m-joy 15 Posted September 25, 2016 Author Posted September 25, 2016 Since the Videos are playing on all other systems than the shield, i do not want to reencode everything. Is there a way for you guys to fix the playback on the apk? Otherwise i might sell the shield and buy something else.
ebr 16339 Posted September 25, 2016 Posted September 25, 2016 Luke - was anything done on the server end to discover the lacing and correct it?
Luke 42249 Posted September 25, 2016 Posted September 25, 2016 Unfortunately I see nothing in ffprobe output to detect it.
m-joy 15 Posted October 11, 2016 Author Posted October 11, 2016 So in conclusion you are telling me that there is no fix for the problem and i paid 6 euro for the app for nothing? For information, Plex can play all movies on my nvidia shield android TV , kodi can, emby can not?!?
ebr 16339 Posted October 11, 2016 Posted October 11, 2016 There are a couple of avenues that may help. 1) It is possible that a future update to the Google player will support this format. 2) If we can figure out why your items are needing to transcode, and eliminate that so they can direct stream, then that may fix it as well.
m-joy 15 Posted October 16, 2016 Author Posted October 16, 2016 Hi, with the latest android tv app 1.2.66g the problem seems to be gone. At least so far as i was able to test. I will have an eye on that
m-joy 15 Posted October 16, 2016 Author Posted October 16, 2016 Jeah seems to be better now. Still having issues with 4k and high Resolution Audio content
Luke 42249 Posted December 7, 2016 Posted December 7, 2016 The latest beta version of the Emby app offers improved playback, refresh rate switching, and all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks !
