daldana 126 Posted October 9, 2021 Posted October 9, 2021 Installed the new deb and it completely broke any hardware acceleration even if I try to use mpv.conf. The video does play, but without hw acceleration, if I have the setting at "None" or "Unset" (only with hwdec=h264_v4l2m2m-copy). Attached are four logs with the four different options. Theater_mpv_log_Auto.txt Theater_mpv_log_Auto-Copy.txt Theater_mpv_log_None.txt Theater_mpv_log_Unset.txt
daldana 126 Posted October 13, 2021 Posted October 13, 2021 @luke or @alucyrd, Any ideas why hw accel can't be called via mpv.conf now? I did notice that mmal and v4l2m2m have been updated to h264_mmal and h264_v4l2m2m (and a new h264_rkmpp, but that's for rock chips I think). Also, the "Video Output" setting is still not honoring the gpu selection, it always goes to libmpv. Thanks.
Luke 42241 Posted October 14, 2021 Posted October 14, 2021 18 hours ago, daldana said: @luke or @alucyrd, Any ideas why hw accel can't be called via mpv.conf now? I did notice that mmal and v4l2m2m have been updated to h264_mmal and h264_v4l2m2m (and a new h264_rkmpp, but that's for rock chips I think). Also, the "Video Output" setting is still not honoring the gpu selection, it always goes to libmpv. Thanks. @alucryd will be looking at this. Thanks.
daldana 126 Posted October 14, 2021 Posted October 14, 2021 BTW, where are the mpv and ffmpeg folders located with this package? I'd like to run some tests but I haven't been able to locate them. Thanks.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 @daldana I think I need to patch mpv's configure files, it seems they're not detecting the pi libraries at compile time even though I have them on the path, that may explain why it fails. As for mpv and ffmpeg, you won't find them, mpv is shipped as libmpv for use with electron, and ffmpeg is statically linked so libmpv is self-contained.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 So there's an open issue that's preventing me to go further: https://github.com/mpv-player/mpv/issues/9215 I'll see if I can fix the build myself, will need to wait for upstream if I can't.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 @daldana Was able to get around it, please try the following package: https://files.alucryd.xyz/emby-theater-deb_3.0.15_armhf.deb Still working on the bootable rpi image, when I get it running I'll be able to test this out in case it doesn't work.
daldana 126 Posted October 15, 2021 Posted October 15, 2021 @alucryd I deleted the old install and installed the new build, but now I can't get any playback on any of the video settings. If I switch to an external player, I can get video just not with mpv. What's funny is that it doesn't even generate an mpv log which makes me wonder if it's calling up mpv at all. Anything you'd like me to try?
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 @daldana Thanks for trying. I'm almost done with the rpi image, looks like I broke mpv by enabling rpi support. I'm actually skipping part of the build because it depends on x11 (and I don't want to build that, especially since it's completely unneeded), but it also includes some functions that are needed for the rpi features. These do not break the build unfortunately and only breaks at run time I'll try to come up with a fix.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 Updated the link above, this one is a tad better, mpv doesn't crash anymore, but I no longer have any video output, currently investigating.
daldana 126 Posted October 15, 2021 Posted October 15, 2021 Tried the new link, same situation. No video and no mpv log generated.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 Weird, it does work here. Could you try running an strace on emby-theater, try to watch a video and post the resulting strace.log here? strace -s 512 -f -o strace.log emby-theater With vo=libmpv, the file starts playing, but with no video. It doesn't seem to respect my hwdec setting in mpv.conf and always defaults to mmal (which I suspect is not working correctly), tried hwdec=no to no avail. With vo=gpu it is stuck at Initializing the gpu context "rpi", and I can't force it to use gpu-context=drm either... Wondering if using real kms instead of fkms might fix that. The mpv guys seem to dislike the rpi blobs, they prefer v4l2m2m as hwdec, and drm as gpu context, even on the rpi, but last I checked at least on the rpi 3 it looked like mmal was still faster than v4l2m2m. BTW, quoting an mpv issue, "v4l2m2m is basically mmal in kernel", I'd be interested in evaluating the state of v4l2m2m if I can get both mmal and v4l2m2m to work.
daldana 126 Posted October 15, 2021 Posted October 15, 2021 Result of trace; pi@raspberrypi:~ $ strace -s 512 -f -o strace.log emby-theater Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: 'null' } CEC Client successfully registered. CEC Adapter Device: { "device": "Recorder1", "lAddr": "1" } UDP Client listening on 0.0.0.0:57368 starting udp receive timer with timeout ms: 1000 timer expired 0 servers received [] cec-client exited with code null With the earlier version, I was only ever able to get v4l2m2m working, never mmal. Also, I could never get it to recognize the gpu0context=drm either and that with the real kms set. Hope this helps.
alucryd 318 Posted October 15, 2021 Posted October 15, 2021 @daldana The command should have generated a strace.log file, that's what will tell me what went wrong, the console doesn't contain enough data.
daldana 126 Posted October 15, 2021 Posted October 15, 2021 Ooops, nothing worked because I forgot to remove the old download and ended up just reinstalling it,sorry! The correct download did produce log mpv log files which I have attached. The "Auto" log is with everything set to auto and it tried to use mmal. The "None" was with None in the hw acceleration setting, it broke on "rpi-overlay". The "Unset" log is one where I had tried to force hwdec=v4l2m2m and vo=gpu in the mpv conf file, it also broke on rpi-overlay.
daldana 126 Posted October 15, 2021 Posted October 15, 2021 Theater_mpv_log_Unset.txtTheater_mpv_log_None.txtTheater_mpv_log_Auto.txt
daldana 126 Posted October 18, 2021 Posted October 18, 2021 @alucryd, Got called away on Friday and wasn't able to get strace log until today. See attached.strace.log
alucryd 318 Posted October 20, 2021 Posted October 20, 2021 Thanks for the strace, can't find any lead in it unfortunately. I updated the above link with a patched libmpv, backported an open PR and fixed a wrong hardcoded path in their code. Maybe that'll help.
daldana 126 Posted October 22, 2021 Posted October 22, 2021 @alucryd, More logs for you! No playback at all when acceleration set to None or Auto and both seem to break on "rpi-overlay". When I set the video out in Emby to libmpv and acceleration to Auto-Copyback, the log shows it tries to software decode, but still no playback at all. Now when I use Unset with the mpv.conf set to vo=libmpv and hwdec=h264_mmal or v4l2m2m, I can get audio playback and the osd overlay but still no actual video playing. Let me know if there is anything else I can do. Theater_mpv_log_All Settings on Auto.txt Theater_mpv_log_None.txt Theater_mpv_log_Setting at libmpv and Auto.txt Theater_mpv_log_Setting at libmpv and Auto-Copyback.txt Theater_mpv_log_Unset with h264_mmal.txt Theater_mpv_log_Unset with h264_v4l2m2m.txt
alucryd 318 Posted October 23, 2021 Posted October 23, 2021 12 hours ago, daldana said: @alucryd, More logs for you! No playback at all when acceleration set to None or Auto and both seem to break on "rpi-overlay". When I set the video out in Emby to libmpv and acceleration to Auto-Copyback, the log shows it tries to software decode, but still no playback at all. Now when I use Unset with the mpv.conf set to vo=libmpv and hwdec=h264_mmal or v4l2m2m, I can get audio playback and the osd overlay but still no actual video playing. Let me know if there is anything else I can do. Theater_mpv_log_All Settings on Auto.txt 22.66 kB · 0 downloads Theater_mpv_log_None.txt 14.64 kB · 0 downloads Theater_mpv_log_Setting at libmpv and Auto.txt 14.64 kB · 0 downloads Theater_mpv_log_Setting at libmpv and Auto-Copyback.txt 22.61 kB · 0 downloads Theater_mpv_log_Unset with h264_mmal.txt 101.07 kB · 0 downloads Theater_mpv_log_Unset with h264_v4l2m2m.txt 80.42 kB · 0 downloads Thanks for the extensive testing! Not sure I can do much more about this as of now, but there are more things I'd like to try. The first is to add vulkan support to our mpv, and I'd also like to try a 64bit version on the pi. 1
OurfamilySpot 5 Posted October 23, 2021 Posted October 23, 2021 6 hours ago, alucryd said: like to try a 64bit version on the pi. That's an exciting statement. Here is hoping..
daldana 126 Posted October 23, 2021 Posted October 23, 2021 And vulkan support would be great too! Thanks alucryd!
Luticus 13 Posted October 25, 2021 Posted October 25, 2021 Sorry, not sure where exactly to ask this, but I was trying to solve the minimize, maximize, close buttons staying visible during playback on version 3.0.15, so I went and got a new copy from https://emby.media/emby-theater-linux.html and installed it as another forum I read suggested. I noticed that one installs as version 3.0.15-1, but the problem is when I install that version playback doesn't seem to work anymore. I get this error: fs access result for path: Error: ENOENT: no such file or directory <some path/filename> If I downgrade to the old 3.0.15, sure enough playback is fixed. I'm running Debian 11 Bullseye and no dependencies seem to be missing. Any advice would be very appreciated! Thanks!
alucryd 318 Posted October 29, 2021 Posted October 29, 2021 (edited) Here are 2 new test debs, they contain the following changes: switched to the latest git head for mpv, it has a lot of welcome enhancements added support for gpu rendering added support for x11 and vulkan (new gpu contexts include x11egl, x11vk, displayvk and a few less interesting others) https://files.alucryd.xyz/emby-theater-deb_3.0.15_armhf.deb https://files.alucryd.xyz/emby-theater-deb_3.0.15_arm64.deb Was able to use gpu rendering via x11egl on the pi3b, no vulkan on pi3b unfortunately, the one unofficial driver doesn't have the necessary extensions. Please give vulkan a try on the pi4 though if you have one, the mesa driver should work there. You will need to build the driver yourself with PiKISS though (it's under the configure sub-menu), please see https://github.com/jmcerrejon/PiKISS I'd be interested in a performance comparison between egl and vulkan on the pi4. We will have bootable armhf and arm64 bootable images available for download soon. Raspberry Pi OS is still based on debian buster so drivers are somewhat ancient. I'm looking into providing the mesa egl and vulkan drivers in our packages for ease of use, but I currently have an issue with libEGL so these will have to wait for a fix. For now the debian drivers will have to do, or you can use PiKISS to build a much newer version. Edited October 29, 2021 by alucryd
