Pancho 9 Posted April 19, 2016 Posted April 19, 2016 (edited) In an effort to make my media more accessible by other systems (Nvidia ShieldTV, Apple TVOS), I have begun converting all of my raw DVD rips that are on my Unraid NAS (Video_TS, Audio_TS folders respectively) over to MKV. I am using the MakeMKV utility so I get a straight across conversion with no drop in quality (since these are already SD). I have noticed that my few test MKV conversions are not displaying 16:9 inside of Emby on the Nvidia ShieldTV (see example below for the movie Bottle Shock). I can play the same MKV inside the Apple TV, SPMC (Kodi) or on my WMC Emby program, and there is no problem playing 16:9. I was unsure if there something I missed in the MakeMKV program causing this only on the ShieldTV? Any ideas? Thanks. Pancho Edited April 19, 2016 by Pancho 1
ebr 16337 Posted April 19, 2016 Posted April 19, 2016 It is in 16:9. It just isn't filling the screen. I would guess the content is from an old DVD rip and the Google player is displaying it either at true resolution or with encoded black content.
AdrianW 1058 Posted April 19, 2016 Posted April 19, 2016 This looks exactly like the issue that plagued ET for a while: Emby 2.0 DVD Anamorphic Resolution issue
raven-au 17 Posted April 20, 2016 Posted April 20, 2016 This problem has been introduced recently. I have been unable to use the Emby client for a while now but seem to have resolved it today only to find that my SD rips not longer display in 16:9.
crystalgipsy 4 Posted April 23, 2016 Posted April 23, 2016 (edited) I am also having this issue on the shield and AFTV. All 16:9 DVD rips are not being diplayed in widescreen but as the SD anamorphic so its not being desqueezed on playback. Edited April 23, 2016 by crystalgipsy
tre4b 4 Posted April 23, 2016 Posted April 23, 2016 My MKVs were playing fine last weekend but this weekend their aspect ratio is all over the place. They all work fine on the browser version with both Chrome and Edge in full screen mode but on the FireTV and Fire Stick they all come up as strange sizes. The strange sizes are consistent between the TV and the stick. i.e. If something is 16:9 with a big border all the way around on one it will be the same on the other. I have just updated the server to 3.0.5931.0 and the fire client is also using the most recent version on both devices.
Lerronious 0 Posted April 23, 2016 Posted April 23, 2016 I'm experiencing the same issues on my Shield TV with a wired connection. The aspect ratio is all over the place and not filling the screen even when 16:9. I also had to switch audio to "compatible". Everything works as it did before when playing the same files on the server and on my Shield Tablet over wifi. Sent from my Nexus 5X using Tapatalk
ebr 16337 Posted April 24, 2016 Posted April 24, 2016 Can you guys find an item that has this problem and then another one that doesn't (preferably also mpeg2 if possible) and post the media info for both? Thanks.
crystalgipsy 4 Posted April 25, 2016 Posted April 25, 2016 (edited) All of my 16:9 ripped DVD mpeg2's have this issue and did not have this issue before last update and they all play fine in the webplayer and Kodi. Media info of one of them, looks like the anamorphic flag is missing although it does give the correct viewing aspect. These where direct rips using MakeMKV no additional transcoding applied. Video CodecMPEG2VIDEOProfileMainLevel8Resolution720x576Aspect ratio16:9AnamorphicNoInterlacedNoFramerate25Bitrate5058 kbpsPixel formatyuv420pRef frames1 Audio LanguageengCodecAC3LayoutstereoChannels2 chBitrate187 kbpsSample rate48000 khzDefaultYes Subtitle LanguageengCodecDVDSUBDefaultYesForcedNoExternalNo Containermkv Edited April 25, 2016 by crystalgipsy
ebr 16337 Posted April 25, 2016 Posted April 25, 2016 So, it looks like the new Google player is just displaying the video exactly the way the information inside the video says it should be - at true resolution since it is not anamorphic. The best way to handle this is probably going to be to implement zooming options in the player interface.
crystalgipsy 4 Posted April 25, 2016 Posted April 25, 2016 So your not using VLC on the shield anymore? Sent from my SM-G925F using Tapatalk
ebr 16337 Posted April 25, 2016 Posted April 25, 2016 So your not using VLC on the shield anymore? Sent from my SM-G925F using Tapatalk No. There are several discussions about that and why in a few threads out here.
crystalgipsy 4 Posted April 25, 2016 Posted April 25, 2016 Ok did not know that. Might explain why playback is not as good as it was in previous version. Sent from my SM-G925F using Tapatalk
ebr 16337 Posted April 25, 2016 Posted April 25, 2016 Ok did not know that. Might explain why playback is not as good as it was in previous version. What does "not as good" mean? The new player actually has capabilities beyond what VLC had in a lot of areas. Like bitstreaming of DD and DTS and faster loading and seeking.
crystalgipsy 4 Posted April 25, 2016 Posted April 25, 2016 Frame skipping mainly which I posted in another post. Sent from my SM-G925F using Tapatalk
ebr 16337 Posted April 26, 2016 Posted April 26, 2016 1.1.77 has zoom options during playback with the internal player that should allow you to adjust for this. Join the Android Open Beta Testing program to test it out.
Pancho 9 Posted April 26, 2016 Author Posted April 26, 2016 Ebr.. thanks for the update in 1.1.77. I can confirm that the internal player zoom options allows me to 'stretch' the picture to full screen. A perfectly acceptable workaround for me. Thanks!
raven-au 17 Posted April 27, 2016 Posted April 27, 2016 Ebr.. thanks for the update in 1.1.77. I can confirm that the internal player zoom options allows me to 'stretch' the picture to full screen. A perfectly acceptable workaround for me. Thanks! I've had this discussion before. Ages ago when I discussed this the anamorphic flag was not set either so that's normal. But AFAIK anamorphic means that the pixels are not square so the video needs to be stretched and not necessarily in both directions so zooming is going to crop part of the picture. Typical 16:9 SD DVD rips don't have square pixels, so to my mind, are anamorphic regardless of what the attributes say. Ian
ebr 16337 Posted April 27, 2016 Posted April 27, 2016 Ebr.. thanks for the update in 1.1.77. I can confirm that the internal player zoom options allows me to 'stretch' the picture to full screen. A perfectly acceptable workaround for me. Thanks! Good deal, except it looks like maybe you used horizontal stretch instead of full zoom in that example. Was that actually a 2.35:1 show?
ebr 16337 Posted April 27, 2016 Posted April 27, 2016 I've had this discussion before. Ages ago when I discussed this the anamorphic flag was not set either so that's normal. But AFAIK anamorphic means that the pixels are not square so the video needs to be stretched and not necessarily in both directions so zooming is going to crop part of the picture. Typical 16:9 SD DVD rips don't have square pixels, so to my mind, are anamorphic regardless of what the attributes say. Ian In his original example above it looked like there was a uniform (in terms of pixels) space around the entire actual picture so a full zoom would be the proper correction (and would be what the other players are doing behind the scenes). The options I implemented, however, give you horizontal and vertical stretch options as well as full zoom though. So, all you 2.35:1 CIH folks out there can now use this with your anamorphic lenses... oh, wait, that's probably just me... .
Pancho 9 Posted April 28, 2016 Author Posted April 28, 2016 Ebr.. You are correct. I did use the 'Horizontal stretch' for the purpose of the screenshot. But using the FULL ZOOM option works as well. Thanks.
raven-au 17 Posted May 2, 2016 Posted May 2, 2016 In his original example above it looked like there was a uniform (in terms of pixels) space around the entire actual picture so a full zoom would be the proper correction (and would be what the other players are doing behind the scenes). The options I implemented, however, give you horizontal and vertical stretch options as well as full zoom though. So, all you 2.35:1 CIH folks out there can now use this with your anamorphic lenses... oh, wait, that's probably just me... . I tried the horizontal stretch and it doesn't fill the screen (probably close to about 2 x 6-7% borders) for me so there is still a little bit of compression. It's adequate I guess since there seems to no other way to resolve it.
scottd34 3 Posted May 28, 2016 Posted May 28, 2016 Is there a way to set the stretch settings by default ? I have some seasons of shows for the kids that all end up playing squished horizontally and it would be nice to set those seasons to stretch horizontally by default.
ebr 16337 Posted May 28, 2016 Posted May 28, 2016 No, sorry. There isn't anywhere to save that information at this time.
