Kipperdawn 5 Posted March 30, 2017 Posted March 30, 2017 Hi Anderbytes. Yes, transcoding is enabled at the user profiles level. I suspect part of the issue is related to the fact that emby should be (or is) transcoding based on bitrate yet the dashboard still reports direct play... doesn't seem like they are communicating correctly.
kwilcox 78 Posted March 31, 2017 Author Posted March 31, 2017 (edited) @@Kipperdawn I have a few more questions: What platform is running your emby server? Is it on your local network? Does the emby browser web client play your videos without issues? Edited March 31, 2017 by kwilcox
Kipperdawn 5 Posted April 1, 2017 Posted April 1, 2017 Hi Kwilcox, - EmbyServer is hosted on Windows Server 2012R2, running natively (ie not in a vm). I7-4771 CPU, 32 GB RAM. I have intel quick sync enabled in emby for transcoding. - Yes, the emby server and TV are on the same network, though the TV is using wifi - 5GHz network. I also have a chromecast-3 (4k version) plugged into the tv. I used to use that for playing on the tv until your app came out. I never had a streaming issue to the chromecast.... sometimes casting didn't work, but that is another issue... preferred your app as i don't need to mess around with the finicky casting. Note, to play chromecast via emby, the server is transcoding down to 11 MBit... that always worked fine. - Yes, the browser (mainly use chrome) work fine, but then they direct stream. Thx again for your help
kwilcox 78 Posted April 2, 2017 Author Posted April 2, 2017 (edited) Uh oh... not good answers. This is pointing to a WebOS compatibility issue (screenplay simply leverages the underlying WebOS HLS capabilities) or something odd about the way your videos were encoded. What's the full version of WebOS on your set? Also, check on your server when you fire up a video to see if a copy of ffmpeg is spawned. The fact that you get a play time on the progress bar means that the server and the TV were able to negotiate a successful stream request. Oh and what version of emby server are you running? Edited April 2, 2017 by kwilcox
muppets4 24 Posted April 2, 2017 Posted April 2, 2017 Since my LG TV came in last week I've tried screenplay a view times. It looks great and has a lot of potential. What I really miss is the first episode option Emby gives me. Is that a feature that will come to screenplay too?
Kipperdawn 5 Posted April 4, 2017 Posted April 4, 2017 Hi Kwilcox, It could very well be an incompatibility between webos / emby / screenplay. I can't find the version of webos on my tv as it isnt shown. The software version is v04.30.65. I am fairly certain it is some form of webos 3. Looking at lg, there is a new firmware for my tv - v04.31.15, and looking at the notes on lg, it appears to be webos 3.5. I am currently running Emby 3.2.7.0. Could try upgrading to the latest, but I tend to wait for a bit so the bugs get worked out first. I have attached 4 snippets - 3 with direct play turned off and different bit rates. Last is using the chromecast directly connected to the tv. Looking at the 3 files, I did notice, though it looks like it is transcoding, it has size=n/a, bitrate=n/a and the framerate is slow. I am not familiar enough with the flags passed in to know if they are correct or not. thx again. kp Direct Play Off - 1 Mbit http://server-1:8096/videos/983bbb23f789b1522cda47fae3f1b018/hls1/main/0.ts?static%20=false&deviceId=c6424699-8981-8d46-1828-7989657f38e2&mediaSourceId=983bbb23f789b1522cda47fae3f1b018&videoCodec=h264&audioCodec=aac&audioStreamIndex=1&videoBitrate=1000000&audioBitrate=128000&maxAudioChannels=5&maxHeight=720&level=41&clientTime=&profile=high&api_key=4bfdc1d053744be5a64b835628d1dd36 {"Protocol":"File","Id":"983bbb23f789b1522cda47fae3f1b018","Path":"\\\\server-1\\Media_Storage_2\\Movies\\The Angry Birds Movie.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS-HD MA","IsRemote":false,"ETag":"63b94aebffc1a9e385f2bfcc135ba872","RunTimeTicks":58338971648,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":16029767,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng Surround","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":16029767,"RequiredHttpHeaders":{}} C:\Applications\Emby\ffmpeg\20160410\ffmpeg.exe -c:v h264_qsv -i file:"\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 1000000 -maxrate 1000000 -bufsize 2000000 -vsync -1 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -codec:a:0 aac -strict experimental -ac 5 -ab 128000 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Applications\Emby\transcoding-temp\3107d8afff5198304b09dd60006612c5.m3u8" -y "C:\Applications\Emby\transcoding-temp\3107d8afff5198304b09dd60006612c5%d.ts" ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv': Metadata: CREATION_TIME : 2016-07-31T07:55:49Z ENCODER : Lavf55.12.0 Duration: 01:37:13.90, start: 0.083000, bitrate: 16029 kb/s Chapter #0:0: start 0.000000, end 425.008000 Metadata: title : Chapter 1 Chapter #0:1: start 425.091000, end 818.151000 Metadata: title : Chapter 2 Chapter #0:2: start 818.234000, end 1222.430000 Metadata: title : Chapter 3 Chapter #0:3: start 1222.513000, end 1538.662000 Metadata: title : Chapter 4 Chapter #0:4: start 1538.745000, end 1977.434000 Metadata: title : Chapter 5 Chapter #0:5: start 1977.517000, end 2314.854000 Metadata: title : Chapter 6 Chapter #0:6: start 2314.937000, end 2496.369000 Metadata: title : Chapter 7 Chapter #0:7: start 2496.452000, end 2832.997000 Metadata: title : Chapter 8 Chapter #0:8: start 2833.080000, end 3124.330000 Metadata: title : Chapter 9 Chapter #0:9: start 3124.413000, end 3367.739000 Metadata: title : Chapter 10 Chapter #0:10: start 3367.822000, end 3548.754000 Metadata: title : Chapter 11 Chapter #0:11: start 3548.837000, end 3822.569000 Metadata: title : Chapter 12 Chapter #0:12: start 3822.652000, end 4305.843000 Metadata: title : Chapter 13 Chapter #0:13: start 4305.926000, end 4735.564000 Metadata: title : Chapter 14 Chapter #0:14: start 4735.647000, end 5034.863000 Metadata: title : Chapter 15 Chapter #0:15: start 5034.946000, end 5833.745000 Metadata: title : Chapter 16 Stream #0:0: Video: h264 (High), nv12, 1920x1040, SAR 255:254 DAR 3060:1651, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s16p (default) Metadata: title : Surround Output #0, segment, to 'C:\Applications\Emby\transcoding-temp\3107d8afff5198304b09dd60006612c5%d.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (h264_qsv), nv12, 1280x690 [sAR 52785:52832 DAR 3060:1651], q=2-31, 1000 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.34.100 h264_qsv Side data: cpb: bitrate max/min/avg: 1000000/0/1000000 buffer size: 2000000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.0, fltp (16 bit), 128 kb/s (default) Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for help frame= 4 fps=0.0 q=0.0 size=N/A time=00:00:00.42 bitrate=N/A speed=0.827x frame= 13 fps= 13 q=-0.0 size=N/A time=00:00:00.81 bitrate=N/A speed=0.786x frame= 24 fps= 16 q=-0.0 size=N/A time=00:00:01.25 bitrate=N/A speed=0.822x frame= 35 fps= 17 q=-0.0 size=N/A time=00:00:01.72 bitrate=N/A speed=0.851x frame= 46 fps= 18 q=-0.0 size=N/A time=00:00:02.17 bitrate=N/A speed=0.86x frame= 56 fps= 18 q=-0.0 size=N/A time=00:00:02.60 bitrate=N/A speed=0.859x frame= 69 fps= 19 q=-0.0 size=N/A time=00:00:03.13 bitrate=N/A speed=0.88x frame= 80 fps= 20 q=-0.0 size=N/A time=00:00:03.60 bitrate=N/A speed=0.887x frame= 92 fps= 20 q=-0.0 size=N/A time=00:00:04.09 bitrate=N/A speed=0.895x frame= 104 fps= 20 q=-0.0 size=N/A time=00:00:04.60 bitrate=N/A speed=0.905x frame= 115 fps= 20 q=-0.0 size=N/A time=00:00:05.05 bitrate=N/A speed=0.896x frame= 126 fps= 21 q=-0.0 size=N/A time=00:00:05.50 bitrate=N/A speed=0.896x frame= 138 fps= 21 q=-0.0 size=N/A time=00:00:06.03 bitrate=N/A speed=0.909x frame= 149 fps= 21 q=-0.0 size=N/A time=00:00:06.46 bitrate=N/A speed=0.903x frame= 159 fps= 21 q=-0.0 size=N/A time=00:00:06.91 bitrate=N/A speed=0.901x frame= 169 fps= 21 q=-0.0 size=N/A time=00:00:07.31 bitrate=N/A speed=0.894x frame= 179 fps= 21 q=-0.0 size=N/A time=00:00:07.74 bitrate=N/A speed=0.89x frame= 190 fps= 21 q=-0.0 size=N/A time=00:00:08.19 bitrate=N/A speed=0.889x frame= 199 fps= 20 q=-0.0 size=N/A time=00:00:08.55 bitrate=N/A speed=0.879x frame= 208 fps= 20 q=-0.0 size=N/A time=00:00:08.96 bitrate=N/A speed=0.874x frame= 219 fps= 20 q=-0.0 size=N/A time=00:00:09.38 bitrate=N/A speed=0.873x frame= 229 fps= 20 q=-0.0 size=N/A time=00:00:09.83 bitrate=N/A speed=0.873x frame= 240 fps= 20 q=-0.0 size=N/A time=00:00:10.26 bitrate=N/A speed=0.869x frame= 251 fps= 20 q=-0.0 size=N/A time=00:00:10.73 bitrate=N/A speed=0.87x frame= 261 fps= 20 q=-0.0 size=N/A time=00:00:11.13 bitrate=N/A speed=0.867x frame= 272 fps= 20 q=-0.0 size=N/A time=00:00:11.60 bitrate=N/A speed=0.869x frame= 281 fps= 20 q=-0.0 size=N/A time=00:00:12.01 bitrate=N/A speed=0.866x frame= 291 fps= 20 q=-0.0 size=N/A time=00:00:12.39 bitrate=N/A speed=0.862x frame= 300 fps= 20 q=-0.0 size=N/A time=00:00:12.80 bitrate=N/A speed=0.86x frame= 311 fps= 20 q=-0.0 size=N/A time=00:00:13.22 bitrate=N/A speed=0.858x frame= 321 fps= 20 q=-0.0 size=N/A time=00:00:13.65 bitrate=N/A speed=0.858x frame= 331 fps= 20 q=-0.0 size=N/A time=00:00:14.08 bitrate=N/A speed=0.857x Direct Play Off - 10 Mbit http://server-1:8096/videos/983bbb23f789b1522cda47fae3f1b018/hls1/main/0.ts?static%20=false&deviceId=c6424699-8981-8d46-1828-7989657f38e2&mediaSourceId=983bbb23f789b1522cda47fae3f1b018&videoCodec=h264&audioCodec=aac&audioStreamIndex=1&videoBitrate=10000000&audioBitrate=128000&maxAudioChannels=5&maxHeight=720&level=41&clientTime=&profile=high&api_key=4bfdc1d053744be5a64b835628d1dd36 {"Protocol":"File","Id":"983bbb23f789b1522cda47fae3f1b018","Path":"\\\\server-1\\Media_Storage_2\\Movies\\The Angry Birds Movie.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS-HD MA","IsRemote":false,"ETag":"63b94aebffc1a9e385f2bfcc135ba872","RunTimeTicks":58338971648,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":16029767,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng Surround","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":16029767,"RequiredHttpHeaders":{}} C:\Applications\Emby\ffmpeg\3.2.2-win64-static\bin\ffmpeg.exe -c:v h264_qsv -i file:"\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 10000000 -maxrate 10000000 -bufsize 20000000 -vsync -1 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(oh*a/2)*2:min(max(iw/dar\,ih)\,720)" -copyts -codec:a:0 aac -strict experimental -ac 5 -ab 128000 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Applications\Emby\transcoding-temp\802ec93430b75f8acc158a1f4c05f271.m3u8" -y "C:\Applications\Emby\transcoding-temp\802ec93430b75f8acc158a1f4c05f271%d.ts" ffmpeg version 3.2.2 Copyright © 2000-2016 the FFmpeg developers built with gcc 5.4.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 34.100 / 55. 34.100 libavcodec 57. 64.101 / 57. 64.101 libavformat 57. 56.100 / 57. 56.100 libavdevice 57. 1.100 / 57. 1.100 libavfilter 6. 65.100 / 6. 65.100 libswscale 4. 2.100 / 4. 2.100 libswresample 2. 3.100 / 2. 3.100 libpostproc 54. 1.100 / 54. 1.100 Input #0, matroska,webm, from 'file:\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv': Metadata: CREATION_TIME : 2016-07-31T07:55:49Z ENCODER : Lavf55.12.0 Duration: 01:37:13.90, start: 0.083000, bitrate: 16029 kb/s Chapter #0:0: start 0.000000, end 425.008000 Metadata: title : Chapter 1 Chapter #0:1: start 425.091000, end 818.151000 Metadata: title : Chapter 2 Chapter #0:2: start 818.234000, end 1222.430000 Metadata: title : Chapter 3 Chapter #0:3: start 1222.513000, end 1538.662000 Metadata: title : Chapter 4 Chapter #0:4: start 1538.745000, end 1977.434000 Metadata: title : Chapter 5 Chapter #0:5: start 1977.517000, end 2314.854000 Metadata: title : Chapter 6 Chapter #0:6: start 2314.937000, end 2496.369000 Metadata: title : Chapter 7 Chapter #0:7: start 2496.452000, end 2832.997000 Metadata: title : Chapter 8 Chapter #0:8: start 2833.080000, end 3124.330000 Metadata: title : Chapter 9 Chapter #0:9: start 3124.413000, end 3367.739000 Metadata: title : Chapter 10 Chapter #0:10: start 3367.822000, end 3548.754000 Metadata: title : Chapter 11 Chapter #0:11: start 3548.837000, end 3822.569000 Metadata: title : Chapter 12 Chapter #0:12: start 3822.652000, end 4305.843000 Metadata: title : Chapter 13 Chapter #0:13: start 4305.926000, end 4735.564000 Metadata: title : Chapter 14 Chapter #0:14: start 4735.647000, end 5034.863000 Metadata: title : Chapter 15 Chapter #0:15: start 5034.946000, end 5833.745000 Metadata: title : Chapter 16 Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1040 [sAR 260:259 DAR 480:259], SAR 255:254 DAR 3060:1651, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s16p (default) Metadata: title : Surround Output #0, segment, to 'C:\Applications\Emby\transcoding-temp\802ec93430b75f8acc158a1f4c05f271%d.ts': Metadata: encoder : Lavf57.56.100 Stream #0:0: Video: h264 (h264_qsv), nv12, 1328x720 [sAR 137700:137033 DAR 3060:1651], q=2-31, 10000 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.64.101 h264_qsv Side data: cpb: bitrate max/min/avg: 10000000/0/10000000 buffer size: 20000000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.0, fltp (16 bit), 128 kb/s (default) Metadata: encoder : Lavc57.64.101 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for help Input stream #0:0 frame changed from size:1920x1040 fmt:yuv420p to size:1920x1040 fmt:nv12 frame= 2 fps=0.0 q=0.0 size=N/A time=00:00:00.29 bitrate=N/A speed=0.546x frame= 10 fps=9.6 q=-0.0 size=N/A time=00:00:00.70 bitrate=N/A speed=0.672x frame= 21 fps= 14 q=-0.0 size=N/A time=00:00:01.15 bitrate=N/A speed=0.745x frame= 32 fps= 16 q=-0.0 size=N/A time=00:00:01.60 bitrate=N/A speed=0.776x frame= 42 fps= 16 q=-0.0 size=N/A time=00:00:02.02 bitrate=N/A speed=0.791x frame= 54 fps= 18 q=-0.0 size=N/A time=00:00:02.53 bitrate=N/A speed=0.829x frame= 65 fps= 18 q=-0.0 size=N/A time=00:00:02.98 bitrate=N/A speed=0.835x frame= 75 fps= 18 q=-0.0 size=N/A time=00:00:03.39 bitrate=N/A speed=0.832x frame= 87 fps= 19 q=-0.0 size=N/A time=00:00:03.88 bitrate=N/A speed=0.848x frame= 99 fps= 19 q=-0.0 size=N/A time=00:00:04.39 bitrate=N/A speed=0.865x frame= 111 fps= 20 q=-0.0 size=N/A time=00:00:04.88 bitrate=N/A speed=0.871x frame= 121 fps= 20 q=-0.0 size=N/A time=00:00:05.31 bitrate=N/A speed=0.865x frame= 133 fps= 20 q=-0.0 size=N/A time=00:00:05.82 bitrate=N/A speed=0.877x frame= 144 fps= 20 q=-0.0 size=N/A time=00:00:06.27 bitrate=N/A speed=0.878x frame= 155 fps= 20 q=-0.0 size=N/A time=00:00:06.72 bitrate=N/A speed=0.878x frame= 165 fps= 20 q=-0.0 size=N/A time=00:00:07.14 bitrate=N/A speed=0.876x frame= 174 fps= 20 q=-0.0 size=N/A time=00:00:07.55 bitrate=N/A speed=0.871x frame= 185 fps= 20 q=-0.0 size=N/A time=00:00:07.97 bitrate=N/A speed=0.867x frame= 195 fps= 20 q=-0.0 size=N/A time=00:00:08.40 bitrate=N/A speed=0.866x frame= 206 fps= 20 q=-0.0 size=N/A time=00:00:08.85 bitrate=N/A speed=0.865x frame= 215 fps= 20 q=-0.0 size=N/A time=00:00:09.23 bitrate=N/A speed=0.86x frame= 225 fps= 20 q=-0.0 size=N/A time=00:00:09.64 bitrate=N/A speed=0.857x frame= 234 fps= 20 q=-0.0 size=N/A time=00:00:10.02 bitrate=N/A speed=0.852x frame= 242 fps= 20 q=-0.0 size=N/A time=00:00:10.36 bitrate=N/A speed=0.845x Direct Play Off - 100 Mbit http://server-1:8096/videos/983bbb23f789b1522cda47fae3f1b018/hls1/main/0.ts?static%20=false&deviceId=c6424699-8981-8d46-1828-7989657f38e2&mediaSourceId=983bbb23f789b1522cda47fae3f1b018&videoCodec=h264&audioCodec=aac&audioStreamIndex=1&videoBitrate=100000000&audioBitrate=128000&maxAudioChannels=5&maxHeight=720&level=41&clientTime=&profile=high&api_key=4bfdc1d053744be5a64b835628d1dd36 {"Protocol":"File","Id":"983bbb23f789b1522cda47fae3f1b018","Path":"\\\\server-1\\Media_Storage_2\\Movies\\The Angry Birds Movie.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS-HD MA","IsRemote":false,"ETag":"63b94aebffc1a9e385f2bfcc135ba872","RunTimeTicks":58338971648,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":16029767,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng Surround","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":16029767,"RequiredHttpHeaders":{}} C:\Applications\Emby\ffmpeg\20160410\ffmpeg.exe -c:v h264_qsv -i file:"\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 16029767 -maxrate 16029767 -bufsize 32059534 -vsync -1 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(oh*a/2)*2:min(max(iw/dar\,ih)\,720)" -copyts -codec:a:0 aac -strict experimental -ac 5 -ab 128000 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Applications\Emby\transcoding-temp\30859200dfeaf7e56c6fe0debd670a52.m3u8" -y "C:\Applications\Emby\transcoding-temp\30859200dfeaf7e56c6fe0debd670a52%d.ts" ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv': Metadata: CREATION_TIME : 2016-07-31T07:55:49Z ENCODER : Lavf55.12.0 Duration: 01:37:13.90, start: 0.083000, bitrate: 16029 kb/s Chapter #0:0: start 0.000000, end 425.008000 Metadata: title : Chapter 1 Chapter #0:1: start 425.091000, end 818.151000 Metadata: title : Chapter 2 Chapter #0:2: start 818.234000, end 1222.430000 Metadata: title : Chapter 3 Chapter #0:3: start 1222.513000, end 1538.662000 Metadata: title : Chapter 4 Chapter #0:4: start 1538.745000, end 1977.434000 Metadata: title : Chapter 5 Chapter #0:5: start 1977.517000, end 2314.854000 Metadata: title : Chapter 6 Chapter #0:6: start 2314.937000, end 2496.369000 Metadata: title : Chapter 7 Chapter #0:7: start 2496.452000, end 2832.997000 Metadata: title : Chapter 8 Chapter #0:8: start 2833.080000, end 3124.330000 Metadata: title : Chapter 9 Chapter #0:9: start 3124.413000, end 3367.739000 Metadata: title : Chapter 10 Chapter #0:10: start 3367.822000, end 3548.754000 Metadata: title : Chapter 11 Chapter #0:11: start 3548.837000, end 3822.569000 Metadata: title : Chapter 12 Chapter #0:12: start 3822.652000, end 4305.843000 Metadata: title : Chapter 13 Chapter #0:13: start 4305.926000, end 4735.564000 Metadata: title : Chapter 14 Chapter #0:14: start 4735.647000, end 5034.863000 Metadata: title : Chapter 15 Chapter #0:15: start 5034.946000, end 5833.745000 Metadata: title : Chapter 16 Stream #0:0: Video: h264 (High), nv12, 1920x1040, SAR 255:254 DAR 3060:1651, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s16p (default) Metadata: title : Surround Output #0, segment, to 'C:\Applications\Emby\transcoding-temp\30859200dfeaf7e56c6fe0debd670a52%d.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (h264_qsv), nv12, 1328x720 [sAR 137700:137033 DAR 3060:1651], q=2-31, 16029 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.34.100 h264_qsv Side data: cpb: bitrate max/min/avg: 16029767/0/16029767 buffer size: 32059534 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.0, fltp (16 bit), 128 kb/s (default) Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for help frame= 3 fps=0.0 q=0.0 size=N/A time=00:00:00.38 bitrate=N/A speed=0.745x frame= 14 fps= 13 q=-0.0 size=N/A time=00:00:00.85 bitrate=N/A speed=0.815x frame= 26 fps= 17 q=-0.0 size=N/A time=00:00:01.34 bitrate=N/A speed=0.86x frame= 38 fps= 18 q=-0.0 size=N/A time=00:00:01.83 bitrate=N/A speed=0.883x frame= 49 fps= 19 q=-0.0 size=N/A time=00:00:02.32 bitrate=N/A speed=0.902x frame= 61 fps= 20 q=-0.0 size=N/A time=00:00:02.79 bitrate=N/A speed=0.903x frame= 71 fps= 20 q=-0.0 size=N/A time=00:00:03.22 bitrate=N/A speed=0.896x frame= 84 fps= 20 q=-0.0 size=N/A time=00:00:03.75 bitrate=N/A speed=0.914x frame= 96 fps= 21 q=-0.0 size=N/A time=00:00:04.28 bitrate=N/A speed=0.927x frame= 110 fps= 21 q=-0.0 size=N/A time=00:00:04.84 bitrate=N/A speed=0.939x frame= 121 fps= 21 q=-0.0 size=N/A time=00:00:05.33 bitrate=N/A speed=0.943x frame= 134 fps= 22 q=-0.0 size=N/A time=00:00:05.84 bitrate=N/A speed=0.947x frame= 144 fps= 22 q=-0.0 size=N/A time=00:00:06.27 bitrate=N/A speed=0.938x frame= 155 fps= 22 q=-0.0 size=N/A time=00:00:06.72 bitrate=N/A speed=0.935x frame= 165 fps= 21 q=-0.0 size=N/A time=00:00:07.14 bitrate=N/A speed=0.926x frame= 175 fps= 21 q=-0.0 size=N/A time=00:00:07.55 bitrate=N/A speed=0.917x frame= 188 fps= 21 q=-0.0 size=N/A time=00:00:08.10 bitrate=N/A speed=0.926x frame= 199 fps= 22 q=-0.0 size=N/A time=00:00:08.57 bitrate=N/A speed=0.927x frame= 208 fps= 21 q=-0.0 size=N/A time=00:00:08.96 bitrate=N/A speed=0.919x frame= 218 fps= 21 q=-0.0 size=N/A time=00:00:09.34 bitrate=N/A speed=0.912x frame= 229 fps= 21 q=-0.0 size=N/A time=00:00:09.81 bitrate=N/A speed=0.913x frame= 238 fps= 21 q=-0.0 size=N/A time=00:00:10.19 bitrate=N/A speed=0.906x frame= 250 fps= 21 q=-0.0 size=N/A time=00:00:10.68 bitrate=N/A speed=0.91x frame= 259 fps= 21 q=-0.0 size=N/A time=00:00:11.07 bitrate=N/A speed=0.903x frame= 268 fps= 21 q=-0.0 size=N/A time=00:00:11.45 bitrate=N/A speed=0.897x Chromecast http://server-1:8096/videos/983bbb23f789b1522cda47fae3f1b018/stream.mkv?DeviceId=fe4bcc43303f642960bb4baf5b143d8d90244569&MediaSourceId=983bbb23f789b1522cda47fae3f1b018&VideoCodec=h264&AudioCodec=ac3,mp3,aac&AudioStreamIndex=1&VideoBitrate=10616000&AudioBitrate=384000&Level=51&Profile=high&PlaySessionId=54d6a72c89e04269973ef157db7094a7&api_key=6b1407b2f6214a3284ec9f296e55353f&CopyTimestamps=true&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=63b94aebffc1a9e385f2bfcc135ba872&RequireAvc=true {"Protocol":"File","Id":"983bbb23f789b1522cda47fae3f1b018","Path":"\\\\server-1\\Media_Storage_2\\Movies\\The Angry Birds Movie.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS-HD MA","IsRemote":false,"ETag":"63b94aebffc1a9e385f2bfcc135ba872","RunTimeTicks":58338971648,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":16029767,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng Surround","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":16029767,"RequiredHttpHeaders":{}} C:\Applications\Emby\ffmpeg\20160410\ffmpeg.exe -c:v h264_qsv -i file:"\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -force_key_frames "expr:gte(t,n_forced*5)" -copyts -avoid_negative_ts disabled -start_at_zero -preset 7 -look_ahead 0 -b:v 10616000 -maxrate 10616000 -bufsize 21232000 -vsync -1 -profile:v high -level 4.1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 384000 -af "aresample=async=1" -y "C:\Applications\Emby\transcoding-temp\5e344d00f16fca80ad1fa49628a86c97.mkv" ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:\\server-1\Media_Storage_2\Movies\The Angry Birds Movie.mkv': Metadata: CREATION_TIME : 2016-07-31T07:55:49Z ENCODER : Lavf55.12.0 Duration: 01:37:13.90, start: 0.083000, bitrate: 16029 kb/s Chapter #0:0: start 0.000000, end 425.008000 Metadata: title : Chapter 1 Chapter #0:1: start 425.091000, end 818.151000 Metadata: title : Chapter 2 Chapter #0:2: start 818.234000, end 1222.430000 Metadata: title : Chapter 3 Chapter #0:3: start 1222.513000, end 1538.662000 Metadata: title : Chapter 4 Chapter #0:4: start 1538.745000, end 1977.434000 Metadata: title : Chapter 5 Chapter #0:5: start 1977.517000, end 2314.854000 Metadata: title : Chapter 6 Chapter #0:6: start 2314.937000, end 2496.369000 Metadata: title : Chapter 7 Chapter #0:7: start 2496.452000, end 2832.997000 Metadata: title : Chapter 8 Chapter #0:8: start 2833.080000, end 3124.330000 Metadata: title : Chapter 9 Chapter #0:9: start 3124.413000, end 3367.739000 Metadata: title : Chapter 10 Chapter #0:10: start 3367.822000, end 3548.754000 Metadata: title : Chapter 11 Chapter #0:11: start 3548.837000, end 3822.569000 Metadata: title : Chapter 12 Chapter #0:12: start 3822.652000, end 4305.843000 Metadata: title : Chapter 13 Chapter #0:13: start 4305.926000, end 4735.564000 Metadata: title : Chapter 14 Chapter #0:14: start 4735.647000, end 5034.863000 Metadata: title : Chapter 15 Chapter #0:15: start 5034.946000, end 5833.745000 Metadata: title : Chapter 16 Stream #0:0: Video: h264 (High), nv12, 1920x1040, SAR 255:254 DAR 3060:1651, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s16p (default) Metadata: title : Surround Output #0, matroska, to 'C:\Applications\Emby\transcoding-temp\5e344d00f16fca80ad1fa49628a86c97.mkv': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (h264_qsv) (H264 / 0x34363248), nv12, 1920x1040 [sAR 255:254 DAR 3060:1651], q=2-31, 10616 kb/s, 23.98 fps, 1k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.34.100 h264_qsv Side data: cpb: bitrate max/min/avg: 10616000/0/10616000 buffer size: 21232000 vbv_delay: -1 Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1, fltp (16 bit), 384 kb/s (default) Metadata: encoder : Lavc57.34.100 ac3 Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native)) Press [q] to stop, [?] for help frame= 7 fps=0.0 q=0.0 size= 0kB time=00:00:00.57 bitrate= 0.0kbits/s speed=1.14x frame= 40 fps= 40 q=-0.0 size= 1792kB time=00:00:01.94 bitrate=7538.9kbits/s speed=1.95x frame= 74 fps= 49 q=-0.0 size= 3919kB time=00:00:03.38 bitrate=9478.1kbits/s speed=2.23x frame= 114 fps= 56 q=-0.0 size= 6145kB time=00:00:05.05 bitrate=9965.9kbits/s speed=2.49x frame= 146 fps= 58 q=-0.0 size= 7963kB time=00:00:06.39 bitrate=10200.4kbits/s speed=2.53x frame= 176 fps= 58 q=-0.0 size= 9762kB time=00:00:07.64 bitrate=10463.1kbits/s speed=2.52x frame= 211 fps= 59 q=-0.0 size= 11926kB time=00:00:09.08 bitrate=10756.0kbits/s speed=2.56x frame= 243 fps= 60 q=-0.0 size= 13697kB time=00:00:10.42 bitrate=10761.2kbits/s speed=2.57x frame= 276 fps= 60 q=-0.0 size= 15575kB time=00:00:11.80 bitrate=10809.7kbits/s speed=2.59x frame= 309 fps= 61 q=-0.0 size= 17377kB time=00:00:13.17 bitrate=10801.3kbits/s speed= 2.6x frame= 342 fps= 61 q=-0.0 size= 19305kB time=00:00:14.55 bitrate=10865.4kbits/s speed=2.62x frame= 371 fps= 61 q=-0.0 size= 20705kB time=00:00:15.80 bitrate=10733.1kbits/s speed= 2.6x frame= 404 fps= 61 q=-0.0 size= 22794kB time=00:00:17.14 bitrate=10890.0kbits/s speed=2.61x frame= 437 fps= 62 q=-0.0 size= 24424kB time=00:00:18.52 bitrate=10801.8kbits/s speed=2.61x frame= 466 fps= 61 q=-0.0 size= 26206kB time=00:00:19.73 bitrate=10875.7kbits/s speed=2.59x frame= 498 fps= 61 q=-0.0 size= 28023kB time=00:00:21.05 bitrate=10905.3kbits/s speed=2.59x frame= 527 fps= 61 q=-0.0 size= 29888kB time=00:00:22.26 bitrate=10995.8kbits/s speed=2.58x frame= 558 fps= 61 q=-0.0 size= 31545kB time=00:00:23.57 bitrate=10959.6kbits/s speed=2.58x frame= 594 fps= 62 q=-0.0 size= 33455kB time=00:00:25.05 bitrate=10940.2kbits/s speed=2.59x frame= 627 fps= 62 q=-0.0 size= 35078kB time=00:00:26.42 bitrate=10873.8kbits/s speed= 2.6x frame= 662 fps= 62 q=-0.0 size= 36913kB time=00:00:27.89 bitrate=10838.7kbits/s speed=2.62x frame= 694 fps= 62 q=-0.0 size= 38720kB time=00:00:29.24 bitrate=10846.9kbits/s speed=2.62x frame= 726 fps= 62 q=-0.0 size= 40452kB time=00:00:30.58 bitrate=10834.1kbits/s speed=2.62x frame= 759 fps= 62 q=-0.0 size= 42511kB time=00:00:31.96 bitrate=10895.5kbits/s speed=2.62x frame= 793 fps= 62 q=-0.0 size= 44613kB time=00:00:33.37 bitrate=10951.8kbits/s speed=2.63x frame= 826 fps= 63 q=-0.0 size= 45994kB time=00:00:34.74 bitrate=10843.6kbits/s speed=2.63x frame= 855 fps= 62 q=-0.0 size= 47773kB time=00:00:35.96 bitrate=10882.1kbits/s speed=2.62x frame= 885 fps= 62 q=-0.0 size= 49692kB time=00:00:37.21 bitrate=10939.6kbits/s speed=2.62x frame= 914 fps= 62 q=-0.0 size= 51191kB time=00:00:38.42 bitrate=10913.2kbits/s speed=2.61x frame= 941 fps= 62 q=-0.0 size= 52597kB time=00:00:39.54 bitrate=10895.3kbits/s speed= 2.6x frame= 968 fps= 61 q=-0.0 size= 54252kB time=00:00:40.66 bitrate=10928.6kbits/s speed=2.58x frame= 994 fps= 61 q=-0.0 size= 55690kB time=00:00:41.75 bitrate=10926.0kbits/s speed=2.57x frame= 1020 fps= 61 q=-0.0 size= 57362kB time=00:00:42.84 bitrate=10968.1kbits/s speed=2.56x
kwilcox 78 Posted April 6, 2017 Author Posted April 6, 2017 (edited) @@Kipperdawn: your set came with WebOS3.0 and your last snippet definitely shows transcoding active. The video looks pretty vanilla too. I'm going to PM you a link to my QA site. Try attaching screenplay to it and testing. Its the same site that LG uses for QA purposes. Videos might lag due to the WAN connection, but they should definitely play. Let me know what your results are! Edited April 6, 2017 by kwilcox
Kipperdawn 5 Posted April 7, 2017 Posted April 7, 2017 Hi Kwilcox, So i redirected screenplay to the address provided, and it definitely works better. I have the video bitrate set to 100 Mbit/s and with direct play off. I will play for a few seconds ~20-30 seconds, then pause for 8 seconds, then continue... it isn't exact as the pauses / play times vary... but at least it does play. There is also a lot of audio chips. Guessing this is a result of distance between the player and server. Given this, i guess it means my problems are either my server config or network config ? thx again for all your support. kp
Kipperdawn 5 Posted April 7, 2017 Posted April 7, 2017 Hi Kwilcox,, So i just tried a bit more experimentation, now that i know the issue lies on my end. I turned of intel quick sync hardware assist as this isn't the first time it caused me issues... and sure enough, it worked. Interestingly enough, i got the same audio chirps. So it has something to do with hardware assisted encoding. I could try nvidia since i have a spare nv card i could put in the computer to see if it has the same issue. So this leads me to a question i have wondered for a while. Do most people use software transcoding ? I find that strange or maybe i have some funny setting because encoding a single stream on my server can easily use 80% of the cpu... so how does one support 3 or 4 streams simultaneously then? When i use hw assist, the server consume 15% of the cpu so i can easily do 4 without the system grinding to a halt. Note, i like the high quality video so i try to get the highest bit rates i can, especially since my tv is 4k... Ideally, no transcoding is required, but if it is, my settings are h264 =slow and crf =15. thx for the help and guidance. kp
kwilcox 78 Posted April 7, 2017 Author Posted April 7, 2017 I suspect that the answer is yes. The Synology platform is very popular for emby server as are VM based implementations such as mine. I believe this is one of the reasons why there was a real demand for the direct streaming option in screenplay. To tell the truth, that's pretty much all I use myself these days.
pstellato 0 Posted April 14, 2017 Posted April 14, 2017 (edited) Is there a way to just log in with an emby account and not have to add an IP address:port? or to access servers that I have access to on my account without having to access direct through IP? I have some servers that I access on my account but don't really have a server set up for myself. I do but its blank at the moment. I can access them through the web on emby, but screenplay does not seem to work that way. I just bought an LG webOS 3.0 TV so I'm new to this. Edited April 14, 2017 by pstellato
kwilcox 78 Posted April 16, 2017 Author Posted April 16, 2017 (edited) You can enter an Emby Server URL for screeenplay as well. Same syntax as a browser. Edited April 16, 2017 by kwilcox
pstellato 0 Posted April 17, 2017 Posted April 17, 2017 You can enter an Emby Server URL for screeenplay as well. Same syntax as a browser. Ok. So I can enter app.emby.media and it will take? That's what I see in the browser.
kwilcox 78 Posted April 17, 2017 Author Posted April 17, 2017 (edited) ahh, now I understand. Screenplay doesn't support the Emby media portal/emby connect. It's designed to connect to and act as a native viewer client for a single emby server. Edited April 17, 2017 by kwilcox
pstellato 0 Posted April 17, 2017 Posted April 17, 2017 OK. Thanks. I'm not set up for that yet. Guess I'm going to have to connect my shield tv back up.
azeos 8 Posted April 23, 2017 Posted April 23, 2017 Sorry for this basic question, but I can't find Screenplay in the LG Content Store. I just bought a 49LH5700 is my tv supported? My country is set to Argentina. Thanks!
iMan 0 Posted April 23, 2017 Posted April 23, 2017 Hi, As the Argentina LG app site is closed (http://ar.lgappstv.com/appspc/close/closingServiceGuide.lge). I'd say it is normal you don't see the app. Try to set the country to any other running and try again...
mastrmind11 728 Posted April 28, 2017 Posted April 28, 2017 Posted in the general LG TV forum, but it's related to screenplay: https://emby.media/community/index.php?/topic/47147-cpu-pegged-why/
kwilcox 78 Posted April 30, 2017 Author Posted April 30, 2017 (edited) direct play on or off in settings? Direct play is actually direct stream from your emby server's perspectie btw. Edited April 30, 2017 by kwilcox
mastrmind11 728 Posted May 1, 2017 Posted May 1, 2017 direct play on or off in settings? Direct play is actually direct stream from your emby server's perspectie btw. direct play is enabled in the settings.
kwilcox 78 Posted May 1, 2017 Author Posted May 1, 2017 (edited) very odd. Your attached logs from the other thread show that screenplay is using HLS. Since WebOS can handle DTS audio for example, its very possible that the negotiated transcoding stream could be much more processor intensive. See the other thread for a code snippet. I don't see how screenplay v1.2.1 can offer an HLS session if directplay is set to enabled. Are you running v1.2.1? Edited May 1, 2017 by kwilcox
johnbury 4 Posted May 1, 2017 Posted May 1, 2017 I have a file (MKV) which plays fine natively in a browser on my Emby Server, but plays only with no sound via my LG TV and Screenplay... The file has 3 embedded language tracks (English is default). All sound tracks have been encoded using a codec (OPUS) I haven't seen before has been used What more info do you need from me to investigate? cheers
kwilcox 78 Posted May 1, 2017 Author Posted May 1, 2017 WebOS probably doesn't have that codec. Your only option is to use transcoding.
johnbury 4 Posted May 1, 2017 Posted May 1, 2017 (edited) I'll give it a go, thanks **** Update!! Turned off 'Direct Play' and it worked a charm!! Thanks Cheers Edited May 1, 2017 by johnbury
