VanillaXtract 3 Posted June 5, 2016 Posted June 5, 2016 (edited) SOLUTION: kodi not being updated: library -> advanced and check realtime monitor no sets showing up: I could never figure out, but it was machine related. Purged kodi and deleted the .kodi folder. Upon reinstallation, everything showed up as it should. I run kodi 16.1 on two different boxes. I was using MySQL to sync my libraries, but then read about Emby so I thought I would give it a shot. It was working great for awhile, but now I have noticed a couple of problems: 1. Emby is not recognizing new media unless I hit scan library. 2. This in turn, means my kodi databases are not being updated. 3. I think this is unrelated, but all my sets have been wiped out. Here is my setup: WHS 2011 -Emby 5972 (newest build as of this post) with Auto Box Sets and Emby.Kodi.Sync.Queue HTPC 1 -Ubuntu minimal 14.04.4 -Kodi 16.1 HTPC 2 -RPi 3 running RetroPie 4.4.9 -Kodi 16.1 Edited June 7, 2016 by VanillaXtract
Solution Luke 42186 Posted June 5, 2016 Solution Posted June 5, 2016 Hi, welcome. Go into library -> advanced and check if the realtime monitor is enabled or not. 1
VanillaXtract 3 Posted June 5, 2016 Author Posted June 5, 2016 You have got to be kidding me! I looked over every setting before I posted, because I did not want to look like an idiot. I can't believed I missed that. Thanks for helping me. How about for my minor annoyance of sets? Before Emby, my movies showed in set, such as Avengers, Halloween, Harry Potter. Now, there are no sets. Auto box set seems to be populating TMDB sets, but this is not transferring over to kodi.
Happy2Play 9800 Posted June 5, 2016 Posted June 5, 2016 Have you tried Refreshing Box Sets? Plugins-Auto Box Sets-Refresh Box Sets
VanillaXtract 3 Posted June 5, 2016 Author Posted June 5, 2016 (edited) Box Sets appears to be working. In emby metadata manager, I see TMDB collection IDs populated. But I guess these do not translate to movie sets in kodi. My problem seems very similar to http://emby.media/community/index.php?/topic/24591-question-about-movie-sets/. I also checked emby and everything is in sets as it should be. Edited June 5, 2016 by VanillaXtract
