screwfaze 38 Posted June 20, 2016 Posted June 20, 2016 As title says I am changing channels but Emby just continues playing the same TV Show that I first played. Its showing the new channel on the remote section but not changing. Please advice sorry if this is a known issue. Thanks
Luke 42243 Posted June 20, 2016 Posted June 20, 2016 Can you describe the exact sequence of events you're taking? thanks.
screwfaze 38 Posted June 20, 2016 Author Posted June 20, 2016 Sure so I start any TV channel on my emby app kodi and it starts playing then I stop and start a different channel but it continues playing from where I left of. Even starting another channel on a different app on my phone it just continues from where I was. It's like it didn't recognize that I am choosing another channel.
Angelblue05 4132 Posted June 20, 2016 Posted June 20, 2016 Sorry Luke, I don't know what it could be - marcelveldt is the one that implemented the "experimental channels". I don't think I'll be able to help much on this one, I don't have live TV. @@screwfaze Can you repeat what you were doing, enable the emby add-on logging, set to Info - If it's not enough info, you can switch to Debug. Check here to see how to grab your Kodi log: http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/
pünktchen 1411 Posted June 21, 2016 Posted June 21, 2016 It seems Kodi doesn't send a "close stream" request to Emby when changing channels. 1
Angelblue05 4132 Posted June 21, 2016 Posted June 21, 2016 Ok and what is required to close stream? I'll add it, thanks for looking into it. I can't find the information.
pünktchen 1411 Posted June 21, 2016 Posted June 21, 2016 Ok and what is required to close stream? I'll add it, thanks for looking into it. I can't find the information.From the log it seems the stream is closed properly when stopping playback in Kodi. So just look in your code what you are doing there, otherwise you have to ask @@Luke for details.
screwfaze 38 Posted June 21, 2016 Author Posted June 21, 2016 Hi Guys, So do you still need my Kodi logs? Thanks
Angelblue05 4132 Posted June 21, 2016 Posted June 21, 2016 Well I do not have Live TV so I can't really help pinpoint the issue. Do you mind still posting your log, so I can see what is happening when you try and change channel? Thanks. Sent from my iPhone using Tapatalk
screwfaze 38 Posted June 21, 2016 Author Posted June 21, 2016 Hi, I have attached the Kodi Log. Thanks 1
Angelblue05 4132 Posted June 21, 2016 Posted June 21, 2016 (edited) @@screwfaze - do you mind trying the latest add-on beta version (2.2.11)? I see that the stream is reported as direct play which I have correctly already. I believe that's the reason it's not working correctly. You are still using 2.0.1 which is very old. Edited June 21, 2016 by Angelblue05
screwfaze 38 Posted June 22, 2016 Author Posted June 22, 2016 Hi, So I have updated the addon to 2.2.11 but still does not change channel. I have changed to Serverwmc by the way. Thanks
pünktchen 1411 Posted June 22, 2016 Posted June 22, 2016 I have changed to Serverwmc by the way. Because of guide images?
screwfaze 38 Posted June 22, 2016 Author Posted June 22, 2016 Yes and just to see if it would work better too. Thanks
screwfaze 38 Posted June 22, 2016 Author Posted June 22, 2016 Serverwmc is allowing me to do series recording of the shows I was not able to with Mediaportal.
pünktchen 1411 Posted June 22, 2016 Posted June 22, 2016 Serverwmc is allowing me to do series recording of the shows I was not able to with Mediaportal.Didn't you follow my instructions in your other thread?
Angelblue05 4132 Posted June 22, 2016 Posted June 22, 2016 It's very weird, the server response shows the corrent channel working - the id to the channel is different... I am not sure what is going on. We send the proper stop to the server I think? @@Luke we use sessions/playing/stopped and also do the activeencodings deletion... I don't know what is missing? Is there something wrong with using /live.m3u8?static=true - again I don't have live tv so any pointers is appreciated to hopefully fix this. Thanks Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted June 23, 2016 Posted June 23, 2016 (edited) @@screwfaze Can you give this build a try? Let me know if it helps with the channel change - if not post your new Kodi log. Thank you Edited June 23, 2016 by Angelblue05
screwfaze 38 Posted June 23, 2016 Author Posted June 23, 2016 Hi, Sorry still the same please find the log attached and thanks for all the hard work. Thanks 1
screwfaze 38 Posted June 23, 2016 Author Posted June 23, 2016 Sorry didn't attach before here it is. Thanks
screwfaze 38 Posted June 23, 2016 Author Posted June 23, 2016 Hi, I have actually noticed an improvement, if I stop the channel and wait about 3 minutes and play another channel it actually plays the new channel now. Looks like it takes abit of time before Emby recognises the change. Thanks 1
