Pancho 9 Posted November 2, 2016 Posted November 2, 2016 (edited) Server Version 3.0.8400.0 (runs on Unraid 6.2.2 Docker) Nvidia Shield TV (6.0 SW ver 3.3) Android TV Beta (1.2.70g) Late last night I started noticing that when I play a DTS movie direct from my Emby server, the audio track is transcoding (instead of playing Direct). This seems to be happening for every movie I have that is DTS or DTS-HD, not just 1 or 2 movies. I am unsure if this is related to the recent Nvidia Shield TV 3.3 update last Friday (10/28) or the recent version of the ATV client (1.2.70g). I have attached logs (server and 4 different movie transcode logs) for your review. Any ideas? Pancho server-63613689960.txt ffmpeg-remux-3a42874e-84aa-4dd6-a39e-58b75a8fdb8b.txt ffmpeg-remux-26f9a6b4-f112-4184-859a-4e9ea83d4700.txt ffmpeg-remux-9b483299-3dd7-47c8-aa0f-7f4181791399.txt ffmpeg-remux-dbc127e7-6580-49c5-b3df-de9c0b009303.txt Edited November 2, 2016 by Pancho
ebr 16337 Posted November 2, 2016 Posted November 2, 2016 Do you have the option to bitstream DTS enabled? Can you send me a log from the app when you play one of these please?
barat 27 Posted November 2, 2016 Posted November 2, 2016 I may confirm, that it's not the server - an hour ago I was straming DTS movie to Raspberry Pi Kodi and my soundbar showed DTS (so it was passed untouched). I have server 3.0.8400.0 for Synology, and Emby for Kodi 2.3.4
Pancho 9 Posted November 2, 2016 Author Posted November 2, 2016 Ebr, Yes I do have the Bitstream DTS audio selected in options. I just updated to the latest beta (1.2.71g), same issue as before (transcoding audio). I have 'sent the logs' via the app to you. Thanks. Pancho
ebr 16337 Posted November 3, 2016 Posted November 3, 2016 Each of these items only have a single ref frame, correct?
Gibscreen 0 Posted November 4, 2016 Posted November 4, 2016 I'm streaming to Chromecast and Emby is no longer converting dts to Dolby digital anymore. I don't see a dts bitstreaming option. Where is this located?
Pancho 9 Posted November 4, 2016 Author Posted November 4, 2016 (edited) Ebr, here is an update to this issue. Upgraded to the latest server here tonight (.8500) and using the latest beta ATV client (1.2.71g), I experience the same problem. After some additional testing, any movie (MKV) that I play (Dolby Digital or DTS) from the Emby server will transcode only the audio (video plays direct). What is interesting, RecordedTV files (MKV - preserve original audio) plays both the audio and video direct. I opted out of the beta program, and installed the stable version of 1.2.69g. Both DTS & Dolby Digital movies play direct (both audio & video). This has to be an issue with the latest ATV beta client. Within the Emby app I have sent logs after running 1.2.71g and also again after I removed and re-installed 1.2.69g. Attached is the server log as well. Thanks. server-63613820592.txt Edited November 4, 2016 by Pancho
ebr 16337 Posted November 4, 2016 Posted November 4, 2016 Each of these items only have a single ref frame, correct? I'm pretty sure that is the issue. For a long time we have been forcing a transcode of h.264 video with only one ref frame because several people reported that they did not decode properly on the Android TV platform. In the last official release we relaxed that restriction and, again, had people report that some of their items would not play properly. So, we have put that restriction back. Until such time as we can figure out how to identify exactly which items will work and which won't, we have to err on the side of the item actually playing. I will try something in the next beta to see if we can catch both situations and not cause a lot of problems in other areas.
Solution ebr 16337 Posted November 5, 2016 Solution Posted November 5, 2016 Have you tried this with the latest beta (.72)?
Pancho 9 Posted November 5, 2016 Author Posted November 5, 2016 (edited) Tried the latest update (.72) today and that has resolved the audio transcoding issues (for DTS & Dolby Digital). Thank you! Edited November 5, 2016 by Pancho
ricardo59 1 Posted November 6, 2016 Posted November 6, 2016 Tengo el mismo problema, ¿es necesario transcodificar? Tengo un i5, y el video no esta en sincronia con el audio, es bastante molesto. Creo que volvere por un tiempo, es una lastima, me encanto la interfaz grafica de emby :/
Luke 42244 Posted November 6, 2016 Posted November 6, 2016 Tengo el mismo problema, ¿es necesario transcodificar? Tengo un i5, y el video no esta en sincronia con el audio, es bastante molesto. Creo que volvere por un tiempo, es una lastima, me encanto la interfaz grafica de emby :/ Hola, bienvenido! Emby no utiliza muchos recursos tampoco. ¿Puede por favor discutir ejemplos específicos? Por favor proporcione la información de cómo informar de un problema de reproducción de medios. Gracias !
ricardo59 1 Posted November 6, 2016 Posted November 6, 2016 ¿Me entiende el español? No manejo muy bien el ingles, aunque podria hacer el esfuerzo, pero el lenguaje tecnico que se utiliza aca me lo hace mas dificil. Mi problema con emby es que en algunos videos el sonido no esta sincronizado con el video, me fije que emby transcodifica el video a diferencia de Ple x, que el video queda en la calidad original.
Luke 42244 Posted November 6, 2016 Posted November 6, 2016 ¿Me entiende el español? No manejo muy bien el ingles, aunque podria hacer el esfuerzo, pero el lenguaje tecnico que se utiliza aca me lo hace mas dificil. Mi problema con emby es que en algunos videos el sonido no esta sincronizado con el video, me fije que emby transcodifica el video a diferencia de Ple x, que el video queda en la calidad original. Por favor, adjunte el registro del servidor del bastidor momento en que ocurrió la actividad. Consulte la sección titulada Server registra Emby. Por favor, facilite el archivo de registro total y completa, y evitar el intento de extraer las secciones pertinentes. Todo es relevante para nosotros. Si un registro de transcodificación servidor también se generó durante la reproducción (en la carpeta de registros del servidor), adjunte eso también. Existen múltiples maneras de acceder a los archivos de registro del servidor Emby. Los registros se pueden acceder directamente dentro de la interfaz web del servidor mediante la navegación a Ayuda -> Registros. Además, la primera página del servidor del tablero de instrumentos Emby contiene la ruta de la carpeta de registros. Si usted está teniendo dificultades para usar la interfaz web, los registros se pueden encontrar en: Windows:% appdata% \ Emby-Server \ logs
Luke 42244 Posted December 7, 2016 Posted December 7, 2016 Hi @@Pancho The latest beta version of the Emby app offers improved playback, refresh rate switching, and all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks !
