Steverido 6 Posted December 17, 2016 Posted December 17, 2016 Hey Guys, I am new to Theater. See attachment. I have episodes showing outside the folder structure. Not sure why because physically they are not. Is it possible to create a theme for Theater like the chocolate theme in Emby for WMC? If so, how difficult would it be? Any pointers? I can see Radeon has created some themes but is it not possible to see screenshots of them before purchasing? Cheers
Luke 42243 Posted December 17, 2016 Posted December 17, 2016 Hi, what do you mean outside the folder structure? Can you discuss an example? Yes it is possible to create skins for Emby Theater, you can learn how to do that here: https://emby.media/community/index.php?/blog/1/entry-302-learn-how-to-create-skins-for-emby-theater/ Thanks !
Steverido 6 Posted December 18, 2016 Author Posted December 18, 2016 Hi, what do you mean outside the folder structure? Can you discuss an example? Yes it is possible to create skins for Emby Theater, you can learn how to do that here: https://emby.media/community/index.php?/blog/1/entry-302-learn-how-to-create-skins-for-emby-theater/ Thanks ! Luke, If you look at the screen capture it shows an episode outside of the folder. It is an episode of the crown but in fact it is actually with in the crown folder in season one folder if that makes sense.
