woozle 2 Posted January 23, 2017 Posted January 23, 2017 I have all the updates. It isn't actually WebOS 2. It is webos 1 with some features from webos 2. which as I say, is why it will WORK on your TV, but it's currently not available for 1.x devices on the store because it doesn't seem to work on devices running 1.2. @@kwilcox is looking into it, but he needs help from someone running an old 1.2 device (assuming anyone is)
kwilcox 78 Posted January 23, 2017 Author Posted January 23, 2017 I have validated that version 1.4 is actually the v2.0 "compatibility update". The final version of WebOS 1 is v1.3.
STiFU 0 Posted January 24, 2017 Posted January 24, 2017 The app is not on the appstore for me, so I guess I am one of those people with a too old TV. I'd love to test this app, though. When I check the software version on my TV, it nowhere says which WebOS version I have. The only infos I get is: -Software version: 04.28.14 -SDK-Version: 03.05 -Browser Version: 6.00.0...... I searched the Web a lot, howto identify my WebOS version, but couldn't find anything. I guess my 2013 LG 55LA6608 is simply too old. Any clues?
kwilcox 78 Posted January 25, 2017 Author Posted January 25, 2017 Your TV is not a WebOS TV unfortunately.
SHSPVR 125 Posted January 25, 2017 Posted January 25, 2017 LG is use Open WebOS is Linux OS better know as Palm OS your LG 55LA6608 has Android 2.3 OS which is using OpenBrowser with very out date hardware and software support
STiFU 0 Posted January 25, 2017 Posted January 25, 2017 Yeah, thanks for the clarification. So, even if that other app for LG is eventually released, it won't be available for my TV. But that's fine. I am actually quite happy with my current setup. I have my TV connected to the pc anyway, so I just use a dedicated firefox window in fullscreen and start videos via DLNA play to. Works sufficiently well!
SHSPVR 125 Posted January 25, 2017 Posted January 25, 2017 Yeah, thanks for the clarification. So, even if that other app for LG is eventually released, it won't be available for my TV. But that's fine. I am actually quite happy with my current setup. I have my TV connected to the pc anyway, so I just use a dedicated firefox window in fullscreen and start videos via DLNA play to. Works sufficiently well! You could look in to pick up Android TV "Nexus Player, Shield TV or Mi Box", Apple TV, Fire TV or Roku 1
kwilcox 78 Posted January 26, 2017 Author Posted January 26, 2017 (edited) FYI: v1.1.9 pushed to the repo. Bug fixes and added played indicator to episodes. I've also got a request in to LG to see if I can make screenplay available on WebOS v1.4 (the WebOS 2 compatibility update) and higher. Edited January 26, 2017 by kwilcox
Andi_bz 0 Posted January 28, 2017 Posted January 28, 2017 (edited) Hi, i have installed the app from the LG appstore. But i'm missing the liveTv menu entry. Backend is tvheadend. What am I doing wrong? Thanks Edited January 28, 2017 by Andi_bz
Engrfc 0 Posted January 29, 2017 Posted January 29, 2017 FYI: v1.1.9 pushed to the repo. Bug fixes and added played indicator to episodes. I've also got a request in to LG to see if I can make screenplay available on WebOS v1.4 (the WebOS 2 compatibility update) and higher. Very interested in this as this is the position I'm in, how long do you think before you get a reply?
kwilcox 78 Posted January 29, 2017 Author Posted January 29, 2017 (edited) Hi, i have installed the app from the LG appstore. But i'm missing the liveTv menu entry. Backend is tvheadend. What am I doing wrong? Thanks Screenplay doesn't support LiveTV. Screenplay supports Media Libraries of type Movies and type TV. For recorded content, you can also use Unset. Edited January 29, 2017 by kwilcox
kwilcox 78 Posted January 29, 2017 Author Posted January 29, 2017 Very interested in this as this is the position I'm in, how long do you think before you get a reply? My inquiry hasn't been viewed yet. I believe S. Korea is celebrating the Lunar New Year currently. Not sure how big a holiday it is for them.
Andi_bz 0 Posted January 29, 2017 Posted January 29, 2017 Screenplay doesn't support LiveTV. Ok. Is this a planed feature? Thanks.
kwilcox 78 Posted January 29, 2017 Author Posted January 29, 2017 Screenplay is designed to be more of an existing content player. I use emby's built in website for scheduling recordings etc, so really what's missing is live DVR playback delay capabilities. I might do that at some point which would give you the ability to view a recorded program while it was still being recorded.
confused_squirrel 0 Posted January 30, 2017 Posted January 30, 2017 107 Hi, I'd really love to get Emby working on my LG TV its a low-end model (LG 32 Inch 32LH604V http://www.lg.com/uk/tvs/lg-32LH604V)but it does run webOS 3.0 and is 1920x1080 however I can't see screenplay in the store and when I try and get the device compatability on the lgstore website I get 'Sorry, this app is not compatible with your device.' Is this because my model has this issue: 'app resolution is only HD (1080x720).'?
pappaq 8 Posted January 31, 2017 Posted January 31, 2017 Hello, is it possible to connect to a https emby server?
Luke 42237 Posted January 31, 2017 Posted January 31, 2017 Hello, is it possible to connect to a https emby server? Hi there @@pappaq, please try it out and report your experience. Thanks !
kwilcox 78 Posted January 31, 2017 Author Posted January 31, 2017 (edited) I just tested this and an immediate "Server Not Found" error is returned. I'm not sure why this is but it might have something to do with the underlying LG handling of XMLHttpRequest(). Perhaps this is due to the self-signed default certificate that my server is using. FTTB, you have to use http. Edited January 31, 2017 by kwilcox
pappaq 8 Posted February 1, 2017 Posted February 1, 2017 I just tested this and an immediate "Server Not Found" error is returned. I'm not sure why this is but it might have something to do with the underlying LG handling of XMLHttpRequest(). Perhaps this is due to the self-signed default certificate that my server is using. FTTB, you have to use http. Yeah, I tested that before asking but thought, that you guys knew the issue. My question was more like: Is there a way to enter a https emby server? But unfortunatly there's not. It's no problem because I'm using my chromecast anyway. I just tried to take one peace of hardware out of there. Thanks for the answers!
Nickbert 7 Posted February 1, 2017 Posted February 1, 2017 (edited) I also noticed this a few weeks ago. I'm currently using your code via a web-browser and gitcdn.xyz: https://gitcdn.xyz/repo/Nickbert7/screenplay/master/index.html Because gitcdn uses https, I was not able to connect to my server via http. I had to modify the server.js to be able to enter https:// in front of the server-URL. This solved this issue: https://github.com/Nickbert7/screenplay/commit/47f01c000e96e7b11a0e457c4c08aa4924e50a1d#diff-ac88d24d8388a10f7a23fb00e8f8e69aL227 Edited February 1, 2017 by Nickbert
kwilcox 78 Posted February 1, 2017 Author Posted February 1, 2017 I did that too btw but was still unable to connect. My changes were pushed to the repo earlier today and also include default port logic: https://github.com/sleuth255/screenplay/commit/7782ef5753fc9ad860465deb3202a5d56e5142f3 That being said, does your server use a self-signed or valid cert? My theory was that it was the self-signed default cert that was causing my problem.
kwilcox 78 Posted February 1, 2017 Author Posted February 1, 2017 FYI all: I have the go-ahead from LG and next release of screenplay will support WebOS1.4 and higher TVs. They just need to fix up their file database and give me a version number to begin with... 1
Nickbert 7 Posted February 1, 2017 Posted February 1, 2017 I use one from Lets Encrypt. So yes, the self signed cert could be the problem... Would you like to test it with my server?
