Emby for Kodi - 3d play required direct play?
benbour
Trying to watch some 3D, but it's not working like it used to with the Kodi library. The video plays side by side, and I cannot change the 3D mode to play in, say, 2D if I want anymore.
I thought maybe direct play was needed from emby to accomplish this, but that's never worked either. The emby server lives on a win 10 machine, and my kodi boxes are openelec (all newest stables for everything).
Content sits on 2  WD mybooks, mapped drives on server. No passwords are needed, although I've tried setting up network credentials in the addon, it's not very clear as to what it actually wants. I read elsewhere someone got direct play working by adding credentials, then doing a complete reset of emby. I tried that, no go. Resetting the library every time I make a change to test is not the way things should be done. I shouldn't need credentials, since I don't from anywhere else. and Emby doesn't seem to accept a blank password. Path substitution is set up. drives look like:
M:\Movies
T:\Television
Sub for:
192.168.x.x\Movies
192.168.x.x\Television
Pretty straight forward,right emby? nope.
When I used to play a 3D source, Kodi would ask me how I'd like to view it. Now it just plays sbs or tab. The problem with this is:
1) If i want to watch the movie on a non-3d TV, I'm out of luck
2) If i want to watch in 3D, Kodi doesn't go into 3D mode, so the OSD and subtitles are all stuck in 2D while the TV is in 3D playing the movie, quite the mess on screen.
Ugly.
Angelblue05
Your path substitution is incorrect because it needs \\ before the ip address.
Sent from my iPhone using Tapatalk
benbour
I don't think that showed up correctly lol. you mean like \\192.168.x.x
Left that out in the post, but they are there on the server.
Angelblue05
You won't get 3D unless you direct play. Can you confirm which playback mode you are using (add-on config > sync options > playback mode)? Also do you have play from http enabled (configs still > playback), if it's enabled, disable it then try to play something in Kodi and post your Kodi log.
benbour
Playback mode is direct path(native) http is unchecked. When I go play it says direct play failed 3 times, and enables http and plays that way. Where can I see this log?
Angelblue05
For log: http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/
You didn't reset your database after switching to native playback mode (it's required to take effect). It's still using add-on playback. However, grab your Kodi log so we can hopefully see why it's not working (you can achieve direct play with add-on playback mode as well). Thanks
Edited by Angelblue05
  • Like 2
benbour
Thanks.
http://xbmclogs.com/pqhyzcbew
Angelblue05
Try re-adding your path substitution... This is the path returned in your log: Verifying path: M:\Risen (2016)\Risen- 2016 .mkv (backward slash can't be escaped)
benbour
Alright so I re-added paths as follows:
M:\Movies
To
nfs://192.168.1.119/nfs/Movies/
I verified access to this nfs path in kodi with success
Captured another log after:
benbour
I think I got it...my mistake was going M:\Movies when M:\ was all that was needed:
M:\
To
looks like I'm getting direct play now. I've now changed playback to native and have begun a full resync,
Now that I can direct play, will I be able to view 3d content normally i.e. have kodi ask me which mode to view it in?
  • Like 1
Angelblue05
It should.
  • Like 1
Guest
