darthweder 3 Posted June 27, 2016 Posted June 27, 2016 Okay. .15 is going to transcode that as well on your NP but I'll make it allow that before we release. Sounds good. Thanks for fixing that ebr!
darthweder 3 Posted June 28, 2016 Posted June 28, 2016 I updated my client to 1.2.15 and it is working perfectly. Both of the shows transcoded, and played.
ebr 16337 Posted June 28, 2016 Posted June 28, 2016 I updated my client to 1.2.15 and it is working perfectly. Both of the shows transcoded, and played. Okay, in the next beta, we'll need to be sure they both still play properly. Thx.
CBers 7554 Posted June 28, 2016 Posted June 28, 2016 Okay, CBers, please test to be sure that still direct plays in VLC on your Shield with .15 when you get it. Yes, all still Direct/V in .15.
ebr 16337 Posted June 28, 2016 Posted June 28, 2016 Yes, all still Direct/V in .15. Thanks. .16 will be going up in a bit. If both of you can confirm those hevc items still play back properly with it, then I should be done dealing with those . 1
ebr 16337 Posted June 29, 2016 Posted June 29, 2016 @@darthweder please test with .16 when you get a chance. Thanks.
CBers 7554 Posted June 29, 2016 Posted June 29, 2016 Thanks. .16 will be going up in a bit. If both of you can confirm those hevc items still play back properly with it, then I should be done dealing with those . Still playing here - Direct/V.
ebr 16337 Posted June 29, 2016 Posted June 29, 2016 Thanks. Once Darth confirms both of his items still play on his NP I can move on. .
darthweder 3 Posted July 10, 2016 Posted July 10, 2016 Sorry, I hadn't checked this in a while. They all play perfectly. Thanks EBR 2
darthweder 3 Posted July 12, 2016 Posted July 12, 2016 @@ebr One of my friends that uses my server from an amazon firestick (the client reports as "Amazon AFTM") is having the same problem I was on my Nexus Player. Any chance you could push that update to the Amazon version of the client?? Thanks in advance! You have been a ton of help. I never thought you guys would be so responsive and helpful.
ebr 16337 Posted July 12, 2016 Posted July 12, 2016 That update should go out to Amazon devices very soon.
darthweder 3 Posted July 12, 2016 Posted July 12, 2016 That update should go out to Amazon devices very soon. Awesome! Thanks
Luke 42244 Posted December 7, 2016 Posted December 7, 2016 Hi @@BJS2 The latest beta version of the Emby app offers improved playback, refresh rate switching, and all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks !
BJS2 0 Posted December 7, 2016 Author Posted December 7, 2016 Hi @@BJS2 The latest beta version of the Emby app offers improved playback, refresh rate switching, and all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks ! Thanks i will try it out.
