. I started emby-theater without any error, and ... now every content is playing: video, music, Live-TV ... all three linux devices ... 2
alucryd 318 Posted March 18, 2022 Posted March 18, 2022 We originally split these libs in an extra directory so they can easily be disabled. Ideally this should be done from within emby with a "Prefer system libs" checkbox, but it could also be done via a conf file in /etc/conf.d, the latter can be implemented fairly quickly.
dedyms 2 Posted March 19, 2022 Posted March 19, 2022 (edited) So on some system with no video loading i realized that emby not looking the right path or not requesting the right name. This is on debian sid. Emby internal package ``` ❯ dpkg-query -L emby-theater | grep radeon /opt/emby-theater/extra/lib/dri/radeonsi_drv_video.so /opt/emby-theater/extra/lib/libdrm_radeon.so.1.0.1 /opt/emby-theater/extra/lib/libdrm_radeon.so /opt/emby-theater/extra/lib/libdrm_radeon.so.1 ``` System vainfo ``` ❯ vainfo libva info: VA-API version 1.14.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: Mesa Gallium driver 21.3.7 for AMD Radeon RX 580 Series (POLARIS10, DRM 3.44.0, 5.16.0-14.1-liquorix-amd64, LLVM 13.0.1) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc ``` libgl1-mesa-dri ``` ❯ dpkg-query -L libgl1-mesa-dri:amd64 /. /usr /usr/lib /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/dri /usr/lib/x86_64-linux-gnu/dri/crocus_dri.so /usr/lib/x86_64-linux-gnu/dri/d3d12_dri.so /usr/lib/x86_64-linux-gnu/dri/i830_dri.so /usr/lib/x86_64-linux-gnu/dri/i915_dri.so /usr/lib/x86_64-linux-gnu/dri/i965_dri.so /usr/lib/x86_64-linux-gnu/dri/iris_dri.so /usr/lib/x86_64-linux-gnu/dri/kms_swrast_dri.so /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so /usr/lib/x86_64-linux-gnu/dri/nouveau_vieux_dri.so /usr/lib/x86_64-linux-gnu/dri/r200_dri.so /usr/lib/x86_64-linux-gnu/dri/r300_dri.so /usr/lib/x86_64-linux-gnu/dri/r600_dri.so /usr/lib/x86_64-linux-gnu/dri/radeon_dri.so /usr/lib/x86_64-linux-gnu/dri/radeonsi_dri.so /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so /usr/lib/x86_64-linux-gnu/dri/virtio_gpu_dri.so /usr/lib/x86_64-linux-gnu/dri/vmwgfx_dri.so /usr/lib/x86_64-linux-gnu/dri/zink_dri.so /usr/share /usr/share/bug /usr/share/bug/libgl1-mesa-dri /usr/share/bug/libgl1-mesa-dri/control /usr/share/bug/libgl1-mesa-dri/script /usr/share/doc /usr/share/doc/libgl1-mesa-dri /usr/share/doc/libgl1-mesa-dri/changelog.Debian.gz /usr/share/doc/libgl1-mesa-dri/changelog.gz /usr/share/doc/libgl1-mesa-dri/copyright /usr/share/drirc.d /usr/share/drirc.d/00-mesa-defaults.conf ``` What emby looking for ``` ❯ emby-theater Gtk-Message: 22:41:57.439: Failed to load module "colorreload-gtk-module" Gtk-Message: 22:41:57.439: Failed to load module "window-decorations-gtk-module" libGL error: MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: '' } ERROR: cec-client not installed, running without cec functionality. cec-client exited with code -2 UDP Client listening on 0.0.0.0:37653 starting udp receive timer with timeout ms: 1000 Message from: 192.168.0.2:7359 ServerDiscovery message received Server discovery json: {"Address":"http://192.168.0.2:8096","Id":"db11e1c2722d4f68839ce90101bc8e09","Name":"Emby-Media"} timer expired 1 servers received [ { Address: 'http://192.168.0.2:8096', Id: 'db11e1c2722d4f68839ce90101bc8e09', Name: 'Emby-Media', EndpointAddress: '192.168.0.2' } ] ``` Edited March 19, 2022 by dedyms Add libgl1-mesa-dri
daldana 126 Posted March 24, 2022 Posted March 24, 2022 @alucryd, Any luck on a new pi image or deb that will work on pi 3b and pi 4?
Luke 42241 Posted April 3, 2022 Posted April 3, 2022 On 3/24/2022 at 3:27 PM, daldana said: @alucryd, Any luck on a new pi image or deb that will work on pi 3b and pi 4? We should have some new updates for the Pi in the near future but the current downloads should work just fine with the Pi4.
daldana 126 Posted April 3, 2022 Posted April 3, 2022 Thanks @luke, I'm running ET on a 3b which works and uses hw acceleration, but the picture actually looks better without hwa. So I'll hope the updates will fix that. 1
QuarkZ 14 Posted April 30, 2022 Posted April 30, 2022 On 3/19/2022 at 8:42 AM, dedyms said: So on some system with no video loading i realized that emby not looking the right path or not requesting the right name. This is on debian sid. Emby internal package ``` ❯ dpkg-query -L emby-theater | grep radeon /opt/emby-theater/extra/lib/dri/radeonsi_drv_video.so /opt/emby-theater/extra/lib/libdrm_radeon.so.1.0.1 /opt/emby-theater/extra/lib/libdrm_radeon.so /opt/emby-theater/extra/lib/libdrm_radeon.so.1 ``` System vainfo ``` ❯ vainfo libva info: VA-API version 1.14.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: Mesa Gallium driver 21.3.7 for AMD Radeon RX 580 Series (POLARIS10, DRM 3.44.0, 5.16.0-14.1-liquorix-amd64, LLVM 13.0.1) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc ``` libgl1-mesa-dri ``` ❯ dpkg-query -L libgl1-mesa-dri:amd64 /. /usr /usr/lib /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/dri /usr/lib/x86_64-linux-gnu/dri/crocus_dri.so /usr/lib/x86_64-linux-gnu/dri/d3d12_dri.so /usr/lib/x86_64-linux-gnu/dri/i830_dri.so /usr/lib/x86_64-linux-gnu/dri/i915_dri.so /usr/lib/x86_64-linux-gnu/dri/i965_dri.so /usr/lib/x86_64-linux-gnu/dri/iris_dri.so /usr/lib/x86_64-linux-gnu/dri/kms_swrast_dri.so /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so /usr/lib/x86_64-linux-gnu/dri/nouveau_vieux_dri.so /usr/lib/x86_64-linux-gnu/dri/r200_dri.so /usr/lib/x86_64-linux-gnu/dri/r300_dri.so /usr/lib/x86_64-linux-gnu/dri/r600_dri.so /usr/lib/x86_64-linux-gnu/dri/radeon_dri.so /usr/lib/x86_64-linux-gnu/dri/radeonsi_dri.so /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so /usr/lib/x86_64-linux-gnu/dri/virtio_gpu_dri.so /usr/lib/x86_64-linux-gnu/dri/vmwgfx_dri.so /usr/lib/x86_64-linux-gnu/dri/zink_dri.so /usr/share /usr/share/bug /usr/share/bug/libgl1-mesa-dri /usr/share/bug/libgl1-mesa-dri/control /usr/share/bug/libgl1-mesa-dri/script /usr/share/doc /usr/share/doc/libgl1-mesa-dri /usr/share/doc/libgl1-mesa-dri/changelog.Debian.gz /usr/share/doc/libgl1-mesa-dri/changelog.gz /usr/share/doc/libgl1-mesa-dri/copyright /usr/share/drirc.d /usr/share/drirc.d/00-mesa-defaults.conf ``` What emby looking for ``` ❯ emby-theater Gtk-Message: 22:41:57.439: Failed to load module "colorreload-gtk-module" Gtk-Message: 22:41:57.439: Failed to load module "window-decorations-gtk-module" libGL error: MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: '' } ERROR: cec-client not installed, running without cec functionality. cec-client exited with code -2 UDP Client listening on 0.0.0.0:37653 starting udp receive timer with timeout ms: 1000 Message from: 192.168.0.2:7359 ServerDiscovery message received Server discovery json: {"Address":"http://192.168.0.2:8096","Id":"db11e1c2722d4f68839ce90101bc8e09","Name":"Emby-Media"} timer expired 1 servers received [ { Address: 'http://192.168.0.2:8096', Id: 'db11e1c2722d4f68839ce90101bc8e09', Name: 'Emby-Media', EndpointAddress: '192.168.0.2' } ] ``` Hello, I'm currently on Kubuntu 22.04 and I see this same behavior using 3.0.15, Nothing actually starts, it just spins until I manually force close it, however 3.0.14 works just fine. Is there any fix for this? I tried Linux Mint also on the same machine and 3.0.15 worked, so I'm guessing something is missing, but not sure what. It's a laptop with Intel Graphics, using i915 drivers Kubuntu on my main machine but using nvidia works also just fine Thanks
carbonbaseunit 19 Posted June 17, 2022 Posted June 17, 2022 (edited) Hi. I simply cannot get Emby Theater to play any videos on my Ubuntu 22.04 laptop. Here is the log. emby-theater libGL error: MESA-LOADER: failed to open crocus: /usr/lib/dri/crocus_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: crocus libGL error: MESA-LOADER: failed to open crocus: /usr/lib/dri/crocus_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: crocus libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: '' } UDP Client listening on 0.0.0.0:60663 starting udp receive timer with timeout ms: 1000 Message from: 192.168.1.16:7359 ServerDiscovery message received Server discovery json: {"Address":"http://192.168.1.16:35400","Id":"5120f4725ecf413992dbc6a2ac344c74","Name":"Shane's Emby Server"} cec-client exited with code 1 timer expired 1 servers received Any help would be appreciated. The server is on a Windows machine. Also this at the end when I try to play a video fs access result for path: Error: ENOENT: no such file or directory, access 'G:\television\*SOMESHOW* (2005)\Season 1\s01e01 - Pilot.mp4' Edited June 17, 2022 by carbonbaseunit Added information
alucryd 318 Posted June 20, 2022 Posted June 20, 2022 @carbonbaseunitPlease try installing libatomic1 if it's not installed. If that still doesn't work, we will have a new deb available for testing shortly.
dedyms 2 Posted June 20, 2022 Posted June 20, 2022 (edited) On 4/30/2022 at 8:56 AM, QuarkZ said: Hello, I'm currently on Kubuntu 22.04 and I see this same behavior using 3.0.15, Nothing actually starts, it just spins until I manually force close it, however 3.0.14 works just fine. Is there any fix for this? I tried Linux Mint also on the same machine and 3.0.15 worked, so I'm guessing something is missing, but not sure what. It's a laptop with Intel Graphics, using i915 drivers Kubuntu on my main machine but using nvidia works also just fine Thanks I had 22.04 upgrade from 20.04 then 3.0.15 work fine, but as i posted my debian sid wont work on 3.0.15, but you posted that 3.0.14 work fine, then i tried to install 3.0.14 version, and it work correctly. I also try to install depedencies like as described https://emby.media/emby-theater-linux.html , but no dice, so in mean i just use what works. Edit: one i noticed is emby theatre 3.0.14 read user mpv.conf, ex you had conf ~/.config/mpv/mpv.conf with infinite loop, the video will play infinite loop, regardless playback set in apps. Edited June 20, 2022 by dedyms
carbonbaseunit 19 Posted June 20, 2022 Posted June 20, 2022 Quote 9 hours ago, alucryd said: @carbonbaseunitPlease try installing libatomic1 if it's not installed. If that still doesn't work, we will have a new deb available for testing shortly. I have this installed already. I have reverted back to 3.0.14 for the time being from the repository here https://ishort.ink/JVDr Thanks you for responding to me.
alucryd 318 Posted July 5, 2022 Posted July 5, 2022 Sorry about the wait, for the longest time I thought I made no progress but it's just that the packages don't play well inside a VM. The flatpak works on my main arch linux machine, since all packages are made from the same binaries it's fair to assume it should translate to the others. Here's a new deb for you to try, for this one it would actually be better to uninstall libatomic1 as I found it would cause issue in my Ubuntu 22.04 VM (might not be the case on an actual system though). https://files.alucryd.xyz/emby-theater-deb_3.0.15_amd64.deb
alucryd 318 Posted July 6, 2022 Posted July 6, 2022 @daldanaStill struggling with rpi support, the new plan is to use the system mpv as I can't get hwaccel to work properly with ours, don't think I will without building our whole ffmpeg/mpv stack on a pi, but that would mean our arm packages would be very much less portable. However using the system mpv comes with its own set of problems because electron essentially comes with a stripped down ffmpeg library that conflicts with mpv. Had found a way to overcome those issues at some point but I can't for the life of me reproduce it on the newly created images. Stay tuned, hopefully I have some good news soon. One good news is the new images will be compatible with the rpi imager so you can set your hostname and wifi connection settings within the tool itself, removing the need to manually do these steps upon first boot.
daldana 126 Posted July 7, 2022 Posted July 7, 2022 @alucryd That is good news! I'm available if you need any testing done...
